Date/Time: Tue, 22 Apr 2025 13:48:22 +0000
Text Locations on Lines and Rays and Rectangles.
View Count: 167
[2025-01-09 17:12:54] |
User708541 - Posts: 135 |
I haven't been able to find the answer to this question anywhere. Main question: Is there a way to set the text to the right side of the chart using the Ray tool, when the ray is extended to the right? My understanding: Line tool: Text location is to the right end of the line. Can text location be changed for lines? Ray tool: Text location is to the left end of the line. Can text location be changed for Rays? If not, why? And is there any plan to have text location flexibility for lines and rays, oh! and rectangles and extended rectangles? |
[2025-01-09 17:27:50] |
Line: The option to move the text from one side to the other is controlled through the option for "Draw Text At End". Refer to the following: Chart Drawing Tools: Line | Ray | Extended Line Configuration Ray: There is no option to have the text drawn at the other end of a Ray. We can not say why it is this way, it just is this way. We have noted this as a feature request. We can not say when we would get to any particular request. Rectangles: You can control the side of the rectangle through the option for "Text on Right". Refer to the following: Chart Drawing Tools: Rectangle | Extending Rectangle | Ellipse | Triangle Configuration For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
