Date/Time: Fri, 20 Sep 2024 04:14:13 +0000
"Array is unallocated" error
View Count: 1211
[2014-09-16 11:42:01] |
User11942 - Posts: 298 |
I get that error message when I try to change Cumulative delta bar study Graph draw type to Bid Ask Volume bars. SC ver 1187 .NET. Please see a quote from log below. HD Request # 2 | Receiving Intraday data for F.US.TFEZ14 starting at 2014-09-16 07:24:04 | 2014-09-16 07:26:52
Socket (1064) | Shutdown and closed. | 2014-09-16 07:26:52 The network socket for historical data has been closed. | 2014-09-16 07:26:52 HD Request # 2 | Received 2 records from 2014-09-16 07:24:04 to 2014-09-16 07:24:04 (0.0 seconds) and wrote 0 records for F.US.TFEZ14 | 2014-09-16 07:26:52 HD Request # 2 | Intraday download COMPLETE for F.US.TFEZ14. Completion time: 0s | 2014-09-16 07:26:52 Real-time Intraday chart data file updates started for F.US.TFEZ14 | 2014-09-16 07:26:52 : Array is unallocated. | 2014-09-16 07:27:13 * : Array is unallocated. | 2014-09-16 07:27:13 * : Array is unallocated. | 2014-09-16 07:27:13 * : Array is unallocated. | 2014-09-16 07:27:13 * : Array is unallocated. | 2014-09-16 07:27:13 * : Array is unallocated. | 2014-09-16 07:27:13 * : Array is unallocated. | 2014-09-16 07:27:13 * : Array is unallocated. | 2014-09-16 07:27:13 * : Array is unallocated. | 2014-09-16 07:27:13 * : Array is unallocated. | 2014-09-16 07:27:13 * : Array is unallocated. | 2014-09-16 07:27:13 * : Array is unallocated. | 2014-09-16 07:27:13 * : Array is unallocated. | 2014-09-16 07:27:13 * : Array is unallocated. | 2014-09-16 07:27:13 * : Array is unallocated. | 2014-09-16 07:27:13 * : Array is unallocated. | 2014-09-16 07:27:13 * : Array is unallocated. | 2014-09-16 07:27:13 * : Array is unallocated. | 2014-09-16 07:27:13 * : Array is unallocated. | 2014-09-16 07:27:13 * : Array is unallocated. | 2014-09-16 07:27:13 * : Array is unallocated. | 2014-09-16 07:27:13 * : Array is unallocated. | 2014-09-16 07:27:13 * : Array is unallocated. | 2014-09-16 07:27:13 * : Array is unallocated. | 2014-09-16 07:27:13 * : Array is unallocated. | 2014-09-16 07:27:13 * : Array is unallocated. | 2014-09-16 07:27:13 * : Array is unallocated. | 2014-09-16 07:27:13 * : Array is unallocated. | 2014-09-16 07:27:13 * : Array is unallocated. | 2014-09-16 07:27:13 * : Array is unallocated. | 2014-09-16 07:27:13 * : Array is unallocated. | 2014-09-16 07:27:13 * : Array is unallocated. | 2014-09-16 07:27:13 * : Array is unallocated. | 2014-09-16 07:27:13 * : Array is unallocated. | 2014-09-16 07:27:13 * : Array is unallocated. | 2014-09-16 07:27:13 * : Array is unallocated. | 2014-09-16 07:27:13 * : Array is unallocated. | 2014-09-16 07:27:13 * : Array is unallocated. | 2014-09-16 07:27:13 * : Array is unallocated. | 2014-09-16 07:27:13 * : Array is unallocated. | 2014-09-16 07:27:13 * : Array is unallocated. | 2014-09-16 07:27:13 * : Array is unallocated. | 2014-09-16 07:27:13 * : Array is unallocated. | 2014-09-16 07:27:13 * : Array is unallocated. | 2014-09-16 07:27:13 * : Array is unallocated. | 2014-09-16 07:27:13 * : Array is unallocated. | 2014-09-16 07:27:13 * : Array is unallocated. | 2014-09-16 07:27:13 * : Array is unallocated. | 2014-09-16 07:27:13 * : Array is unallocated. | 2014-09-16 07:27:13 * : Array is unallocated. | 2014-09-16 07:27:13 * : Array is unallocated. | 2014-09-16 07:27:13 * : Array is unallocated. | 2014-09-16 07:27:13 * : Array is unallocated. | 2014-09-16 07:27:13 * : Array is unallocated. | 2014-09-16 07:27:13 * : Array is unallocated. | 2014-09-16 07:27:13 * : Array is unallocated. | 2014-09-16 07:27:13 * : Array is unallocated. | 2014-09-16 07:27:13 * : Array is unallocated. | 2014-09-16 07:27:13 * : Array is unallocated. | 2014-09-16 07:27:13 * : Array is unallocated. | 2014-09-16 07:27:13 * : Array is unallocated. | 2014-09-16 07:27:13 * : Array is unallocated. | 2014-09-16 07:27:13 * : Array is unallocated. | 2014-09-16 07:27:13 * : Array is unallocated. | 2014-09-16 07:27:13 * : Array is unallocated. | 2014-09-16 07:27:13 * : Array is unallocated. | 2014-09-16 07:27:13 * : Array is unallocated. | 2014-09-16 07:27:13 * : Array is unallocated. | 2014-09-16 07:27:13 * : Array is unallocated. | 2014-09-16 07:27:13 * : Array is unallocated. | 2014-09-16 07:27:13 * : Array is unallocated. | 2014-09-16 07:27:13 * : Array is unallocated. | 2014-09-16 07:27:13 * : Array is unallocated. | 2014-09-16 07:27:13 * : Array is unallocated. | 2014-09-16 07:27:13 * : Array is unallocated. | 2014-09-16 07:27:13 * : Array is unallocated. | 2014-09-16 07:27:13 * : Array is unallocated. | 2014-09-16 07:27:13 * : Array is unallocated. | 2014-09-16 07:27:13 * : Array is unallocated. | 2014-09-16 07:27:13 * : Array is unallocated. | 2014-09-16 07:27:13 * : Array is unallocated. | 2014-09-16 07:27:13 * : Array is unallocated. | 2014-09-16 07:27:13 * : Array is unallocated. | 2014-09-16 07:27:13 * : Array is unallocated. | 2014-09-16 07:27:13 * : Array is unallocated. | 2014-09-16 07:27:13 * : Array is unallocated. | 2014-09-16 07:27:13 * : Array is unallocated. | 2014-09-16 07:27:13 * : Array is unallocated. | 2014-09-16 07:27:13 * : Array is unallocated. | 2014-09-16 07:27:13 * : Array is unallocated. | 2014-09-16 07:27:13 * : Array is unallocated. | 2014-09-16 07:27:13 * : Array is unallocated. | 2014-09-16 07:27:13 * : Array is unallocated. | 2014-09-16 07:27:13 * : Array is unallocated. | 2014-09-16 07:27:13 * : Array is unallocated. | 2014-09-16 07:27:13 * : Array is unallocated. | 2014-09-16 07:27:13 * : Array is unallocated. | 2014-09-16 07:27:13 * : Array is unallocated. | 2014-09-16 07:27:13 * : Array is unallocated. | 2014-09-16 07:27:13 * : Array is unallocated. | 2014-09-16 07:27:13 * Array message repeat count limit reached. | 2014-09-16 07:27:13 * Please advise. Thanks. |
[2014-09-16 16:05:39] |
Cumulative Delta Bars are not compatible with the Graph Draw Type: Bid Ask Volume Bars.
