Date/Time: Wed, 16 Sep 2026 06:32:28 +0000
INCOMING DATA
View Count: 1170
| [2014-09-16 11:42:59] |
| User82486 - Posts: 43 |
My friend and I live several miles apart. We both use Sierra Charts of identical time bars with the same underlying stock symbol. Why are the OHLC values different in some cases substantially. Where does the problem lie? Our broker and Data source is Interactive Brokers. Fred |
| [2014-09-16 16:11:38] |
This would be due to differences with the computer clock on the systems. Refer to help topic 38: http://www.sierrachart.com/index.php?page=doc/helpdetails38.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
