Date/Time: Tue, 22 Apr 2025 14:17:41 +0000
[User Discussion] - Diagonal AskVol BidVolume Difference actual- background colouring
View Count: 185
[2025-01-09 09:13:08] |
User669552 - Posts: 26 |
Could you assist me in the creation of a simple range per bar chart. Which has a back ground type “Diagonal Ask Bid difference” and background coloring method based on “Diagonal AskVol BidVolume Difference actual.” With a volume profile bar length Relative to all visible bar.
[2025-01-09 11:49:14] |
Just to add. I expect a bar with 8 price levels to have 7 diagonal imbalances. I want to have a horizontal bars at 7 price levels (for a bar with 8 price levels) showing positive difference in green. negative difference in red.
[2025-01-09 16:44:10] |
This is well beyond what we offer for support. If you want help getting something like this setup, we recommend contacting one of the people at the following link: Sierra Chart Personal Assistance For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
