Date/Time: Tue, 22 Apr 2025 13:57:13 +0000
Changing alignment for Open Marker/Boxes in Numbers Bar study?
View Count: 110
[2025-01-08 16:57:58] |
soranthous - Posts: 1 |
For the Numbers bar study, I prefer to have the volume profile right aligned. This is in column 1. However, a right aligned volume profile in column 1 with Open Marker/Boxes in column 1 is not as "clean" to read/view as the default left aligned volume profile in column 1 with Open Marker/Boxes in column 1. I tried changing the column for the Open Marker to column 2, but the only way I could get it to appear was to select some type of text (e.g. volume) in column 2, which created a messy look. Is there a better way to do what I'm trying to accomplish? Thank you.
[2025-01-08 19:19:14] |
You have found the options available. The only other thing we can suggest is to use a different marker style to see if something else works better for you.
