Date/Time: Tue, 22 Apr 2025 13:45:22 +0000
Number Bars Study show diffirent result
View Count: 182
[2025-01-09 04:17:42]
MrTienDatVn - Posts: 16
As you see, i try add Number Bars Study in Intradaychart.
But have 2 problem:
1. Rows 0 x 0 and Space no data.
2. Same Timeframe 1m, but show different result.
I try search in forum help before but i couldn't how to fix it.
How can i config or fix it. Many thank.
imageScreenshot_119.png / V - Attached On 2025-01-09 04:15:14 UTC - Size: 252.22 KB - 47 views
attachmentFootPrint.Cht - Attached On 2025-01-09 04:15:44 UTC - Size: 15.82 KB - 85 views
[2025-01-09 16:21:14]
John - SC Support - Posts: 39395
The rows with 0 x 0 and gaps are normal. This is just due to how this particular product is traded.
The different results in the two charts is due to the setting for "Gap Fill". You have these set differently between the two charts. Refer to the following:
Chart Settings: Intraday Chart Bar Period >> Gap Fill (Chart >> Chart Settings >> Bar Period >> Intraday Chart Bar Period Settings menu)
[2025-01-10 02:55:52]
Thank you so much
