Date/Time: Tue, 22 Apr 2025 13:42:27 +0000
Trackpad-Friendly Scroll
View Count: 225
[2025-01-10 00:03:24]
fooboy - Posts: 3
Can Sierra have a global option for scrolling charts which is optimized for trackpads? It could operate like so:
Scroll up/down: scrolls vertical scale up/down
SHIFT+Scroll up/down: zooms vertical scale out/in
Scroll left/right: scrolls horizontal scale left/right
SHIFT+Scroll left/right: zooms horizontal scale out/in
Separately, can we have a global option to set all vertical and horizontal zoom operations to be centered at the cursor?
Thanks!
[2025-01-10 22:32:53]
Sierra_Chart Engineering - Posts: 19305
This should all be supported. Refer to:
General Settings Window: Scroll Wheel Setting (Global Settings >> General Settings >> GUI >> Scroll)
[2025-01-15 05:14:40]
fooboy - Posts: 3
Yes I looked through those options before making this post; they do not do what I'm asking for here.
Thanks,
[2025-01-15 06:50:57]
This is all that we have to offer:
One note:
You can toggle these behaviors with the Control key:
Chart Scale and Scale Adjusting: Inverting the Scale Mode
