Date/Time: Tue, 22 Apr 2025 14:29:32 +0000
[User Discussion] - Historical Chart not loading specified days
View Count: 248
[2025-01-10 14:57:36] |
nord - Posts: 5 |
Hi, Everything was working fine until today when I opened the charts and it only loads around 24 days of historical chart of any symbols. It was fine yesterday but when I startup the computer, SC just limits my charts. I didnt even change any settings but now the chart won't load the settings' charts no. of days. I tried to redownload the data but it still doesnt allow me to load the number of days that I specified. |
[2025-01-12 18:16:50] |
iAmTheFuture - Posts: 3 |
little fix I found that might help is changing the (Date Range in File From) to 2025-01-01 applying it and then switching it back further to 2024 or so on
[2025-01-12 20:16:47] |
Sierra_Chart Engineering - Posts: 19305 |
Changing the date range in file is irrelevant. The data is there. Does the chart have a scrollbar at the bottom? Remove any fill space: Working With Charts: Scrolling The Chart and Right Side Fill Space Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
