Date/Time: Tue, 22 Apr 2025 14:29:32 +0000
modifying order quantity from order line on chart
View Count: 176
[2025-01-08 16:42:59] |
User935845 - Posts: 13 |
I used to could change the order quantity on a chart that has an attached trade window by clicking on the order line quantity. A menu would then pop up and I could adjust the quantity on an order that has not yet been filled. This was so on SIM or live trading. My problem is now when I clik the quantity on the order line NO MENU appears. Is there some setting somewhere I need to look at to make the menu appear? I have looked at and tried different ideas from the support forum, but nothing works. |
[2025-01-08 19:16:17] |
We have responded to this here: Order quantity modification from chart window Please do not post more than once for an issue. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
