Date/Time: Fri, 20 Sep 2024 03:43:45 +0000
Tpo And Volume Developing Value Area Lines
View Count: 1829
[2014-09-16 12:41:30] |
User49270 - Posts: 48 |
Hi, I am trying to make each of the developing value area lines each straight lines across the chart at the current value instead of having a bunch of stair step or dash lines all over the chart . Thank you
[2014-09-16 16:20:05] |
Therefore, you do not want Developing Value Area Lines. Go into the Study Settings for the study and set Draw Developing Value Area Lines to No Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-09-16 17:32:15
[2014-09-16 17:24:39] |
Thanks but yes I do want developing value area lines but I just want a horizontal line at the current values instead of stair step lines at all the previous values as they have developed which clutters the chart. Basically a current value area line for each. Thanks
[2014-09-16 17:33:01] |
What we said previously will accomplish what you want.
[2014-09-17 12:43:01] |
I set Draw Developing Value Area Lines to No and now it works like I want it to. Thank you for the help
