Date/Time: Tue, 22 Apr 2025 18:22:20 +0000
Teton Slow Order Execution
View Count: 152
[2025-01-08 13:37:21]
User753526 - Posts: 57
I've noticed today that the execution time for orders via Teton are running slow.. up to 10 seconds etc. to modify an order. Then once flattened, a new order appears as though it was stuck in line waiting to execute. This was occuring on ES_F and MES
Message Log below
2025-01-08 08:09:42.648 | Trade activity files set size: 2572
2025-01-08 08:09:42.709 | Reading Internal Order ID file.
2025-01-08 08:09:42.756 | Reading Trade Orders file.
2025-01-08 08:09:42.756 | Reading Trade Positions file.
2025-01-08 08:09:42.756 | Reading Trade Account Data files.
2025-01-08 08:09:42.760 | NTP | No privilege to adjust system time: Failed to adjust privileges. Windows error code 1300: Not all privileges or groups referenced are assigned to the caller.
2025-01-08 08:09:42.760 | Software version: 2700 64-bit
2025-01-08 08:09:42.760 | Primary Thread ID: 28164
2025-01-08 08:09:42.760 | Usage end date: 2025-02-08
2025-01-08 08:09:42.760 | Enabled for: Advanced Features 2.
2025-01-08 08:09:42.760 | Enabled for: Sierra Chart Historical Data Service.
2025-01-08 08:09:42.760 | Enabled for: Denali Real-Time Exchange Data Feed.
2025-01-08 08:09:42.760 | Enabled for: Delayed Denali Exchange Data Feed.
2025-01-08 08:09:42.760 | Enabled for exchange2: CME
2025-01-08 08:09:42.760 | Enabled for exchange2: COMEX
2025-01-08 08:09:42.760 | Allow Support for Sierra Chart Data Feeds is enabled.
2025-01-08 08:09:42.760 | Current selected Data/Trading service: Teton CME Order Routing
2025-01-08 08:09:42.760 | Custom symbol settings values: enabled
2025-01-08 08:09:42.760 | Chart Update Interval: 500
2025-01-08 08:09:42.760 | Intraday Data Storage Time Unit: 0
2025-01-08 08:09:42.760 | Time Zone: -05:00:00 (EST-05EDT+01,M3.2.0/02:00,M11.1.0/02:00)
2025-01-08 08:09:42.760 | 2025-01-08 13:09:42 Local computer time in UTC
2025-01-08 08:09:42.760 | 2025-01-08 08:09:42 Local computer time in SC Time Zone
2025-01-08 08:09:42.760 | 2025-01-08 13:09:43 Server time in UTC
2025-01-08 08:09:42.760 | Local computer UTC time and Server UTC time difference: 2 seconds.
2025-01-08 08:09:42.760 | Program path: C:\SierraChart - EdgeClear\
2025-01-08 08:09:42.760 | Data Files path: C:\SierraChart - EdgeClear\Data\
2025-01-08 08:09:42.760 | OS Version Number: 10.0
2025-01-08 08:09:42.760 | Locale Setting: C
2025-01-08 08:09:42.761 | DLLs: ICTMarketOpens_64.dll, UserContributedStudies_64.dll
2025-01-08 08:09:42.761 | Allowed protected custom studies:
2025-01-08 08:09:42.761 | Crash reporter started: true
2025-01-08 08:09:42.778 | Checking for new symbol settings. Requested symbol settings MD5 for service code sc_futures_direct.dtc.trading. Request ID: 1.
2025-01-08 08:09:42.785 | WSACleanup called.
2025-01-08 08:09:42.796 | Chat: Chat Window created. Connecting to server.
2025-01-08 08:09:42.796 | WSACleanup called.
2025-01-08 08:09:42.799 | Chat | Connecting to the server chat2.sierracharts.com. Port 10065
2025-01-08 08:09:42.857 | HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Shutdown started. Waiting for graceful close.
2025-01-08 08:09:42.921 | DTC Client socket (5) | Creating socket. Using TLS 1.2.
2025-01-08 08:09:42.921 | DTC Client socket (5) | New receive buffer size: 0
2025-01-08 08:09:42.921 | DTC Client socket (5) | Connecting to IP: 64.152.155.20.
2025-01-08 08:09:43.101 | HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Socket gracefully closed by remote side.
2025-01-08 08:09:43.101 | HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Closed.
2025-01-08 08:09:43.163 | Chat | Network connection to server complete.
2025-01-08 08:09:43.163 | Chat | Starting socket receive thread.
2025-01-08 08:09:43.163 | Chat | Sending encoding request to server: Binary VLS. Compression: none
2025-01-08 08:09:43.602 | Received 5 login tokens.
2025-01-08 08:09:43.891 | Chat | Setting DTC encoding to Binary VLS
2025-01-08 08:09:43.891 | Chat | Sending logon request message.
2025-01-08 08:09:44.115 | Symbol settings MD5 received. Request ID: 1.
2025-01-08 08:09:44.115 | Requested symbol settings for service code sc_futures_direct.dtc.trading. Request ID: 2.
2025-01-08 08:09:44.164 | Chat | Received logon response.
2025-01-08 08:09:44.164 | Chat | Server Name: SC DTC Server. Build=52153.
2025-01-08 08:09:44.164 | Chat | Server protocol version: 8. Client protocol version: 8
2025-01-08 08:09:44.164 | Chat | Successfully connected. Connected to SC DTC Protocol server. Service=chat_server.data|SymbolSettings=chat_server.data.
2025-01-08 08:09:44.164 | Chat | Trading is not supported.
2025-01-08 08:09:44.164 | Chat | MarketDepthIsSupported: 1
2025-01-08 08:09:45.289 | Requested user files to download.
2025-01-08 08:09:46.028 | Symbol settings received. Request ID: 2.
2025-01-08 08:09:47.286 |
2025-01-08 08:09:47.286 | Teton CME Order Routing | Firm: IronBeam
2025-01-08 08:09:47.290 | Teton CME Order Routing | Connecting to the server futurestrading10.sierracharts.com. Port 11085
2025-01-08 08:09:47.412 | DTC Client socket (1) | Creating socket. Using TLS 1.2.
2025-01-08 08:09:47.412 | DTC Client socket (1) | New receive buffer size: 0
2025-01-08 08:09:47.412 | DTC Client socket (1) | Connecting to IP: 208.185.224.130.
2025-01-08 08:09:47.806 | Teton CME Order Routing | Network connection to server complete.
2025-01-08 08:09:47.806 | Teton CME Order Routing | Starting socket receive thread.
2025-01-08 08:09:47.806 | Teton CME Order Routing | Sending encoding request to server: Binary VLS. Compression: none
2025-01-08 08:09:57.762 | MESH25_FUT_CME #1 | Reloading chart.
2025-01-08 08:09:57.762 | MESH25_FUT_CME #1 | StartDateTimeForLoadingOrderFills: 2024-01-02 00:00:00
2025-01-08 08:09:57.780 | MESH25_FUT_CME #1 | Chart data loading complete.
2025-01-08 08:09:57.815 | MESH25_FUT_CME 1 Min #2 | Reloading chart.
2025-01-08 08:09:58.074 | MNQH25_FUT_CME 15 Min #3 | Reloading chart.
2025-01-08 08:09:58.343 | MNQH25_FUT_CME #4 | Reloading chart.
2025-01-08 08:09:58.344 | MNQH25_FUT_CME #4 | StartDateTimeForLoadingOrderFills: 2024-01-02 00:00:00
2025-01-08 08:09:58.361 | MNQH25_FUT_CME #4 | Chart data loading complete.
2025-01-08 08:09:58.373 | MGCG25_FUT_CME 5 Min #7 | Reloading chart.
2025-01-08 08:09:58.656 | MCLX24_FUT_CME 5 Min #12 | Reloading chart.
2025-01-08 08:09:58.931 | 6AH25_FUT_CME 5 Min #9 | Reloading chart.
2025-01-08 08:09:59.216 | M6AH25_FUT_CME 15 Min #15 | Reloading chart.
2025-01-08 08:09:59.493 | 6JZ24_FUT_CME 5 Min #5 | Reloading chart.
2025-01-08 08:09:59.762 | 6JZ24_FUT_CME #6 | Reloading chart.
2025-01-08 08:09:59.762 | 6JZ24_FUT_CME #6 | StartDateTimeForLoadingOrderFills: 2024-01-02 00:00:00
2025-01-08 08:09:59.762 | 6JZ24_FUT_CME #6 | Chart data loading complete.
2025-01-08 08:10:00.042 | MGCG25_FUT_CME #8 | Reloading chart.
2025-01-08 08:10:00.042 | MGCG25_FUT_CME #8 | StartDateTimeForLoadingOrderFills: 2024-01-02 00:00:00
2025-01-08 08:10:00.060 | MGCG25_FUT_CME #8 | Chart data loading complete.
2025-01-08 08:10:00.323 | 6AH25_FUT_CME #10 | Reloading chart.
2025-01-08 08:10:00.323 | 6AH25_FUT_CME #10 | StartDateTimeForLoadingOrderFills: 2024-01-02 00:00:00
2025-01-08 08:10:00.323 | 6AH25_FUT_CME #10 | Chart data loading complete.
2025-01-08 08:10:00.588 | MCLX24_FUT_CME #11 | Reloading chart.
2025-01-08 08:10:00.589 | MCLX24_FUT_CME #11 | StartDateTimeForLoadingOrderFills: 2024-01-02 00:00:00
2025-01-08 08:10:00.589 | MCLX24_FUT_CME #11 | Chart data loading complete.
2025-01-08 08:10:00.895 | 6EZ24_FUT_CME 30 Min #13 | Reloading chart.
2025-01-08 08:10:01.196 | 6EZ24_FUT_CME #14 | Reloading chart.
2025-01-08 08:10:01.196 | 6EZ24_FUT_CME #14 | StartDateTimeForLoadingOrderFills: 2024-01-02 00:00:00
2025-01-08 08:10:01.196 | 6EZ24_FUT_CME #14 | Chart data loading complete.
2025-01-08 08:10:01.461 | M6AH25_FUT_CME #16 | Reloading chart.
2025-01-08 08:10:01.462 | M6AH25_FUT_CME #16 | StartDateTimeForLoadingOrderFills: 2024-01-02 00:00:00
2025-01-08 08:10:01.462 | M6AH25_FUT_CME #16 | Chart data loading complete.
2025-01-08 08:10:01.748 | ESH25_FUT_CME #17 | Reloading chart.
2025-01-08 08:10:01.749 | ESH25_FUT_CME #17 | StartDateTimeForLoadingOrderFills: 2024-01-02 00:00:00
2025-01-08 08:10:01.766 | ESH25_FUT_CME #17 | Chart data loading complete.
2025-01-08 08:10:01.812 | MESH25_FUT_CME 1 Min #2 | StartDateTimeForLoadingOrderFills: 2024-01-02 00:00:00
2025-01-08 08:10:01.841 | MESH25_FUT_CME 1 Min #2 | Chart data loading complete.
2025-01-08 08:10:01.845 | MGCG25_FUT_CME 5 Min #7 | StartDateTimeForLoadingOrderFills: 2024-01-02 00:00:00
2025-01-08 08:10:01.846 | MGCG25_FUT_CME 5 Min #7 | Chart data loading complete.
2025-01-08 08:10:01.849 | MCLX24_FUT_CME 5 Min #12 | StartDateTimeForLoadingOrderFills: 2023-10-15 00:00:00
2025-01-08 08:10:01.850 | MCLX24_FUT_CME 5 Min #12 | Chart data loading complete.
2025-01-08 08:10:01.851 | MNQH25_FUT_CME 15 Min #3 | StartDateTimeForLoadingOrderFills: 2024-01-02 00:00:00
2025-01-08 08:10:01.852 | MNQH25_FUT_CME 15 Min #3 | Chart data loading complete.
2025-01-08 08:10:01.852 | Teton CME Order Routing | Setting DTC encoding to Binary VLS
2025-01-08 08:10:01.852 | Teton CME Order Routing | Sending logon request message.
2025-01-08 08:10:01.854 | 6AH25_FUT_CME 5 Min #9 | StartDateTimeForLoadingOrderFills: 2024-01-02 00:00:00
2025-01-08 08:10:01.854 | 6AH25_FUT_CME 5 Min #9 | Chart data loading complete.
2025-01-08 08:10:01.855 | M6AH25_FUT_CME 15 Min #15 | StartDateTimeForLoadingOrderFills: 2024-01-02 00:00:00
2025-01-08 08:10:01.856 | M6AH25_FUT_CME 15 Min #15 | Chart data loading complete.
2025-01-08 08:10:01.860 | 6JZ24_FUT_CME 5 Min #5 | StartDateTimeForLoadingOrderFills: 2023-12-10 00:00:00
2025-01-08 08:10:01.860 | 6JZ24_FUT_CME 5 Min #5 | Chart data loading complete.
2025-01-08 08:10:01.874 | 6EZ24_FUT_CME 30 Min #13 | StartDateTimeForLoadingOrderFills: 2023-12-10 00:00:00
2025-01-08 08:10:01.875 | 6EZ24_FUT_CME 30 Min #13 | Chart data loading complete.
2025-01-08 08:10:02.072 | Mapping MESH25_FUT_CME to MESH25. Service code: cme
2025-01-08 08:10:02.072 | Using symbol data fast lookup vector
2025-01-08 08:10:02.072 | Starting DelayedDownloadMonitoringTimer
2025-01-08 08:10:02.072 | Starting HDTimeoutTimer
2025-01-08 08:10:02.072 | Added historical Intraday data request for MESH25_FUT_CME to the queue.
2025-01-08 08:10:02.073 | Intraday data recording state for symbol MESH25_FUT_CME is set to download 'Pending'.
2025-01-08 08:10:02.076 | Triggering next historical data download in queue.
2025-01-08 08:10:02.078 | HD Request # 1 | Downloading Intraday chart data for MESH25_FUT_CME to the file MESH25_FUT_CME.scid. Service: cme
2025-01-08 08:10:02.078 | HD Request # 1 | Download start date-time: 2025-01-08 08:09:28.000000. File last date-time: 2025-01-08 08:09:28.960000
2025-01-08 08:10:02.079 | HD Request # 1 | Using server: ds32.sierracharts.com port 10150
2025-01-08 08:10:02.079 | Socket (2) | Creating socket.
2025-01-08 08:10:02.079 | Socket (2) | New receive buffer size: 0
2025-01-08 08:10:02.079 | Socket (2) | Connecting to IP: 67.214.125.3.
2025-01-08 08:10:02.104 | Mapping MNQH25_FUT_CME to MNQH25. Service code: cme
2025-01-08 08:10:02.104 | Added historical Intraday data request for MNQH25_FUT_CME to the queue.
2025-01-08 08:10:02.104 | Intraday data recording state for symbol MNQH25_FUT_CME is set to download 'Pending'.
2025-01-08 08:10:02.104 | Triggering next historical data download in queue.
2025-01-08 08:10:02.108 | Mapping MGCG25_FUT_CME to MGCG25. Service code: comex
2025-01-08 08:10:02.108 | Added historical Intraday data request for MGCG25_FUT_CME to the queue.
2025-01-08 08:10:02.108 | Intraday data recording state for symbol MGCG25_FUT_CME is set to download 'Pending'.
2025-01-08 08:10:02.108 | Triggering next historical data download in queue.
2025-01-08 08:10:02.111 | Mapping MCLX24_FUT_CME to MCLX24. Service code: nymex
2025-01-08 08:10:02.111 | Added historical Intraday data request for MCLX24_FUT_CME to the queue.
2025-01-08 08:10:02.111 | Intraday data recording state for symbol MCLX24_FUT_CME is set to download 'Pending'.
2025-01-08 08:10:02.111 | Triggering next historical data download in queue.
2025-01-08 08:10:02.112 | Mapping 6AH25_FUT_CME to 6AH25. Service code: cme
2025-01-08 08:10:02.112 | Added historical Intraday data request for 6AH25_FUT_CME to the queue.
2025-01-08 08:10:02.112 | Intraday data recording state for symbol 6AH25_FUT_CME is set to download 'Pending'.
2025-01-08 08:10:02.112 | Triggering next historical data download in queue.
2025-01-08 08:10:02.113 | Mapping M6AH25_FUT_CME to M6AH25. Service code: cme
2025-01-08 08:10:02.113 | Added historical Intraday data request for M6AH25_FUT_CME to the queue.
2025-01-08 08:10:02.113 | Intraday data recording state for symbol M6AH25_FUT_CME is set to download 'Pending'.
2025-01-08 08:10:02.113 | Triggering next historical data download in queue.
2025-01-08 08:10:02.114 | Mapping 6JZ24_FUT_CME to 6JZ24. Service code: cme
2025-01-08 08:10:02.114 | Added historical Intraday data request for 6JZ24_FUT_CME to the queue.
2025-01-08 08:10:02.114 | Intraday data recording state for symbol 6JZ24_FUT_CME is set to download 'Pending'.
2025-01-08 08:10:02.114 | Triggering next historical data download in queue.
2025-01-08 08:10:02.119 | Mapping 6EZ24_FUT_CME to 6EZ24. Service code: cme
2025-01-08 08:10:02.119 | Added historical Intraday data request for 6EZ24_FUT_CME to the queue.
2025-01-08 08:10:02.119 | Intraday data recording state for symbol 6EZ24_FUT_CME is set to download 'Pending'.
2025-01-08 08:10:02.119 | Triggering next historical data download in queue.
2025-01-08 08:10:02.259 | Mapping ESH25_FUT_CME to ESH25. Service code: cme
2025-01-08 08:10:02.259 | Added historical Intraday data request for ESH25_FUT_CME to the queue.
2025-01-08 08:10:02.259 | Intraday data recording state for symbol ESH25_FUT_CME is set to download 'Pending'.
2025-01-08 08:10:02.259 | Triggering next historical data download in queue.
2025-01-08 08:10:02.310 | Teton CME Order Routing | Received logon response.
2025-01-08 08:10:02.310 | Teton CME Order Routing | Server Name: SC DTC Server. Build=51528.
2025-01-08 08:10:02.310 | Teton CME Order Routing | Server protocol version: 8. Client protocol version: 8
2025-01-08 08:10:02.310 | Teton CME Order Routing | Successfully connected. Connected to SC DTC Protocol server. Service=cme_ilink3.trading|SymbolSettings=cme_ilink_live.trading.
2025-01-08 08:10:02.310 | Teton CME Order Routing | Trading is supported.
2025-01-08 08:10:02.310 | Teton CME Order Routing | Order cancel and replace is supported.
2025-01-08 08:10:02.310 | Teton CME Order Routing | OCO Orders supported.
2025-01-08 08:10:02.310 | Teton CME Order Routing | Bracket Orders supported.
2025-01-08 08:10:02.310 | Teton CME Order Routing | MarketDepthIsSupported: 1
2025-01-08 08:10:02.310 | Teton CME Order Routing | Connected to server complete.
2025-01-08 08:10:02.314 | No download requests in the queue to start downloads for.
2025-01-08 08:10:02.314 | Triggering next historical data download in queue.
2025-01-08 08:10:02.314 | No download requests in the queue to start downloads for. | Number times message added: 1
2025-01-08 08:10:02.315 | Subscribing to symbol for symbol alert. MESU4.CME
2025-01-08 08:10:02.315 | Using symbol data fast lookup vector
2025-01-08 08:10:02.315 | Teton CME Order Routing | Starting real-time market data updates for: MESU4.CME. ID: 1
2025-01-08 08:10:02.315 | Teton CME Order Routing | Subscribing to streaming market data in the service client is not supported. Symbol: MESU4.CME
2025-01-08 08:10:02.315 | Teton CME Order Routing | Requesting security definition data for: MESU4.CME. ID: 1
2025-01-08 08:10:02.315 | Subscribing to symbol for symbol alert. MESU4.CME | Number times message added: 2
2025-01-08 08:10:02.315 | Subscribing to symbol for symbol alert. MNQU4.CME
2025-01-08 08:10:02.315 | Teton CME Order Routing | Starting real-time market data updates for: MNQU4.CME. ID: 2
2025-01-08 08:10:02.315 | Teton CME Order Routing | Subscribing to streaming market data in the service client is not supported. Symbol: MNQU4.CME
2025-01-08 08:10:02.315 | Teton CME Order Routing | Requesting security definition data for: MNQU4.CME. ID: 2
2025-01-08 08:10:02.317 | Teton CME Order Routing | Performing query for most recent Order Activity Date-Time.
2025-01-08 08:10:02.317 | Mapping MESH25_FUT_CME to MESH25. Service code: cme
2025-01-08 08:10:02.317 | Denali Data Feed | Starting real-time market data updates for: MESH25_FUT_CME (MESH25). ID: 3 Service code: cme
2025-01-08 08:10:02.321 | Denali Data Feed | Connecting to the server ds27.sierracharts.com. Port 443
2025-01-08 08:10:02.324 | Denali Data Feed | Requesting security definition data for: MESH25_FUT_CME (MESH25). ID: 3
2025-01-08 08:10:02.333 | Mapping 6AH25_FUT_CME to 6AH25. Service code: cme
2025-01-08 08:10:02.333 | Denali Data Feed | Starting real-time market data updates for: 6AH25_FUT_CME (6AH25). ID: 4 Service code: cme
2025-01-08 08:10:02.333 | Denali Data Feed | Requesting security definition data for: 6AH25_FUT_CME (6AH25). ID: 4
2025-01-08 08:10:02.355 | Mapping MNQH25_FUT_CME to MNQH25. Service code: cme
2025-01-08 08:10:02.355 | Denali Data Feed | Starting real-time market data updates for: MNQH25_FUT_CME (MNQH25). ID: 5 Service code: cme
2025-01-08 08:10:02.355 | Denali Data Feed | Requesting security definition data for: MNQH25_FUT_CME (MNQH25). ID: 5
2025-01-08 08:10:02.371 | Mapping MGCG25_FUT_CME to MGCG25. Service code: comex
2025-01-08 08:10:02.371 | Denali Data Feed | Starting real-time market data updates for: MGCG25_FUT_CME (MGCG25). ID: 6 Service code: comex
2025-01-08 08:10:02.371 | Denali Data Feed | Requesting security definition data for: MGCG25_FUT_CME (MGCG25). ID: 6
2025-01-08 08:10:02.386 | Mapping 6EZ24_FUT_CME to 6EZ24. Service code: cme
2025-01-08 08:10:02.387 | Denali Data Feed | Starting real-time market data updates for: 6EZ24_FUT_CME (6EZ24). ID: 7 Service code: cme
2025-01-08 08:10:02.387 | Denali Data Feed | Requesting security definition data for: 6EZ24_FUT_CME (6EZ24). ID: 7
2025-01-08 08:10:02.433 | DTC Client socket (3) | Creating socket.
2025-01-08 08:10:02.433 | DTC Client socket (3) | New receive buffer size: 0
2025-01-08 08:10:02.433 | DTC Client socket (3) | Connecting to IP: 208.185.224.131.
2025-01-08 08:10:02.450 | Mapping M6AH25_FUT_CME to M6AH25. Service code: cme
2025-01-08 08:10:02.450 | Denali Data Feed | Starting real-time market data updates for: M6AH25_FUT_CME (M6AH25). ID: 8 Service code: cme
2025-01-08 08:10:02.450 | Denali Data Feed | Requesting security definition data for: M6AH25_FUT_CME (M6AH25). ID: 8
2025-01-08 08:10:02.495 | Mapping 6JZ24_FUT_CME to 6JZ24. Service code: cme
2025-01-08 08:10:02.496 | Denali Data Feed | Starting real-time market data updates for: 6JZ24_FUT_CME (6JZ24). ID: 9 Service code: cme
2025-01-08 08:10:02.496 | Denali Data Feed | Requesting security definition data for: 6JZ24_FUT_CME (6JZ24). ID: 9
2025-01-08 08:10:02.588 | Mapping MCLX24_FUT_CME to MCLX24. Service code: nymex
2025-01-08 08:10:02.588 | Delayed Data Feed | Starting real-time market data updates for: MCLX24_FUT_CME (MCLX24). ID: 10 Service code: nymex
2025-01-08 08:10:02.592 | Delayed Data Feed | Connecting to the server ds27.sierracharts.com. Port 10043
2025-01-08 08:10:02.592 | DTC Client socket (4) | Creating socket.
2025-01-08 08:10:02.592 | DTC Client socket (4) | New receive buffer size: 0
2025-01-08 08:10:02.592 | DTC Client socket (4) | Connecting to IP: 208.185.224.131.
2025-01-08 08:10:02.596 | HD Request # 1 | Setting DTC encoding to Binary VLS
2025-01-08 08:10:02.596 | HD Request # 1 | Sending historical data logon request message.
2025-01-08 08:10:02.596 | Delayed Data Feed | Requesting security definition data for: MCLX24_FUT_CME (MCLX24). ID: 10
2025-01-08 08:10:02.748 | Mapping ESH25_FUT_CME to ESH25. Service code: cme
2025-01-08 08:10:02.748 | Denali Data Feed | Starting real-time market data updates for: ESH25_FUT_CME (ESH25). ID: 11 Service code: cme
2025-01-08 08:10:02.748 | Denali Data Feed | Requesting security definition data for: ESH25_FUT_CME (ESH25). ID: 11
2025-01-08 08:10:02.818 | Denali Data Feed | Network connection to server complete.
2025-01-08 08:10:02.818 | Denali Data Feed | Starting socket receive thread.
2025-01-08 08:10:02.818 | Denali Data Feed | Sending encoding request to server: Binary VLS. Compression: high
2025-01-08 08:10:02.893 | HD Request # 1 | Requesting Intraday data. Start date-time: 2025-01-08 08:09:28. Record interval: 0. Symbol: MESH25
2025-01-08 08:10:02.941 | Delayed Data Feed | Network connection to server complete.
2025-01-08 08:10:02.941 | Delayed Data Feed | Starting socket receive thread.
2025-01-08 08:10:02.941 | Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: high
2025-01-08 08:10:03.145 | HD Request # 1 | Decompressing data.
2025-01-08 08:10:03.216 | Denali Data Feed | Setting DTC encoding to Binary VLS
2025-01-08 08:10:03.216 | Denali Data Feed | Sending logon request message.
2025-01-08 08:10:03.320 | Delayed Data Feed | Setting DTC encoding to Binary VLS
2025-01-08 08:10:03.320 | Delayed Data Feed | Sending logon request message.
2025-01-08 08:10:03.400 | HD Request # 1 | Receiving Intraday data for MESH25_FUT_CME starting at 2025-01-08 08:09:28.323000
2025-01-08 08:10:03.401 | Socket (2) | CloseSocket call.
2025-01-08 08:10:03.401 | Socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 08:10:03.401 | Historical data download thread signaled to stop.
2025-01-08 08:10:03.401 | HD Request # 1 | Timestamp of first Intraday data file record written: 2025-01-08 08:09:29.604000.
2025-01-08 08:10:03.401 | HD Request # 1 | Received 206 Intraday data records from 2025-01-08 08:09:28.323000 to 2025-01-08 08:10:04.609000 (36.3 seconds. Delay: -1.2 seconds) and wrote 203 records for MESH25_FUT_CME
2025-01-08 08:10:03.402 | HD Request # 1 | Add time&sales data | Remembered last file record date-time: 2025-01-08 13:10:04.609000
2025-01-08 08:10:03.402 | HD Request # 1 | Completion time: 1s.
2025-01-08 08:10:03.402 | HD Request # 1 | Intraday data download complete for MESH25_FUT_CME. Unique request ID: 1
2025-01-08 08:10:03.402 | Removing historical data download ID 1.
2025-01-08 08:10:03.402 | Real-time Intraday chart data file updates started for MESH25_FUT_CME
2025-01-08 08:10:03.402 | Intraday chart data file opened for MESH25_FUT_CME
2025-01-08 08:10:03.402 | HD Request # 1 | Enabling Intraday chart updating for symbol.
2025-01-08 08:10:03.402 | Triggering next historical data download in queue.
2025-01-08 08:10:03.402 | Historical data for MESH25_FUT_CME is delayed because connection to main data feed is not present. Current data will be received upon connection.
2025-01-08 08:10:03.402 | Delaying start of download for MNQH25_FUT_CME.
2025-01-08 08:10:03.607 | Denali Data Feed | Received logon response.
2025-01-08 08:10:03.607 | Denali Data Feed | Server Name: RealTimeServer.
2025-01-08 08:10:03.607 | Denali Data Feed | Server protocol version: 8. Client protocol version: 8
2025-01-08 08:10:03.607 | Denali Data Feed | Logon error received from server: Data service (sc_exchange2.datafeed) is disabled or unsupported. A software update may be necessary.
2025-01-08 08:10:03.607 | Denali Data Feed | Failed connections: 1
2025-01-08 08:10:03.607 | Denali Data Feed | Waiting for socket receive thread to end
2025-01-08 08:10:03.608 | DTC Client socket (3) | CloseSocket call.
2025-01-08 08:10:03.608 | DTC Client socket (3) | Shutdown started. Waiting for graceful close.
2025-01-08 08:10:03.608 | Denali Data Feed | Disconnected from the server.
2025-01-08 08:10:03.608 | Denali Data Feed | Data feed disconnected. Will reconnect in 3 seconds.
2025-01-08 08:10:03.655 | Socket (2) | Socket gracefully closed by remote side.
2025-01-08 08:10:03.655 | Socket (2) | Closed.
2025-01-08 08:10:03.993 | DTC Client socket (3) | Socket gracefully closed by remote side.
2025-01-08 08:10:03.993 | DTC Client socket (3) | Closed.
2025-01-08 08:10:04.595 | Teton CME Order Routing | Requesting historical order activity from server. Start date-time UTC: 2025-01-08 13:00:10.080674
2025-01-08 08:10:06.619 | Denali Data Feed | Connecting to the server ds26-2.sierracharts.com. Port 443
2025-01-08 08:10:06.730 | DTC Client socket (2) | Creating socket.
2025-01-08 08:10:06.730 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 08:10:06.730 | DTC Client socket (2) | Connecting to IP: 64.152.155.18.
2025-01-08 08:10:06.977 | Denali Data Feed | Network connection to server complete.
2025-01-08 08:10:06.977 | Denali Data Feed | Starting socket receive thread.
2025-01-08 08:10:06.977 | Denali Data Feed | Sending encoding request to server: Binary VLS. Compression: high
2025-01-08 08:10:07.229 | Denali Data Feed | Setting DTC encoding to Binary VLS
2025-01-08 08:10:07.229 | Denali Data Feed | Sending logon request message.
2025-01-08 08:10:07.308 | Requesting market depth updates for: 6AH25_FUT_CME if supported. NumLevels=50
2025-01-08 08:10:07.308 | Requesting market depth updates for: 6EZ24_FUT_CME if supported. NumLevels=50
2025-01-08 08:10:07.308 | Requesting market depth updates for: 6JZ24_FUT_CME if supported. NumLevels=50
2025-01-08 08:10:07.308 | Requesting market depth updates for: ESH25_FUT_CME if supported. NumLevels=50
2025-01-08 08:10:07.308 | Requesting market depth updates for: M6AH25_FUT_CME if supported. NumLevels=50
2025-01-08 08:10:07.308 | Requesting market depth updates for: MCLX24_FUT_CME if supported. NumLevels=50
2025-01-08 08:10:07.308 | Requesting market depth updates for: MESH25_FUT_CME if supported. NumLevels=50
2025-01-08 08:10:07.308 | Requesting market depth updates for: MGCG25_FUT_CME if supported. NumLevels=50
2025-01-08 08:10:07.308 | Requesting market depth updates for: MNQH25_FUT_CME if supported. NumLevels=50
2025-01-08 08:10:07.973 | Teton CME Order Routing | Security Definition request has been rejected. Reason: Unsupported symbol: MESU4.CME. ID = 1
2025-01-08 08:10:07.973 | Teton CME Order Routing | Security Definition request has been rejected. Reason: Unsupported symbol: MNQU4.CME. ID = 2
2025-01-08 08:10:07.973 | Updated verified funded futures trading account ending date to: 2025-02-07 13:10:07
2025-01-08 08:10:07.973 | Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: MESH25_FUT_CME
2025-01-08 08:10:07.973 | Teton CME Order Routing | Setting external service identifier for symbol MESH25_FUT_CME to 42005347
2025-01-08 08:10:07.973 | Teton CME Order Routing | Received security definition for symbol MESH25_FUT_CME
2025-01-08 08:10:07.973 | Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: 6AH25_FUT_CME
2025-01-08 08:10:07.973 | Teton CME Order Routing | Setting external service identifier for symbol 6AH25_FUT_CME to 52126
2025-01-08 08:10:07.973 | Teton CME Order Routing | Received security definition for symbol 6AH25_FUT_CME
2025-01-08 08:10:07.973 | Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: MNQH25_FUT_CME
2025-01-08 08:10:07.973 | Teton CME Order Routing | Setting external service identifier for symbol MNQH25_FUT_CME to 42003617
2025-01-08 08:10:07.973 | Teton CME Order Routing | Received security definition for symbol MNQH25_FUT_CME
2025-01-08 08:10:07.973 | Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: MGCG25_FUT_CME
2025-01-08 08:10:07.973 | Teton CME Order Routing | Setting external service identifier for symbol MGCG25_FUT_CME to 69
2025-01-08 08:10:07.973 | Teton CME Order Routing | Received security definition for symbol MGCG25_FUT_CME
2025-01-08 08:10:07.973 | Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: 6EZ24_FUT_CME
2025-01-08 08:10:07.973 | Teton CME Order Routing | Setting external service identifier for symbol 6EZ24_FUT_CME to 331
2025-01-08 08:10:07.973 | Teton CME Order Routing | Received security definition for symbol 6EZ24_FUT_CME
2025-01-08 08:10:07.984 | Denali Data Feed | Received logon response.
2025-01-08 08:10:07.984 | Denali Data Feed | Server Name: SC Realtime Server.
2025-01-08 08:10:07.984 | Denali Data Feed | Server protocol version: 8. Client protocol version: 8
2025-01-08 08:10:07.984 | Denali Data Feed | Successfully connected.
2025-01-08 08:10:07.984 | Denali Data Feed | Trading is not supported.
2025-01-08 08:10:07.984 | Denali Data Feed | MarketDepthIsSupported: 1
2025-01-08 08:10:07.984 | Denali Data Feed | Restarting real-time data updates for symbol: 6AH25_FUT_CME -> 6AH25. Market Depth data restarted.
2025-01-08 08:10:07.984 | Denali Data Feed | Restarting real-time data updates for symbol: 6EZ24_FUT_CME -> 6EZ24. Market Depth data restarted.
2025-01-08 08:10:07.984 | Denali Data Feed | Restarting real-time data updates for symbol: 6JZ24_FUT_CME -> 6JZ24. Market Depth data restarted.
2025-01-08 08:10:07.984 | Denali Data Feed | Restarting real-time data updates for symbol: ESH25_FUT_CME -> ESH25. Market Depth data restarted.
2025-01-08 08:10:07.984 | Denali Data Feed | Restarting real-time data updates for symbol: M6AH25_FUT_CME -> M6AH25. Market Depth data restarted.
2025-01-08 08:10:07.984 | Added historical Intraday data request for MESH25_FUT_CME to the queue.
2025-01-08 08:10:07.984 | Intraday data recording state for symbol MESH25_FUT_CME is set to download 'Pending'.
2025-01-08 08:10:07.984 | Triggering next historical data download in queue.
2025-01-08 08:10:07.984 | Denali Data Feed | Restarting real-time data updates for symbol: MESH25_FUT_CME -> MESH25. Market Depth data restarted.
2025-01-08 08:10:07.984 | Denali Data Feed | Restarting real-time data updates for symbol: MGCG25_FUT_CME -> MGCG25. Market Depth data restarted.
2025-01-08 08:10:07.984 | Denali Data Feed | Restarting real-time data updates for symbol: MNQH25_FUT_CME -> MNQH25. Market Depth data restarted.
2025-01-08 08:10:08.730 | Denali Data Feed | Clearing market depth for 6AH25_FUT_CME
2025-01-08 08:10:08.730 | Denali Data Feed | Clearing market depth for 6EZ24_FUT_CME
2025-01-08 08:10:08.730 | Denali Data Feed | Clearing market depth for 6JZ24_FUT_CME
2025-01-08 08:10:08.730 | Denali Data Feed | Clearing market depth for ESH25_FUT_CME
2025-01-08 08:10:08.730 | Denali Data Feed | Clearing market depth for M6AH25_FUT_CME
2025-01-08 08:10:08.730 | Denali Data Feed | Clearing market depth for MESH25_FUT_CME
2025-01-08 08:10:08.730 | Denali Data Feed | Clearing market depth for MGCG25_FUT_CME
2025-01-08 08:10:08.731 | Denali Data Feed | Clearing market depth for MNQH25_FUT_CME
2025-01-08 08:10:08.731 | Denali Data Feed | Setting external service identifier for symbol 6AH25_FUT_CME to 52126
2025-01-08 08:10:08.731 | Denali Data Feed | Received security definition for symbol 6AH25_FUT_CME
2025-01-08 08:10:08.731 | Denali Data Feed | Real-time data for symbol 6EZ24_FUT_CME is currently unavailable.
2025-01-08 08:10:08.731 | Denali Data Feed | Received security definition for symbol 6EZ24_FUT_CME
2025-01-08 08:10:08.731 | Denali Data Feed | Real-time data for symbol 6JZ24_FUT_CME is currently unavailable.
2025-01-08 08:10:08.731 | Denali Data Feed | Received security definition for symbol 6JZ24_FUT_CME
2025-01-08 08:10:08.731 | Denali Data Feed | Setting external service identifier for symbol ESH25_FUT_CME to 5002
2025-01-08 08:10:08.731 | Denali Data Feed | Received security definition for symbol ESH25_FUT_CME
2025-01-08 08:10:08.731 | Denali Data Feed | Setting external service identifier for symbol M6AH25_FUT_CME to 42185124
2025-01-08 08:10:08.731 | Denali Data Feed | Received security definition for symbol M6AH25_FUT_CME
2025-01-08 08:10:08.731 | Denali Data Feed | Setting external service identifier for symbol MESH25_FUT_CME to 42005347
2025-01-08 08:10:08.731 | Denali Data Feed | Received security definition for symbol MESH25_FUT_CME
2025-01-08 08:10:08.731 | Denali Data Feed | Setting external service identifier for symbol MGCG25_FUT_CME to 69
2025-01-08 08:10:08.731 | Denali Data Feed | Received security definition for symbol MGCG25_FUT_CME
2025-01-08 08:10:08.731 | Denali Data Feed | Setting external service identifier for symbol MNQH25_FUT_CME to 42003617
2025-01-08 08:10:08.731 | Denali Data Feed | Received security definition for symbol MNQH25_FUT_CME
2025-01-08 08:10:13.147 | HD Request # 2 | Downloading Intraday chart data for MNQH25_FUT_CME to the file MNQH25_FUT_CME.scid. Service: cme
2025-01-08 08:10:13.148 | HD Request # 2 | Download start date-time: 2025-01-08 08:09:29.000000. File last date-time: 2025-01-08 08:09:29.090001
2025-01-08 08:10:13.148 | HD Request # 2 | Using server: ds32.sierracharts.com port 10149
2025-01-08 08:10:13.148 | Socket (3) | Creating socket.
2025-01-08 08:10:13.148 | Socket (3) | New receive buffer size: 0
2025-01-08 08:10:13.148 | Socket (3) | Connecting to IP: 67.214.125.3.
2025-01-08 08:10:13.647 | HD Request # 2 | Setting DTC encoding to Binary VLS
2025-01-08 08:10:13.647 | HD Request # 2 | Sending historical data logon request message.
2025-01-08 08:10:13.937 | HD Request # 2 | Requesting Intraday data. Start date-time: 2025-01-08 08:09:29. Record interval: 0. Symbol: MNQH25
2025-01-08 08:10:14.186 | HD Request # 2 | Decompressing data.
2025-01-08 08:10:14.435 | HD Request # 2 | Receiving Intraday data for MNQH25_FUT_CME starting at 2025-01-08 08:09:29.090000
2025-01-08 08:10:14.436 | Socket (3) | CloseSocket call.
2025-01-08 08:10:14.436 | Socket (3) | Shutdown started. Waiting for graceful close.
2025-01-08 08:10:14.436 | Historical data download thread signaled to stop.
2025-01-08 08:10:14.436 | HD Request # 2 | Timestamp of first Intraday data file record written: 2025-01-08 08:09:29.609000.
2025-01-08 08:10:14.436 | HD Request # 2 | Received 844 Intraday data records from 2025-01-08 08:09:29.090000 to 2025-01-08 08:10:12.973001 (43.9 seconds. Delay: 1.5 seconds) and wrote 842 records for MNQH25_FUT_CME
2025-01-08 08:10:14.436 | HD Request # 2 | Add time&sales data | Remembered last file record date-time: 2025-01-08 13:10:12.973001
2025-01-08 08:10:14.436 | Added 48 Time and Sales records to Intraday data file for MNQH25_FUT_CME after download.
2025-01-08 08:10:14.436 | HD Request # 2 | Completion time: 1s.
2025-01-08 08:10:14.436 | HD Request # 2 | Intraday data download complete for MNQH25_FUT_CME. Unique request ID: 2
2025-01-08 08:10:14.436 | Removing historical data download ID 2.
2025-01-08 08:10:14.437 | Real-time Intraday chart data file updates started for MNQH25_FUT_CME
2025-01-08 08:10:14.437 | Intraday chart data file opened for MNQH25_FUT_CME
2025-01-08 08:10:14.437 | HD Request # 2 | Enabling Intraday chart updating for symbol.
2025-01-08 08:10:14.437 | Triggering next historical data download in queue.
2025-01-08 08:10:14.437 | HD Request # 3 | Downloading Intraday chart data for MGCG25_FUT_CME to the file MGCG25_FUT_CME.scid. Service: comex
2025-01-08 08:10:14.437 | HD Request # 3 | Download start date-time: 2025-01-08 08:09:29.000000. File last date-time: 2025-01-08 08:09:29.388000
2025-01-08 08:10:14.437 | HD Request # 3 | Using server: ds32.sierracharts.com port 10150
2025-01-08 08:10:14.437 | Socket (6) | Creating socket.
2025-01-08 08:10:14.437 | Socket (6) | New receive buffer size: 0
2025-01-08 08:10:14.437 | Socket (6) | Connecting to IP: 67.214.125.3.
2025-01-08 08:10:14.683 | Socket (3) | Socket gracefully closed by remote side.
2025-01-08 08:10:14.684 | Socket (3) | Closed.
2025-01-08 08:10:14.908 | HD Request # 3 | Setting DTC encoding to Binary VLS
2025-01-08 08:10:14.908 | HD Request # 3 | Sending historical data logon request message.
2025-01-08 08:10:15.142 | HD Request # 3 | Requesting Intraday data. Start date-time: 2025-01-08 08:09:29. Record interval: 0. Symbol: MGCG25
2025-01-08 08:10:15.375 | HD Request # 3 | Decompressing data.
2025-01-08 08:10:15.609 | HD Request # 3 | Receiving Intraday data for MGCG25_FUT_CME starting at 2025-01-08 08:09:29.085000
2025-01-08 08:10:15.609 | Socket (6) | CloseSocket call.
2025-01-08 08:10:15.609 | Historical data download thread signaled to stop.
2025-01-08 08:10:15.609 | Socket (6) | Shutdown started. Waiting for graceful close.
2025-01-08 08:10:15.609 | HD Request # 3 | Timestamp of first Intraday data file record written: 2025-01-08 08:09:29.589000.
2025-01-08 08:10:15.609 | HD Request # 3 | Received 162 Intraday data records from 2025-01-08 08:09:29.085000 to 2025-01-08 08:10:14.972000 (45.9 seconds. Delay: 0.6 seconds) and wrote 160 records for MGCG25_FUT_CME
2025-01-08 08:10:15.610 | HD Request # 3 | Add time&sales data | Remembered last file record date-time: 2025-01-08 13:10:14.972000
2025-01-08 08:10:15.610 | HD Request # 3 | Completion time: 1s.
2025-01-08 08:10:15.610 | HD Request # 3 | Intraday data download complete for MGCG25_FUT_CME. Unique request ID: 3
2025-01-08 08:10:15.610 | Removing historical data download ID 3.
2025-01-08 08:10:15.610 | Real-time Intraday chart data file updates started for MGCG25_FUT_CME
2025-01-08 08:10:15.610 | Intraday chart data file opened for MGCG25_FUT_CME
2025-01-08 08:10:15.610 | HD Request # 3 | Enabling Intraday chart updating for symbol.
2025-01-08 08:10:15.610 | Triggering next historical data download in queue.
2025-01-08 08:10:15.610 | Delaying start of download for MCLX24_FUT_CME.
2025-01-08 08:10:15.844 | Socket (6) | Socket gracefully closed by remote side.
2025-01-08 08:10:15.844 | Socket (6) | Closed.
2025-01-08 08:10:17.227 | Delayed Data Feed | Received logon response.
2025-01-08 08:10:17.227 | Delayed Data Feed | Server Name: RealTimeServer.
2025-01-08 08:10:17.227 | Delayed Data Feed | Server protocol version: 8. Client protocol version: 8
2025-01-08 08:10:17.227 | Delayed Data Feed | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary.
2025-01-08 08:10:17.227 | Delayed Data Feed | Failed connections: 1
2025-01-08 08:10:17.227 | Delayed Data Feed | Waiting for socket receive thread to end
2025-01-08 08:10:17.227 | DTC Client socket (4) | CloseSocket call.
2025-01-08 08:10:17.227 | DTC Client socket (4) | Shutdown started. Waiting for graceful close.
2025-01-08 08:10:17.227 | Delayed Data Feed | Disconnected from the server.
2025-01-08 08:10:17.227 | Delayed Data Feed | Data feed disconnected. Will reconnect in 5 seconds.
2025-01-08 08:10:18.030 | Opened cached Intraday file: C:\SierraChart - EdgeClear\Data\MNQH25_FUT_CME.scid. Thread ID: 25844
2025-01-08 08:10:18.030 | Opened cached Intraday file: C:\SierraChart - EdgeClear\Data\MGCG25_FUT_CME.scid. Thread ID: 25844
2025-01-08 08:10:22.222 | Delayed Data Feed | Connecting to the server ds26-2.sierracharts.com. Port 10043
2025-01-08 08:10:22.223 | DTC Client socket (3) | Creating socket.
2025-01-08 08:10:22.223 | DTC Client socket (3) | New receive buffer size: 0
2025-01-08 08:10:22.223 | DTC Client socket (3) | Connecting to IP: 64.152.155.18.
2025-01-08 08:10:22.464 | Delayed Data Feed | Network connection to server complete.
2025-01-08 08:10:22.464 | Delayed Data Feed | Starting socket receive thread.
2025-01-08 08:10:22.464 | Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: high
2025-01-08 08:10:22.713 | Delayed Data Feed | Setting DTC encoding to Binary VLS
2025-01-08 08:10:22.713 | Delayed Data Feed | Sending logon request message.
2025-01-08 08:10:23.462 | Delayed Data Feed | Received logon response.
2025-01-08 08:10:23.462 | Delayed Data Feed | Server Name: SC Realtime Server.
2025-01-08 08:10:23.462 | Delayed Data Feed | Server protocol version: 8. Client protocol version: 8
2025-01-08 08:10:23.462 | Delayed Data Feed | Successfully connected.
2025-01-08 08:10:23.462 | Delayed Data Feed | Trading is not supported.
2025-01-08 08:10:23.462 | Delayed Data Feed | MarketDepthIsSupported: 1
2025-01-08 08:10:23.462 | Delayed Data Feed | Restarting real-time data updates for symbol: MCLX24_FUT_CME -> MCLX24. Market Depth data restarted.
2025-01-08 08:10:24.211 | Delayed Data Feed | Clearing market depth for MCLX24_FUT_CME
2025-01-08 08:10:24.212 | Delayed Data Feed | Real-time data for symbol MCLX24_FUT_CME is currently unavailable.
2025-01-08 08:10:24.212 | Delayed Data Feed | Received security definition for symbol MCLX24_FUT_CME
2025-01-08 08:10:27.968 | ExtendTheFundedTradingAccountStatusExpirationDate: Sending request.
2025-01-08 08:10:29.042 | ExtendTheFundedTradingAccountStatusExpirationDate | Result: {"Result":"The Funded Trading Account Status Expiration Date is more than 25 days into the future. The Date is currently: 2025-02-04"}. Success=true
2025-01-08 08:10:29.060 | HD Request # 4 | Downloading Intraday chart data for MCLX24_FUT_CME to the file MCLX24_FUT_CME.scid. Service: nymex
2025-01-08 08:10:29.061 | HD Request # 4 | Download start date-time: 2024-10-21 14:29:29.000000. File last date-time: 2024-10-21 14:29:29.817001
2025-01-08 08:10:29.061 | HD Request # 4 | Using server: ds28.sierracharts.com port 10149
2025-01-08 08:10:29.061 | Socket (7) | Creating socket.
2025-01-08 08:10:29.061 | Socket (7) | New receive buffer size: 0
2025-01-08 08:10:29.061 | Socket (7) | Connecting to IP: 67.214.125.5.
2025-01-08 08:10:29.542 | HD Request # 4 | Setting DTC encoding to Binary VLS
2025-01-08 08:10:29.542 | HD Request # 4 | Sending historical data logon request message.
2025-01-08 08:10:29.820 | HD Request # 4 | Requesting Intraday data. Start date-time: 2024-10-21 14:29:29. Record interval: 0. Symbol: MCLX24
2025-01-08 08:10:30.055 | HD Request # 4 | Decompressing data.
2025-01-08 08:10:30.287 | HD Request # 4 | Receiving Intraday data for MCLX24_FUT_CME starting at 2024-10-21 14:29:29.817000
2025-01-08 08:10:30.287 | Socket (7) | CloseSocket call.
2025-01-08 08:10:30.287 | Socket (7) | Shutdown started. Waiting for graceful close.
2025-01-08 08:10:30.287 | Historical data download thread signaled to stop.
2025-01-08 08:10:30.287 | HD Request # 4 | Received 2 Intraday data records from 2024-10-21 14:29:29.817000 to 2024-10-21 14:29:29.817001 (0.0 seconds. Delay: 78.8 days) and wrote 0 records for MCLX24_FUT_CME
2025-01-08 08:10:30.287 | HD Request # 4 | Add time&sales data | Remembered last file record date-time: 2024-10-21 18:29:29.817001
2025-01-08 08:10:30.287 | HD Request # 4 | Completion time: 1s.
2025-01-08 08:10:30.287 | HD Request # 4 | Intraday data download complete for MCLX24_FUT_CME. Unique request ID: 4
2025-01-08 08:10:30.287 | Removing historical data download ID 4.
2025-01-08 08:10:30.287 | Real-time Intraday chart data file updates started for MCLX24_FUT_CME
2025-01-08 08:10:30.287 | Intraday chart data file opened for MCLX24_FUT_CME
2025-01-08 08:10:30.287 | HD Request # 4 | Enabling Intraday chart updating for symbol.
2025-01-08 08:10:30.287 | Triggering next historical data download in queue.
2025-01-08 08:10:30.287 | HD Request # 5 | Downloading Intraday chart data for 6AH25_FUT_CME to the file 6AH25_FUT_CME.scid. Service: cme
2025-01-08 08:10:30.287 | HD Request # 5 | Download start date-time: 2025-01-08 08:09:26.000000. File last date-time: 2025-01-08 08:09:26.746001
2025-01-08 08:10:30.287 | HD Request # 5 | Using server: ds32.sierracharts.com port 10150
2025-01-08 08:10:30.288 | Socket (6) | Creating socket.
2025-01-08 08:10:30.288 | Socket (6) | New receive buffer size: 0
2025-01-08 08:10:30.288 | Socket (6) | Connecting to IP: 67.214.125.3.
2025-01-08 08:10:30.519 | Socket (7) | Socket gracefully closed by remote side.
2025-01-08 08:10:30.519 | Socket (7) | Closed.
2025-01-08 08:10:30.774 | HD Request # 5 | Setting DTC encoding to Binary VLS
2025-01-08 08:10:30.774 | HD Request # 5 | Sending historical data logon request message.
2025-01-08 08:10:31.015 | HD Request # 5 | Requesting Intraday data. Start date-time: 2025-01-08 08:09:26. Record interval: 0. Symbol: 6AH25
2025-01-08 08:10:31.256 | HD Request # 5 | Decompressing data.
2025-01-08 08:10:31.497 | HD Request # 5 | Receiving Intraday data for 6AH25_FUT_CME starting at 2025-01-08 08:09:26.746000
2025-01-08 08:10:31.498 | Socket (6) | CloseSocket call.
2025-01-08 08:10:31.498 | Socket (6) | Shutdown started. Waiting for graceful close.
2025-01-08 08:10:31.498 | Historical data download thread signaled to stop.
2025-01-08 08:10:31.498 | HD Request # 5 | Timestamp of first Intraday data file record written: 2025-01-08 08:09:29.582000.
2025-01-08 08:10:31.498 | HD Request # 5 | Received 62 Intraday data records from 2025-01-08 08:09:26.746000 to 2025-01-08 08:10:28.252002 (61.5 seconds. Delay: 3.2 seconds) and wrote 60 records for 6AH25_FUT_CME
2025-01-08 08:10:31.498 | HD Request # 5 | Add time&sales data | Remembered last file record date-time: 2025-01-08 13:10:28.252002
2025-01-08 08:10:31.498 | Added 1 Time and Sales records to Intraday data file for 6AH25_FUT_CME after download.
2025-01-08 08:10:31.498 | HD Request # 5 | Completion time: 1s.
2025-01-08 08:10:31.498 | HD Request # 5 | Intraday data download complete for 6AH25_FUT_CME. Unique request ID: 5
2025-01-08 08:10:31.498 | Removing historical data download ID 5.
2025-01-08 08:10:31.498 | Real-time Intraday chart data file updates started for 6AH25_FUT_CME
2025-01-08 08:10:31.498 | Intraday chart data file opened for 6AH25_FUT_CME
2025-01-08 08:10:31.498 | HD Request # 5 | Enabling Intraday chart updating for symbol.
2025-01-08 08:10:31.498 | Triggering next historical data download in queue.
2025-01-08 08:10:31.498 | HD Request # 6 | Downloading Intraday chart data for M6AH25_FUT_CME to the file M6AH25_FUT_CME.scid. Service: cme
2025-01-08 08:10:31.499 | HD Request # 6 | Download start date-time: 2025-01-08 08:09:29.000000. File last date-time: 2025-01-08 08:09:29.019000
2025-01-08 08:10:31.499 | HD Request # 6 | Using server: ds32.sierracharts.com port 10149
2025-01-08 08:10:31.499 | Socket (7) | Creating socket.
2025-01-08 08:10:31.499 | Socket (7) | New receive buffer size: 0
2025-01-08 08:10:31.499 | Socket (7) | Connecting to IP: 67.214.125.3.
2025-01-08 08:10:31.739 | Socket (6) | Socket gracefully closed by remote side.
2025-01-08 08:10:31.739 | Socket (6) | Closed.
2025-01-08 08:10:32.012 | HD Request # 6 | Setting DTC encoding to Binary VLS
2025-01-08 08:10:32.012 | HD Request # 6 | Sending historical data logon request message.
2025-01-08 08:10:32.265 | HD Request # 6 | Requesting Intraday data. Start date-time: 2025-01-08 08:09:29. Record interval: 0. Symbol: M6AH25
2025-01-08 08:10:32.519 | HD Request # 6 | Decompressing data.
2025-01-08 08:10:32.772 | HD Request # 6 | Receiving Intraday data for M6AH25_FUT_CME starting at 2025-01-08 08:09:29.019000
2025-01-08 08:10:32.772 | Socket (7) | CloseSocket call.
2025-01-08 08:10:32.772 | Historical data download thread signaled to stop.
2025-01-08 08:10:32.772 | Socket (7) | Shutdown started. Waiting for graceful close.
2025-01-08 08:10:32.772 | HD Request # 6 | Timestamp of first Intraday data file record written: 2025-01-08 08:09:46.824000.
2025-01-08 08:10:32.773 | HD Request # 6 | Received 15 Intraday data records from 2025-01-08 08:09:29.019000 to 2025-01-08 08:10:28.252000 (59.2 seconds. Delay: 4.5 seconds) and wrote 14 records for M6AH25_FUT_CME
2025-01-08 08:10:32.773 | HD Request # 6 | Add time&sales data | Remembered last file record date-time: 2025-01-08 13:10:28.252000
2025-01-08 08:10:32.773 | HD Request # 6 | Completion time: 1s.
2025-01-08 08:10:32.773 | HD Request # 6 | Intraday data download complete for M6AH25_FUT_CME. Unique request ID: 6
2025-01-08 08:10:32.773 | Removing historical data download ID 6.
2025-01-08 08:10:32.773 | Real-time Intraday chart data file updates started for M6AH25_FUT_CME
2025-01-08 08:10:32.773 | Intraday chart data file opened for M6AH25_FUT_CME
2025-01-08 08:10:32.773 | HD Request # 6 | Enabling Intraday chart updating for symbol.
2025-01-08 08:10:32.773 | Triggering next historical data download in queue.
2025-01-08 08:10:32.773 | HD Request # 7 | Downloading Intraday chart data for 6JZ24_FUT_CME to the file 6JZ24_FUT_CME.scid. Service: cme
2025-01-08 08:10:32.773 | HD Request # 7 | Download start date-time: 2024-12-16 10:15:05.000000. File last date-time: 2024-12-16 10:15:05.968000
2025-01-08 08:10:32.773 | HD Request # 7 | Using server: ds32.sierracharts.com port 10150
2025-01-08 08:10:32.773 | Socket (6) | Creating socket.
2025-01-08 08:10:32.773 | Socket (6) | New receive buffer size: 0
2025-01-08 08:10:32.773 | Socket (6) | Connecting to IP: 67.214.125.3.
2025-01-08 08:10:33.027 | Socket (7) | Socket gracefully closed by remote side.
2025-01-08 08:10:33.027 | Socket (7) | Closed.
2025-01-08 08:10:33.276 | HD Request # 7 | Setting DTC encoding to Binary VLS
2025-01-08 08:10:33.276 | HD Request # 7 | Sending historical data logon request message.
2025-01-08 08:10:33.568 | HD Request # 7 | Requesting Intraday data. Start date-time: 2024-12-16 10:15:05. Record interval: 0. Symbol: 6JZ24
2025-01-08 08:10:33.819 | HD Request # 7 | Decompressing data.
2025-01-08 08:10:34.071 | HD Request # 7 | Receiving Intraday data for 6JZ24_FUT_CME starting at 2024-12-16 10:15:05.968000
2025-01-08 08:10:34.071 | Socket (6) | CloseSocket call.
2025-01-08 08:10:34.071 | Socket (6) | Shutdown started. Waiting for graceful close.
2025-01-08 08:10:34.071 | Historical data download thread signaled to stop.
2025-01-08 08:10:34.071 | HD Request # 7 | Received 1 Intraday data record from 2024-12-16 10:15:05.968000 to 2024-12-16 10:15:05.968000 (0.0 seconds. Delay: 22.9 days) and wrote 0 records for 6JZ24_FUT_CME
2025-01-08 08:10:34.071 | HD Request # 7 | Add time&sales data | Remembered last file record date-time: 2024-12-16 15:15:05.968000
2025-01-08 08:10:34.071 | HD Request # 7 | Completion time: 2s.
2025-01-08 08:10:34.071 | HD Request # 7 | Intraday data download complete for 6JZ24_FUT_CME. Unique request ID: 7
2025-01-08 08:10:34.071 | Removing historical data download ID 7.
2025-01-08 08:10:34.071 | Real-time Intraday chart data file updates started for 6JZ24_FUT_CME
2025-01-08 08:10:34.071 | Intraday chart data file opened for 6JZ24_FUT_CME
2025-01-08 08:10:34.071 | HD Request # 7 | Enabling Intraday chart updating for symbol.
2025-01-08 08:10:34.071 | Triggering next historical data download in queue.
2025-01-08 08:10:34.071 | HD Request # 8 | Downloading Intraday chart data for 6EZ24_FUT_CME to the file 6EZ24_FUT_CME.scid. Service: cme
2025-01-08 08:10:34.071 | HD Request # 8 | Download start date-time: 2024-12-16 10:14:47.000000. File last date-time: 2024-12-16 10:14:47.497000
2025-01-08 08:10:34.072 | HD Request # 8 | Using server: ds32.sierracharts.com port 10149
2025-01-08 08:10:34.072 | Socket (7) | Creating socket.
2025-01-08 08:10:34.072 | Socket (7) | New receive buffer size: 0
2025-01-08 08:10:34.072 | Socket (7) | Connecting to IP: 67.214.125.3.
2025-01-08 08:10:34.323 | Socket (6) | Socket gracefully closed by remote side.
2025-01-08 08:10:34.323 | Socket (6) | Closed.
2025-01-08 08:10:34.584 | HD Request # 8 | Setting DTC encoding to Binary VLS
2025-01-08 08:10:34.584 | HD Request # 8 | Sending historical data logon request message.
2025-01-08 08:10:34.836 | HD Request # 8 | Requesting Intraday data. Start date-time: 2024-12-16 10:14:47. Record interval: 0. Symbol: 6EZ24
2025-01-08 08:10:35.088 | HD Request # 8 | Decompressing data.
2025-01-08 08:10:35.340 | HD Request # 8 | Receiving Intraday data for 6EZ24_FUT_CME starting at 2024-12-16 10:14:47.497000
2025-01-08 08:10:35.340 | Socket (7) | CloseSocket call.
2025-01-08 08:10:35.340 | Socket (7) | Shutdown started. Waiting for graceful close.
2025-01-08 08:10:35.340 | Historical data download thread signaled to stop.
2025-01-08 08:10:35.340 | HD Request # 8 | Received 1 Intraday data record from 2024-12-16 10:14:47.497000 to 2024-12-16 10:14:47.497000 (0.0 seconds. Delay: 22.9 days) and wrote 0 records for 6EZ24_FUT_CME
2025-01-08 08:10:35.340 | HD Request # 8 | Add time&sales data | Remembered last file record date-time: 2024-12-16 15:14:47.497000
2025-01-08 08:10:35.340 | HD Request # 8 | Completion time: 1s.
2025-01-08 08:10:35.340 | HD Request # 8 | Intraday data download complete for 6EZ24_FUT_CME. Unique request ID: 8
2025-01-08 08:10:35.340 | Removing historical data download ID 8.
2025-01-08 08:10:35.340 | Real-time Intraday chart data file updates started for 6EZ24_FUT_CME
2025-01-08 08:10:35.340 | Intraday chart data file opened for 6EZ24_FUT_CME
2025-01-08 08:10:35.340 | HD Request # 8 | Enabling Intraday chart updating for symbol.
2025-01-08 08:10:35.340 | Triggering next historical data download in queue.
2025-01-08 08:10:35.340 | HD Request # 9 | Downloading Intraday chart data for ESH25_FUT_CME to the file ESH25_FUT_CME.scid. Service: cme
2025-01-08 08:10:35.340 | HD Request # 9 | Download start date-time: 2025-01-08 08:09:29.000000. File last date-time: 2025-01-08 08:09:29.060000
2025-01-08 08:10:35.340 | HD Request # 9 | Using server: ds32.sierracharts.com port 10150
2025-01-08 08:10:35.340 | Socket (6) | Creating socket.
2025-01-08 08:10:35.340 | Socket (6) | New receive buffer size: 0
2025-01-08 08:10:35.340 | Socket (6) | Connecting to IP: 67.214.125.3.
2025-01-08 08:10:35.593 | Socket (7) | Socket gracefully closed by remote side.
2025-01-08 08:10:35.593 | Socket (7) | Closed.
2025-01-08 08:10:35.814 | HD Request # 9 | Setting DTC encoding to Binary VLS
2025-01-08 08:10:35.814 | HD Request # 9 | Sending historical data logon request message.
2025-01-08 08:10:36.046 | HD Request # 9 | Requesting Intraday data. Start date-time: 2025-01-08 08:09:29. Record interval: 0. Symbol: ESH25
2025-01-08 08:10:36.277 | HD Request # 9 | Decompressing data.
2025-01-08 08:10:36.511 | HD Request # 9 | Receiving Intraday data for ESH25_FUT_CME starting at 2025-01-08 08:09:29.060000
2025-01-08 08:10:36.511 | Socket (6) | CloseSocket call.
2025-01-08 08:10:36.511 | Historical data download thread signaled to stop.
2025-01-08 08:10:36.511 | Socket (6) | Shutdown started. Waiting for graceful close.
2025-01-08 08:10:36.511 | HD Request # 9 | Timestamp of first Intraday data file record written: 2025-01-08 08:09:29.605000.
2025-01-08 08:10:36.511 | HD Request # 9 | Received 489 Intraday data records from 2025-01-08 08:09:29.060000 to 2025-01-08 08:10:36.527001 (67.5 seconds. Delay: -0.0 seconds) and wrote 488 records for ESH25_FUT_CME
2025-01-08 08:10:36.511 | HD Request # 9 | Add time&sales data | Remembered last file record date-time: 2025-01-08 13:10:36.527001
2025-01-08 08:10:36.512 | HD Request # 9 | Completion time: 1s.
2025-01-08 08:10:36.512 | HD Request # 9 | Intraday data download complete for ESH25_FUT_CME. Unique request ID: 9
2025-01-08 08:10:36.512 | Removing historical data download ID 9.
2025-01-08 08:10:36.512 | Real-time Intraday chart data file updates started for ESH25_FUT_CME
2025-01-08 08:10:36.512 | Intraday chart data file opened for ESH25_FUT_CME
2025-01-08 08:10:36.512 | HD Request # 9 | Enabling Intraday chart updating for symbol.
2025-01-08 08:10:36.512 | Triggering next historical data download in queue.
2025-01-08 08:10:36.512 | HD Request # 10 | Downloading Intraday chart data for MESH25_FUT_CME to the file MESH25_FUT_CME.scid. Service: cme
2025-01-08 08:10:36.512 | HD Request # 10 | Download start date-time: 2025-01-08 08:10:04.000000. File last date-time: 2025-01-08 08:10:04.609000
2025-01-08 08:10:36.512 | HD Request # 10 | Using server: ds32.sierracharts.com port 10149
2025-01-08 08:10:36.512 | Socket (7) | Creating socket.
2025-01-08 08:10:36.512 | Socket (7) | New receive buffer size: 0
2025-01-08 08:10:36.512 | Socket (7) | Connecting to IP: 67.214.125.3.
2025-01-08 08:10:36.743 | Socket (6) | Socket gracefully closed by remote side.
2025-01-08 08:10:36.743 | Socket (6) | Closed.
2025-01-08 08:10:37.023 | HD Request # 10 | Setting DTC encoding to Binary VLS
2025-01-08 08:10:37.023 | HD Request # 10 | Sending historical data logon request message.
2025-01-08 08:10:37.276 | HD Request # 10 | Requesting Intraday data. Start date-time: 2025-01-08 08:10:04. Record interval: 0. Symbol: MESH25
2025-01-08 08:10:37.529 | HD Request # 10 | Decompressing data.
2025-01-08 08:10:37.782 | HD Request # 10 | Receiving Intraday data for MESH25_FUT_CME starting at 2025-01-08 08:10:04.609000
2025-01-08 08:10:37.782 | Socket (7) | CloseSocket call.
2025-01-08 08:10:37.782 | Socket (7) | Shutdown started. Waiting for graceful close.
2025-01-08 08:10:37.783 | Historical data download thread signaled to stop.
2025-01-08 08:10:37.783 | HD Request # 10 | Timestamp of first Intraday data file record written: 2025-01-08 08:10:05.710000.
2025-01-08 08:10:37.784 | HD Request # 10 | Received 139 Intraday data records from 2025-01-08 08:10:04.609000 to 2025-01-08 08:10:36.636001 (32.0 seconds. Delay: 1.1 seconds) and wrote 138 records for MESH25_FUT_CME
2025-01-08 08:10:37.784 | HD Request # 10 | Add time&sales data | Remembered last file record date-time: 2025-01-08 13:10:36.636001
2025-01-08 08:10:37.784 | Added 6 Time and Sales records to Intraday data file for MESH25_FUT_CME after download.
2025-01-08 08:10:37.784 | HD Request # 10 | Completion time: 1s.
2025-01-08 08:10:37.784 | HD Request # 10 | Intraday data download complete for MESH25_FUT_CME. Unique request ID: 10
2025-01-08 08:10:37.784 | Removing historical data download ID 10.
2025-01-08 08:10:37.784 | Real-time Intraday chart data file updates started for MESH25_FUT_CME
2025-01-08 08:10:37.784 | Intraday chart data file opened for MESH25_FUT_CME
2025-01-08 08:10:37.784 | HD Request # 10 | Enabling Intraday chart updating for symbol.
2025-01-08 08:10:37.784 | No download requests in the queue to start downloads for.
2025-01-08 08:10:37.918 | DTC Client socket (4) | Socket gracefully closed by remote side.
2025-01-08 08:10:37.918 | DTC Client socket (4) | Closed.
2025-01-08 08:10:38.036 | Socket (7) | Socket gracefully closed by remote side.
2025-01-08 08:10:38.036 | Socket (7) | Closed.
2025-01-08 08:10:38.209 | Opened cached Intraday file: C:\SierraChart - EdgeClear\Data\MESH25_FUT_CME.scid. Thread ID: 25844
2025-01-08 08:10:38.209 | Opened cached Intraday file: C:\SierraChart - EdgeClear\Data\6AH25_FUT_CME.scid. Thread ID: 25844
2025-01-08 08:10:38.209 | Opened cached Intraday file: C:\SierraChart - EdgeClear\Data\ESH25_FUT_CME.scid. Thread ID: 25844
2025-01-08 08:10:53.341 | Opened cached Intraday file: C:\SierraChart - EdgeClear\Data\M6AH25_FUT_CME.scid. Thread ID: 25844
2025-01-08 08:11:07.297 | Teton CME Order Routing | There has been no activity on the network socket for 1m. Will reconnect.
2025-01-08 08:11:07.297 | Connection to the external service has been lost.
2025-01-08 08:11:07.313 | Teton CME Order Routing | Waiting for socket receive thread to end
2025-01-08 08:11:07.313 | DTC Client socket (1) | CloseSocket call.
2025-01-08 08:11:07.313 | DTC Client socket (1) | Max send buffers used during socket life: 5
2025-01-08 08:11:07.313 | DTC Client socket (1) | Max send buffer size during socket life: 511
2025-01-08 08:11:07.313 | Teton CME Order Routing | Disconnected.
2025-01-08 08:11:07.313 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2025-01-08 08:11:07.313 | DTC Client socket (1) | Shutdown started. Waiting for graceful close.
2025-01-08 08:11:09.310 |
2025-01-08 08:11:09.310 | Teton CME Order Routing | Firm: IronBeam
2025-01-08 08:11:09.310 | Teton CME Order Routing | Connecting to the server futurestrading10.sierracharts.com. Port 11085
2025-01-08 08:11:09.310 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2025-01-08 08:11:09.310 | DTC Client socket (4) | New receive buffer size: 0
2025-01-08 08:11:09.310 | DTC Client socket (4) | Connecting to IP: 208.185.224.130.
2025-01-08 08:11:12.716 | Teton CME Order Routing | Network connection to server complete.
2025-01-08 08:11:12.716 | Teton CME Order Routing | Starting socket receive thread.
2025-01-08 08:11:12.716 | Teton CME Order Routing | Sending encoding request to server: Binary VLS. Compression: none
2025-01-08 08:11:16.925 | Teton CME Order Routing | Setting DTC encoding to Binary VLS
2025-01-08 08:11:16.925 | Teton CME Order Routing | Sending logon request message.
2025-01-08 08:11:18.396 | Teton CME Order Routing | Received logon response.
2025-01-08 08:11:18.396 | Teton CME Order Routing | Server Name: SC DTC Server. Build=51528.
2025-01-08 08:11:18.396 | Teton CME Order Routing | Server protocol version: 8. Client protocol version: 8
2025-01-08 08:11:18.396 | Teton CME Order Routing | Successfully connected. Connected to SC DTC Protocol server. Service=cme_ilink3.trading|SymbolSettings=cme_ilink_live.trading.
2025-01-08 08:11:18.396 | Teton CME Order Routing | Trading is supported.
2025-01-08 08:11:18.396 | Teton CME Order Routing | Order cancel and replace is supported.
2025-01-08 08:11:18.396 | Teton CME Order Routing | OCO Orders supported.
2025-01-08 08:11:18.396 | Teton CME Order Routing | Bracket Orders supported.
2025-01-08 08:11:18.396 | Teton CME Order Routing | MarketDepthIsSupported: 1
2025-01-08 08:11:18.396 | Teton CME Order Routing | Connected to server complete.
2025-01-08 08:11:18.396 | No download requests in the queue to start downloads for. | Number times message added: 3
2025-01-08 08:11:18.396 | Updated verified funded futures trading account ending date to: 2025-02-07 13:11:18
2025-01-08 08:11:18.398 | Teton CME Order Routing | Performing query for most recent Order Activity Date-Time.
2025-01-08 08:11:18.400 | Teton CME Order Routing | Requesting historical order activity from server. Start date-time UTC: 2025-01-08 13:00:10.080674
2025-01-08 08:11:18.792 | Updated verified funded futures trading account ending date to: 2025-02-07 13:11:18
2025-01-08 08:11:18.807 | Teton CME Order Routing | Received final trade activity snapshot. Count=1. No data. TradeAccount=40233487
2025-01-08 08:13:26.526 | DTC Client socket (1) | Socket gracefully closed by remote side.
2025-01-08 08:13:26.526 | DTC Client socket (1) | Closed.
2025-01-08 08:25:09.332 | Teton CME Order Routing | There has been no activity on the network socket for 41s. Will reconnect.
2025-01-08 08:25:09.332 | Connection to the external service has been lost.
2025-01-08 08:25:09.347 | Teton CME Order Routing | Waiting for socket receive thread to end
2025-01-08 08:25:09.348 | DTC Client socket (4) | CloseSocket call.
2025-01-08 08:25:09.348 | DTC Client socket (4) | Max send buffers used during socket life: 3
2025-01-08 08:25:09.348 | DTC Client socket (4) | Max send buffer size during socket life: 461
2025-01-08 08:25:09.348 | DTC Client socket (4) | Shutdown started. Waiting for graceful close.
2025-01-08 08:25:09.348 | Teton CME Order Routing | Disconnected.
2025-01-08 08:25:09.348 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2025-01-08 08:25:11.340 |
2025-01-08 08:25:11.340 | Teton CME Order Routing | Firm: IronBeam
2025-01-08 08:25:11.340 | Teton CME Order Routing | Connecting to the server futurestrading10.sierracharts.com. Port 11085
2025-01-08 08:25:11.340 | DTC Client socket (1) | Creating socket. Using TLS 1.2.
2025-01-08 08:25:11.341 | DTC Client socket (1) | New receive buffer size: 0
2025-01-08 08:25:11.341 | DTC Client socket (1) | Connecting to IP: 208.185.224.130.
2025-01-08 08:25:11.731 | Teton CME Order Routing | Network connection to server complete.
2025-01-08 08:25:11.731 | Teton CME Order Routing | Starting socket receive thread.
2025-01-08 08:25:11.731 | Teton CME Order Routing | Sending encoding request to server: Binary VLS. Compression: none
2025-01-08 08:25:12.903 | Teton CME Order Routing | Setting DTC encoding to Binary VLS
2025-01-08 08:25:12.903 | Teton CME Order Routing | Sending logon request message.
2025-01-08 08:25:13.354 | Teton CME Order Routing | Received logon response.
2025-01-08 08:25:13.354 | Teton CME Order Routing | Server Name: SC DTC Server. Build=51528.
2025-01-08 08:25:13.354 | Teton CME Order Routing | Server protocol version: 8. Client protocol version: 8
2025-01-08 08:25:13.354 | Teton CME Order Routing | Successfully connected. Connected to SC DTC Protocol server. Service=cme_ilink3.trading|SymbolSettings=cme_ilink_live.trading.
2025-01-08 08:25:13.354 | Teton CME Order Routing | Trading is supported.
2025-01-08 08:25:13.354 | Teton CME Order Routing | Order cancel and replace is supported.
2025-01-08 08:25:13.354 | Teton CME Order Routing | OCO Orders supported.
2025-01-08 08:25:13.354 | Teton CME Order Routing | Bracket Orders supported.
2025-01-08 08:25:13.354 | Teton CME Order Routing | MarketDepthIsSupported: 1
2025-01-08 08:25:13.354 | Teton CME Order Routing | Connected to server complete.
2025-01-08 08:25:13.354 | No download requests in the queue to start downloads for. | Number times message added: 3
2025-01-08 08:25:13.354 | Updated verified funded futures trading account ending date to: 2025-02-07 13:25:13
2025-01-08 08:25:13.356 | Teton CME Order Routing | Performing query for most recent Order Activity Date-Time.
2025-01-08 08:25:13.358 | Teton CME Order Routing | Requesting historical order activity from server. Start date-time UTC: 2025-01-08 13:23:58.268257
2025-01-08 08:25:14.448 | Updated verified funded futures trading account ending date to: 2025-02-07 13:25:14
2025-01-08 08:25:14.448 | Teton CME Order Routing | Received final trade activity snapshot. Count=2. TradeAccount=40233487
2025-01-08 08:25:19.007 | DTC Client socket (4) | Socket gracefully closed by remote side.
2025-01-08 08:25:19.007 | DTC Client socket (4) | Closed.
2025-01-08 08:31:51.346 | Teton CME Order Routing | There has been no activity on the network socket for 51s. Will reconnect.
2025-01-08 08:31:51.346 | Connection to the external service has been lost.
2025-01-08 08:31:51.361 | Teton CME Order Routing | Waiting for socket receive thread to end
2025-01-08 08:31:51.362 | DTC Client socket (1) | CloseSocket call.
2025-01-08 08:31:51.362 | DTC Client socket (1) | Max send buffers used during socket life: 4
2025-01-08 08:31:51.362 | DTC Client socket (1) | Max send buffer size during socket life: 236
2025-01-08 08:31:51.362 | Teton CME Order Routing | Disconnected.
2025-01-08 08:31:51.362 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2025-01-08 08:31:51.362 | DTC Client socket (1) | Shutdown started. Waiting for graceful close.
2025-01-08 08:31:53.361 |
2025-01-08 08:31:53.361 | Teton CME Order Routing | Firm: IronBeam
2025-01-08 08:31:53.361 | Teton CME Order Routing | Connecting to the server futurestrading10.sierracharts.com. Port 11085
2025-01-08 08:31:53.361 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2025-01-08 08:31:53.361 | DTC Client socket (4) | New receive buffer size: 0
2025-01-08 08:31:53.361 | DTC Client socket (4) | Connecting to IP: 208.185.224.130.
2025-01-08 08:31:56.760 | Teton CME Order Routing | Network connection to server complete.
2025-01-08 08:31:56.760 | Teton CME Order Routing | Starting socket receive thread.
2025-01-08 08:31:56.760 | Teton CME Order Routing | Sending encoding request to server: Binary VLS. Compression: none
2025-01-08 08:31:57.930 | Teton CME Order Routing | Setting DTC encoding to Binary VLS
2025-01-08 08:31:57.930 | Teton CME Order Routing | Sending logon request message.
2025-01-08 08:31:59.293 | Teton CME Order Routing | Received logon response.
2025-01-08 08:31:59.293 | Teton CME Order Routing | Server Name: SC DTC Server. Build=51528.
2025-01-08 08:31:59.293 | Teton CME Order Routing | Server protocol version: 8. Client protocol version: 8
2025-01-08 08:31:59.293 | Teton CME Order Routing | Successfully connected. Connected to SC DTC Protocol server. Service=cme_ilink3.trading|SymbolSettings=cme_ilink_live.trading.
2025-01-08 08:31:59.293 | Teton CME Order Routing | Trading is supported.
2025-01-08 08:31:59.293 | Teton CME Order Routing | Order cancel and replace is supported.
2025-01-08 08:31:59.293 | Teton CME Order Routing | OCO Orders supported.
2025-01-08 08:31:59.293 | Teton CME Order Routing | Bracket Orders supported.
2025-01-08 08:31:59.293 | Teton CME Order Routing | MarketDepthIsSupported: 1
2025-01-08 08:31:59.293 | Teton CME Order Routing | Connected to server complete.
2025-01-08 08:31:59.293 | No download requests in the queue to start downloads for. | Number times message added: 3
2025-01-08 08:31:59.293 | Updated verified funded futures trading account ending date to: 2025-02-07 13:31:59
2025-01-08 08:31:59.295 | Teton CME Order Routing | Performing query for most recent Order Activity Date-Time.
2025-01-08 08:31:59.297 | Teton CME Order Routing | Requesting historical order activity from server. Start date-time UTC: 2025-01-08 13:31:10.188204
2025-01-08 08:32:02.303 | Updated verified funded futures trading account ending date to: 2025-02-07 13:32:02
2025-01-08 08:32:02.303 | Teton CME Order Routing | Received final trade activity snapshot. Count=2. TradeAccount=40233487
2025-01-08 08:33:52.823 | DTC Client socket (1) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine.
2025-01-08 08:33:52.823 | DTC Client socket (1) | Socket gracefully closed by remote side.
2025-01-08 08:33:52.823 | DTC Client socket (1) | Closed.
[2025-01-08 13:40:06]
User753526 - Posts: 57
I just tested it on my Topstep/Rithmic account and it is also lagging up to around 10 seconds before executing.
Below is another message log but for the Topstep/Rithmic account.
2025-01-05 14:31:25.353 | Trade activity files set size: 3012
2025-01-05 14:31:25.358 | Rithmic Direct - DTC | Processed connection points. Count: 347
2025-01-05 14:31:25.376 | Created the DTC Protocol server.
2025-01-05 14:31:25.377 | DTC Protocol Server listening on port 11099.
2025-01-05 14:31:25.377 | Reading Internal Order ID file.
2025-01-05 14:31:25.404 | Reading Trade Orders file.
2025-01-05 14:31:25.404 | Reading Trade Positions file.
2025-01-05 14:31:25.405 | Reading Trade Account Data files.
2025-01-05 14:31:25.407 | NTP | No privilege to adjust system time: Failed to adjust privileges. Windows error code 1300: Not all privileges or groups referenced are assigned to the caller.
2025-01-05 14:31:25.407 | Software version: 2700 64-bit
2025-01-05 14:31:25.407 | Primary Thread ID: 25416
2025-01-05 14:31:25.407 | Usage end date: 2025-01-11
2025-01-05 14:31:25.407 | Enabled for: Advanced Features 2.
2025-01-05 14:31:25.407 | Enabled for: Sierra Chart Historical Data Service.
2025-01-05 14:31:25.407 | Enabled for: Denali Real-Time Exchange Data Feed.
2025-01-05 14:31:25.407 | Enabled for: Delayed Denali Exchange Data Feed.
2025-01-05 14:31:25.407 | Enabled for exchange2: CME
2025-01-05 14:31:25.407 | Enabled for exchange2: COMEX
2025-01-05 14:31:25.407 | Allow Support for Sierra Chart Data Feeds is enabled.
2025-01-05 14:31:25.407 | Current selected Data/Trading service: Rithmic Direct - DTC
2025-01-05 14:31:25.407 | Custom symbol settings values: enabled
2025-01-05 14:31:25.407 | Chart Update Interval: 500
2025-01-05 14:31:25.407 | Intraday Data Storage Time Unit: 0
2025-01-05 14:31:25.407 | Time Zone: -05:00:00 (EST-05EDT+01,M3.2.0/02:00,M11.1.0/02:00)
2025-01-05 14:31:25.407 | 2025-01-05 19:31:25 Local computer time in UTC
2025-01-05 14:31:25.407 | 2025-01-05 14:31:25 Local computer time in SC Time Zone
2025-01-05 14:31:25.407 | 2025-01-05 19:31:23 Server time in UTC
2025-01-05 14:31:25.407 | Local computer UTC time and Server UTC time difference: 1 seconds.
2025-01-05 14:31:25.407 | Program path: C:\SierraChart - TopStep\
2025-01-05 14:31:25.407 | Data Files path: C:\SierraChart - TopStep\Data\
2025-01-05 14:31:25.407 | OS Version Number: 10.0
2025-01-05 14:31:25.407 | Locale Setting: C
2025-01-05 14:31:25.408 | DLLs: ICTMarketOpens_64.dll, UserContributedStudies_64.dll
2025-01-05 14:31:25.408 | Allowed protected custom studies:
2025-01-05 14:31:25.408 | Crash reporter started: true
2025-01-05 14:31:25.417 | Created the DTC Protocol historical data server.
2025-01-05 14:31:25.418 | HD Server Manager | Listening on port 11098.
2025-01-05 14:31:25.418 | Checking for new symbol settings. Requested symbol settings MD5 for service code rithmic_v2.trading. Request ID: 1.
2025-01-05 14:31:25.420 | WSACleanup called.
2025-01-05 14:31:25.426 | Chat: Chat Window created. Connecting to server.
2025-01-05 14:31:25.427 | WSACleanup called.
2025-01-05 14:31:25.427 | Chat | Connecting to the server chat2.sierracharts.com. Port 10065
2025-01-05 14:31:25.460 | HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Shutdown started. Waiting for graceful close.
2025-01-05 14:31:25.707 | HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Socket gracefully closed by remote side.
2025-01-05 14:31:25.707 | HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Closed.
2025-01-05 14:31:25.851 | HTTPS connection ID:1 to downloads.rithmic.com:443 for request ID:1 (4) | Creating socket. Using TLS 1.2.
2025-01-05 14:31:25.851 | HTTPS connection ID:1 to downloads.rithmic.com:443 for request ID:1 (4) | New receive buffer size: 0
2025-01-05 14:31:25.851 | HTTPS connection ID:1 to downloads.rithmic.com:443 for request ID:1 (4) | Connecting to IP: 216.66.0.130.
2025-01-05 14:31:25.998 | DTC Client socket (6) | Creating socket. Using TLS 1.2.
2025-01-05 14:31:25.998 | DTC Client socket (6) | New receive buffer size: 0
2025-01-05 14:31:25.998 | DTC Client socket (6) | Connecting to IP: 64.152.155.20.
2025-01-05 14:31:26.200 | Received 5 login tokens.
2025-01-05 14:31:26.247 | Chat | Network connection to server complete.
2025-01-05 14:31:26.247 | Chat | Starting socket receive thread.
2025-01-05 14:31:26.247 | Chat | Sending encoding request to server: Binary VLS. Compression: none
2025-01-05 14:31:26.994 | Chat | Setting DTC encoding to Binary VLS
2025-01-05 14:31:26.994 | Chat | Sending logon request message.
2025-01-05 14:31:27.146 | Symbol settings MD5 received. Request ID: 1.
2025-01-05 14:31:27.146 | Symbol settings are up-to-date for rithmic_v2.trading.
2025-01-05 14:31:27.265 | Rithmic Direct - DTC | Wrote file: C:\SierraChart - TopStep\RithmicConnections.json. Size: 81131
2025-01-05 14:31:27.266 | Rithmic Direct - DTC | Processed connection points. Count: 347
2025-01-05 14:31:27.267 | Chat | Received logon response.
2025-01-05 14:31:27.267 | Chat | Server Name: SC DTC Server. Build=52080.
2025-01-05 14:31:27.267 | Chat | Server protocol version: 8. Client protocol version: 8
2025-01-05 14:31:27.267 | Chat | Successfully connected. Connected to SC DTC Protocol server. Service=chat_server.data|SymbolSettings=chat_server.data.
2025-01-05 14:31:27.267 | Chat | Trading is not supported.
2025-01-05 14:31:27.267 | Chat | MarketDepthIsSupported: 1
2025-01-05 14:31:27.509 | HTTPS connection ID:1 to downloads.rithmic.com:443 for request ID:1 (4) | CloseSocket call.
2025-01-05 14:31:27.509 | HTTPS connection ID:1 to downloads.rithmic.com:443 for request ID:1 (4) | Shutdown started. Waiting for graceful close.
2025-01-05 14:31:27.745 | HTTPS connection ID:1 to downloads.rithmic.com:443 for request ID:1 (4) | Socket gracefully closed by remote side.
2025-01-05 14:31:27.745 | HTTPS connection ID:1 to downloads.rithmic.com:443 for request ID:1 (4) | Closed.
2025-01-05 14:31:27.925 | Requested user files to download.
2025-01-05 14:31:29.926 |
2025-01-05 14:31:29.926 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated
2025-01-05 14:31:29.926 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50508
2025-01-05 14:31:29.927 | Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50508
2025-01-05 14:31:30.330 | DTC Client socket (1) | Creating socket. Using TLS 1.2.
2025-01-05 14:31:30.331 | DTC Client socket (1) | New receive buffer size: 0
2025-01-05 14:31:30.331 | DTC Client socket (1) | Connecting to IP: 216.57.156.163.
2025-01-05 14:31:30.572 | Rithmic Direct - DTC | Network connection to server complete.
2025-01-05 14:31:30.572 | Rithmic Direct - DTC | Starting socket receive thread.
2025-01-05 14:31:30.572 | Rithmic Direct - DTC | Setting DTC encoding to Binary
2025-01-05 14:31:30.572 | Rithmic Direct - DTC | Sending logon request message.
2025-01-05 14:31:31.300 | Rithmic Direct - DTC | Received logon response.
2025-01-05 14:31:31.300 | Rithmic Direct - DTC | Server Name: .
2025-01-05 14:31:31.300 | Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8
2025-01-05 14:31:31.300 | Rithmic Direct - DTC | Successfully connected.
2025-01-05 14:31:31.300 | Rithmic Direct - DTC | Trading is supported.
2025-01-05 14:31:31.300 | Rithmic Direct - DTC | Order cancel and replace is supported.
2025-01-05 14:31:31.300 | Rithmic Direct - DTC | OCO Orders supported.
2025-01-05 14:31:31.300 | Rithmic Direct - DTC | Symbol and Exchange Delimiter: .
2025-01-05 14:31:31.300 | Rithmic Direct - DTC | MarketDepthIsSupported: 0
2025-01-05 14:31:31.300 | Rithmic Direct - DTC | Connected to server complete.
2025-01-05 14:31:31.301 | No download requests in the queue to start downloads for. | Number times message added: 3
2025-01-05 14:31:31.301 | Subscribing to symbol for symbol alert. NQZ4.CME
2025-01-05 14:31:31.301 | Mapping NQZ4.CME to NQZ24. Service code: cme
2025-01-05 14:31:31.301 | Using symbol data fast lookup vector
2025-01-05 14:31:31.301 | Denali Data Feed | Starting real-time market data updates for: NQZ4.CME (NQZ24). ID: 1 Service code: cme
2025-01-05 14:31:31.302 | Denali Data Feed | Connecting to the server ds32-2.sierracharts.com. Port 443
2025-01-05 14:31:31.303 | Denali Data Feed | Requesting security definition data for: NQZ4.CME (NQZ24). ID: 1
2025-01-05 14:31:31.303 | Subscribing to symbol for symbol alert. GCZ4.COMEX
2025-01-05 14:31:31.303 | Mapping GCZ4.COMEX to GCZ24. Service code: comex
2025-01-05 14:31:31.303 | Denali Data Feed | Starting real-time market data updates for: GCZ4.COMEX (GCZ24). ID: 2 Service code: comex
2025-01-05 14:31:31.303 | Denali Data Feed | Requesting security definition data for: GCZ4.COMEX (GCZ24). ID: 2
2025-01-05 14:31:31.425 | DTC Client socket (2) | Creating socket.
2025-01-05 14:31:31.425 | DTC Client socket (2) | New receive buffer size: 0
2025-01-05 14:31:31.425 | DTC Client socket (2) | Connecting to IP: 67.214.125.4.
2025-01-05 14:31:31.662 | Denali Data Feed | Network connection to server complete.
2025-01-05 14:31:31.662 | Denali Data Feed | Starting socket receive thread.
2025-01-05 14:31:31.662 | Denali Data Feed | Sending encoding request to server: Binary VLS. Compression: high
2025-01-05 14:31:31.925 | Denali Data Feed | Setting DTC encoding to Binary VLS
2025-01-05 14:31:31.925 | Denali Data Feed | Sending logon request message.
2025-01-05 14:31:32.677 | Denali Data Feed | Received logon response.
2025-01-05 14:31:32.677 | Denali Data Feed | Server Name: SC Realtime Server.
2025-01-05 14:31:32.677 | Denali Data Feed | Server protocol version: 8. Client protocol version: 8
2025-01-05 14:31:32.677 | Denali Data Feed | Successfully connected.
2025-01-05 14:31:32.677 | Denali Data Feed | Trading is not supported.
2025-01-05 14:31:32.677 | Denali Data Feed | MarketDepthIsSupported: 1
2025-01-05 14:31:32.677 | Denali Data Feed | Restarting real-time data updates for symbol: GCZ4.COMEX -> GCZ24
2025-01-05 14:31:32.677 | Denali Data Feed | Restarting real-time data updates for symbol: NQZ4.CME -> NQZ24
2025-01-05 14:31:33.427 | Denali Data Feed | Real-time data for symbol GCZ4.COMEX is currently unavailable.
2025-01-05 14:31:33.427 | Denali Data Feed | Received security definition for symbol GCZ4.COMEX
2025-01-05 14:31:33.427 | Denali Data Feed | Real-time data for symbol NQZ4.CME is currently unavailable.
2025-01-05 14:31:33.427 | Denali Data Feed | Received security definition for symbol NQZ4.CME
2025-01-05 14:31:47.636 | ESH5.CME [CBV] #14 | Reloading chart.
2025-01-05 14:31:47.648 | Starting DelayedDownloadMonitoringTimer
2025-01-05 14:31:47.648 | Starting HDTimeoutTimer
2025-01-05 14:31:47.648 | Added historical Intraday data request for ESH5.CME to the queue.
2025-01-05 14:31:47.649 | Triggering next historical data download in queue.
2025-01-05 14:31:47.649 | ESH5.CME [CBV] #14 | Performing continuous chart historical Daily data download for symbol ESH5.CME starting at last date in file.
2025-01-05 14:31:47.649 | Starting DelayedDownloadMonitoringTimer
2025-01-05 14:31:47.649 | Starting HDTimeoutTimer
2025-01-05 14:31:47.649 | Added historical Daily data request for ESH5.CME to the queue.
2025-01-05 14:31:47.650 | Triggering next historical data download in queue.
2025-01-05 14:31:47.727 | ESH5.CME [CBV] #14 | Waiting for historical downloads to complete with the IDs: 1, 2,
2025-01-05 14:31:47.754 | ESH5.CME [CBV] #3 | Reloading chart.
2025-01-05 14:31:47.840 | ESH5.CME [CBV] #3 | Waiting for historical downloads to complete with the IDs: 1, 2,
2025-01-05 14:31:47.847 | ESH5.CME [CBV] 240 Min #15 | Reloading chart.
2025-01-05 14:31:47.931 | ESH5.CME [CBV] 240 Min #15 | Waiting for historical downloads to complete with the IDs: 1, 2,
2025-01-05 14:31:47.938 | ESH5.CME [CBV] Monthly #4 | Reloading chart.
2025-01-05 14:31:47.938 | ESH5.CME [CBV] Monthly #4 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2025-01-05 14:31:47.938 | ESH5.CME [CBV] Monthly #4 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2025-01-05 14:31:48.119 | ESH5.CME [CBV] Monthly #4 | Waiting for historical downloads to complete with the IDs: 2,
2025-01-05 14:31:48.125 | ESH5.CME [CBV] Weekly #5 | Reloading chart.
2025-01-05 14:31:48.125 | ESH5.CME [CBV] Weekly #5 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2025-01-05 14:31:48.125 | ESH5.CME [CBV] Weekly #5 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2025-01-05 14:31:48.305 | ESH5.CME [CBV] Weekly #5 | Waiting for historical downloads to complete with the IDs: 2,
2025-01-05 14:31:48.332 | ESH5.CME [CBV] Daily #6 | Reloading chart.
2025-01-05 14:31:48.332 | ESH5.CME [CBV] Daily #6 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2025-01-05 14:31:48.332 | ESH5.CME [CBV] Daily #6 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2025-01-05 14:31:48.505 | ESH5.CME [CBV] Daily #6 | Waiting for historical downloads to complete with the IDs: 2,
2025-01-05 14:31:48.513 | ESH5.CME [CBV] 240 Min #7 | Reloading chart.
2025-01-05 14:31:48.593 | ESH5.CME [CBV] 240 Min #7 | Waiting for historical downloads to complete with the IDs: 1, 2,
2025-01-05 14:31:48.601 | ESH5.CME [CBV] 30 Min #17 | Reloading chart.
2025-01-05 14:31:48.612 | ESH5.CME [CBV] 30 Min #17 | Waiting for historical downloads to complete with the IDs: 1, 2,
2025-01-05 14:31:48.619 | ESH5.CME [CBV] 15 Min #10 | Reloading chart.
2025-01-05 14:31:48.698 | ESH5.CME [CBV] 15 Min #10 | Waiting for historical downloads to complete with the IDs: 1, 2,
2025-01-05 14:31:48.705 | ESH5.CME [CBV] 10 Min #2 | Reloading chart.
2025-01-05 14:31:48.784 | ESH5.CME [CBV] 10 Min #2 | Waiting for historical downloads to complete with the IDs: 1, 2,
2025-01-05 14:31:48.791 | ESH5.CME 5 Min #12 | Reloading chart.
2025-01-05 14:31:48.797 | MESH5.CME 1 Min #1 | Reloading chart.
2025-01-05 14:31:48.830 | ESH5.CME [CBV] 60 Min #8 | Reloading chart.
2025-01-05 14:31:48.874 | ESH5.CME [CBV] 60 Min #8 | Waiting for historical downloads to complete with the IDs: 1, 2,
2025-01-05 14:31:48.905 | ESH5.CME 5 Min #11 | Reloading chart.
2025-01-05 14:31:48.937 | ESH5.CME Rev. 16t-20 #13 | Reloading chart.
2025-01-05 14:31:49.060 | ESH5.CME #9 | Reloading chart.
2025-01-05 14:31:49.061 | ESH5.CME #9 | StartDateTimeForLoadingOrderFills: 2023-12-30 00:00:00
2025-01-05 14:31:49.068 | ESH5.CME #9 | Chart data loading complete.
2025-01-05 14:31:49.185 | MESH5.CME #18 | Reloading chart.
2025-01-05 14:31:49.185 | MESH5.CME #18 | StartDateTimeForLoadingOrderFills: 2023-12-30 00:00:00
2025-01-05 14:31:49.185 | MESH5.CME #18 | Chart data loading complete.
2025-01-05 14:31:49.191 | SPX500 60 Min #16 | Reloading chart.
2025-01-05 14:31:49.198 | Mapping ESH5.CME to ESH25. Service code: cme
2025-01-05 14:31:49.198 | HD Request # 1 | Downloading Intraday chart data for ESH5.CME to the file ESH5.CME.scid. Service: cme
2025-01-05 14:31:49.199 | HD Request # 1 | Download start date-time: 2025-01-03 16:08:18.000000. File last date-time: 2025-01-03 16:08:18.018000
2025-01-05 14:31:49.199 | HD Request # 1 | Using server: ds32.sierracharts.com port 10150
2025-01-05 14:31:49.199 | HD Request # 2 | Downloading Historical Daily chart data for ESH5.CME. Starting date: 2024-12-30. Service: rithmic.trading
2025-01-05 14:31:49.308 | Socket (3) | Creating socket.
2025-01-05 14:31:49.308 | Socket (3) | New receive buffer size: 0
2025-01-05 14:31:49.308 | Socket (3) | Connecting to IP: 67.214.125.3.
2025-01-05 14:31:49.312 | Denali Data Feed | Starting real-time market data updates for: ESH5.CME (ESH25). ID: 3 Service code: cme
2025-01-05 14:31:49.312 | Denali Data Feed | Requesting security definition data for: ESH5.CME (ESH25). ID: 3
2025-01-05 14:31:49.312 | Mapping MESH5.CME to MESH25. Service code: cme
2025-01-05 14:31:49.312 | Denali Data Feed | Starting real-time market data updates for: MESH5.CME (MESH25). ID: 4 Service code: cme
2025-01-05 14:31:49.312 | Denali Data Feed | Requesting security definition data for: MESH5.CME (MESH25). ID: 4
2025-01-05 14:31:49.313 | Added historical Intraday data request for MESH5.CME to the queue.
2025-01-05 14:31:49.313 | Intraday data recording state for symbol MESH5.CME is set to download 'Pending'.
2025-01-05 14:31:49.313 | Triggering next historical data download in queue.
2025-01-05 14:31:49.411 | ESH5.CME[M] 5 Min #11 | StartDateTimeForLoadingOrderFills: 2023-12-28 00:00:00
2025-01-05 14:31:49.427 | ESH5.CME[M] 5 Min #11 | Chart data loading complete.
2025-01-05 14:31:49.649 | SPX500 60 Min #16 | StartDateTimeForLoadingOrderFills: 2023-12-28 00:00:00
2025-01-05 14:31:49.652 | SPX500 60 Min #16 | Chart data loading complete.
2025-01-05 14:31:49.684 | Using Bid/Ask average for last trade price for SPX500
2025-01-05 14:31:49.684 | SC Data with Depth | Starting real-time market data updates for: SPX500. ID: 5 Service code: fxcm
2025-01-05 14:31:49.686 | SC Data with Depth | Connecting to the server ds12.sierracharts.com. Port 443
2025-01-05 14:31:49.687 | SC Data with Depth | Requesting security definition data for: SPX500. ID: 5
2025-01-05 14:31:49.687 | Added historical Intraday data request for SPX500 to the queue.
2025-01-05 14:31:49.687 | Intraday data recording state for symbol SPX500 is set to download 'Pending'.
2025-01-05 14:31:49.687 | Triggering next historical data download in queue.
2025-01-05 14:31:49.734 | MESH5.CME[M] 1 Min #1 | StartDateTimeForLoadingOrderFills: 2023-12-28 00:00:00
2025-01-05 14:31:49.742 | MESH5.CME[M] 1 Min #1 | Chart data loading complete.
2025-01-05 14:31:49.809 | DTC Client socket (5) | Creating socket.
2025-01-05 14:31:49.809 | DTC Client socket (5) | New receive buffer size: 0
2025-01-05 14:31:49.809 | DTC Client socket (5) | Connecting to IP: 69.39.70.241.
2025-01-05 14:31:49.820 | HD Request # 1 | Setting DTC encoding to Binary VLS
2025-01-05 14:31:49.820 | HD Request # 1 | Sending historical data logon request message.
2025-01-05 14:31:49.917 | HTTPS connection ID:2 to downloads.rithmic.com:443 for request ID:2 (7) | Creating socket. Using TLS 1.2.
2025-01-05 14:31:49.917 | HTTPS connection ID:2 to downloads.rithmic.com:443 for request ID:2 (7) | New receive buffer size: 0
2025-01-05 14:31:49.917 | HTTPS connection ID:2 to downloads.rithmic.com:443 for request ID:2 (7) | Connecting to IP: 216.66.0.130.
2025-01-05 14:31:49.976 | ESH5.CME 5 Min #12 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2024-12-26 09:40:00. Next Bar Date Time: 2024-12-26 09:35:00. Filename: ESH5.CME.scid
2025-01-05 14:31:50.033 | Denali Data Feed | Setting external service identifier for symbol ESH5.CME to 5002
2025-01-05 14:31:50.033 | Denali Data Feed | Received security definition for symbol ESH5.CME
2025-01-05 14:31:50.033 | Denali Data Feed | Setting external service identifier for symbol MESH5.CME to 42005347
2025-01-05 14:31:50.033 | Denali Data Feed | Received security definition for symbol MESH5.CME
2025-01-05 14:31:50.042 | SC Data with Depth | Network connection to server complete.
2025-01-05 14:31:50.042 | SC Data with Depth | Starting socket receive thread.
2025-01-05 14:31:50.042 | SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: high
2025-01-05 14:31:50.115 | HD Request # 1 | Requesting Intraday data. Start date-time: 2025-01-03 16:08:18. Record interval: 0. Symbol: ESH25
2025-01-05 14:31:50.300 | SC Data with Depth | Setting DTC encoding to Binary VLS
2025-01-05 14:31:50.300 | SC Data with Depth | Sending logon request message.
2025-01-05 14:31:50.368 | HD Request # 1 | Decompressing data.
2025-01-05 14:31:50.380 | HD Request # 2 | Requesting historical Daily data for ESH25 starting at 2024-12-29. SC External HD service.
2025-01-05 14:31:50.635 | HD Request # 1 | Receiving Intraday data for ESH5.CME starting at 2025-01-03 16:08:18.018000
2025-01-05 14:31:50.831 | ESH5.CME[M] 5 Min #12 | StartDateTimeForLoadingOrderFills: 2023-12-28 00:00:00
2025-01-05 14:31:50.838 | ESH5.CME[M] 5 Min #12 | Chart data loading complete.
2025-01-05 14:31:50.912 | NQH5.CME [CBV] #16 | Reloading chart.
2025-01-05 14:31:50.918 | Added historical Intraday data request for NQH5.CME to the queue.
2025-01-05 14:31:50.918 | Triggering next historical data download in queue.
2025-01-05 14:31:50.918 | NQH5.CME [CBV] #16 | Performing continuous chart historical Daily data download for symbol NQH5.CME starting at last date in file.
2025-01-05 14:31:50.918 | Added historical Daily data request for NQH5.CME to the queue.
2025-01-05 14:31:50.945 | NQH5.CME [CBV] #16 | Waiting for historical downloads to complete with the IDs: 5, 6,
2025-01-05 14:31:50.952 | Socket (3) | CloseSocket call.
2025-01-05 14:31:50.952 | Socket (3) | Shutdown started. Waiting for graceful close.
2025-01-05 14:31:50.971 | NQH5.CME [CBV] #3 | Reloading chart.
2025-01-05 14:31:51.057 | NQH5.CME [CBV] #3 | Waiting for historical downloads to complete with the IDs: 5, 6,
2025-01-05 14:31:51.063 | NQH5.CME [CBV] 60 Min #14 | Reloading chart.
2025-01-05 14:31:51.144 | NQH5.CME [CBV] 60 Min #14 | Waiting for historical downloads to complete with the IDs: 5, 6,
2025-01-05 14:31:51.151 | NQH5.CME [CBV] Monthly #4 | Reloading chart.
2025-01-05 14:31:51.151 | NQH5.CME [CBV] Monthly #4 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2025-01-05 14:31:51.151 | NQH5.CME [CBV] Monthly #4 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2025-01-05 14:31:51.207 | Socket (3) | Socket gracefully closed by remote side.
2025-01-05 14:31:51.207 | Socket (3) | Closed.
2025-01-05 14:31:51.329 | NQH5.CME [CBV] Monthly #4 | Waiting for historical downloads to complete with the IDs: 6,
2025-01-05 14:31:51.337 | NQH5.CME [CBV] Weekly #5 | Reloading chart.
2025-01-05 14:31:51.337 | NQH5.CME [CBV] Weekly #5 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2025-01-05 14:31:51.337 | NQH5.CME [CBV] Weekly #5 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2025-01-05 14:31:51.513 | NQH5.CME [CBV] Weekly #5 | Waiting for historical downloads to complete with the IDs: 6,
2025-01-05 14:31:51.551 | NQH5.CME [CBV] Daily #6 | Reloading chart.
2025-01-05 14:31:51.551 | NQH5.CME [CBV] Daily #6 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2025-01-05 14:31:51.551 | NQH5.CME [CBV] Daily #6 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2025-01-05 14:31:51.722 | NQH5.CME [CBV] Daily #6 | Waiting for historical downloads to complete with the IDs: 6,
2025-01-05 14:31:51.755 | NQH5.CME [CBV] 60 Min #11 | Reloading chart.
2025-01-05 14:31:51.793 | NQH5.CME [CBV] 60 Min #11 | Waiting for historical downloads to complete with the IDs: 5, 6,
2025-01-05 14:31:51.820 | NQH5.CME [CBV] 15 Min #1 | Reloading chart.
2025-01-05 14:31:51.900 | NQH5.CME [CBV] 15 Min #1 | Waiting for historical downloads to complete with the IDs: 5, 6,
2025-01-05 14:31:51.932 | NQH5.CME [CBV] 5 Min #15 | Reloading chart.
2025-01-05 14:31:51.944 | NQH5.CME [CBV] 5 Min #15 | Waiting for historical downloads to complete with the IDs: 5, 6,
2025-01-05 14:31:51.965 | MNQH5.CME Rev. 16t-20 #13 | Reloading chart.
2025-01-05 14:31:51.974 | NQH5.CME [CBV] 240 Min #7 | Reloading chart.
2025-01-05 14:31:52.056 | NQH5.CME [CBV] 240 Min #7 | Waiting for historical downloads to complete with the IDs: 5, 6,
2025-01-05 14:31:52.064 | NQH5.CME [CBV] 30 Min #8 | Reloading chart.
2025-01-05 14:31:52.075 | NQH5.CME [CBV] 30 Min #8 | Waiting for historical downloads to complete with the IDs: 5, 6,
2025-01-05 14:31:52.082 | MNQH5.CME [CBV] 1 Min #10 | Reloading chart.
2025-01-05 14:31:52.083 | Added historical Intraday data request for MNQH5.CME to the queue.
2025-01-05 14:31:52.084 | MNQH5.CME [CBV] 1 Min #10 | Performing continuous chart historical Daily data download for symbol MNQH5.CME starting at last date in file.
2025-01-05 14:31:52.084 | Added historical Daily data request for MNQH5.CME to the queue.
2025-01-05 14:31:52.094 | MNQH5.CME [CBV] 1 Min #10 | Waiting for historical downloads to complete with the IDs: 7, 8,
2025-01-05 14:31:52.101 | MNQH5.CME 15 Min #12 | Reloading chart.
2025-01-05 14:31:52.237 | NQH5.CME #17 | Reloading chart.
2025-01-05 14:31:52.237 | NQH5.CME #17 | StartDateTimeForLoadingOrderFills: 2023-12-30 00:00:00
2025-01-05 14:31:52.245 | NQH5.CME #17 | Chart data loading complete.
2025-01-05 14:31:52.380 | MNQH5.CME #19 | Reloading chart.
2025-01-05 14:31:52.381 | MNQH5.CME #19 | StartDateTimeForLoadingOrderFills: 2023-12-30 00:00:00
2025-01-05 14:31:52.381 | MNQH5.CME #19 | Chart data loading complete.
2025-01-05 14:31:52.385 | Historical data download thread signaled to stop.
2025-01-05 14:31:52.385 | HD Request # 1 | Timestamp of first Intraday data file record written: 2025-01-03 16:08:19.614000.
2025-01-05 14:31:52.385 | HD Request # 1 | Received 8757 Intraday data records from 2025-01-03 16:08:18.018000 to 2025-01-03 16:59:59.585005 (51.7 minutes. Delay: 45.5 hours) and wrote 8756 records for ESH5.CME
2025-01-05 14:31:52.386 | HD Request # 1 | Add time&sales data | Remembered last file record date-time: 2025-01-03 21:59:59.585005
2025-01-05 14:31:52.386 | HD Request # 1 | Completion time: 3s.
2025-01-05 14:31:52.386 | HD Request # 1 | Intraday data download complete for ESH5.CME. Unique request ID: 1
2025-01-05 14:31:52.386 | Removing historical data download ID 1.
2025-01-05 14:31:52.386 | Real-time Intraday chart data file updates started for ESH5.CME
2025-01-05 14:31:52.386 | Intraday chart data file opened for ESH5.CME
2025-01-05 14:31:52.386 | HD Request # 1 | Enabling Intraday chart updating for symbol.
2025-01-05 14:31:52.386 | Triggering next historical data download in queue.
2025-01-05 14:31:52.404 | ESH5.CME[M] Rev. 16t-20 #13 | Chart data loading complete.
2025-01-05 14:31:52.405 | Rithmic Direct - DTC | Wrote file: C:\SierraChart - TopStep\RithmicConnections.json. Size: 81131
2025-01-05 14:31:52.405 | Rithmic Direct - DTC | Processed connection points. Count: 347
2025-01-05 14:31:52.406 | SC Data with Depth | Received logon response.
2025-01-05 14:31:52.406 | SC Data with Depth | Server Name: SC Realtime Server.
2025-01-05 14:31:52.406 | SC Data with Depth | Server protocol version: 8. Client protocol version: 8
2025-01-05 14:31:52.406 | SC Data with Depth | Successfully connected.
2025-01-05 14:31:52.406 | SC Data with Depth | Trading is not supported.
2025-01-05 14:31:52.406 | SC Data with Depth | MarketDepthIsSupported: 1
2025-01-05 14:31:52.406 | SC Data with Depth | Restarting real-time data updates for symbol: SPX500
2025-01-05 14:31:52.406 | HD Request # 2 | Receiving historical Daily data for ESH5.CME starting at 2024-12-30.
2025-01-05 14:31:52.406 | HD Request # 2 | Writing historical Daily data to the file ESH5.CME.dly.
2025-01-05 14:31:52.408 | HD Request # 2 | Bytes received: 246
2025-01-05 14:31:52.408 | HD Request # 2 | Received 4 Daily data records from 2024-12-30 00:00:00 to 2025-01-03 00:00:00 (5.0 days) and wrote 4 records for ESH5.CME
2025-01-05 14:31:52.408 | HD Request # 2 | Completion time: 3s.
2025-01-05 14:31:52.408 | HD Request # 2 | Daily data download complete for ESH5.CME. Unique request ID: 2
2025-01-05 14:31:52.408 | Removing historical data download ID 2.
2025-01-05 14:31:52.408 | Triggering next historical data download in queue.
2025-01-05 14:31:52.418 | Delaying start of download for MESH5.CME.
2025-01-05 14:31:52.418 | Mapping NQH5.CME to NQH25. Service code: cme
2025-01-05 14:31:52.419 | HD Request # 3 | Downloading Historical Daily chart data for NQH5.CME. Starting date: 2024-12-30. Service: rithmic.trading
2025-01-05 14:31:52.462 | ESH5.CME [CBV] Monthly #4 | Download is complete for all contract months in chart. Proceeding with data load.
2025-01-05 14:31:52.463 | ESH5.CME [CBV] Monthly #4 | Reloading chart.
2025-01-05 14:31:52.621 | ESH5.CME [CBV] 240 Min #7 | Download is complete for all contract months in chart. Proceeding with data load.
2025-01-05 14:31:52.621 | ESH5.CME [CBV] 240 Min #7 | Reloading chart.
2025-01-05 14:31:52.708 | ESH5.CME [CBV] Monthly #4 | Chart data loading complete.
2025-01-05 14:31:52.710 | ESH5.CME [CBV] 15 Min #10 | Download is complete for all contract months in chart. Proceeding with data load.
2025-01-05 14:31:52.711 | ESH5.CME [CBV] 15 Min #10 | Reloading chart.
2025-01-05 14:31:52.808 | ESH5.CME [CBV] 30 Min #17 | Download is complete for all contract months in chart. Proceeding with data load.
2025-01-05 14:31:52.808 | ESH5.CME [CBV] 30 Min #17 | Reloading chart.
2025-01-05 14:31:52.823 | ESH5.CME [CBV] Weekly #5 | Download is complete for all contract months in chart. Proceeding with data load.
2025-01-05 14:31:52.823 | ESH5.CME [CBV] Weekly #5 | Reloading chart.
2025-01-05 14:31:53.002 | ESH5.CME [CBV] #14 | Download is complete for all contract months in chart. Proceeding with data load.
2025-01-05 14:31:53.002 | ESH5.CME [CBV] #14 | Reloading chart.
2025-01-05 14:31:53.103 | ESH5.CME [CBV] Weekly #5 | Chart data loading complete.
2025-01-05 14:31:53.104 | ESH5.CME [CBV] 10 Min #2 | Download is complete for all contract months in chart. Proceeding with data load.
2025-01-05 14:31:53.104 | ESH5.CME [CBV] 10 Min #2 | Reloading chart.
2025-01-05 14:31:53.206 | SC Data with Depth | Setting external service identifier for symbol SPX500 to 55
2025-01-05 14:31:53.206 | SC Data with Depth | Received security definition for symbol SPX500
2025-01-05 14:31:53.206 | ESH5.CME [CBV] #3 | Download is complete for all contract months in chart. Proceeding with data load.
2025-01-05 14:31:53.207 | ESH5.CME [CBV] #3 | Reloading chart.
2025-01-05 14:31:53.336 | Requesting market depth updates for: ESH5.CME if supported. NumLevels=50
2025-01-05 14:31:53.336 | Requesting market depth updates for: MESH5.CME if supported. NumLevels=50
2025-01-05 14:31:53.336 | Mapping MNQH5.CME to MNQH25. Service code: cme
2025-01-05 14:31:53.336 | Denali Data Feed | Starting real-time market data updates for: MNQH5.CME (MNQH25). ID: 7 Service code: cme
2025-01-05 14:31:53.336 | Denali Data Feed | Requesting security definition data for: MNQH5.CME (MNQH25). ID: 7
2025-01-05 14:31:53.336 | Requesting market depth updates for: MNQH5.CME if supported. NumLevels=50
2025-01-05 14:31:53.336 | Denali Data Feed | Starting real-time market data updates for: NQH5.CME (NQH25). ID: 6 Service code: cme
2025-01-05 14:31:53.336 | Denali Data Feed | Requesting security definition data for: NQH5.CME (NQH25). ID: 6
2025-01-05 14:31:53.336 | Requesting market depth updates for: NQH5.CME if supported. NumLevels=50
2025-01-05 14:31:53.337 | ESH5.CME [CBV] 60 Min #8 | Download is complete for all contract months in chart. Proceeding with data load.
2025-01-05 14:31:53.337 | ESH5.CME [CBV] 60 Min #8 | Reloading chart.
2025-01-05 14:31:53.415 | ESH5.CME [CBV] Daily #6 | Download is complete for all contract months in chart. Proceeding with data load.
2025-01-05 14:31:53.416 | ESH5.CME [CBV] Daily #6 | Reloading chart.
2025-01-05 14:31:53.621 | HD Request # 3 | Requesting historical Daily data for NQH25 starting at 2024-12-29. SC External HD service.
2025-01-05 14:31:53.667 | ESH5.CME [CBV] 240 Min #15 | Download is complete for all contract months in chart. Proceeding with data load.
2025-01-05 14:31:53.667 | ESH5.CME [CBV] 240 Min #15 | Reloading chart.
2025-01-05 14:31:53.778 | ESH5.CME [CBV] Daily #6 | Chart data loading complete.
2025-01-05 14:31:53.781 | HTTPS connection ID:2 to downloads.rithmic.com:443 for request ID:2 (7) | CloseSocket call.
2025-01-05 14:31:53.782 | HTTPS connection ID:2 to downloads.rithmic.com:443 for request ID:2 (7) | Shutdown started. Waiting for graceful close.
2025-01-05 14:31:53.821 | ESH5.CME [CBV] Monthly #4 | Reloading chart.
2025-01-05 14:31:53.821 | ESH5.CME [CBV] Monthly #4 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2025-01-05 14:31:53.821 | ESH5.CME [CBV] Monthly #4 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2025-01-05 14:31:53.883 | MNQH5.CME Rev. 16t-20 #13 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2024-12-26 09:40:21. Next Bar Date Time: 2024-12-26 09:38:35. Filename: MNQH5.CME.scid
2025-01-05 14:31:54.018 | HTTPS connection ID:2 to downloads.rithmic.com:443 for request ID:2 (7) | Socket gracefully closed by remote side.
2025-01-05 14:31:54.018 | HTTPS connection ID:2 to downloads.rithmic.com:443 for request ID:2 (7) | Closed.
2025-01-05 14:31:54.264 | Denali Data Feed | Clearing market depth for ESH5.CME
2025-01-05 14:31:54.264 | Denali Data Feed | Clearing market depth for MESH5.CME
2025-01-05 14:31:54.264 | Denali Data Feed | Clearing market depth for MNQH5.CME
2025-01-05 14:31:54.264 | Denali Data Feed | Clearing market depth for NQH5.CME
2025-01-05 14:31:54.267 | Denali Data Feed | Setting external service identifier for symbol MNQH5.CME to 42003617
2025-01-05 14:31:54.267 | Denali Data Feed | Received security definition for symbol MNQH5.CME
2025-01-05 14:31:54.267 | Denali Data Feed | Setting external service identifier for symbol NQH5.CME to 42288528
2025-01-05 14:31:54.267 | Denali Data Feed | Received security definition for symbol NQH5.CME
2025-01-05 14:31:54.268 | ESH5.CME [CBV] 240 Min #7 | Reloading chart.
2025-01-05 14:31:54.484 | ESH5.CME [CBV] Monthly #4 | Chart data loading complete.
2025-01-05 14:31:54.486 | ESH5.CME [CBV] 15 Min #10 | Reloading chart.
2025-01-05 14:31:54.719 | ESH5.CME [CBV] 30 Min #17 | Reloading chart.
2025-01-05 14:31:54.752 | ESH5.CME [CBV] Weekly #5 | Reloading chart.
2025-01-05 14:31:54.752 | ESH5.CME [CBV] Weekly #5 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2025-01-05 14:31:54.752 | ESH5.CME [CBV] Weekly #5 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2025-01-05 14:31:55.190 | HD Request # 3 | Receiving historical Daily data for NQH5.CME starting at 2024-12-30.
2025-01-05 14:31:55.190 | HD Request # 3 | Writing historical Daily data to the file NQH5.CME.dly.
2025-01-05 14:31:55.191 | HD Request # 3 | Bytes received: 244
2025-01-05 14:31:55.191 | HD Request # 3 | Received 4 Daily data records from 2024-12-30 00:00:00 to 2025-01-03 00:00:00 (5.0 days) and wrote 4 records for NQH5.CME
2025-01-05 14:31:55.191 | HD Request # 3 | Completion time: 3s.
2025-01-05 14:31:55.191 | HD Request # 3 | Daily data download complete for NQH5.CME. Unique request ID: 6
2025-01-05 14:31:55.191 | Removing historical data download ID 6.
2025-01-05 14:31:55.192 |
2025-01-05 14:31:55.192 | Triggering next historical data download in queue.
2025-01-05 14:31:55.193 | HD Request # 4 | Downloading Historical Daily chart data for MNQH5.CME. Starting date: 2024-12-27. Service: rithmic.trading
2025-01-05 14:31:55.196 | ESH5.CME [CBV] #14 | Reloading chart.
2025-01-05 14:31:55.420 | ESH5.CME [CBV] Weekly #5 | Chart data loading complete.
2025-01-05 14:31:55.421 | ESH5.CME [CBV] 10 Min #2 | Reloading chart.
2025-01-05 14:31:55.645 | ESH5.CME [CBV] 30 Min #17 | StartDateTimeForLoadingOrderFills: 2023-12-28 00:00:00
2025-01-05 14:31:55.648 | ESH5.CME [CBV] 30 Min #17 | Chart data loading complete.
2025-01-05 14:31:55.649 | ESH5.CME [CBV] #3 | Reloading chart.
2025-01-05 14:31:55.862 | MNQH5.CME[M] 15 Min #12 | StartDateTimeForLoadingOrderFills: 2023-12-28 00:00:00
2025-01-05 14:31:55.868 | MNQH5.CME[M] 15 Min #12 | Chart data loading complete.
2025-01-05 14:31:55.871 | ESH5.CME [CBV] 60 Min #8 | Reloading chart.
2025-01-05 14:31:55.971 | MNQH5.CME[M] Rev. 16t-20 #13 | StartDateTimeForLoadingOrderFills: 2023-12-28 00:00:00
2025-01-05 14:31:56.079 | MNQH5.CME[M] Rev. 16t-20 #13 | Chart data loading complete.
2025-01-05 14:31:56.176 | NQH5.CME [CBV] Weekly #5 | Download is complete for all contract months in chart. Proceeding with data load.
2025-01-05 14:31:56.176 | NQH5.CME [CBV] Weekly #5 | Reloading chart.
2025-01-05 14:31:56.318 | ESH5.CME [CBV] Daily #6 | Reloading chart.
2025-01-05 14:31:56.318 | ESH5.CME [CBV] Daily #6 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2025-01-05 14:31:56.318 | ESH5.CME [CBV] Daily #6 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2025-01-05 14:31:56.729 | NQH5.CME [CBV] Weekly #5 | Chart data loading complete.
2025-01-05 14:31:56.729 | HD Request # 4 | Requesting historical Daily data for NMH25 starting at 2024-12-26. SC External HD service.
2025-01-05 14:31:56.761 | NQH5.CME [CBV] Daily #6 | Download is complete for all contract months in chart. Proceeding with data load.
2025-01-05 14:31:56.762 | NQH5.CME [CBV] Daily #6 | Reloading chart.
2025-01-05 14:31:56.894 | ESH5.CME [CBV] Daily #6 | Chart data loading complete.
2025-01-05 14:31:56.897 | NQH5.CME [CBV] Monthly #4 | Download is complete for all contract months in chart. Proceeding with data load.
2025-01-05 14:31:56.898 | NQH5.CME [CBV] Monthly #4 | Reloading chart.
2025-01-05 14:31:57.060 | NQH5.CME [CBV] Daily #6 | Chart data loading complete.
2025-01-05 14:31:57.060 | ESH5.CME [CBV] 240 Min #15 | Reloading chart.
2025-01-05 14:31:57.269 | NQH5.CME [CBV] Monthly #4 | Chart data loading complete.
2025-01-05 14:31:57.279 | HD Request # 5 | Downloading Intraday chart data for MESH5.CME to the file MESH5.CME.scid. Service: cme
2025-01-05 14:31:57.279 | HD Request # 5 | Download start date-time: 2025-01-03 16:08:19.000000. File last date-time: 2025-01-03 16:08:19.219000
2025-01-05 14:31:57.279 | HD Request # 5 | Using server: ds32.sierracharts.com port 10149
2025-01-05 14:31:57.279 | Socket (8) | Creating socket.
2025-01-05 14:31:57.279 | Socket (8) | New receive buffer size: 0
2025-01-05 14:31:57.279 | Socket (8) | Connecting to IP: 67.214.125.3.
2025-01-05 14:31:57.286 | NQH5.CME [CBV] Weekly #5 | Reloading chart.
2025-01-05 14:31:57.286 | NQH5.CME [CBV] Weekly #5 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2025-01-05 14:31:57.286 | NQH5.CME [CBV] Weekly #5 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2025-01-05 14:31:57.659 | HD Request # 4 | Receiving historical Daily data for MNQH5.CME starting at 2024-12-27.
2025-01-05 14:31:57.660 | HD Request # 4 | Writing historical Daily data to the file MNQH5.CME.dly.
2025-01-05 14:31:57.661 | HD Request # 4 | Bytes received: 379
2025-01-05 14:31:57.661 | HD Request # 4 | Received 6 Daily data records from 2024-12-27 00:00:00 to 2025-01-03 00:00:00 (8.0 days) and wrote 5 records for MNQH5.CME
2025-01-05 14:31:57.661 | HD Request # 4 | Completion time: 2s.
2025-01-05 14:31:57.661 | HD Request # 4 | Daily data download complete for MNQH5.CME. Unique request ID: 8
2025-01-05 14:31:57.661 | Removing historical data download ID 8.
2025-01-05 14:31:57.661 | No download requests in the queue to start downloads for.
2025-01-05 14:31:57.663 | NQH5.CME [CBV] Daily #6 | Reloading chart.
2025-01-05 14:31:57.663 | NQH5.CME [CBV] Daily #6 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2025-01-05 14:31:57.663 | NQH5.CME [CBV] Daily #6 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2025-01-05 14:31:57.759 | HD Request # 5 | Setting DTC encoding to Binary VLS
2025-01-05 14:31:57.759 | HD Request # 5 | Sending historical data logon request message.
2025-01-05 14:31:58.001 | NQH5.CME [CBV] Weekly #5 | Chart data loading complete.
2025-01-05 14:31:58.006 | NQH5.CME [CBV] Monthly #4 | Reloading chart.
2025-01-05 14:31:58.006 | NQH5.CME [CBV] Monthly #4 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2025-01-05 14:31:58.006 | NQH5.CME [CBV] Monthly #4 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2025-01-05 14:31:58.035 | HD Request # 5 | Requesting Intraday data. Start date-time: 2025-01-03 16:08:19. Record interval: 0. Symbol: MESH25
2025-01-05 14:31:58.271 | HD Request # 5 | Decompressing data.
2025-01-05 14:31:58.359 | NQH5.CME [CBV] Daily #6 | Chart data loading complete.
2025-01-05 14:31:58.407 | GCG5.COMEX [CBV] #14 | Reloading chart.
2025-01-05 14:31:58.425 | Added historical Intraday data request for GCG5.COMEX to the queue.
2025-01-05 14:31:58.425 | Triggering next historical data download in queue.
2025-01-05 14:31:58.426 | GCG5.COMEX [CBV] #14 | Performing continuous chart historical Daily data download for symbol GCG5.COMEX starting at last date in file.
2025-01-05 14:31:58.426 | Added historical Daily data request for GCG5.COMEX to the queue.
2025-01-05 14:31:58.426 | Triggering next historical data download in queue.
2025-01-05 14:31:58.545 | GCG5.COMEX [CBV] #14 | Waiting for historical downloads to complete with the IDs: 9, 10,
2025-01-05 14:31:58.555 | GCG5.COMEX [CBV] #3 | Reloading chart.
2025-01-05 14:31:58.680 | GCG5.COMEX [CBV] #3 | Waiting for historical downloads to complete with the IDs: 9, 10,
2025-01-05 14:31:58.690 | GCG5.COMEX [CBV] 240 Min #15 | Reloading chart.
2025-01-05 14:31:58.753 | HD Request # 5 | Receiving Intraday data for MESH5.CME starting at 2025-01-03 16:08:19.219000
2025-01-05 14:31:58.754 | Socket (8) | CloseSocket call.
2025-01-05 14:31:58.754 | Socket (8) | Shutdown started. Waiting for graceful close.
2025-01-05 14:31:58.818 | GCG5.COMEX [CBV] 240 Min #15 | Waiting for historical downloads to complete with the IDs: 9, 10,
2025-01-05 14:31:58.828 | GCG5.COMEX [CBV] Monthly #4 | Reloading chart.
2025-01-05 14:31:58.828 | GCG5.COMEX [CBV] Monthly #4 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2025-01-05 14:31:58.828 | GCG5.COMEX [CBV] Monthly #4 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2025-01-05 14:31:58.991 | Socket (8) | Socket gracefully closed by remote side.
2025-01-05 14:31:58.991 | Socket (8) | Closed.
2025-01-05 14:31:59.109 | GCG5.COMEX [CBV] Monthly #4 | Waiting for historical downloads to complete with the IDs: 10,
2025-01-05 14:31:59.120 | GCG5.COMEX [CBV] Weekly #5 | Reloading chart.
2025-01-05 14:31:59.120 | GCG5.COMEX [CBV] Weekly #5 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2025-01-05 14:31:59.120 | GCG5.COMEX [CBV] Weekly #5 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2025-01-05 14:31:59.393 | GCG5.COMEX [CBV] Weekly #5 | Waiting for historical downloads to complete with the IDs: 10,
2025-01-05 14:31:59.405 | GCG5.COMEX [CBV] Daily #6 | Reloading chart.
2025-01-05 14:31:59.405 | GCG5.COMEX [CBV] Daily #6 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2025-01-05 14:31:59.405 | GCG5.COMEX [CBV] Daily #6 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2025-01-05 14:31:59.676 | GCG5.COMEX [CBV] Daily #6 | Waiting for historical downloads to complete with the IDs: 10,
2025-01-05 14:31:59.720 | GCG5.COMEX [CBV] 30 Min #17 | Reloading chart.
2025-01-05 14:31:59.738 | GCG5.COMEX [CBV] 30 Min #17 | Waiting for historical downloads to complete with the IDs: 9, 10,
2025-01-05 14:31:59.805 | GCG5.COMEX [CBV] 240 Min #7 | Reloading chart.
2025-01-05 14:31:59.939 | GCG5.COMEX [CBV] 240 Min #7 | Waiting for historical downloads to complete with the IDs: 9, 10,
2025-01-05 14:31:59.982 | GCG5.COMEX [CBV] 15 Min #10 | Reloading chart.
2025-01-05 14:32:00.116 | GCG5.COMEX [CBV] 15 Min #10 | Waiting for historical downloads to complete with the IDs: 9, 10,
2025-01-05 14:32:00.128 | GCG5.COMEX 5 Min #12 | Reloading chart.
2025-01-05 14:32:00.170 | GCG5.COMEX [CBV] 60 Min #8 | Reloading chart.
2025-01-05 14:32:00.216 | GCG5.COMEX [CBV] 60 Min #8 | Waiting for historical downloads to complete with the IDs: 9, 10,
2025-01-05 14:32:00.256 | GCG5.COMEX 5 Min #11 | Reloading chart.
2025-01-05 14:32:00.289 | GCG5.COMEX Rev. 16t-20 #13 | Reloading chart.
2025-01-05 14:32:00.463 | ESU4.CME #9 | Reloading chart.
2025-01-05 14:32:00.463 | ESU4.CME #9 | StartDateTimeForLoadingOrderFills: 2023-12-30 00:00:00
2025-01-05 14:32:00.464 | ESU4.CME #9 | Chart data loading complete.
2025-01-05 14:32:00.472 | MGCG5.COMEX 1 Min #1 | Reloading chart.
2025-01-05 14:32:00.659 | MGCG5.COMEX #16 | Reloading chart.
2025-01-05 14:32:00.660 | MGCG5.COMEX #16 | StartDateTimeForLoadingOrderFills: 2023-12-30 00:00:00
2025-01-05 14:32:00.660 | MGCG5.COMEX #16 | Chart data loading complete.
2025-01-05 14:32:00.669 | USDX Daily #19 | Reloading chart.
2025-01-05 14:32:00.850 | MGCG5.COMEX #21 | Reloading chart.
2025-01-05 14:32:00.850 | MGCG5.COMEX #21 | StartDateTimeForLoadingOrderFills: 2023-12-30 00:00:00
2025-01-05 14:32:00.850 | MGCG5.COMEX #21 | Chart data loading complete.
2025-01-05 14:32:00.853 | NQH5.CME [CBV] Monthly #4 | Chart data loading complete.
2025-01-05 14:32:00.855 | Mapping GCG5.COMEX to GCG25. Service code: comex
2025-01-05 14:32:00.856 | HD Request # 6 | Downloading Historical Daily chart data for GCG5.COMEX. Starting date: 2024-12-30. Service: rithmic.trading
2025-01-05 14:32:00.858 | Historical data download thread signaled to stop.
2025-01-05 14:32:00.858 | HD Request # 5 | Timestamp of first Intraday data file record written: 2025-01-03 16:08:21.811000.
2025-01-05 14:32:00.859 | HD Request # 5 | Received 3681 Intraday data records from 2025-01-03 16:08:19.219000 to 2025-01-03 16:59:59.926000 (51.7 minutes. Delay: 45.5 hours) and wrote 3680 records for MESH5.CME
2025-01-05 14:32:00.859 | HD Request # 5 | Add time&sales data | Remembered last file record date-time: 2025-01-03 21:59:59.926000
2025-01-05 14:32:00.859 | HD Request # 5 | Completion time: 3s.
2025-01-05 14:32:00.859 | HD Request # 5 | Intraday data download complete for MESH5.CME. Unique request ID: 3
2025-01-05 14:32:00.859 | Removing historical data download ID 3.
2025-01-05 14:32:00.859 | Real-time Intraday chart data file updates started for MESH5.CME
2025-01-05 14:32:00.859 | Intraday chart data file opened for MESH5.CME
2025-01-05 14:32:00.859 | HD Request # 5 | Enabling Intraday chart updating for symbol.
2025-01-05 14:32:00.859 | Triggering next historical data download in queue.
2025-01-05 14:32:00.870 | GCG5.COMEX 5 Min #11 | StartDateTimeForLoadingOrderFills: 2023-12-28 00:00:00
2025-01-05 14:32:00.886 | GCG5.COMEX 5 Min #11 | Chart data loading complete.
2025-01-05 14:32:00.910 | MGCG5.COMEX 1 Min #1 | StartDateTimeForLoadingOrderFills: 2023-12-28 00:00:00
2025-01-05 14:32:00.911 | MGCG5.COMEX 1 Min #1 | Chart data loading complete.
2025-01-05 14:32:00.911 | USDX Daily #19 | StartDateTimeForLoadingOrderFills: 2023-12-28 00:00:00
2025-01-05 14:32:00.912 | USDX Daily #19 | >= 1 Day from current Date to last Date in file. Downloading historical Daily data
2025-01-05 14:32:00.912 | USDX Daily #19 | Chart data loading complete.
2025-01-05 14:32:00.913 | GCG5.COMEX 5 Min #12 | StartDateTimeForLoadingOrderFills: 2023-12-28 00:00:00
2025-01-05 14:32:00.925 | GCG5.COMEX 5 Min #12 | Chart data loading complete.
2025-01-05 14:32:00.925 | HD Request # 7 | Downloading Intraday chart data for SPX500 to the file SPX500.scid. Service: fxcm
2025-01-05 14:32:00.925 | HD Request # 7 | Download start date-time: 2025-01-03 16:08:18.000000. File last date-time: 2025-01-03 16:08:18.060000
2025-01-05 14:32:00.926 | HD Request # 7 | Using server: ds12.sierracharts.com port 10150
2025-01-05 14:32:00.926 | Socket (7) | Creating socket.
2025-01-05 14:32:00.926 | Socket (7) | New receive buffer size: 0
2025-01-05 14:32:00.926 | Socket (7) | Connecting to IP: 69.39.70.241.
2025-01-05 14:32:00.926 | GCG5.COMEX Rev. 16t-20 #13 | StartDateTimeForLoadingOrderFills: 2023-12-28 00:00:00
2025-01-05 14:32:00.933 | GCG5.COMEX Rev. 16t-20 #13 | Chart data loading complete.
2025-01-05 14:32:01.021 | Denali Data Feed | Starting real-time market data updates for: GCG5.COMEX (GCG25). ID: 8 Service code: comex
2025-01-05 14:32:01.021 | Denali Data Feed | Requesting security definition data for: GCG5.COMEX (GCG25). ID: 8
2025-01-05 14:32:01.041 | Mapping MGCG5.COMEX to MGCG25. Service code: comex
2025-01-05 14:32:01.041 | Denali Data Feed | Starting real-time market data updates for: MGCG5.COMEX (MGCG25). ID: 9 Service code: comex
2025-01-05 14:32:01.041 | Denali Data Feed | Requesting security definition data for: MGCG5.COMEX (MGCG25). ID: 9
2025-01-05 14:32:01.041 | Added historical Intraday data request for MGCG5.COMEX to the queue.
2025-01-05 14:32:01.041 | Intraday data recording state for symbol MGCG5.COMEX is set to download 'Pending'.
2025-01-05 14:32:01.041 | Triggering next historical data download in queue.
2025-01-05 14:32:01.042 | Mapping ESU4.CME to ESU24. Service code: cme
2025-01-05 14:32:01.042 | Denali Data Feed | Starting real-time market data updates for: ESU4.CME (ESU24). ID: 10 Service code: cme
2025-01-05 14:32:01.042 | Denali Data Feed | Requesting security definition data for: ESU4.CME (ESU24). ID: 10
2025-01-05 14:32:01.042 | Added historical Intraday data request for ESU4.CME to the queue.
2025-01-05 14:32:01.042 | Intraday data recording state for symbol ESU4.CME is set to download 'Pending'.
2025-01-05 14:32:01.042 | Triggering next historical data download in queue.
2025-01-05 14:32:01.178 | Added historical Daily data request for USDX to the queue.
2025-01-05 14:32:01.178 | Triggering next historical data download in queue.
2025-01-05 14:32:01.179 | SC Data with Depth | Starting real-time market data updates for: USDX. ID: 11 Service code: fxstatscalc
2025-01-05 14:32:01.179 | SC Data with Depth | Requesting security definition data for: USDX. ID: 11
2025-01-05 14:32:01.319 | Requesting market depth updates for: ESU4.CME if supported. NumLevels=50
2025-01-05 14:32:01.319 | Requesting market depth updates for: GCG5.COMEX if supported. NumLevels=50
2025-01-05 14:32:01.319 | Requesting market depth updates for: MGCG5.COMEX if supported. NumLevels=50
2025-01-05 14:32:01.412 | HD Request # 7 | Setting DTC encoding to Binary VLS
2025-01-05 14:32:01.412 | HD Request # 7 | Sending historical data logon request message.
2025-01-05 14:32:01.681 | HD Request # 7 | Requesting Intraday data. Start date-time: 2025-01-03 16:08:18. Record interval: 0. Symbol: SPX500
2025-01-05 14:32:01.774 | Denali Data Feed | Clearing market depth for ESU4.CME
2025-01-05 14:32:01.774 | Denali Data Feed | Clearing market depth for GCG5.COMEX
2025-01-05 14:32:01.774 | Denali Data Feed | Clearing market depth for MGCG5.COMEX
2025-01-05 14:32:01.774 | Denali Data Feed | Setting external service identifier for symbol GCG5.COMEX to 1551
2025-01-05 14:32:01.774 | Denali Data Feed | Received security definition for symbol GCG5.COMEX
2025-01-05 14:32:01.774 | Denali Data Feed | Setting external service identifier for symbol MGCG5.COMEX to 69
2025-01-05 14:32:01.774 | Denali Data Feed | Received security definition for symbol MGCG5.COMEX
2025-01-05 14:32:01.774 | Denali Data Feed | Real-time data for symbol ESU4.CME is currently unavailable.
2025-01-05 14:32:01.774 | Denali Data Feed | Received security definition for symbol ESU4.CME
2025-01-05 14:32:01.916 | HD Request # 7 | Decompressing data.
2025-01-05 14:32:01.925 | HD Request # 6 | Requesting historical Daily data for GCG25 starting at 2024-12-29. SC External HD service.
2025-01-05 14:32:01.925 | SC Data with Depth | Setting external service identifier for symbol USDX to 1
2025-01-05 14:32:01.925 | SC Data with Depth | Received security definition for symbol USDX
2025-01-05 14:32:02.153 | HD Request # 7 | Receiving Intraday data for SPX500 starting at 2025-01-03 16:08:18.060000
2025-01-05 14:32:02.153 | Socket (7) | CloseSocket call.
2025-01-05 14:32:02.153 | Socket (7) | Shutdown started. Waiting for graceful close.
2025-01-05 14:32:02.153 | Historical data download thread signaled to stop.
2025-01-05 14:32:02.153 | HD Request # 7 | Timestamp of first Intraday data file record written: 2025-01-03 16:08:24.286000.
2025-01-05 14:32:02.153 | HD Request # 7 | Received 693 Intraday data records from 2025-01-03 16:08:18.060000 to 2025-01-03 16:44:58.325000 (36.7 minutes. Delay: 45.8 hours) and wrote 692 records for SPX500
2025-01-05 14:32:02.154 | HD Request # 7 | Add time&sales data | Remembered last file record date-time: 2025-01-03 21:44:58.325000
2025-01-05 14:32:02.154 | HD Request # 7 | Completion time: 2s.
2025-01-05 14:32:02.154 | HD Request # 7 | Intraday data download complete for SPX500. Unique request ID: 4
2025-01-05 14:32:02.154 | Removing historical data download ID 4.
2025-01-05 14:32:02.154 | Real-time Intraday chart data file updates started for SPX500
2025-01-05 14:32:02.154 | Intraday chart data file opened for SPX500
2025-01-05 14:32:02.154 | HD Request # 7 | Enabling Intraday chart updating for symbol.
2025-01-05 14:32:02.154 | Triggering next historical data download in queue.
2025-01-05 14:32:02.154 | HD Request # 8 | Downloading Intraday chart data for NQH5.CME to the file NQH5.CME.scid. Service: cme
2025-01-05 14:32:02.154 | HD Request # 8 | Download start date-time: 2025-01-03 16:08:19.000000. File last date-time: 2025-01-03 16:08:19.464000
2025-01-05 14:32:02.154 | HD Request # 8 | Using server: ds32.sierracharts.com port 10149
2025-01-05 14:32:02.154 | Socket (8) | Creating socket.
2025-01-05 14:32:02.154 | Socket (8) | New receive buffer size: 0
2025-01-05 14:32:02.154 | Socket (8) | Connecting to IP: 67.214.125.3.
2025-01-05 14:32:02.387 | Socket (7) | Socket gracefully closed by remote side.
2025-01-05 14:32:02.387 | Socket (7) | Closed.
2025-01-05 14:32:02.650 | HD Request # 8 | Setting DTC encoding to Binary VLS
2025-01-05 14:32:02.650 | HD Request # 8 | Sending historical data logon request message.
2025-01-05 14:32:02.896 | HD Request # 8 | Requesting Intraday data. Start date-time: 2025-01-03 16:08:19. Record interval: 0. Symbol: NQH25
2025-01-05 14:32:02.932 | HD Request # 6 | Receiving historical Daily data for GCG5.COMEX starting at 2024-12-30.
2025-01-05 14:32:02.933 | HD Request # 6 | Writing historical Daily data to the file GCG5.COMEX.dly.
2025-01-05 14:32:02.935 | HD Request # 6 | Bytes received: 218
2025-01-05 14:32:02.935 | HD Request # 6 | Received 4 Daily data records from 2024-12-30 00:00:00 to 2025-01-03 00:00:00 (5.0 days) and wrote 4 records for GCG5.COMEX
2025-01-05 14:32:02.935 | HD Request # 6 | Completion time: 2s.
2025-01-05 14:32:02.935 | HD Request # 6 | Daily data download complete for GCG5.COMEX. Unique request ID: 10
2025-01-05 14:32:02.935 | Removing historical data download ID 10.
2025-01-05 14:32:02.935 | No download requests in the queue to start downloads for.
2025-01-05 14:32:03.122 | GCG5.COMEX [CBV] Weekly #5 | Download is complete for all contract months in chart. Proceeding with data load.
2025-01-05 14:32:03.123 | GCG5.COMEX [CBV] Weekly #5 | Reloading chart.
2025-01-05 14:32:03.141 | HD Request # 8 | Decompressing data.
2025-01-05 14:32:03.396 | HD Request # 8 | Receiving Intraday data for NQH5.CME starting at 2025-01-03 16:08:19.083000
2025-01-05 14:32:03.643 | Socket (8) | CloseSocket call.
2025-01-05 14:32:03.643 | Socket (8) | Shutdown started. Waiting for graceful close.
2025-01-05 14:32:03.706 | Historical data download thread signaled to stop.
2025-01-05 14:32:03.707 | HD Request # 8 | Timestamp of first Intraday data file record written: 2025-01-03 16:08:20.000000.
2025-01-05 14:32:03.707 | HD Request # 8 | Received 6640 Intraday data records from 2025-01-03 16:08:19.083000 to 2025-01-03 16:59:59.503000 (51.7 minutes. Delay: 45.5 hours) and wrote 6638 records for NQH5.CME
2025-01-05 14:32:03.707 | HD Request # 8 | Add time&sales data | Remembered last file record date-time: 2025-01-03 21:59:59.503000
2025-01-05 14:32:03.707 | HD Request # 8 | Completion time: 1s.
2025-01-05 14:32:03.707 | HD Request # 8 | Intraday data download complete for NQH5.CME. Unique request ID: 5
2025-01-05 14:32:03.707 | Removing historical data download ID 5.
2025-01-05 14:32:03.707 | Real-time Intraday chart data file updates started for NQH5.CME
2025-01-05 14:32:03.707 | Intraday chart data file opened for NQH5.CME
2025-01-05 14:32:03.707 | HD Request # 8 | Enabling Intraday chart updating for symbol.
2025-01-05 14:32:03.707 | Triggering next historical data download in queue.
2025-01-05 14:32:03.707 | HD Request # 9 | Downloading Intraday chart data for MNQH5.CME to the file MNQH5.CME.scid. Service: cme
2025-01-05 14:32:03.708 | HD Request # 9 | Download start date-time: 2025-01-03 16:08:18.000000. File last date-time: 2025-01-03 16:08:18.954000
2025-01-05 14:32:03.708 | HD Request # 9 | Using server: ds32.sierracharts.com port 10150
2025-01-05 14:32:03.708 | Socket (4) | Creating socket.
2025-01-05 14:32:03.708 | Socket (4) | New receive buffer size: 0
2025-01-05 14:32:03.708 | Socket (4) | Connecting to IP: 67.214.125.3.
2025-01-05 14:32:03.713 | NQH5.CME [CBV] 60 Min #11 | Download is complete for all contract months in chart. Proceeding with data load.
2025-01-05 14:32:03.714 | NQH5.CME [CBV] 60 Min #11 | Reloading chart.
2025-01-05 14:32:03.771 | NQH5.CME [CBV] 15 Min #1 | Download is complete for all contract months in chart. Proceeding with data load.
2025-01-05 14:32:03.772 | NQH5.CME [CBV] 15 Min #1 | Reloading chart.
2025-01-05 14:32:03.845 | GCG5.COMEX [CBV] Weekly #5 | Chart data loading complete.
2025-01-05 14:32:03.848 | GCG5.COMEX [CBV] Monthly #4 | Download is complete for all contract months in chart. Proceeding with data load.
2025-01-05 14:32:03.849 | GCG5.COMEX [CBV] Monthly #4 | Reloading chart.
2025-01-05 14:32:03.888 | Socket (8) | Socket gracefully closed by remote side.
2025-01-05 14:32:03.888 | Socket (8) | Closed.
2025-01-05 14:32:04.214 | HD Request # 9 | Setting DTC encoding to Binary VLS
2025-01-05 14:32:04.214 | HD Request # 9 | Sending historical data logon request message.
2025-01-05 14:32:04.462 | HD Request # 9 | Requesting Intraday data. Start date-time: 2025-01-03 16:08:18. Record interval: 0. Symbol: MNQH25
2025-01-05 14:32:04.490 | NQH5.CME [CBV] #16 | Download is complete for all contract months in chart. Proceeding with data load.
2025-01-05 14:32:04.490 | NQH5.CME [CBV] #16 | Reloading chart.
2025-01-05 14:32:04.537 | GCG5.COMEX [CBV] Daily #6 | Download is complete for all contract months in chart. Proceeding with data load.
2025-01-05 14:32:04.538 | GCG5.COMEX [CBV] Daily #6 | Reloading chart.
2025-01-05 14:32:04.710 | HD Request # 9 | Decompressing data.
2025-01-05 14:32:04.971 | HD Request # 9 | Receiving Intraday data for MNQH5.CME starting at 2025-01-03 16:08:18.954000
2025-01-05 14:32:05.223 | GCG5.COMEX [CBV] Monthly #4 | Chart data loading complete.
2025-01-05 14:32:05.224 | NQH5.CME [CBV] 5 Min #15 | Download is complete for all contract months in chart. Proceeding with data load.
2025-01-05 14:32:05.225 | NQH5.CME [CBV] 5 Min #15 | Reloading chart.
2025-01-05 14:32:05.241 | NQH5.CME [CBV] #3 | Download is complete for all contract months in chart. Proceeding with data load.
2025-01-05 14:32:05.242 | NQH5.CME [CBV] #3 | Reloading chart.
2025-01-05 14:32:05.262 | NQH5.CME [CBV] 5 Min #15 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2024-12-26 09:40:00. Next Bar Date Time: 2024-12-26 09:35:00. Filename: NQH5.CME.scid
2025-01-05 14:32:05.320 | NQH5.CME [CBV] 240 Min #7 | Download is complete for all contract months in chart. Proceeding with data load.
2025-01-05 14:32:05.320 | NQH5.CME [CBV] 240 Min #7 | Reloading chart.
2025-01-05 14:32:05.398 | GCG5.COMEX [CBV] Daily #6 | Chart data loading complete.
2025-01-05 14:32:05.399 | NQH5.CME [CBV] 60 Min #14 | Download is complete for all contract months in chart. Proceeding with data load.
2025-01-05 14:32:05.399 | NQH5.CME [CBV] 60 Min #14 | Reloading chart.
2025-01-05 14:32:05.467 | Socket (4) | CloseSocket call.
2025-01-05 14:32:05.467 | Socket (4) | Shutdown started. Waiting for graceful close.
2025-01-05 14:32:05.493 | Historical data download thread signaled to stop.
2025-01-05 14:32:05.493 | HD Request # 9 | Timestamp of first Intraday data file record written: 2025-01-03 16:08:20.001000.
2025-01-05 14:32:05.493 | HD Request # 9 | Received 11162 Intraday data records from 2025-01-03 16:08:18.954000 to 2025-01-03 16:59:58.839000 (51.7 minutes. Delay: 45.5 hours) and wrote 11161 records for MNQH5.CME
2025-01-05 14:32:05.494 | HD Request # 9 | Add time&sales data | Remembered last file record date-time: 2025-01-03 21:59:58.839000
2025-01-05 14:32:05.494 | HD Request # 9 | Completion time: 2s.
2025-01-05 14:32:05.494 | HD Request # 9 | Intraday data download complete for MNQH5.CME. Unique request ID: 7
2025-01-05 14:32:05.494 | Removing historical data download ID 7.
2025-01-05 14:32:05.494 | Real-time Intraday chart data file updates started for MNQH5.CME
2025-01-05 14:32:05.494 | Intraday chart data file opened for MNQH5.CME
2025-01-05 14:32:05.494 | HD Request # 9 | Enabling Intraday chart updating for symbol.
2025-01-05 14:32:05.494 | Triggering next historical data download in queue.
2025-01-05 14:32:05.494 | Delaying start of download for GCG5.COMEX.
2025-01-05 14:32:05.494 | MNQH5.CME [CBV] 1 Min #10 | Download is complete for all contract months in chart. Proceeding with data load.
2025-01-05 14:32:05.495 | MNQH5.CME [CBV] 1 Min #10 | Reloading chart.
2025-01-05 14:32:05.505 | NQH5.CME [CBV] 30 Min #8 | Download is complete for all contract months in chart. Proceeding with data load.
2025-01-05 14:32:05.506 | NQH5.CME [CBV] 30 Min #8 | Reloading chart.
2025-01-05 14:32:05.521 | GCG5.COMEX [CBV] Weekly #5 | Reloading chart.
2025-01-05 14:32:05.521 | GCG5.COMEX [CBV] Weekly #5 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2025-01-05 14:32:05.521 | GCG5.COMEX [CBV] Weekly #5 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2025-01-05 14:32:05.715 | Socket (4) | Socket gracefully closed by remote side.
2025-01-05 14:32:05.715 | Socket (4) | Closed.
2025-01-05 14:32:06.846 | NQH5.CME [CBV] 5 Min #15 | StartDateTimeForLoadingOrderFills: 2023-12-28 00:00:00
2025-01-05 14:32:06.897 | NQH5.CME [CBV] 5 Min #15 | Chart data loading complete.
2025-01-05 14:32:07.003 | GCG5.COMEX [CBV] Weekly #5 | Chart data loading complete.
2025-01-05 14:32:07.020 | MNQH5.CME [CBV] 1 Min #10 | StartDateTimeForLoadingOrderFills: 2023-12-28 00:00:00
2025-01-05 14:32:07.055 | MNQH5.CME [CBV] 1 Min #10 | Chart data loading complete.
2025-01-05 14:32:07.085 | HD Request # 10 | Downloading Intraday chart data for GCG5.COMEX to the file GCG5.COMEX.scid. Service: comex
2025-01-05 14:32:07.085 | HD Request # 10 | Download start date-time: 2025-01-03 16:08:07.000000. File last date-time: 2025-01-03 16:08:07.602007
2025-01-05 14:32:07.085 | HD Request # 10 | Using server: ds32.sierracharts.com port 10149
2025-01-05 14:32:07.085 | Socket (3) | Creating socket.
2025-01-05 14:32:07.085 | Socket (3) | New receive buffer size: 0
2025-01-05 14:32:07.085 | Socket (3) | Connecting to IP: 67.214.125.3.
2025-01-05 14:32:07.120 | NQH5.CME [CBV] 60 Min #11 | Reloading chart.
2025-01-05 14:32:07.268 | NQH5.CME [CBV] 15 Min #1 | Reloading chart.
2025-01-05 14:32:07.515 | GCG5.COMEX [CBV] Monthly #4 | Reloading chart.
2025-01-05 14:32:07.515 | GCG5.COMEX [CBV] Monthly #4 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2025-01-05 14:32:07.515 | GCG5.COMEX [CBV] Monthly #4 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2025-01-05 14:32:07.554 | HD Request # 10 | Setting DTC encoding to Binary VLS
2025-01-05 14:32:07.554 | HD Request # 10 | Sending historical data logon request message.
2025-01-05 14:32:07.785 | HD Request # 10 | Requesting Intraday data. Start date-time: 2025-01-03 16:08:07. Record interval: 0. Symbol: GCG25
2025-01-05 14:32:08.016 | HD Request # 10 | Decompressing data.
2025-01-05 14:32:08.252 | HD Request # 10 | Receiving Intraday data for GCG5.COMEX starting at 2025-01-03 16:08:07.602000
2025-01-05 14:32:08.254 | Socket (3) | CloseSocket call.
2025-01-05 14:32:08.254 | Socket (3) | Shutdown started. Waiting for graceful close.
2025-01-05 14:32:08.485 | Socket (3) | Socket gracefully closed by remote side.
2025-01-05 14:32:08.485 | Socket (3) | Closed.
2025-01-05 14:32:08.743 | NQH5.CME [CBV] 30 Min #8 | StartDateTimeForLoadingOrderFills: 2023-12-28 00:00:00
2025-01-05 14:32:08.753 | NQH5.CME [CBV] 30 Min #8 | Chart data loading complete.
2025-01-05 14:32:08.753 | Historical data download thread signaled to stop.
2025-01-05 14:32:08.753 | HD Request # 10 | Timestamp of first Intraday data file record written: 2025-01-03 16:08:34.036000.
2025-01-05 14:32:08.754 | HD Request # 10 | Received 1991 Intraday data records from 2025-01-03 16:08:07.602000 to 2025-01-03 16:59:59.951000 (51.9 minutes. Delay: 45.5 hours) and wrote 1983 records for GCG5.COMEX
2025-01-05 14:32:08.755 | HD Request # 10 | Add time&sales data | Remembered last file record date-time: 2025-01-03 21:59:59.951000
2025-01-05 14:32:08.755 | HD Request # 10 | Completion time: 1s.
2025-01-05 14:32:08.755 | HD Request # 10 | Intraday data download complete for GCG5.COMEX. Unique request ID: 9
2025-01-05 14:32:08.755 | Removing historical data download ID 9.
2025-01-05 14:32:08.755 | Real-time Intraday chart data file updates started for GCG5.COMEX
2025-01-05 14:32:08.755 | Intraday chart data file opened for GCG5.COMEX
2025-01-05 14:32:08.755 | HD Request # 10 | Enabling Intraday chart updating for symbol.
2025-01-05 14:32:08.755 | Triggering next historical data download in queue.
2025-01-05 14:32:08.755 | HD Request # 11 | Downloading Intraday chart data for MGCG5.COMEX to the file MGCG5.COMEX.scid. Service: comex
2025-01-05 14:32:08.755 | HD Request # 11 | Download start date-time: 2025-01-03 16:08:07.000000. File last date-time: 2025-01-03 16:08:07.603002
2025-01-05 14:32:08.755 | HD Request # 11 | Using server: ds32.sierracharts.com port 10150
2025-01-05 14:32:08.755 | Socket (3) | Creating socket.
2025-01-05 14:32:08.755 | Socket (3) | New receive buffer size: 0
2025-01-05 14:32:08.755 | Socket (3) | Connecting to IP: 67.214.125.3.
2025-01-05 14:32:08.809 | GCG5.COMEX [CBV] #14 | Download is complete for all contract months in chart. Proceeding with data load.
2025-01-05 14:32:08.810 | GCG5.COMEX [CBV] #14 | Reloading chart.
2025-01-05 14:32:09.183 | GCG5.COMEX [CBV] Monthly #4 | Chart data loading complete.
2025-01-05 14:32:09.184 | NQH5.CME [CBV] #16 | Reloading chart.
2025-01-05 14:32:09.245 | HD Request # 11 | Setting DTC encoding to Binary VLS
2025-01-05 14:32:09.245 | HD Request # 11 | Sending historical data logon request message.
2025-01-05 14:32:09.276 | GCG5.COMEX [CBV] Daily #6 | Reloading chart.
2025-01-05 14:32:09.276 | GCG5.COMEX [CBV] Daily #6 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2025-01-05 14:32:09.276 | GCG5.COMEX [CBV] Daily #6 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2025-01-05 14:32:09.486 | HD Request # 11 | Requesting Intraday data. Start date-time: 2025-01-03 16:08:07. Record interval: 0. Symbol: MGCG25
2025-01-05 14:32:09.729 | HD Request # 11 | Decompressing data.
2025-01-05 14:32:09.975 | HD Request # 11 | Receiving Intraday data for MGCG5.COMEX starting at 2025-01-03 16:08:07.603000
2025-01-05 14:32:09.975 | Socket (3) | CloseSocket call.
2025-01-05 14:32:09.975 | Socket (3) | Shutdown started. Waiting for graceful close.
2025-01-05 14:32:10.217 | Socket (3) | Socket gracefully closed by remote side.
2025-01-05 14:32:10.217 | Socket (3) | Closed.
2025-01-05 14:32:10.620 | Historical data download thread signaled to stop.
2025-01-05 14:32:10.620 | HD Request # 11 | Timestamp of first Intraday data file record written: 2025-01-03 16:08:20.400000.
2025-01-05 14:32:10.620 | HD Request # 11 | Received 1434 Intraday data records from 2025-01-03 16:08:07.603000 to 2025-01-03 16:59:59.806000 (51.9 minutes. Delay: 45.5 hours) and wrote 1431 records for MGCG5.COMEX
2025-01-05 14:32:10.621 | HD Request # 11 | Add time&sales data | Remembered last file record date-time: 2025-01-03 21:59:59.806000
2025-01-05 14:32:10.621 | HD Request # 11 | Completion time: 2s.
2025-01-05 14:32:10.621 | HD Request # 11 | Intraday data download complete for MGCG5.COMEX. Unique request ID: 11
2025-01-05 14:32:10.621 | Removing historical data download ID 11.
2025-01-05 14:32:10.621 | Real-time Intraday chart data file updates started for MGCG5.COMEX
2025-01-05 14:32:10.621 | Intraday chart data file opened for MGCG5.COMEX
2025-01-05 14:32:10.621 | HD Request # 11 | Enabling Intraday chart updating for symbol.
2025-01-05 14:32:10.621 | Triggering next historical data download in queue.
2025-01-05 14:32:10.622 | HD Request # 12 | Downloading Intraday chart data for ESU4.CME to the file ESU4.CME.scid. Service: cme
2025-01-05 14:32:10.622 | HD Request # 12 | Download start date-time: 2024-09-20 09:29:59.000000. File last date-time: 2024-09-20 09:29:59.856000
2025-01-05 14:32:10.622 | HD Request # 12 | Using server: ds32.sierracharts.com port 10149
2025-01-05 14:32:10.622 | Socket (3) | Creating socket.
2025-01-05 14:32:10.622 | Socket (3) | New receive buffer size: 0
2025-01-05 14:32:10.622 | Socket (3) | Connecting to IP: 67.214.125.3.
2025-01-05 14:32:10.635 | GCG5.COMEX [CBV] 15 Min #10 | Download is complete for all contract months in chart. Proceeding with data load.
2025-01-05 14:32:10.635 | GCG5.COMEX [CBV] 15 Min #10 | Reloading chart.
2025-01-05 14:32:11.026 | GCG5.COMEX [CBV] Daily #6 | Chart data loading complete.
2025-01-05 14:32:11.098 | HD Request # 12 | Setting DTC encoding to Binary VLS
2025-01-05 14:32:11.098 | HD Request # 12 | Sending historical data logon request message.
2025-01-05 14:32:11.119 | SIH5.COMEX [CBV] #14 | Reloading chart.
2025-01-05 14:32:11.157 | Added historical Intraday data request for SIH5.COMEX to the queue.
2025-01-05 14:32:11.157 | Triggering next historical data download in queue.
2025-01-05 14:32:11.159 | SIH5.COMEX [CBV] #14 | Performing continuous chart historical Daily data download for symbol SIH5.COMEX starting at last date in file.
2025-01-05 14:32:11.159 | Added historical Daily data request for SIH5.COMEX to the queue.
2025-01-05 14:32:11.159 | Triggering next historical data download in queue.
2025-01-05 14:32:11.334 | HD Request # 12 | Requesting Intraday data. Start date-time: 2024-09-20 09:29:59. Record interval: 0. Symbol: ESU24
2025-01-05 14:32:11.359 | SIH5.COMEX [CBV] #14 | Waiting for historical downloads to complete with the IDs: 14, 15,
2025-01-05 14:32:11.374 | SIH5.COMEX [CBV] #3 | Reloading chart.
2025-01-05 14:32:11.569 | HD Request # 12 | Decompressing data.
2025-01-05 14:32:11.578 | SIH5.COMEX [CBV] #3 | Waiting for historical downloads to complete with the IDs: 14, 15,
2025-01-05 14:32:11.592 | SIH5.COMEX [CBV] 240 Min #15 | Reloading chart.
2025-01-05 14:32:11.804 | HD Request # 12 | Receiving Intraday data for ESU4.CME starting at 2024-09-20 09:29:59.011000
2025-01-05 14:32:11.804 | Socket (3) | CloseSocket call.
2025-01-05 14:32:11.804 | Socket (3) | Shutdown started. Waiting for graceful close.
2025-01-05 14:32:11.805 | SIH5.COMEX [CBV] 240 Min #15 | Waiting for historical downloads to complete with the IDs: 14, 15,
2025-01-05 14:32:11.820 | SIH5.COMEX [CBV] Monthly #4 | Reloading chart.
2025-01-05 14:32:11.820 | SIH5.COMEX [CBV] Monthly #4 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2025-01-05 14:32:11.820 | SIH5.COMEX [CBV] Monthly #4 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2025-01-05 14:32:12.040 | Socket (3) | Socket gracefully closed by remote side.
2025-01-05 14:32:12.040 | Socket (3) | Closed.
2025-01-05 14:32:12.290 | SIH5.COMEX [CBV] Monthly #4 | Waiting for historical downloads to complete with the IDs: 15,
2025-01-05 14:32:12.306 | SIH5.COMEX [CBV] Weekly #5 | Reloading chart.
2025-01-05 14:32:12.306 | SIH5.COMEX [CBV] Weekly #5 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2025-01-05 14:32:12.306 | SIH5.COMEX [CBV] Weekly #5 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2025-01-05 14:32:12.766 | SIH5.COMEX [CBV] Weekly #5 | Waiting for historical downloads to complete with the IDs: 15,
2025-01-05 14:32:12.825 | SIH5.COMEX [CBV] Daily #6 | Reloading chart.
2025-01-05 14:32:12.825 | SIH5.COMEX [CBV] Daily #6 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2025-01-05 14:32:12.825 | SIH5.COMEX [CBV] Daily #6 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2025-01-05 14:32:13.276 | SIH5.COMEX [CBV] Daily #6 | Waiting for historical downloads to complete with the IDs: 15,
2025-01-05 14:32:13.297 | SIH5.COMEX [CBV] 240 Min #7 | Reloading chart.
2025-01-05 14:32:13.494 | SIH5.COMEX [CBV] 240 Min #7 | Waiting for historical downloads to complete with the IDs: 14, 15,
2025-01-05 14:32:13.567 | SIH5.COMEX [CBV] 60 Min #8 | Reloading chart.
2025-01-05 14:32:13.674 | SIH5.COMEX [CBV] 60 Min #8 | Waiting for historical downloads to complete with the IDs: 14, 15,
2025-01-05 14:32:13.693 | SIH5.COMEX [CBV] 30 Min #17 | Reloading chart.
2025-01-05 14:32:13.720 | SIH5.COMEX [CBV] 30 Min #17 | Waiting for historical downloads to complete with the IDs: 14, 15,
2025-01-05 14:32:13.771 | SIH5.COMEX [CBV] 15 Min #10 | Reloading chart.
2025-01-05 14:32:13.978 | SIH5.COMEX [CBV] 15 Min #10 | Waiting for historical downloads to complete with the IDs: 14, 15,
2025-01-05 14:32:13.996 | SIH5.COMEX 5 Min #12 | Reloading chart.
2025-01-05 14:32:14.066 | SIH5.COMEX 5 Min #11 | Reloading chart.
2025-01-05 14:32:14.088 | SIH5.COMEX Rev. 16t-20 #13 | Reloading chart.
2025-01-05 14:32:14.302 | SIH5.COMEX 5 Min #12 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2024-12-26 09:50:00. Next Bar Date Time: 2024-12-26 09:45:00. Filename: SIH5.COMEX.scid
2025-01-05 14:32:14.327 | ESU4.CME #9 | Reloading chart.
2025-01-05 14:32:14.329 | ESU4.CME #9 | StartDateTimeForLoadingOrderFills: 2023-12-30 00:00:00
2025-01-05 14:32:14.329 | ESU4.CME #9 | Chart data loading complete.
2025-01-05 14:32:14.343 | SILH5.COMEX 1 Min #1 | Reloading chart.
2025-01-05 14:32:14.589 | MGCG5.COMEX #16 | Reloading chart.
2025-01-05 14:32:14.589 | MGCG5.COMEX #16 | StartDateTimeForLoadingOrderFills: 2023-12-30 00:00:00
2025-01-05 14:32:14.589 | MGCG5.COMEX #16 | Chart data loading complete.
2025-01-05 14:32:14.861 | GCG5.COMEX #18 | Reloading chart.
2025-01-05 14:32:14.861 | GCG5.COMEX #18 | StartDateTimeForLoadingOrderFills: 2023-12-30 00:00:00
2025-01-05 14:32:14.884 | GCG5.COMEX #18 | Chart data loading complete.
2025-01-05 14:32:14.897 | USDX 240 Min #19 | Reloading chart.
2025-01-05 14:32:15.145 | MGCG5.COMEX #21 | Reloading chart.
2025-01-05 14:32:15.148 | MGCG5.COMEX #21 | StartDateTimeForLoadingOrderFills: 2023-12-30 00:00:00
2025-01-05 14:32:15.148 | MGCG5.COMEX #21 | Chart data loading complete.
2025-01-05 14:32:15.163 | Mapping SIH5.COMEX to SIH25. Service code: comex
2025-01-05 14:32:15.165 | HD Request # 13 | Downloading Historical Daily chart data for SIH5.COMEX. Starting date: 2024-12-30. Service: rithmic.trading
2025-01-05 14:32:15.167 | Historical data download thread signaled to stop.
2025-01-05 14:32:15.167 | HD Request # 12 | Received 12 Intraday data records from 2024-09-20 09:29:59.011000 to 2024-09-20 09:29:59.856000 (0.8 seconds. Delay: 107.3 days) and wrote 0 records for ESU4.CME
2025-01-05 14:32:15.167 | HD Request # 12 | Add time&sales data | Remembered last file record date-time: 2024-09-20 13:29:59.856000
2025-01-05 14:32:15.168 | HD Request # 12 | Completion time: 5s.
2025-01-05 14:32:15.168 | HD Request # 12 | Intraday data download complete for ESU4.CME. Unique request ID: 12
2025-01-05 14:32:15.168 | Removing historical data download ID 12.
2025-01-05 14:32:15.168 | Real-time Intraday chart data file updates started for ESU4.CME
2025-01-05 14:32:15.168 | Intraday chart data file opened for ESU4.CME
2025-01-05 14:32:15.168 | HD Request # 12 | Enabling Intraday chart updating for symbol.
2025-01-05 14:32:15.168 | Triggering next historical data download in queue.
2025-01-05 14:32:15.184 | SIH5.COMEX 5 Min #11 | StartDateTimeForLoadingOrderFills: 2023-12-28 00:00:00
2025-01-05 14:32:15.226 | SIH5.COMEX 5 Min #11 | Chart data loading complete.
2025-01-05 14:32:15.282 | SIH5.COMEX 5 Min #12 | StartDateTimeForLoadingOrderFills: 2023-12-28 00:00:00
2025-01-05 14:32:15.295 | SIH5.COMEX 5 Min #12 | Chart data loading complete.
2025-01-05 14:32:15.297 | SIH5.COMEX Rev. 16t-20 #13 | StartDateTimeForLoadingOrderFills: 2023-12-28 00:00:00
2025-01-05 14:32:15.300 | SIH5.COMEX Rev. 16t-20 #13 | Chart data loading complete.
2025-01-05 14:32:15.303 | SILH5.COMEX 1 Min #1 | StartDateTimeForLoadingOrderFills: 2023-12-28 00:00:00
2025-01-05 14:32:15.304 | SILH5.COMEX 1 Min #1 | Chart data loading complete.
2025-01-05 14:32:15.311 | HD Request # 14 | Downloading Historical Daily chart data for USDX. Starting date: 2024-12-31. Service: fxstatscalc
2025-01-05 14:32:15.311 | HD Request # 14 | Using server: ds4.sierracharts.com port 10150
2025-01-05 14:32:15.426 | Socket (4) | Creating socket.
2025-01-05 14:32:15.427 | Socket (4) | New receive buffer size: 0
2025-01-05 14:32:15.427 | Socket (4) | Connecting to IP: 67.214.125.7.
2025-01-05 14:32:15.512 | GCG5.COMEX [CBV] #3 | Download is complete for all contract months in chart. Proceeding with data load.
2025-01-05 14:32:15.513 | GCG5.COMEX [CBV] #3 | Reloading chart.
2025-01-05 14:32:15.910 | HD Request # 14 | Setting DTC encoding to Binary VLS
2025-01-05 14:32:15.910 | HD Request # 14 | Sending historical data logon request message.
2025-01-05 14:32:15.958 | NQH5.CME [CBV] 5 Min #15 | Reloading chart.
2025-01-05 14:32:15.999 | NQH5.CME [CBV] #3 | Reloading chart.
2025-01-05 14:32:16.030 | NQH5.CME [CBV] 5 Min #15 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2024-12-26 09:40:00. Next Bar Date Time: 2024-12-26 09:35:00. Filename: NQH5.CME.scid
2025-01-05 14:32:16.174 | HD Request # 14 | Requesting historical Daily data starting at 2024-12-31.
2025-01-05 14:32:16.410 | HD Request # 14 | Decompressing data.
2025-01-05 14:32:16.420 | USDX 240 Min #19 | StartDateTimeForLoadingOrderFills: 2023-12-28 00:00:00
2025-01-05 14:32:16.420 | USDX 240 Min #19 | Chart data loading complete.
2025-01-05 14:32:16.420 | HD Request # 13 | Requesting historical Daily data for SIH25 starting at 2024-12-29. SC External HD service.
2025-01-05 14:32:16.423 | NQH5.CME [CBV] 240 Min #7 | Reloading chart.
2025-01-05 14:32:16.442 | HD Request # 14 | Receiving historical Daily data for USDX starting at 2024-12-31.
2025-01-05 14:32:16.442 | HD Request # 14 | Writing historical Daily data to the file USDX.dly.
2025-01-05 14:32:16.462 | Socket (4) | CloseSocket call.
2025-01-05 14:32:16.462 | Socket (4) | Shutdown started. Waiting for graceful close.
2025-01-05 14:32:16.700 | Socket (4) | Socket gracefully closed by remote side.
2025-01-05 14:32:16.700 | Socket (4) | Closed.
2025-01-05 14:32:16.796 | Historical data download thread signaled to stop.
2025-01-05 14:32:16.796 | HD Request # 14 | Received 3 Daily data records from 2024-12-31 00:00:00 to 2025-01-03 00:00:00 (4.0 days) and wrote 3 records for USDX
2025-01-05 14:32:16.796 | HD Request # 14 | Completion time: 1s.
2025-01-05 14:32:16.796 | HD Request # 14 | Daily data download complete for USDX. Unique request ID: 13
2025-01-05 14:32:16.796 | Removing historical data download ID 13.
2025-01-05 14:32:16.796 | Triggering next historical data download in queue.
2025-01-05 14:32:16.796 | HD Request # 15 | Downloading Intraday chart data for SIH5.COMEX to the file SIH5.COMEX.scid. Service: comex
2025-01-05 14:32:16.797 | HD Request # 15 | Download start date-time: 2025-01-03 16:07:36.000000. File last date-time: 2025-01-03 16:07:36.514001
2025-01-05 14:32:16.797 | HD Request # 15 | Using server: ds32.sierracharts.com port 10149
2025-01-05 14:32:16.797 | Socket (4) | Creating socket.
2025-01-05 14:32:16.797 | Socket (4) | New receive buffer size: 0
2025-01-05 14:32:16.797 | Socket (4) | Connecting to IP: 67.214.125.3.
2025-01-05 14:32:16.838 | NQH5.CME [CBV] 60 Min #14 | Reloading chart.
2025-01-05 14:32:17.115 | NQH5.CME [CBV] 5 Min #15 | StartDateTimeForLoadingOrderFills: 2023-12-28 00:00:00
2025-01-05 14:32:17.158 | NQH5.CME [CBV] 5 Min #15 | Chart data loading complete.
2025-01-05 14:32:17.211 | NQH5.CME [CBV] 30 Min #8 | Reloading chart.
2025-01-05 14:32:17.253 | MNQH5.CME [CBV] 1 Min #10 | Reloading chart.
2025-01-05 14:32:17.277 | HD Request # 15 | Setting DTC encoding to Binary VLS
2025-01-05 14:32:17.277 | HD Request # 15 | Sending historical data logon request message.
2025-01-05 14:32:17.317 | Denali Data Feed | Starting real-time market data updates for: SIH5.COMEX (SIH25). ID: 12 Service code: comex
2025-01-05 14:32:17.317 | Denali Data Feed | Requesting security definition data for: SIH5.COMEX (SIH25). ID: 12
2025-01-05 14:32:17.317 | Requesting market depth updates for: SIH5.COMEX if supported. NumLevels=50
2025-01-05 14:32:17.321 | USDX[M] Daily #19 | Reloading chart.
2025-01-05 14:32:17.325 | GCG5.COMEX [CBV] 60 Min #8 | Download is complete for all contract months in chart. Proceeding with data load.
2025-01-05 14:32:17.326 | GCG5.COMEX [CBV] 60 Min #8 | Reloading chart.
2025-01-05 14:32:17.475 | USDX[M] Daily #19 | StartDateTimeForLoadingOrderFills: 2023-12-28 00:00:00
2025-01-05 14:32:17.475 | USDX[M] Daily #19 | Chart data loading complete.
2025-01-05 14:32:17.480 | GCG5.COMEX [CBV] 240 Min #15 | Download is complete for all contract months in chart. Proceeding with data load.
2025-01-05 14:32:17.480 | GCG5.COMEX [CBV] 240 Min #15 | Reloading chart.
2025-01-05 14:32:17.515 | HD Request # 15 | Requesting Intraday data. Start date-time: 2025-01-03 16:07:36. Record interval: 0. Symbol: SIH25
2025-01-05 14:32:17.752 | HD Request # 15 | Decompressing data.
2025-01-05 14:32:17.989 | HD Request # 15 | Receiving Intraday data for SIH5.COMEX starting at 2025-01-03 16:07:36.513000
2025-01-05 14:32:17.990 | Socket (4) | CloseSocket call.
2025-01-05 14:32:17.990 | Socket (4) | Shutdown started. Waiting for graceful close.
2025-01-05 14:32:18.004 | HD Request # 13 | Receiving historical Daily data for SIH5.COMEX starting at 2024-12-30.
2025-01-05 14:32:18.005 | HD Request # 13 | Writing historical Daily data to the file SIH5.COMEX.dly.
2025-01-05 14:32:18.008 | HD Request # 13 | Bytes received: 214
2025-01-05 14:32:18.008 | HD Request # 13 | Received 4 Daily data records from 2024-12-30 00:00:00 to 2025-01-03 00:00:00 (5.0 days) and wrote 4 records for SIH5.COMEX
2025-01-05 14:32:18.008 | HD Request # 13 | Completion time: 3s.
2025-01-05 14:32:18.008 | HD Request # 13 | Daily data download complete for SIH5.COMEX. Unique request ID: 15
2025-01-05 14:32:18.008 | Removing historical data download ID 15.
2025-01-05 14:32:18.008 | No download requests in the queue to start downloads for.
2025-01-05 14:32:18.008 | Historical data download thread signaled to stop.
2025-01-05 14:32:18.009 | HD Request # 15 | Timestamp of first Intraday data file record written: 2025-01-03 16:08:36.224000.
2025-01-05 14:32:18.009 | HD Request # 15 | Received 335 Intraday data records from 2025-01-03 16:07:36.513000 to 2025-01-03 16:59:56.040000 (52.3 minutes. Delay: 45.5 hours) and wrote 324 records for SIH5.COMEX
2025-01-05 14:32:18.010 | HD Request # 15 | Add time&sales data | Remembered last file record date-time: 2025-01-03 21:59:56.040000
2025-01-05 14:32:18.010 | HD Request # 15 | Completion time: 2s.
2025-01-05 14:32:18.010 | HD Request # 15 | Intraday data download complete for SIH5.COMEX. Unique request ID: 14
2025-01-05 14:32:18.010 | Removing historical data download ID 14.
2025-01-05 14:32:18.010 | Real-time Intraday chart data file updates started for SIH5.COMEX
2025-01-05 14:32:18.010 | Intraday chart data file opened for SIH5.COMEX
2025-01-05 14:32:18.010 | HD Request # 15 | Enabling Intraday chart updating for symbol.
2025-01-05 14:32:18.010 | No download requests in the queue to start downloads for.
2025-01-05 14:32:18.130 | 6AH5.CME [CBV] #14 | Reloading chart.
2025-01-05 14:32:18.228 | Socket (4) | Socket gracefully closed by remote side.
2025-01-05 14:32:18.228 | Socket (4) | Closed.
2025-01-05 14:32:18.919 | Denali Data Feed | Clearing market depth for SIH5.COMEX
2025-01-05 14:32:20.094 | NQH5.CME [CBV] #16 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2024-12-26 09:40:00. Next Bar Date Time: 2024-12-26 09:38:00. Filename: NQH5.CME.scid
2025-01-05 14:32:20.102 | NQH5.CME [CBV] #16 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2024-12-26 09:57:00. Next Bar Date Time: 2024-12-26 09:55:00. Filename: NQH5.CME.scid
2025-01-05 14:32:20.392 | Added historical Intraday data request for 6AH5.CME to the queue.
2025-01-05 14:32:20.392 | Triggering next historical data download in queue.
2025-01-05 14:32:20.517 | 6AH5.CME [CBV] #14 | Performing continuous chart historical Daily data download for symbol 6AH5.CME starting at last date in file.
2025-01-05 14:32:20.517 | Added historical Daily data request for 6AH5.CME to the queue.
2025-01-05 14:32:20.517 | Triggering next historical data download in queue.
2025-01-05 14:32:20.695 | 6AH5.CME [CBV] #14 | Waiting for historical downloads to complete with the IDs: 16, 17,
2025-01-05 14:32:20.719 | 6AH5.CME [CBV] #3 | Reloading chart.
2025-01-05 14:32:20.909 | 6AH5.CME [CBV] #3 | Waiting for historical downloads to complete with the IDs: 16, 17,
2025-01-05 14:32:20.927 | 6AH5.CME [CBV] 60 Min #15 | Reloading chart.
2025-01-05 14:32:21.097 | 6AH5.CME [CBV] 60 Min #15 | Waiting for historical downloads to complete with the IDs: 16, 17,
2025-01-05 14:32:21.115 | 6AH5.CME [CBV] Monthly #4 | Reloading chart.
2025-01-05 14:32:21.115 | 6AH5.CME [CBV] Monthly #4 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2025-01-05 14:32:21.115 | 6AH5.CME [CBV] Monthly #4 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2025-01-05 14:32:21.524 | 6AH5.CME [CBV] Monthly #4 | Waiting for historical downloads to complete with the IDs: 17,
2025-01-05 14:32:21.551 | 6AH5.CME [CBV] Weekly #5 | Reloading chart.
2025-01-05 14:32:21.551 | 6AH5.CME [CBV] Weekly #5 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2025-01-05 14:32:21.551 | 6AH5.CME [CBV] Weekly #5 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2025-01-05 14:32:21.946 | 6AH5.CME [CBV] Weekly #5 | Waiting for historical downloads to complete with the IDs: 17,
2025-01-05 14:32:21.964 | 6AH5.CME [CBV] Daily #6 | Reloading chart.
2025-01-05 14:32:21.964 | 6AH5.CME [CBV] Daily #6 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2025-01-05 14:32:21.964 | 6AH5.CME [CBV] Daily #6 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2025-01-05 14:32:22.245 | GCG5.COMEX [CBV] #14 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2024-12-26 10:42:00. Next Bar Date Time: 2024-12-26 10:40:00. Filename: GCG5.COMEX.scid
2025-01-05 14:32:22.287 | 6AH5.CME [CBV] Daily #6 | Waiting for historical downloads to complete with the IDs: 17,
2025-01-05 14:32:22.349 | 6AH5.CME [CBV] 240 Min #7 | Reloading chart.
2025-01-05 14:32:22.550 | 6AH5.CME [CBV] 240 Min #7 | Waiting for historical downloads to complete with the IDs: 16, 17,
2025-01-05 14:32:22.655 | 6AH5.CME [CBV] 60 Min #8 | Reloading chart.
2025-01-05 14:32:22.742 | 6AH5.CME [CBV] 60 Min #8 | Waiting for historical downloads to complete with the IDs: 16, 17,
2025-01-05 14:32:22.799 | 6AH5.CME 5 Min #11 | Reloading chart.
2025-01-05 14:32:22.826 | 6AH5.CME [CBV] 30 Min #17 | Reloading chart.
2025-01-05 14:32:22.841 | 6AH5.CME [CBV] 30 Min #17 | Waiting for historical downloads to complete with the IDs: 16, 17,
2025-01-05 14:32:22.887 | 6AH5.CME [CBV] 15 Min #10 | Reloading chart.
2025-01-05 14:32:23.036 | 6AH5.CME [CBV] 15 Min #10 | Waiting for historical downloads to complete with the IDs: 16, 17,
2025-01-05 14:32:23.056 | 6AH5.CME 15 Min #12 | Reloading chart.
2025-01-05 14:32:23.102 | 6AH5.CME Rev. 16t-20 #13 | Reloading chart.
2025-01-05 14:32:23.380 | ESH5.CME #9 | Reloading chart.
2025-01-05 14:32:23.384 | ESH5.CME #9 | StartDateTimeForLoadingOrderFills: 2023-12-30 00:00:00
2025-01-05 14:32:23.384 | ESH5.CME #9 | Chart data loading complete.
2025-01-05 14:32:23.409 | M6AH5.CME 60 Min #1 | Reloading chart.
2025-01-05 14:32:23.684 | 6AH5.CME #18 | Reloading chart.
2025-01-05 14:32:23.685 | 6AH5.CME #18 | StartDateTimeForLoadingOrderFills: 2023-12-30 00:00:00
2025-01-05 14:32:23.685 | 6AH5.CME #18 | Chart data loading complete.
2025-01-05 14:32:23.734 | Denali Data Feed | Setting external service identifier for symbol SIH5.COMEX to 5556
2025-01-05 14:32:23.734 | Denali Data Feed | Received security definition for symbol SIH5.COMEX
2025-01-05 14:32:23.735 | MNQH5.CME [CBV] 1 Min #10 | StartDateTimeForLoadingOrderFills: 2023-12-28 00:00:00
2025-01-05 14:32:23.802 | MNQH5.CME [CBV] 1 Min #10 | Chart data loading complete.
2025-01-05 14:32:23.803 | Mapping 6AH5.CME to 6AH25. Service code: cme
2025-01-05 14:32:23.803 | HD Request # 16 | Downloading Intraday chart data for 6AH5.CME to the file 6AH5.CME.scid. Service: cme
2025-01-05 14:32:23.803 | HD Request # 16 | Download start date-time: 2025-01-03 16:07:47.000000. File last date-time: 2025-01-03 16:07:47.212000
2025-01-05 14:32:23.803 | HD Request # 16 | Using server: ds32.sierracharts.com port 10150
2025-01-05 14:32:23.803 | Socket (4) | Creating socket.
2025-01-05 14:32:23.803 | Socket (4) | New receive buffer size: 0
2025-01-05 14:32:23.803 | Socket (4) | Connecting to IP: 67.214.125.3.
2025-01-05 14:32:23.804 | HD Request # 17 | Downloading Historical Daily chart data for 6AH5.CME. Starting date: 2024-12-30. Service: rithmic.trading
2025-01-05 14:32:24.081 | NQH5.CME [CBV] #16 | Chart data loading complete.
2025-01-05 14:32:24.085 | NQH5.CME [CBV] 30 Min #8 | StartDateTimeForLoadingOrderFills: 2023-12-28 00:00:00
2025-01-05 14:32:24.097 | NQH5.CME [CBV] 30 Min #8 | Chart data loading complete.
2025-01-05 14:32:24.307 | HD Request # 16 | Setting DTC encoding to Binary VLS
2025-01-05 14:32:24.307 | HD Request # 16 | Sending historical data logon request message.
2025-01-05 14:32:24.511 | GCG5.COMEX [CBV] #14 | Chart data loading complete.
2025-01-05 14:32:24.522 | 6AH5.CME 5 Min #11 | StartDateTimeForLoadingOrderFills: 2023-12-28 00:00:00
2025-01-05 14:32:24.596 | HD Request # 16 | Requesting Intraday data. Start date-time: 2025-01-03 16:07:47. Record interval: 0. Symbol: 6AH25
2025-01-05 14:32:24.611 | 6AH5.CME 5 Min #11 | Chart data loading complete.
2025-01-05 14:32:24.621 | 6AH5.CME 15 Min #12 | StartDateTimeForLoadingOrderFills: 2023-12-28 00:00:00
2025-01-05 14:32:24.626 | 6AH5.CME 15 Min #12 | Chart data loading complete.
2025-01-05 14:32:24.628 | 6AH5.CME Rev. 16t-20 #13 | StartDateTimeForLoadingOrderFills: 2023-12-28 00:00:00
2025-01-05 14:32:24.629 | 6AH5.CME Rev. 16t-20 #13 | Chart data loading complete.
2025-01-05 14:32:24.770 | M6AH5.CME 60 Min #1 | StartDateTimeForLoadingOrderFills: 2023-12-28 00:00:00
2025-01-05 14:32:24.770 | M6AH5.CME 60 Min #1 | Chart data loading complete.
2025-01-05 14:32:24.845 | HD Request # 16 | Decompressing data.
2025-01-05 14:32:24.850 | GCG5.COMEX [CBV] 30 Min #17 | Download is complete for all contract months in chart. Proceeding with data load.
2025-01-05 14:32:24.851 | GCG5.COMEX [CBV] 30 Min #17 | Reloading chart.
2025-01-05 14:32:24.943 | GCG5.COMEX [CBV] 240 Min #7 | Download is complete for all contract months in chart. Proceeding with data load.
2025-01-05 14:32:24.943 | GCG5.COMEX [CBV] 240 Min #7 | Reloading chart.
2025-01-05 14:32:25.095 | HD Request # 16 | Receiving Intraday data for 6AH5.CME starting at 2025-01-03 16:07:47.212000
2025-01-05 14:32:25.095 | Socket (4) | CloseSocket call.
2025-01-05 14:32:25.095 | Socket (4) | Shutdown started. Waiting for graceful close.
2025-01-05 14:32:25.344 | Socket (4) | Socket gracefully closed by remote side.
2025-01-05 14:32:25.344 | Socket (4) | Closed.
2025-01-05 14:32:25.423 | Historical data download thread signaled to stop.
2025-01-05 14:32:25.423 | HD Request # 16 | Timestamp of first Intraday data file record written: 2025-01-03 16:08:36.712000.
2025-01-05 14:32:25.423 | HD Request # 16 | Received 308 Intraday data records from 2025-01-03 16:07:47.212000 to 2025-01-03 16:59:55.751000 (52.1 minutes. Delay: 45.5 hours) and wrote 307 records for 6AH5.CME
2025-01-05 14:32:25.425 | HD Request # 16 | Add time&sales data | Remembered last file record date-time: 2025-01-03 21:59:55.751000
2025-01-05 14:32:25.425 | HD Request # 16 | Completion time: 2s.
2025-01-05 14:32:25.425 | HD Request # 16 | Intraday data download complete for 6AH5.CME. Unique request ID: 16
2025-01-05 14:32:25.425 | Removing historical data download ID 16.
2025-01-05 14:32:25.425 | Real-time Intraday chart data file updates started for 6AH5.CME
2025-01-05 14:32:25.425 | Intraday chart data file opened for 6AH5.CME
2025-01-05 14:32:25.425 | HD Request # 16 | Enabling Intraday chart updating for symbol.
2025-01-05 14:32:25.425 | No download requests in the queue to start downloads for.
2025-01-05 14:32:25.593 | HD Request # 17 | Requesting historical Daily data for A6H25 starting at 2024-12-29. SC External HD service.
2025-01-05 14:32:25.600 | GCG5.COMEX [CBV] 30 Min #17 | StartDateTimeForLoadingOrderFills: 2023-12-28 00:00:00
2025-01-05 14:32:25.606 | GCG5.COMEX [CBV] 30 Min #17 | Chart data loading complete.
2025-01-05 14:32:25.671 | GCG5.COMEX [CBV] #14 | Reloading chart.
2025-01-05 14:32:26.341 | GCG5.COMEX [CBV] 15 Min #10 | Reloading chart.
2025-01-05 14:32:27.069 | GCG5.COMEX [CBV] 60 Min #8 | Chart data loading complete.
2025-01-05 14:32:27.069 | HD Request # 17 | Receiving historical Daily data for 6AH5.CME starting at 2024-12-30.
2025-01-05 14:32:27.069 | HD Request # 17 | Writing historical Daily data to the file 6AH5.CME.dly.
2025-01-05 14:32:27.132 | HD Request # 17 | Bytes received: 232
2025-01-05 14:32:27.132 | HD Request # 17 | Received 4 Daily data records from 2024-12-30 00:00:00 to 2025-01-03 00:00:00 (5.0 days) and wrote 4 records for 6AH5.CME
2025-01-05 14:32:27.132 | HD Request # 17 | Completion time: 4s.
2025-01-05 14:32:27.132 | HD Request # 17 | Daily data download complete for 6AH5.CME. Unique request ID: 17
2025-01-05 14:32:27.132 | Removing historical data download ID 17.
2025-01-05 14:32:27.133 |
2025-01-05 14:32:27.133 | No download requests in the queue to start downloads for.
2025-01-05 14:32:27.140 | SIH5.COMEX [CBV] #14 | Download is complete for all contract months in chart. Proceeding with data load.
2025-01-05 14:32:27.140 | SIH5.COMEX [CBV] #14 | Reloading chart.
2025-01-05 14:32:27.508 | SIH5.COMEX [CBV] #3 | Download is complete for all contract months in chart. Proceeding with data load.
2025-01-05 14:32:27.508 | SIH5.COMEX [CBV] #3 | Reloading chart.
2025-01-05 14:32:27.911 | SIH5.COMEX [CBV] 240 Min #15 | Download is complete for all contract months in chart. Proceeding with data load.
2025-01-05 14:32:27.911 | SIH5.COMEX [CBV] 240 Min #15 | Reloading chart.
2025-01-05 14:32:28.277 | SIH5.COMEX [CBV] Monthly #4 | Download is complete for all contract months in chart. Proceeding with data load.
2025-01-05 14:32:28.278 | SIH5.COMEX [CBV] Monthly #4 | Reloading chart.
2025-01-05 14:32:29.429 | SIH5.COMEX [CBV] Weekly #5 | Download is complete for all contract months in chart. Proceeding with data load.
2025-01-05 14:32:29.430 | SIH5.COMEX [CBV] Weekly #5 | Reloading chart.
2025-01-05 14:32:30.472 | GCG5.COMEX [CBV] 240 Min #15 | Chart data loading complete.
2025-01-05 14:32:30.476 | SIH5.COMEX [CBV] Monthly #4 | Chart data loading complete.
2025-01-05 14:32:30.476 | SIH5.COMEX [CBV] Daily #6 | Download is complete for all contract months in chart. Proceeding with data load.
2025-01-05 14:32:30.477 | SIH5.COMEX [CBV] Daily #6 | Reloading chart.
2025-01-05 14:32:31.594 | SIH5.COMEX [CBV] Weekly #5 | Chart data loading complete.
2025-01-05 14:32:31.596 | SIH5.COMEX [CBV] 240 Min #7 | Download is complete for all contract months in chart. Proceeding with data load.
2025-01-05 14:32:31.597 | SIH5.COMEX [CBV] 240 Min #7 | Reloading chart.
2025-01-05 14:32:32.217 | SIH5.COMEX [CBV] Daily #6 | Chart data loading complete.
2025-01-05 14:32:32.217 | SIH5.COMEX [CBV] 60 Min #8 | Download is complete for all contract months in chart. Proceeding with data load.
2025-01-05 14:32:32.218 | SIH5.COMEX [CBV] 60 Min #8 | Reloading chart.
2025-01-05 14:32:32.310 | SIH5.COMEX [CBV] #14 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2024-12-26 09:57:00. Next Bar Date Time: 2024-12-26 09:55:00. Filename: SIH5.COMEX.scid
2025-01-05 14:32:32.770 | SIH5.COMEX [CBV] #14 | Chart data loading complete.
2025-01-05 14:32:32.773 | SIH5.COMEX [CBV] 240 Min #15 | Chart data loading complete.
2025-01-05 14:32:32.776 | SIH5.COMEX [CBV] 30 Min #17 | Download is complete for all contract months in chart. Proceeding with data load.
2025-01-05 14:32:32.777 | SIH5.COMEX [CBV] 30 Min #17 | Reloading chart.
2025-01-05 14:32:32.850 | SIH5.COMEX [CBV] 15 Min #10 | Download is complete for all contract months in chart. Proceeding with data load.
2025-01-05 14:32:32.851 | SIH5.COMEX [CBV] 15 Min #10 | Reloading chart.
2025-01-05 14:32:33.360 | SIH5.COMEX [CBV] 30 Min #17 | StartDateTimeForLoadingOrderFills: 2023-12-28 00:00:00
2025-01-05 14:32:33.363 | SIH5.COMEX [CBV] 30 Min #17 | Chart data loading complete.
2025-01-05 14:32:33.412 | Mapping SILH5.COMEX to SILH25. Service code: comex
2025-01-05 14:32:33.412 | Denali Data Feed | Starting real-time market data updates for: SILH5.COMEX (SILH25). ID: 14 Service code: comex
2025-01-05 14:32:33.412 | Denali Data Feed | Requesting security definition data for: SILH5.COMEX (SILH25). ID: 14
2025-01-05 14:32:33.412 | Added historical Intraday data request for SILH5.COMEX to the queue.
2025-01-05 14:32:33.412 | Intraday data recording state for symbol SILH5.COMEX is set to download 'Pending'.
2025-01-05 14:32:33.412 | Triggering next historical data download in queue.
2025-01-05 14:32:33.412 | Delaying start of download for SILH5.COMEX.
2025-01-05 14:32:33.416 | Added historical Intraday data request for USDX to the queue.
2025-01-05 14:32:33.416 | Intraday data recording state for symbol USDX is set to download 'Pending'.
2025-01-05 14:32:33.416 | Triggering next historical data download in queue.
2025-01-05 14:32:33.418 | GCG5.COMEX [CBV] #3 | Reloading chart.
2025-01-05 14:32:34.495 | Denali Data Feed | Setting external service identifier for symbol SILH5.COMEX to 42007667
2025-01-05 14:32:34.495 | Denali Data Feed | Received security definition for symbol SILH5.COMEX
2025-01-05 14:32:34.538 | GCG5.COMEX [CBV] 60 Min #8 | Reloading chart.
2025-01-05 14:32:34.942 | GCG5.COMEX [CBV] 240 Min #15 | Reloading chart.
2025-01-05 14:32:36.213 | SIH5.COMEX [CBV] #3 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2024-12-26 09:57:00. Next Bar Date Time: 2024-12-26 09:55:00. Filename: SIH5.COMEX.scid
2025-01-05 14:32:36.252 | 6AH5.CME [CBV] #14 | Download is complete for all contract months in chart. Proceeding with data load.
2025-01-05 14:32:36.252 | 6AH5.CME [CBV] #14 | Reloading chart.
2025-01-05 14:32:37.961 | SIH5.COMEX [CBV] #3 | Chart data loading complete.
2025-01-05 14:32:37.963 | SIH5.COMEX [CBV] 60 Min #8 | StartDateTimeForLoadingOrderFills: 2023-12-28 00:00:00
2025-01-05 14:32:38.061 | SIH5.COMEX [CBV] 60 Min #8 | Chart data loading complete.
2025-01-05 14:32:38.153 | 6AH5.CME [CBV] #3 | Download is complete for all contract months in chart. Proceeding with data load.
2025-01-05 14:32:38.153 | 6AH5.CME [CBV] #3 | Reloading chart.
2025-01-05 14:32:38.813 | GCG5.COMEX [CBV] #3 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2024-12-26 10:42:00. Next Bar Date Time: 2024-12-26 10:40:00. Filename: GCG5.COMEX.scid
2025-01-05 14:32:39.261 | GCG5.COMEX [CBV] #14 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2024-12-26 10:42:00. Next Bar Date Time: 2024-12-26 10:40:00. Filename: GCG5.COMEX.scid
2025-01-05 14:32:39.624 | ESH5.CME [CBV][M] 60 Min #8 | Chart data loading complete.
2025-01-05 14:32:40.201 | GCG5.COMEX [CBV] #3 | Chart data loading complete.
2025-01-05 14:32:40.643 | GCG5.COMEX [CBV] #14 | Chart data loading complete.
2025-01-05 14:32:40.648 | SIH5.COMEX [CBV] 240 Min #7 | Chart data loading complete.
2025-01-05 14:32:40.798 | GCG5.COMEX [CBV] 15 Min #10 | Chart data loading complete.
2025-01-05 14:32:40.858 | SIH5.COMEX [CBV] 15 Min #10 | Chart data loading complete.
2025-01-05 14:32:40.859 | Denali Data Feed | Starting real-time market data updates for: 6AH5.CME (6AH25). ID: 13 Service code: cme
2025-01-05 14:32:40.859 | Denali Data Feed | Requesting security definition data for: 6AH5.CME (6AH25). ID: 13
2025-01-05 14:32:40.859 | Requesting market depth updates for: 6AH5.CME if supported. NumLevels=50
2025-01-05 14:32:40.859 | 6AH5.CME [CBV] 60 Min #15 | Download is complete for all contract months in chart. Proceeding with data load.
2025-01-05 14:32:40.859 | 6AH5.CME [CBV] 60 Min #15 | Reloading chart.
2025-01-05 14:32:41.391 | 6AH5.CME [CBV] Monthly #4 | Download is complete for all contract months in chart. Proceeding with data load.
2025-01-05 14:32:41.392 | 6AH5.CME [CBV] Monthly #4 | Reloading chart.
2025-01-05 14:32:41.650 | Denali Data Feed | Clearing market depth for 6AH5.CME
2025-01-05 14:32:42.700 | Denali Data Feed | Setting external service identifier for symbol 6AH5.CME to 52126
2025-01-05 14:32:42.700 | Denali Data Feed | Received security definition for symbol 6AH5.CME
2025-01-05 14:32:43.011 | NQH5.CME [CBV][M] 60 Min #11 | Chart data loading complete.
2025-01-05 14:32:43.188 | 6AH5.CME [CBV] #14 | Chart data loading complete.
2025-01-05 14:32:43.189 | 6AH5.CME [CBV] Monthly #4 | Chart data loading complete.
2025-01-05 14:32:43.268 | GCG5.COMEX [CBV] 60 Min #8 | Chart data loading complete.
2025-01-05 14:32:43.269 | 6AH5.CME [CBV] Weekly #5 | Download is complete for all contract months in chart. Proceeding with data load.
2025-01-05 14:32:43.270 | 6AH5.CME [CBV] Weekly #5 | Reloading chart.
2025-01-05 14:32:44.471 | 6AH5.CME [CBV] 60 Min #15 | Chart data loading complete.
2025-01-05 14:32:44.471 | 6AH5.CME [CBV] Daily #6 | Download is complete for all contract months in chart. Proceeding with data load.
2025-01-05 14:32:44.472 | 6AH5.CME [CBV] Daily #6 | Reloading chart.
2025-01-05 14:32:45.621 | 6AH5.CME [CBV] Weekly #5 | Chart data loading complete.
2025-01-05 14:32:45.623 | GCG5.COMEX [CBV] 240 Min #15 | Chart data loading complete.
2025-01-05 14:32:45.624 | 6AH5.CME [CBV] 240 Min #7 | Download is complete for all contract months in chart. Proceeding with data load.
2025-01-05 14:32:45.624 | 6AH5.CME [CBV] 240 Min #7 | Reloading chart.
2025-01-05 14:32:46.145 | 6AH5.CME [CBV] Daily #6 | Chart data loading complete.
2025-01-05 14:32:46.343 | GCG5.COMEX [CBV] 240 Min #7 | Chart data loading complete.
2025-01-05 14:32:46.347 | 6AH5.CME [CBV] 60 Min #8 | Download is complete for all contract months in chart. Proceeding with data load.
2025-01-05 14:32:46.348 | 6AH5.CME [CBV] 60 Min #8 | Reloading chart.
2025-01-05 14:32:46.610 | 6AH5.CME [CBV] 30 Min #17 | Download is complete for all contract months in chart. Proceeding with data load.
2025-01-05 14:32:46.611 | 6AH5.CME [CBV] 30 Min #17 | Reloading chart.
2025-01-05 14:32:46.699 | 6AH5.CME [CBV] 15 Min #10 | Download is complete for all contract months in chart. Proceeding with data load.
2025-01-05 14:32:46.700 | 6AH5.CME [CBV] 15 Min #10 | Reloading chart.
2025-01-05 14:32:47.357 | 6AH5.CME [CBV] 30 Min #17 | StartDateTimeForLoadingOrderFills: 2023-12-28 00:00:00
2025-01-05 14:32:47.363 | 6AH5.CME [CBV] 30 Min #17 | Chart data loading complete.
2025-01-05 14:32:47.367 | Mapping M6AH5.CME to M6AH25. Service code: cme
2025-01-05 14:32:47.367 | Denali Data Feed | Starting real-time market data updates for: M6AH5.CME (M6AH25). ID: 15 Service code: cme
2025-01-05 14:32:47.367 | Denali Data Feed | Requesting security definition data for: M6AH5.CME (M6AH25). ID: 15
2025-01-05 14:32:47.367 | Added historical Intraday data request for M6AH5.CME to the queue.
2025-01-05 14:32:47.367 | Intraday data recording state for symbol M6AH5.CME is set to download 'Pending'.
2025-01-05 14:32:47.367 | Triggering next historical data download in queue.
2025-01-05 14:32:47.417 | GCG5.COMEX [CBV] 30 Min #17 | Reloading chart.
2025-01-05 14:32:47.544 | GCG5.COMEX [CBV] 240 Min #7 | Reloading chart.
2025-01-05 14:32:48.607 | 6AH5.CME [CBV] #3 | Chart data loading complete.
2025-01-05 14:32:48.607 | Denali Data Feed | Setting external service identifier for symbol M6AH5.CME to 42185124
2025-01-05 14:32:48.607 | Denali Data Feed | Received security definition for symbol M6AH5.CME
2025-01-05 14:32:48.611 | GCG5.COMEX [CBV] 30 Min #17 | StartDateTimeForLoadingOrderFills: 2023-12-28 00:00:00
2025-01-05 14:32:48.618 | GCG5.COMEX [CBV] 30 Min #17 | Chart data loading complete.
2025-01-05 14:32:48.783 | 6AH5.CME [CBV] 60 Min #8 | StartDateTimeForLoadingOrderFills: 2023-12-28 00:00:00
2025-01-05 14:32:48.840 | 6AH5.CME [CBV] 60 Min #8 | Chart data loading complete.
2025-01-05 14:32:48.882 | HD Request # 18 | Downloading Intraday chart data for SILH5.COMEX to the file SILH5.COMEX.scid. Service: comex
2025-01-05 14:32:48.882 | HD Request # 18 | Download start date-time: 2025-01-03 16:07:36.000000. File last date-time: 2025-01-03 16:07:36.514000
2025-01-05 14:32:48.882 | HD Request # 18 | Using server: ds32.sierracharts.com port 10149
2025-01-05 14:32:48.882 | Socket (3) | Creating socket.
2025-01-05 14:32:48.883 | Socket (3) | New receive buffer size: 0
2025-01-05 14:32:48.883 | Socket (3) | Connecting to IP: 67.214.125.3.
2025-01-05 14:32:49.237 | SIH5.COMEX [CBV] #14 | Reloading chart.
2025-01-05 14:32:49.350 | HD Request # 18 | Setting DTC encoding to Binary VLS
2025-01-05 14:32:49.350 | HD Request # 18 | Sending historical data logon request message.
2025-01-05 14:32:49.626 | HD Request # 18 | Requesting Intraday data. Start date-time: 2025-01-03 16:07:36. Record interval: 0. Symbol: SILH25
2025-01-05 14:32:49.811 | SIH5.COMEX [CBV] #3 | Reloading chart.
2025-01-05 14:32:49.857 | HD Request # 18 | Decompressing data.
2025-01-05 14:32:50.089 | HD Request # 18 | Receiving Intraday data for SILH5.COMEX starting at 2025-01-03 16:07:36.514000
2025-01-05 14:32:50.089 | Socket (3) | CloseSocket call.
2025-01-05 14:32:50.089 | Socket (3) | Shutdown started. Waiting for graceful close.
2025-01-05 14:32:50.300 | Historical data download thread signaled to stop.
2025-01-05 14:32:50.300 | HD Request # 18 | Timestamp of first Intraday data file record written: 2025-01-03 16:10:27.610000.
2025-01-05 14:32:50.300 | HD Request # 18 | Received 179 Intraday data records from 2025-01-03 16:07:36.514000 to 2025-01-03 16:59:52.448000 (52.3 minutes. Delay: 45.5 hours) and wrote 178 records for SILH5.COMEX
2025-01-05 14:32:50.302 | HD Request # 18 | Add time&sales data | Remembered last file record date-time: 2025-01-03 21:59:52.448000
2025-01-05 14:32:50.302 | HD Request # 18 | Completion time: 2s.
2025-01-05 14:32:50.302 | HD Request # 18 | Intraday data download complete for SILH5.COMEX. Unique request ID: 18
2025-01-05 14:32:50.302 | Removing historical data download ID 18.
2025-01-05 14:32:50.302 | Real-time Intraday chart data file updates started for SILH5.COMEX
2025-01-05 14:32:50.302 | Intraday chart data file opened for SILH5.COMEX
2025-01-05 14:32:50.302 | HD Request # 18 | Enabling Intraday chart updating for symbol.
2025-01-05 14:32:50.302 | Triggering next historical data download in queue.
2025-01-05 14:32:50.302 | HD Request # 19 | Downloading Intraday chart data for USDX to the file USDX.scid. Service: fxstatscalc
2025-01-05 14:32:50.302 | HD Request # 19 | Download start date-time: 2025-01-03 16:08:18.000000. File last date-time: 2025-01-03 16:08:18.000000
2025-01-05 14:32:50.302 | HD Request # 19 | Using server: ds12.sierracharts.com port 10150
2025-01-05 14:32:50.303 | SIH5.COMEX [CBV] 240 Min #15 | Reloading chart.
2025-01-05 14:32:50.304 | Socket (4) | Creating socket.
2025-01-05 14:32:50.304 | Socket (4) | New receive buffer size: 0
2025-01-05 14:32:50.304 | Socket (4) | Connecting to IP: 69.39.70.241.
2025-01-05 14:32:50.321 | Socket (3) | Socket gracefully closed by remote side.
2025-01-05 14:32:50.321 | Socket (3) | Closed.
2025-01-05 14:32:50.814 | HD Request # 19 | Setting DTC encoding to Binary VLS
2025-01-05 14:32:50.814 | HD Request # 19 | Sending historical data logon request message.
2025-01-05 14:32:50.890 | SIH5.COMEX [CBV] Monthly #4 | Reloading chart.
2025-01-05 14:32:50.890 | SIH5.COMEX [CBV] Monthly #4 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2025-01-05 14:32:50.890 | SIH5.COMEX [CBV] Monthly #4 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2025-01-05 14:32:51.109 | HD Request # 19 | Requesting Intraday data. Start date-time: 2025-01-03 16:08:18. Record interval: 0. Symbol: USDX
2025-01-05 14:32:51.351 | HD Request # 19 | Decompressing data.
2025-01-05 14:32:51.831 | HD Request # 19 | Receiving Intraday data for USDX starting at 2025-01-03 16:08:18.000000
2025-01-05 14:32:52.065 | Socket (4) | CloseSocket call.
2025-01-05 14:32:52.065 | Socket (4) | Shutdown started. Waiting for graceful close.
2025-01-05 14:32:52.301 | Socket (4) | Socket gracefully closed by remote side.
2025-01-05 14:32:52.301 | Socket (4) | Closed.
2025-01-05 14:32:52.547 | Historical data download thread signaled to stop.
2025-01-05 14:32:52.548 | HD Request # 19 | Timestamp of first Intraday data file record written: 2025-01-03 16:08:20.000000.
2025-01-05 14:32:52.548 | HD Request # 19 | Received 2554 Intraday data records from 2025-01-03 16:08:18.000000 to 2025-01-03 16:59:44.000000 (51.4 minutes. Delay: 45.6 hours) and wrote 2553 records for USDX
2025-01-05 14:32:52.551 | HD Request # 19 | Add time&sales data | Remembered last file record date-time: 2025-01-03 21:59:44.000000
2025-01-05 14:32:52.551 | HD Request # 19 | Completion time: 2s.
2025-01-05 14:32:52.551 | HD Request # 19 | Intraday data download complete for USDX. Unique request ID: 19
2025-01-05 14:32:52.551 | Removing historical data download ID 19.
2025-01-05 14:32:52.551 | Real-time Intraday chart data file updates started for USDX
2025-01-05 14:32:52.551 | Intraday chart data file opened for USDX
2025-01-05 14:32:52.551 | HD Request # 19 | Enabling Intraday chart updating for symbol.
2025-01-05 14:32:52.551 | Triggering next historical data download in queue.
2025-01-05 14:32:52.551 | Delaying start of download for M6AH5.CME.
2025-01-05 14:32:52.553 | SIH5.COMEX [CBV] Weekly #5 | Reloading chart.
2025-01-05 14:32:52.553 | SIH5.COMEX [CBV] Weekly #5 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2025-01-05 14:32:52.553 | SIH5.COMEX [CBV] Weekly #5 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2025-01-05 14:32:53.559 | SIH5.COMEX [CBV] #14 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2024-12-26 09:57:00. Next Bar Date Time: 2024-12-26 09:55:00. Filename: SIH5.COMEX.scid
2025-01-05 14:32:53.850 | SIH5.COMEX [CBV] Monthly #4 | Chart data loading complete.
2025-01-05 14:32:53.897 | 6AH5.CME [CBV] 240 Min #7 | Chart data loading complete.
2025-01-05 14:32:54.057 | SIH5.COMEX [CBV] #14 | Chart data loading complete.
2025-01-05 14:32:54.059 | SIH5.COMEX [CBV] Weekly #5 | Chart data loading complete.
2025-01-05 14:32:54.060 | SIH5.COMEX [CBV] Daily #6 | Reloading chart.
2025-01-05 14:32:54.060 | SIH5.COMEX [CBV] Daily #6 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2025-01-05 14:32:54.060 | SIH5.COMEX [CBV] Daily #6 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2025-01-05 14:32:55.308 | SIH5.COMEX [CBV] 240 Min #15 | Chart data loading complete.
2025-01-05 14:32:55.312 | NQH5.CME [CBV][M] 60 Min #14 | Chart data loading complete.
2025-01-05 14:32:55.313 | 6AH5.CME [CBV] 15 Min #10 | StartDateTimeForLoadingOrderFills: 2023-12-28 00:00:00
2025-01-05 14:32:55.372 | 6AH5.CME [CBV] 15 Min #10 | Chart data loading complete.
2025-01-05 14:32:55.433 | SIH5.COMEX [CBV] 240 Min #7 | Reloading chart.
2025-01-05 14:32:55.920 | SIH5.COMEX [CBV] Daily #6 | Chart data loading complete.
2025-01-05 14:32:55.922 | SIH5.COMEX [CBV] 60 Min #8 | Reloading chart.
2025-01-05 14:32:56.152 | SIH5.COMEX [CBV] 30 Min #17 | Reloading chart.
2025-01-05 14:32:56.221 | SIH5.COMEX [CBV] 15 Min #10 | Reloading chart.
2025-01-05 14:32:56.739 | SIH5.COMEX [CBV] 30 Min #17 | StartDateTimeForLoadingOrderFills: 2023-12-28 00:00:00
2025-01-05 14:32:56.741 | SIH5.COMEX [CBV] 30 Min #17 | Chart data loading complete.
2025-01-05 14:32:56.891 | 6AH5.CME [CBV] #14 | Reloading chart.
2025-01-05 14:32:57.548 | SIH5.COMEX [CBV] #3 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2024-12-26 09:57:00. Next Bar Date Time: 2024-12-26 09:55:00. Filename: SIH5.COMEX.scid
2025-01-05 14:32:57.814 | SIH5.COMEX [CBV] #3 | Chart data loading complete.
2025-01-05 14:32:57.824 | 6AH5.CME [CBV] #3 | Reloading chart.
2025-01-05 14:32:58.520 | 6AH5.CME [CBV] 60 Min #15 | Reloading chart.
2025-01-05 14:32:59.310 | SIH5.COMEX [CBV] 60 Min #8 | StartDateTimeForLoadingOrderFills: 2023-12-28 00:00:00
2025-01-05 14:32:59.367 | SIH5.COMEX [CBV] 60 Min #8 | Chart data loading complete.
2025-01-05 14:32:59.443 | 6AH5.CME [CBV] Monthly #4 | Reloading chart.
2025-01-05 14:32:59.443 | 6AH5.CME [CBV] Monthly #4 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2025-01-05 14:32:59.443 | 6AH5.CME [CBV] Monthly #4 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2025-01-05 14:33:01.385 | 6AH5.CME [CBV] #14 | Chart data loading complete.
2025-01-05 14:33:01.386 | 6AH5.CME [CBV] Weekly #5 | Reloading chart.
2025-01-05 14:33:01.386 | 6AH5.CME [CBV] Weekly #5 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2025-01-05 14:33:01.386 | 6AH5.CME [CBV] Weekly #5 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2025-01-05 14:33:02.738 | 6AH5.CME [CBV] Monthly #4 | Chart data loading complete.
2025-01-05 14:33:02.743 | 6AH5.CME [CBV] 60 Min #15 | Chart data loading complete.
2025-01-05 14:33:02.744 | 6AH5.CME [CBV] Daily #6 | Reloading chart.
2025-01-05 14:33:02.744 | 6AH5.CME [CBV] Daily #6 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2025-01-05 14:33:02.744 | 6AH5.CME [CBV] Daily #6 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2025-01-05 14:33:03.906 | SIH5.COMEX [CBV] 15 Min #10 | Chart data loading complete.
2025-01-05 14:33:03.908 | 6AH5.CME [CBV] Weekly #5 | Chart data loading complete.
2025-01-05 14:33:03.912 | SIH5.COMEX [CBV] 240 Min #7 | Chart data loading complete.
2025-01-05 14:33:03.915 | ESH5.CME [CBV][M] 240 Min #15 | Chart data loading complete.
2025-01-05 14:33:03.916 | 6AH5.CME [CBV] 240 Min #7 | Reloading chart.
2025-01-05 14:33:04.466 | 6AH5.CME [CBV] Daily #6 | Chart data loading complete.
2025-01-05 14:33:04.489 | 6AH5.CME [CBV] 60 Min #8 | Reloading chart.
2025-01-05 14:33:04.735 | 6AH5.CME [CBV] 30 Min #17 | Reloading chart.
2025-01-05 14:33:04.803 | 6AH5.CME [CBV] 15 Min #10 | Reloading chart.
2025-01-05 14:33:05.575 | 6AH5.CME [CBV] #3 | Chart data loading complete.
2025-01-05 14:33:05.576 | 6AH5.CME [CBV] 30 Min #17 | StartDateTimeForLoadingOrderFills: 2023-12-28 00:00:00
2025-01-05 14:33:05.579 | 6AH5.CME [CBV] 30 Min #17 | Chart data loading complete.
2025-01-05 14:33:05.763 | GCG5.COMEX [CBV] 240 Min #7 | Chart data loading complete.
2025-01-05 14:33:06.024 | HD Request # 20 | Downloading Intraday chart data for M6AH5.CME to the file M6AH5.CME.scid. Service: cme
2025-01-05 14:33:06.024 | HD Request # 20 | Download start date-time: 2025-01-03 16:07:21.000000. File last date-time: 2025-01-03 16:07:21.377000
2025-01-05 14:33:06.024 | HD Request # 20 | Using server: ds32.sierracharts.com port 10149
2025-01-05 14:33:06.024 | Socket (3) | Creating socket.
2025-01-05 14:33:06.024 | Socket (3) | New receive buffer size: 0
2025-01-05 14:33:06.024 | Socket (3) | Connecting to IP: 67.214.125.3.
2025-01-05 14:33:06.523 | HD Request # 20 | Setting DTC encoding to Binary VLS
2025-01-05 14:33:06.523 | HD Request # 20 | Sending historical data logon request message.
2025-01-05 14:33:06.567 | 6AH5.CME [CBV][M] 60 Min #8 | StartDateTimeForLoadingOrderFills: 2023-12-28 00:00:00
2025-01-05 14:33:06.598 | 6AH5.CME [CBV][M] 60 Min #8 | Chart data loading complete.
2025-01-05 14:33:06.769 | HD Request # 20 | Requesting Intraday data. Start date-time: 2025-01-03 16:07:21. Record interval: 0. Symbol: M6AH25
2025-01-05 14:33:07.015 | HD Request # 20 | Decompressing data.
2025-01-05 14:33:07.261 | HD Request # 20 | Receiving Intraday data for M6AH5.CME starting at 2025-01-03 16:07:21.377000
2025-01-05 14:33:07.261 | Socket (3) | CloseSocket call.
2025-01-05 14:33:07.261 | Socket (3) | Shutdown started. Waiting for graceful close.
2025-01-05 14:33:07.261 | Historical data download thread signaled to stop.
2025-01-05 14:33:07.261 | HD Request # 20 | Timestamp of first Intraday data file record written: 2025-01-03 16:09:00.152000.
2025-01-05 14:33:07.261 | HD Request # 20 | Received 81 Intraday data records from 2025-01-03 16:07:21.377000 to 2025-01-03 16:59:54.460001 (52.6 minutes. Delay: 45.6 hours) and wrote 80 records for M6AH5.CME
2025-01-05 14:33:07.262 | HD Request # 20 | Add time&sales data | Remembered last file record date-time: 2025-01-03 21:59:54.460001
2025-01-05 14:33:07.262 | HD Request # 20 | Completion time: 1s.
2025-01-05 14:33:07.262 | HD Request # 20 | Intraday data download complete for M6AH5.CME. Unique request ID: 20
2025-01-05 14:33:07.262 | Removing historical data download ID 20.
2025-01-05 14:33:07.262 | Real-time Intraday chart data file updates started for M6AH5.CME
2025-01-05 14:33:07.262 | Intraday chart data file opened for M6AH5.CME
2025-01-05 14:33:07.262 | HD Request # 20 | Enabling Intraday chart updating for symbol.
2025-01-05 14:33:07.262 | No download requests in the queue to start downloads for.
2025-01-05 14:33:07.507 | Socket (3) | Socket gracefully closed by remote side.
2025-01-05 14:33:07.507 | Socket (3) | Closed.
2025-01-05 14:33:10.445 | 6AH5.CME [CBV][M] 15 Min #10 | StartDateTimeForLoadingOrderFills: 2023-12-28 00:00:00
2025-01-05 14:33:10.483 | 6AH5.CME [CBV][M] 15 Min #10 | Chart data loading complete.
2025-01-05 14:33:10.569 | 6AH5.CME [CBV][M] 240 Min #7 | Chart data loading complete.
2025-01-05 14:33:16.286 | NQH5.CME [CBV][M] 15 Min #1 | StartDateTimeForLoadingOrderFills: 2023-12-28 00:00:00
2025-01-05 14:33:16.475 | NQH5.CME [CBV][M] 15 Min #1 | Chart data loading complete.
2025-01-05 14:33:18.979 | NQH5.CME [CBV] #3 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2024-12-26 09:40:00. Next Bar Date Time: 2024-12-26 09:38:00. Filename: NQH5.CME.scid
2025-01-05 14:33:18.986 | NQH5.CME [CBV] #3 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2024-12-26 09:57:00. Next Bar Date Time: 2024-12-26 09:55:00. Filename: NQH5.CME.scid
2025-01-05 14:33:20.337 | NQH5.CME [CBV][M] #3 | Chart data loading complete.
2025-01-05 14:33:23.408 | ESH5.CME [CBV] #14 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2024-12-26 09:40:00. Next Bar Date Time: 2024-12-26 09:38:00. Filename: ESH5.CME.scid
2025-01-05 14:33:24.636 | ESH5.CME [CBV][M] #14 | Chart data loading complete.
2025-01-05 14:33:25.611 | NQH5.CME [CBV][M] 240 Min #7 | Chart data loading complete.
2025-01-05 14:33:37.557 | ESH5.CME [CBV] 10 Min #2 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2024-12-26 09:40:00. Next Bar Date Time: 2024-12-26 09:30:00. Filename: ESH5.CME.scid
2025-01-05 14:33:38.596 | ESH5.CME [CBV][M] 10 Min #2 | Chart data loading complete.
2025-01-05 14:33:40.640 | ESH5.CME [CBV] #3 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2024-12-26 09:40:00. Next Bar Date Time: 2024-12-26 09:38:00. Filename: ESH5.CME.scid
2025-01-05 14:33:41.900 | ESH5.CME [CBV][M] #3 | Chart data loading complete.
2025-01-05 14:33:41.903 | ESH5.CME [CBV][M] 240 Min #7 | Chart data loading complete.
2025-01-05 14:33:45.169 | ESH5.CME [CBV][M] 15 Min #10 | StartDateTimeForLoadingOrderFills: 2023-12-28 00:00:00
2025-01-05 14:33:45.195 | ESH5.CME [CBV][M] 15 Min #10 | Chart data loading complete.
2025-01-05 15:04:38.569 | 6AH5.CME[M] 15 Min #12 | Reloading chart.
2025-01-05 15:04:38.649 | 6AH5.CME[M] 15 Min #12 | StartDateTimeForLoadingOrderFills: 2023-12-28 00:00:00
2025-01-05 15:04:38.655 | 6AH5.CME[M] 15 Min #12 | Chart data loading complete.
2025-01-05 15:06:10.698 | Saved Chartbook: 6A.Cht. Time: 0.0389 seconds.
2025-01-05 15:06:12.830 | Unsubscribed from market depth data for 6AH5.CME
2025-01-05 15:06:14.788 | 6AH5.CME [CBV] #14 | Reloading chart.
2025-01-05 15:06:15.104 | 6AH5.CME [CBV] #3 | Reloading chart.
2025-01-05 15:06:15.420 | 6AH5.CME [CBV] 60 Min #15 | Reloading chart.
2025-01-05 15:06:15.772 | 6AH5.CME [CBV] Monthly #4 | Reloading chart.
2025-01-05 15:06:15.772 | 6AH5.CME [CBV] Monthly #4 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2025-01-05 15:06:15.772 | 6AH5.CME [CBV] Monthly #4 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2025-01-05 15:06:16.588 | 6AH5.CME [CBV] Weekly #5 | Reloading chart.
2025-01-05 15:06:16.588 | 6AH5.CME [CBV] Weekly #5 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2025-01-05 15:06:16.588 | 6AH5.CME [CBV] Weekly #5 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2025-01-05 15:06:17.368 | 6AH5.CME [CBV] Daily #6 | Reloading chart.
2025-01-05 15:06:17.368 | 6AH5.CME [CBV] Daily #6 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2025-01-05 15:06:17.368 | 6AH5.CME [CBV] Daily #6 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2025-01-05 15:06:18.070 | 6AH5.CME [CBV] 240 Min #7 | Reloading chart.
2025-01-05 15:06:18.475 | 6AH5.CME [CBV] 60 Min #8 | Reloading chart.
2025-01-05 15:06:18.654 | 6AH5.CME 5 Min #11 | Reloading chart.
2025-01-05 15:06:18.708 | 6AH5.CME [CBV] 30 Min #17 | Reloading chart.
2025-01-05 15:06:18.761 | 6AH5.CME [CBV] 15 Min #10 | Reloading chart.
2025-01-05 15:06:19.086 | 6AH5.CME 15 Min #12 | Reloading chart.
2025-01-05 15:06:19.118 | 6AH5.CME Rev. 16t-20 #13 | Reloading chart.
2025-01-05 15:06:19.313 | ESH5.CME #9 | Reloading chart.
2025-01-05 15:06:19.314 | ESH5.CME #9 | StartDateTimeForLoadingOrderFills: 2023-12-30 00:00:00
2025-01-05 15:06:19.314 | ESH5.CME #9 | Chart data loading complete.
2025-01-05 15:06:19.323 | M6AH5.CME 60 Min #1 | Reloading chart.
2025-01-05 15:06:19.518 | 6AH5.CME #18 | Reloading chart.
2025-01-05 15:06:19.519 | 6AH5.CME #18 | StartDateTimeForLoadingOrderFills: 2023-12-30 00:00:00
2025-01-05 15:06:19.519 | 6AH5.CME #18 | Chart data loading complete.
2025-01-05 15:06:19.528 | 6AH5.CME [CBV] Monthly #4 | Chart data loading complete.
2025-01-05 15:06:19.616 | 6AH5.CME [CBV] #14 | Chart data loading complete.
2025-01-05 15:06:19.619 | 6AH5.CME [CBV] 60 Min #15 | Chart data loading complete.
2025-01-05 15:06:19.621 | 6AH5.CME [CBV] Weekly #5 | Chart data loading complete.
2025-01-05 15:06:19.624 | 6AH5.CME [CBV] Daily #6 | Chart data loading complete.
2025-01-05 15:06:19.628 | 6AH5.CME 5 Min #11 | StartDateTimeForLoadingOrderFills: 2023-12-28 00:00:00
2025-01-05 15:06:19.642 | 6AH5.CME 5 Min #11 | Chart data loading complete.
2025-01-05 15:06:19.644 | 6AH5.CME [CBV] 30 Min #17 | StartDateTimeForLoadingOrderFills: 2023-12-28 00:00:00
2025-01-05 15:06:19.673 | 6AH5.CME [CBV] 30 Min #17 | Chart data loading complete.
2025-01-05 15:06:19.814 | 6AH5.CME [CBV] #3 | Chart data loading complete.
2025-01-05 15:06:19.818 | 6AH5.CME 15 Min #12 | StartDateTimeForLoadingOrderFills: 2023-12-28 00:00:00
2025-01-05 15:06:19.821 | 6AH5.CME 15 Min #12 | Chart data loading complete.
2025-01-05 15:06:19.821 | 6AH5.CME Rev. 16t-20 #13 | StartDateTimeForLoadingOrderFills: 2023-12-28 00:00:00
2025-01-05 15:06:19.822 | 6AH5.CME Rev. 16t-20 #13 | Chart data loading complete.
2025-01-05 15:06:19.871 | M6AH5.CME 60 Min #1 | StartDateTimeForLoadingOrderFills: 2023-12-28 00:00:00
2025-01-05 15:06:19.871 | M6AH5.CME 60 Min #1 | Chart data loading complete.
2025-01-05 15:06:19.873 | 6AH5.CME [CBV] 60 Min #8 | StartDateTimeForLoadingOrderFills: 2023-12-28 00:00:00
2025-01-05 15:06:19.894 | 6AH5.CME [CBV] 60 Min #8 | Chart data loading complete.
2025-01-05 15:06:20.326 | Requesting market depth updates for: 6AH5.CME if supported. NumLevels=50
2025-01-05 15:06:21.072 | Denali Data Feed | Clearing market depth for 6AH5.CME
2025-01-05 15:06:21.646 | 6AH5.CME [CBV][M] 240 Min #7 | Chart data loading complete.
2025-01-05 15:06:21.861 | 6AH5.CME [CBV][M] 15 Min #10 | StartDateTimeForLoadingOrderFills: 2023-12-28 00:00:00
2025-01-05 15:06:21.885 | 6AH5.CME [CBV][M] 15 Min #10 | Chart data loading complete.
2025-01-05 17:30:37.293 | SC Data with Depth | Real-time data for symbol SPX500 is currently unavailable.
2025-01-05 17:31:06.562 | SC Data with Depth | Setting external service identifier for symbol SPX500 to 55
2025-01-05 17:31:06.562 | SC Data with Depth | Received security definition for symbol SPX500
2025-01-05 17:31:06.562 | SC Data with Depth | Real-time data for symbol SPX500 has been restored.
2025-01-05 17:31:06.562 | Added historical Intraday data request for SPX500 to the queue.
2025-01-05 17:31:06.562 | Intraday data recording state for symbol SPX500 is set to download 'Pending'.
2025-01-05 17:31:06.562 | Triggering next historical data download in queue.
2025-01-05 17:31:06.562 | HD Request # 21 | Downloading Intraday chart data for SPX500 to the file SPX500.scid. Service: fxcm
2025-01-05 17:31:06.562 | HD Request # 21 | Download start date-time: 2025-01-03 16:44:58.000000. File last date-time: 2025-01-03 16:44:58.325000
2025-01-05 17:31:06.562 | HD Request # 21 | Using server: ds4.sierracharts.com port 10150
2025-01-05 17:31:06.679 | Socket (3) | Creating socket.
2025-01-05 17:31:06.679 | Socket (3) | New receive buffer size: 0
2025-01-05 17:31:06.679 | Socket (3) | Connecting to IP: 67.214.125.7.
2025-01-05 17:31:07.192 | HD Request # 21 | Setting DTC encoding to Binary VLS
2025-01-05 17:31:07.192 | HD Request # 21 | Sending historical data logon request message.
2025-01-05 17:31:11.258 | HD Request # 21 | Requesting Intraday data. Start date-time: 2025-01-03 16:44:58. Record interval: 0. Symbol: SPX500
2025-01-05 17:31:11.395 | Opened cached Intraday file: C:\SierraChart - TopStep\Data\USDX.scid. Thread ID: 16528
2025-01-05 17:31:11.497 | HD Request # 21 | Decompressing data.
2025-01-05 17:31:11.737 | HD Request # 21 | Receiving Intraday data for SPX500 starting at 2025-01-03 16:44:58.325000
2025-01-05 17:31:11.737 | Socket (3) | CloseSocket call.
2025-01-05 17:31:11.737 | Socket (3) | Shutdown started. Waiting for graceful close.
2025-01-05 17:31:11.737 | Historical data download thread signaled to stop.
2025-01-05 17:31:11.737 | HD Request # 21 | Received 1 Intraday data record from 2025-01-03 16:44:58.325000 to 2025-01-03 16:44:58.325000 (0.0 seconds. Delay: 2.0 days) and wrote 0 records for SPX500
2025-01-05 17:31:11.737 | HD Request # 21 | Add time&sales data | Remembered last file record date-time: 2025-01-03 21:44:58.325000
2025-01-05 17:31:11.737 | HD Request # 21 | Completion time: 5s.
2025-01-05 17:31:11.737 | HD Request # 21 | Intraday data download complete for SPX500. Unique request ID: 21
2025-01-05 17:31:11.737 | Removing historical data download ID 21.
2025-01-05 17:31:11.737 | Real-time Intraday chart data file updates started for SPX500
2025-01-05 17:31:11.737 | Intraday chart data file opened for SPX500
2025-01-05 17:31:11.737 | HD Request # 21 | Enabling Intraday chart updating for symbol.
2025-01-05 17:31:11.737 | No download requests in the queue to start downloads for.
2025-01-05 17:31:11.991 | Socket (3) | Socket gracefully closed by remote side.
2025-01-05 17:31:11.991 | Socket (3) | Closed.
2025-01-05 17:35:57.619 | Denali Data Feed | Real-time data for symbol MGCG5.COMEX is currently unavailable.
2025-01-05 17:35:57.619 | Denali Data Feed | Real-time data for symbol GCG5.COMEX is currently unavailable.
2025-01-05 17:35:57.619 | Denali Data Feed | Real-time data for symbol SIH5.COMEX is currently unavailable.
2025-01-05 17:35:57.619 | Denali Data Feed | Real-time data for symbol SILH5.COMEX is currently unavailable.
2025-01-05 17:36:01.524 | Denali Data Feed | Real-time data for symbol ESH5.CME is currently unavailable.
2025-01-05 17:36:01.524 | Denali Data Feed | Real-time data for symbol 6AH5.CME is currently unavailable.
2025-01-05 17:36:01.524 | Denali Data Feed | Real-time data for symbol M6AH5.CME is currently unavailable.
2025-01-05 17:36:01.524 | Denali Data Feed | Real-time data for symbol MNQH5.CME is currently unavailable.
2025-01-05 17:36:01.524 | Denali Data Feed | Real-time data for symbol MESH5.CME is currently unavailable.
2025-01-05 17:36:01.524 | Denali Data Feed | Real-time data for symbol NQH5.CME is currently unavailable.
2025-01-05 17:37:03.949 | Denali Data Feed | Clearing market depth for ESH5.CME
2025-01-05 17:37:03.950 | Denali Data Feed | Setting external service identifier for symbol ESH5.CME to 5002
2025-01-05 17:37:03.950 | Denali Data Feed | Received security definition for symbol ESH5.CME
2025-01-05 17:37:03.950 | Denali Data Feed | Real-time data for symbol ESH5.CME has been restored.
2025-01-05 17:37:03.950 | Added historical Intraday data request for ESH5.CME to the queue.
2025-01-05 17:37:03.950 | Intraday data recording state for symbol ESH5.CME is set to download 'Pending'.
2025-01-05 17:37:03.950 | Triggering next historical data download in queue.
2025-01-05 17:37:03.950 | HD Request # 22 | Downloading Intraday chart data for ESH5.CME to the file ESH5.CME.scid. Service: cme
2025-01-05 17:37:03.951 | HD Request # 22 | Download start date-time: 2025-01-03 16:59:59.000000. File last date-time: 2025-01-03 16:59:59.585005
2025-01-05 17:37:03.951 | HD Request # 22 | Using server: ds32.sierracharts.com port 10149
2025-01-05 17:37:03.951 | Socket (3) | Creating socket.
2025-01-05 17:37:03.951 | Socket (3) | New receive buffer size: 0
2025-01-05 17:37:03.951 | Socket (3) | Connecting to IP: 67.214.125.3.
2025-01-05 17:37:05.375 | HD Request # 22 | Setting DTC encoding to Binary VLS
2025-01-05 17:37:05.375 | HD Request # 22 | Sending historical data logon request message.
2025-01-05 17:37:07.981 | Denali Data Feed | Clearing market depth for 6AH5.CME
2025-01-05 17:37:07.982 | Denali Data Feed | Setting external service identifier for symbol 6AH5.CME to 52126
2025-01-05 17:37:07.982 | Denali Data Feed | Received security definition for symbol 6AH5.CME
2025-01-05 17:37:07.982 | Denali Data Feed | Real-time data for symbol 6AH5.CME has been restored.
2025-01-05 17:37:07.982 | Added historical Intraday data request for 6AH5.CME to the queue.
2025-01-05 17:37:07.982 | Intraday data recording state for symbol 6AH5.CME is set to download 'Pending'.
2025-01-05 17:37:07.982 | Triggering next historical data download in queue.
2025-01-05 17:37:07.982 | Denali Data Feed | Setting external service identifier for symbol M6AH5.CME to 42185124
2025-01-05 17:37:07.982 | Denali Data Feed | Received security definition for symbol M6AH5.CME
2025-01-05 17:37:07.982 | Denali Data Feed | Real-time data for symbol M6AH5.CME has been restored.
2025-01-05 17:37:07.982 | Added historical Intraday data request for M6AH5.CME to the queue.
2025-01-05 17:37:07.982 | Intraday data recording state for symbol M6AH5.CME is set to download 'Pending'.
2025-01-05 17:37:16.239 | HD Request # 22 | Requesting Intraday data. Start date-time: 2025-01-03 16:59:59. Record interval: 0. Symbol: ESH25
2025-01-05 17:37:16.487 | HD Request # 22 | Decompressing data.
2025-01-05 17:37:16.735 | HD Request # 22 | Receiving Intraday data for ESH5.CME starting at 2025-01-03 16:59:59.503000
2025-01-05 17:37:16.735 | Socket (3) | CloseSocket call.
2025-01-05 17:37:16.735 | Socket (3) | Shutdown started. Waiting for graceful close.
2025-01-05 17:37:16.735 | Historical data download thread signaled to stop.
2025-01-05 17:37:16.735 | HD Request # 22 | Received 8 Intraday data records from 2025-01-03 16:59:59.503000 to 2025-01-03 16:59:59.585005 (0.1 seconds. Delay: 2.0 days) and wrote 0 records for ESH5.CME
2025-01-05 17:37:16.735 | HD Request # 22 | Add time&sales data | Remembered last file record date-time: 2025-01-03 21:59:59.585005
2025-01-05 17:37:16.735 | HD Request # 22 | Completion time: 13s.
2025-01-05 17:37:16.735 | HD Request # 22 | Intraday data download complete for ESH5.CME. Unique request ID: 22
2025-01-05 17:37:16.735 | Removing historical data download ID 22.
2025-01-05 17:37:16.735 | Real-time Intraday chart data file updates started for ESH5.CME
2025-01-05 17:37:16.735 | Intraday chart data file opened for ESH5.CME
2025-01-05 17:37:16.735 | HD Request # 22 | Enabling Intraday chart updating for symbol.
2025-01-05 17:37:16.735 | Triggering next historical data download in queue.
2025-01-05 17:37:16.735 | HD Request # 23 | Downloading Intraday chart data for 6AH5.CME to the file 6AH5.CME.scid. Service: cme
2025-01-05 17:37:16.735 | HD Request # 23 | Download start date-time: 2025-01-03 16:59:55.000000. File last date-time: 2025-01-03 16:59:55.751000
2025-01-05 17:37:16.735 | HD Request # 23 | Using server: ds32.sierracharts.com port 10150
2025-01-05 17:37:16.736 | Socket (4) | Creating socket.
2025-01-05 17:37:16.736 | Socket (4) | New receive buffer size: 0
2025-01-05 17:37:16.736 | Socket (4) | Connecting to IP: 67.214.125.3.
2025-01-05 17:37:16.984 | Socket (3) | Socket gracefully closed by remote side.
2025-01-05 17:37:16.984 | Socket (3) | Closed.
2025-01-05 17:37:17.236 | HD Request # 23 | Setting DTC encoding to Binary VLS
2025-01-05 17:37:17.236 | HD Request # 23 | Sending historical data logon request message.
2025-01-05 17:37:20.319 | HD Request # 23 | Requesting Intraday data. Start date-time: 2025-01-03 16:59:55. Record interval: 0. Symbol: 6AH25
2025-01-05 17:37:20.561 | HD Request # 23 | Decompressing data.
2025-01-05 17:37:20.804 | HD Request # 23 | Receiving Intraday data for 6AH5.CME starting at 2025-01-03 16:59:55.751000
2025-01-05 17:37:20.804 | Socket (4) | CloseSocket call.
2025-01-05 17:37:20.804 | Socket (4) | Shutdown started. Waiting for graceful close.
2025-01-05 17:37:20.812 | Historical data download thread signaled to stop.
2025-01-05 17:37:20.812 | HD Request # 23 | Received 1 Intraday data record from 2025-01-03 16:59:55.751000 to 2025-01-03 16:59:55.751000 (0.0 seconds. Delay: 2.0 days) and wrote 0 records for 6AH5.CME
2025-01-05 17:37:20.812 | HD Request # 23 | Add time&sales data | Remembered last file record date-time: 2025-01-03 21:59:55.751000
2025-01-05 17:37:20.812 | HD Request # 23 | Completion time: 4s.
2025-01-05 17:37:20.812 | HD Request # 23 | Intraday data download complete for 6AH5.CME. Unique request ID: 23
2025-01-05 17:37:20.812 | Removing historical data download ID 23.
2025-01-05 17:37:20.812 | Real-time Intraday chart data file updates started for 6AH5.CME
2025-01-05 17:37:20.812 | Intraday chart data file opened for 6AH5.CME
2025-01-05 17:37:20.812 | HD Request # 23 | Enabling Intraday chart updating for symbol.
2025-01-05 17:37:20.812 | Triggering next historical data download in queue.
2025-01-05 17:37:20.812 | HD Request # 24 | Downloading Intraday chart data for M6AH5.CME to the file M6AH5.CME.scid. Service: cme
2025-01-05 17:37:20.812 | HD Request # 24 | Download start date-time: 2025-01-03 16:59:54.000000. File last date-time: 2025-01-03 16:59:54.460001
2025-01-05 17:37:20.812 | HD Request # 24 | Using server: ds32.sierracharts.com port 10149
2025-01-05 17:37:20.813 | Socket (3) | Creating socket.
2025-01-05 17:37:20.813 | Socket (3) | New receive buffer size: 0
2025-01-05 17:37:20.813 | Socket (3) | Connecting to IP: 67.214.125.3.
2025-01-05 17:37:21.049 | Socket (4) | Socket gracefully closed by remote side.
2025-01-05 17:37:21.049 | Socket (4) | Closed.
2025-01-05 17:37:21.340 | HD Request # 24 | Setting DTC encoding to Binary VLS
2025-01-05 17:37:21.340 | HD Request # 24 | Sending historical data logon request message.
2025-01-05 17:37:21.728 | HD Request # 24 | Requesting Intraday data. Start date-time: 2025-01-03 16:59:54. Record interval: 0. Symbol: M6AH25
2025-01-05 17:37:21.990 | HD Request # 24 | Decompressing data.
2025-01-05 17:37:22.002 | Denali Data Feed | Clearing market depth for MNQH5.CME
2025-01-05 17:37:22.002 | Denali Data Feed | Clearing market depth for MESH5.CME
2025-01-05 17:37:22.002 | Denali Data Feed | Clearing market depth for NQH5.CME
2025-01-05 17:37:22.002 | Denali Data Feed | Setting external service identifier for symbol MNQH5.CME to 42003617
2025-01-05 17:37:22.002 | Denali Data Feed | Received security definition for symbol MNQH5.CME
2025-01-05 17:37:22.002 | Denali Data Feed | Real-time data for symbol MNQH5.CME has been restored.
2025-01-05 17:37:22.002 | Added historical Intraday data request for MNQH5.CME to the queue.
2025-01-05 17:37:22.002 | Intraday data recording state for symbol MNQH5.CME is set to download 'Pending'.
2025-01-05 17:37:22.002 | Triggering next historical data download in queue.
2025-01-05 17:37:22.002 | Denali Data Feed | Setting external service identifier for symbol MESH5.CME to 42005347
2025-01-05 17:37:22.002 | Denali Data Feed | Received security definition for symbol MESH5.CME
2025-01-05 17:37:22.002 | Denali Data Feed | Real-time data for symbol MESH5.CME has been restored.
2025-01-05 17:37:22.002 | Added historical Intraday data request for MESH5.CME to the queue.
2025-01-05 17:37:22.002 | Intraday data recording state for symbol MESH5.CME is set to download 'Pending'.
2025-01-05 17:37:22.002 | Denali Data Feed | Setting external service identifier for symbol NQH5.CME to 42288528
2025-01-05 17:37:22.002 | Denali Data Feed | Received security definition for symbol NQH5.CME
2025-01-05 17:37:22.002 | Denali Data Feed | Real-time data for symbol NQH5.CME has been restored.
2025-01-05 17:37:22.002 | Added historical Intraday data request for NQH5.CME to the queue.
2025-01-05 17:37:22.002 | Intraday data recording state for symbol NQH5.CME is set to download 'Pending'.
2025-01-05 17:37:22.298 | HD Request # 24 | Receiving Intraday data for M6AH5.CME starting at 2025-01-03 16:59:54.130000
2025-01-05 17:37:22.298 | Socket (3) | CloseSocket call.
2025-01-05 17:37:22.298 | Historical data download thread signaled to stop.
2025-01-05 17:37:22.298 | Socket (3) | Shutdown started. Waiting for graceful close.
2025-01-05 17:37:22.298 | HD Request # 24 | Received 4 Intraday data records from 2025-01-03 16:59:54.130000 to 2025-01-03 16:59:54.460001 (0.3 seconds. Delay: 2.0 days) and wrote 0 records for M6AH5.CME
2025-01-05 17:37:22.299 | HD Request # 24 | Add time&sales data | Remembered last file record date-time: 2025-01-03 21:59:54.460001
2025-01-05 17:37:22.299 | HD Request # 24 | Completion time: 2s.
2025-01-05 17:37:22.299 | HD Request # 24 | Intraday data download complete for M6AH5.CME. Unique request ID: 24
2025-01-05 17:37:22.299 | Removing historical data download ID 24.
2025-01-05 17:37:22.299 | Real-time Intraday chart data file updates started for M6AH5.CME
2025-01-05 17:37:22.299 | Intraday chart data file opened for M6AH5.CME
2025-01-05 17:37:22.299 | HD Request # 24 | Enabling Intraday chart updating for symbol.
2025-01-05 17:37:22.299 | Triggering next historical data download in queue.
2025-01-05 17:37:22.299 | HD Request # 25 | Downloading Intraday chart data for MNQH5.CME to the file MNQH5.CME.scid. Service: cme
2025-01-05 17:37:22.299 | HD Request # 25 | Download start date-time: 2025-01-03 16:59:58.000000. File last date-time: 2025-01-03 16:59:58.839000
2025-01-05 17:37:22.299 | HD Request # 25 | Using server: ds32.sierracharts.com port 10150
2025-01-05 17:37:22.299 | Socket (4) | Creating socket.
2025-01-05 17:37:22.299 | Socket (4) | New receive buffer size: 0
2025-01-05 17:37:22.299 | Socket (4) | Connecting to IP: 67.214.125.3.
2025-01-05 17:37:22.564 | Socket (3) | Socket gracefully closed by remote side.
2025-01-05 17:37:22.564 | Socket (3) | Closed.
2025-01-05 17:37:24.583 | HD Request # 25 | Setting DTC encoding to Binary VLS
2025-01-05 17:37:24.583 | HD Request # 25 | Sending historical data logon request message.
2025-01-05 17:37:25.208 | HD Request # 25 | Requesting Intraday data. Start date-time: 2025-01-03 16:59:58. Record interval: 0. Symbol: MNQH25
2025-01-05 17:37:25.472 | HD Request # 25 | Decompressing data.
2025-01-05 17:37:25.769 | HD Request # 25 | Receiving Intraday data for MNQH5.CME starting at 2025-01-03 16:59:58.116000
2025-01-05 17:37:25.769 | Socket (4) | CloseSocket call.
2025-01-05 17:37:25.769 | Socket (4) | Shutdown started. Waiting for graceful close.
2025-01-05 17:37:25.799 | Historical data download thread signaled to stop.
2025-01-05 17:37:25.799 | HD Request # 25 | Received 7 Intraday data records from 2025-01-03 16:59:58.116000 to 2025-01-03 16:59:58.839000 (0.7 seconds. Delay: 2.0 days) and wrote 0 records for MNQH5.CME
2025-01-05 17:37:25.799 | HD Request # 25 | Add time&sales data | Remembered last file record date-time: 2025-01-03 21:59:58.839000
2025-01-05 17:37:25.799 | HD Request # 25 | Completion time: 3s.
2025-01-05 17:37:25.799 | HD Request # 25 | Intraday data download complete for MNQH5.CME. Unique request ID: 25
2025-01-05 17:37:25.799 | Removing historical data download ID 25.
2025-01-05 17:37:25.799 | Real-time Intraday chart data file updates started for MNQH5.CME
2025-01-05 17:37:25.799 | Intraday chart data file opened for MNQH5.CME
2025-01-05 17:37:25.799 | HD Request # 25 | Enabling Intraday chart updating for symbol.
2025-01-05 17:37:25.799 | Triggering next historical data download in queue.
2025-01-05 17:37:25.799 | HD Request # 26 | Downloading Intraday chart data for MESH5.CME to the file MESH5.CME.scid. Service: cme
2025-01-05 17:37:25.799 | HD Request # 26 | Download start date-time: 2025-01-03 16:59:59.000000. File last date-time: 2025-01-03 16:59:59.926000
2025-01-05 17:37:25.799 | HD Request # 26 | Using server: ds32.sierracharts.com port 10149
2025-01-05 17:37:25.799 | Socket (7) | Creating socket.
2025-01-05 17:37:25.799 | Socket (7) | New receive buffer size: 0
2025-01-05 17:37:25.799 | Socket (7) | Connecting to IP: 67.214.125.3.
2025-01-05 17:37:26.006 | Socket (4) | Socket gracefully closed by remote side.
2025-01-05 17:37:26.006 | Socket (4) | Closed.
2025-01-05 17:37:26.283 | HD Request # 26 | Setting DTC encoding to Binary VLS
2025-01-05 17:37:26.283 | HD Request # 26 | Sending historical data logon request message.
2025-01-05 17:37:26.526 | HD Request # 26 | Requesting Intraday data. Start date-time: 2025-01-03 16:59:59. Record interval: 0. Symbol: MESH25
2025-01-05 17:37:26.767 | HD Request # 26 | Decompressing data.
2025-01-05 17:37:27.007 | HD Request # 26 | Receiving Intraday data for MESH5.CME starting at 2025-01-03 16:59:59.032000
2025-01-05 17:37:27.007 | Socket (7) | CloseSocket call.
2025-01-05 17:37:27.007 | Socket (7) | Shutdown started. Waiting for graceful close.
2025-01-05 17:37:27.031 | Historical data download thread signaled to stop.
2025-01-05 17:37:27.031 | HD Request # 26 | Received 6 Intraday data records from 2025-01-03 16:59:59.032000 to 2025-01-03 16:59:59.926000 (0.9 seconds. Delay: 2.0 days) and wrote 0 records for MESH5.CME
2025-01-05 17:37:27.031 | HD Request # 26 | Add time&sales data | Remembered last file record date-time: 2025-01-03 21:59:59.926000
2025-01-05 17:37:27.031 | HD Request # 26 | Completion time: 2s.
2025-01-05 17:37:27.031 | HD Request # 26 | Intraday data download complete for MESH5.CME. Unique request ID: 26
2025-01-05 17:37:27.031 | Removing historical data download ID 26.
2025-01-05 17:37:27.031 | Real-time Intraday chart data file updates started for MESH5.CME
2025-01-05 17:37:27.031 | Intraday chart data file opened for MESH5.CME
2025-01-05 17:37:27.031 | HD Request # 26 | Enabling Intraday chart updating for symbol.
2025-01-05 17:37:27.031 | Triggering next historical data download in queue.
2025-01-05 17:37:27.031 | HD Request # 27 | Downloading Intraday chart data for NQH5.CME to the file NQH5.CME.scid. Service: cme
2025-01-05 17:37:27.031 | HD Request # 27 | Download start date-time: 2025-01-03 16:59:59.000000. File last date-time: 2025-01-03 16:59:59.503000
2025-01-05 17:37:27.032 | HD Request # 27 | Using server: ds32.sierracharts.com port 10150
2025-01-05 17:37:27.032 | Socket (3) | Creating socket.
2025-01-05 17:37:27.032 | Socket (3) | New receive buffer size: 0
2025-01-05 17:37:27.032 | Socket (3) | Connecting to IP: 67.214.125.3.
2025-01-05 17:37:27.249 | Socket (7) | Socket gracefully closed by remote side.
2025-01-05 17:37:27.250 | Socket (7) | Closed.
2025-01-05 17:37:27.521 | HD Request # 27 | Setting DTC encoding to Binary VLS
2025-01-05 17:37:27.521 | HD Request # 27 | Sending historical data logon request message.
2025-01-05 17:37:27.760 | HD Request # 27 | Requesting Intraday data. Start date-time: 2025-01-03 16:59:59. Record interval: 0. Symbol: NQH25
2025-01-05 17:37:28.003 | HD Request # 27 | Decompressing data.
2025-01-05 17:37:28.290 | HD Request # 27 | Receiving Intraday data for NQH5.CME starting at 2025-01-03 16:59:59.503000
2025-01-05 17:37:28.290 | Socket (3) | CloseSocket call.
2025-01-05 17:37:28.290 | Socket (3) | Shutdown started. Waiting for graceful close.
2025-01-05 17:37:28.290 | Historical data download thread signaled to stop.
2025-01-05 17:37:28.290 | HD Request # 27 | Received 1 Intraday data record from 2025-01-03 16:59:59.503000 to 2025-01-03 16:59:59.503000 (0.0 seconds. Delay: 2.0 days) and wrote 0 records for NQH5.CME
2025-01-05 17:37:28.290 | HD Request # 27 | Add time&sales data | Remembered last file record date-time: 2025-01-03 21:59:59.503000
2025-01-05 17:37:28.290 | HD Request # 27 | Completion time: 1s.
2025-01-05 17:37:28.290 | HD Request # 27 | Intraday data download complete for NQH5.CME. Unique request ID: 27
2025-01-05 17:37:28.291 | Removing historical data download ID 27.
2025-01-05 17:37:28.291 | Real-time Intraday chart data file updates started for NQH5.CME
2025-01-05 17:37:28.291 | Intraday chart data file opened for NQH5.CME
2025-01-05 17:37:28.291 | HD Request # 27 | Enabling Intraday chart updating for symbol.
2025-01-05 17:37:28.291 | No download requests in the queue to start downloads for.
2025-01-05 17:37:28.531 | Socket (3) | Socket gracefully closed by remote side.
2025-01-05 17:37:28.531 | Socket (3) | Closed.
2025-01-05 17:37:43.738 | Denali Data Feed | Clearing market depth for MGCG5.COMEX
2025-01-05 17:37:43.738 | Denali Data Feed | Clearing market depth for GCG5.COMEX
2025-01-05 17:37:43.739 | Denali Data Feed | Clearing market depth for SIH5.COMEX
2025-01-05 17:37:43.739 | Denali Data Feed | Setting external service identifier for symbol MGCG5.COMEX to 69
2025-01-05 17:37:43.739 | Denali Data Feed | Received security definition for symbol MGCG5.COMEX
2025-01-05 17:37:43.739 | Denali Data Feed | Real-time data for symbol MGCG5.COMEX has been restored.
2025-01-05 17:37:43.739 | Added historical Intraday data request for MGCG5.COMEX to the queue.
2025-01-05 17:37:43.739 | Intraday data recording state for symbol MGCG5.COMEX is set to download 'Pending'.
2025-01-05 17:37:43.739 | Triggering next historical data download in queue.
2025-01-05 17:37:43.739 | Denali Data Feed | Setting external service identifier for symbol GCG5.COMEX to 1551
2025-01-05 17:37:43.739 | Denali Data Feed | Received security definition for symbol GCG5.COMEX
2025-01-05 17:37:43.739 | Denali Data Feed | Real-time data for symbol GCG5.COMEX has been restored.
2025-01-05 17:37:43.739 | Added historical Intraday data request for GCG5.COMEX to the queue.
2025-01-05 17:37:43.739 | Intraday data recording state for symbol GCG5.COMEX is set to download 'Pending'.
2025-01-05 17:37:43.739 | Denali Data Feed | Setting external service identifier for symbol SIH5.COMEX to 5556
2025-01-05 17:37:43.739 | Denali Data Feed | Received security definition for symbol SIH5.COMEX
2025-01-05 17:37:43.739 | Denali Data Feed | Real-time data for symbol SIH5.COMEX has been restored.
2025-01-05 17:37:43.739 | Added historical Intraday data request for SIH5.COMEX to the queue.
2025-01-05 17:37:43.739 | Intraday data recording state for symbol SIH5.COMEX is set to download 'Pending'.
2025-01-05 17:37:43.739 | Denali Data Feed | Setting external service identifier for symbol SILH5.COMEX to 42007667
2025-01-05 17:37:43.739 | Denali Data Feed | Received security definition for symbol SILH5.COMEX
2025-01-05 17:37:43.739 | Denali Data Feed | Real-time data for symbol SILH5.COMEX has been restored.
2025-01-05 17:37:43.739 | Added historical Intraday data request for SILH5.COMEX to the queue.
2025-01-05 17:37:43.739 | Intraday data recording state for symbol SILH5.COMEX is set to download 'Pending'.
2025-01-05 17:37:43.739 | HD Request # 28 | Downloading Intraday chart data for MGCG5.COMEX to the file MGCG5.COMEX.scid. Service: comex
2025-01-05 17:37:43.739 | HD Request # 28 | Download start date-time: 2025-01-03 16:59:59.000000. File last date-time: 2025-01-03 16:59:59.806000
2025-01-05 17:37:43.739 | HD Request # 28 | Using server: ds32.sierracharts.com port 10149
2025-01-05 17:37:43.739 | Socket (3) | Creating socket.
2025-01-05 17:37:43.739 | Socket (3) | New receive buffer size: 0
2025-01-05 17:37:43.739 | Socket (3) | Connecting to IP: 67.214.125.3.
2025-01-05 17:37:44.244 | HD Request # 28 | Setting DTC encoding to Binary VLS
2025-01-05 17:37:44.244 | HD Request # 28 | Sending historical data logon request message.
2025-01-05 17:37:44.492 | HD Request # 28 | Requesting Intraday data. Start date-time: 2025-01-03 16:59:59. Record interval: 0. Symbol: MGCG25
2025-01-05 17:37:44.739 | HD Request # 28 | Decompressing data.
2025-01-05 17:37:44.988 | HD Request # 28 | Receiving Intraday data for MGCG5.COMEX starting at 2025-01-03 16:59:59.390000
2025-01-05 17:37:44.988 | Socket (3) | CloseSocket call.
2025-01-05 17:37:44.988 | Socket (3) | Shutdown started. Waiting for graceful close.
2025-01-05 17:37:44.988 | Historical data download thread signaled to stop.
2025-01-05 17:37:44.988 | HD Request # 28 | Received 3 Intraday data records from 2025-01-03 16:59:59.390000 to 2025-01-03 16:59:59.806000 (0.4 seconds. Delay: 2.0 days) and wrote 0 records for MGCG5.COMEX
2025-01-05 17:37:44.989 | HD Request # 28 | Add time&sales data | Remembered last file record date-time: 2025-01-03 21:59:59.806000
2025-01-05 17:37:44.989 | HD Request # 28 | Completion time: 1s.
2025-01-05 17:37:44.989 | HD Request # 28 | Intraday data download complete for MGCG5.COMEX. Unique request ID: 28
2025-01-05 17:37:44.989 | Removing historical data download ID 28.
2025-01-05 17:37:44.989 | Real-time Intraday chart data file updates started for MGCG5.COMEX
2025-01-05 17:37:44.989 | Intraday chart data file opened for MGCG5.COMEX
2025-01-05 17:37:44.989 | HD Request # 28 | Enabling Intraday chart updating for symbol.
2025-01-05 17:37:44.989 | Triggering next historical data download in queue.
2025-01-05 17:37:44.989 | HD Request # 29 | Downloading Intraday chart data for GCG5.COMEX to the file GCG5.COMEX.scid. Service: comex
2025-01-05 17:37:44.989 | HD Request # 29 | Download start date-time: 2025-01-03 16:59:59.000000. File last date-time: 2025-01-03 16:59:59.951000
2025-01-05 17:37:44.989 | HD Request # 29 | Using server: ds32.sierracharts.com port 10150
2025-01-05 17:37:44.989 | Socket (4) | Creating socket.
2025-01-05 17:37:44.989 | Socket (4) | New receive buffer size: 0
2025-01-05 17:37:44.989 | Socket (4) | Connecting to IP: 67.214.125.3.
2025-01-05 17:37:45.239 | Socket (3) | Socket gracefully closed by remote side.
2025-01-05 17:37:45.240 | Socket (3) | Closed.
2025-01-05 17:37:45.466 | HD Request # 29 | Setting DTC encoding to Binary VLS
2025-01-05 17:37:45.466 | HD Request # 29 | Sending historical data logon request message.
2025-01-05 17:37:45.702 | HD Request # 29 | Requesting Intraday data. Start date-time: 2025-01-03 16:59:59. Record interval: 0. Symbol: GCG25
2025-01-05 17:37:45.934 | HD Request # 29 | Decompressing data.
2025-01-05 17:37:46.207 | HD Request # 29 | Receiving Intraday data for GCG5.COMEX starting at 2025-01-03 16:59:59.951000
2025-01-05 17:37:46.207 | Socket (4) | CloseSocket call.
2025-01-05 17:37:46.208 | Socket (4) | Shutdown started. Waiting for graceful close.
2025-01-05 17:37:46.297 | Historical data download thread signaled to stop.
2025-01-05 17:37:46.297 | HD Request # 29 | Received 1 Intraday data record from 2025-01-03 16:59:59.951000 to 2025-01-03 16:59:59.951000 (0.0 seconds. Delay: 2.0 days) and wrote 0 records for GCG5.COMEX
2025-01-05 17:37:46.297 | HD Request # 29 | Add time&sales data | Remembered last file record date-time: 2025-01-03 21:59:59.951000
2025-01-05 17:37:46.297 | HD Request # 29 | Completion time: 2s.
2025-01-05 17:37:46.297 | HD Request # 29 | Intraday data download complete for GCG5.COMEX. Unique request ID: 29
2025-01-05 17:37:46.297 | Removing historical data download ID 29.
2025-01-05 17:37:46.297 | Real-time Intraday chart data file updates started for GCG5.COMEX
2025-01-05 17:37:46.297 | Intraday chart data file opened for GCG5.COMEX
2025-01-05 17:37:46.297 | HD Request # 29 | Enabling Intraday chart updating for symbol.
2025-01-05 17:37:46.297 | Triggering next historical data download in queue.
2025-01-05 17:37:46.297 | HD Request # 30 | Downloading Intraday chart data for SIH5.COMEX to the file SIH5.COMEX.scid. Service: comex
2025-01-05 17:37:46.297 | HD Request # 30 | Download start date-time: 2025-01-03 16:59:56.000000. File last date-time: 2025-01-03 16:59:56.040000
2025-01-05 17:37:46.297 | HD Request # 30 | Using server: ds32.sierracharts.com port 10149
2025-01-05 17:37:46.298 | Socket (3) | Creating socket.
2025-01-05 17:37:46.298 | Socket (3) | New receive buffer size: 0
2025-01-05 17:37:46.298 | Socket (3) | Connecting to IP: 67.214.125.3.
2025-01-05 17:37:46.442 | Socket (4) | Socket gracefully closed by remote side.
2025-01-05 17:37:46.442 | Socket (4) | Closed.
2025-01-05 17:37:46.798 | HD Request # 30 | Setting DTC encoding to Binary VLS
2025-01-05 17:37:46.798 | HD Request # 30 | Sending historical data logon request message.
2025-01-05 17:37:49.342 | HD Request # 30 | Requesting Intraday data. Start date-time: 2025-01-03 16:59:56. Record interval: 0. Symbol: SIH25
2025-01-05 17:37:49.576 | HD Request # 30 | Decompressing data.
2025-01-05 17:37:49.810 | HD Request # 30 | Receiving Intraday data for SIH5.COMEX starting at 2025-01-03 16:59:56.040000
2025-01-05 17:37:49.810 | Socket (3) | CloseSocket call.
2025-01-05 17:37:49.810 | Socket (3) | Shutdown started. Waiting for graceful close.
2025-01-05 17:37:49.834 | Historical data download thread signaled to stop.
2025-01-05 17:37:49.834 | HD Request # 30 | Received 1 Intraday data record from 2025-01-03 16:59:56.040000 to 2025-01-03 16:59:56.040000 (0.0 seconds. Delay: 2.0 days) and wrote 0 records for SIH5.COMEX
2025-01-05 17:37:49.834 | HD Request # 30 | Add time&sales data | Remembered last file record date-time: 2025-01-03 21:59:56.040000
2025-01-05 17:37:49.834 | HD Request # 30 | Completion time: 3s.
2025-01-05 17:37:49.834 | HD Request # 30 | Intraday data download complete for SIH5.COMEX. Unique request ID: 30
2025-01-05 17:37:49.834 | Removing historical data download ID 30.
2025-01-05 17:37:49.834 | Real-time Intraday chart data file updates started for SIH5.COMEX
2025-01-05 17:37:49.834 | Intraday chart data file opened for SIH5.COMEX
2025-01-05 17:37:49.834 | HD Request # 30 | Enabling Intraday chart updating for symbol.
2025-01-05 17:37:49.834 | Triggering next historical data download in queue.
2025-01-05 17:37:49.834 | HD Request # 31 | Downloading Intraday chart data for SILH5.COMEX to the file SILH5.COMEX.scid. Service: comex
2025-01-05 17:37:49.834 | HD Request # 31 | Download start date-time: 2025-01-03 16:59:52.000000. File last date-time: 2025-01-03 16:59:52.448000
2025-01-05 17:37:49.834 | HD Request # 31 | Using server: ds32.sierracharts.com port 10150
2025-01-05 17:37:49.834 | Socket (4) | Creating socket.
2025-01-05 17:37:49.834 | Socket (4) | New receive buffer size: 0
2025-01-05 17:37:49.834 | Socket (4) | Connecting to IP: 67.214.125.3.
2025-01-05 17:37:50.044 | Socket (3) | Socket gracefully closed by remote side.
2025-01-05 17:37:50.044 | Socket (3) | Closed.
2025-01-05 17:37:50.320 | HD Request # 31 | Setting DTC encoding to Binary VLS
2025-01-05 17:37:50.320 | HD Request # 31 | Sending historical data logon request message.
2025-01-05 17:37:51.614 | HD Request # 31 | Requesting Intraday data. Start date-time: 2025-01-03 16:59:52. Record interval: 0. Symbol: SILH25
2025-01-05 17:37:51.851 | HD Request # 31 | Decompressing data.
2025-01-05 17:37:52.086 | HD Request # 31 | Receiving Intraday data for SILH5.COMEX starting at 2025-01-03 16:59:52.448000
2025-01-05 17:37:52.086 | Socket (4) | CloseSocket call.
2025-01-05 17:37:52.086 | Socket (4) | Shutdown started. Waiting for graceful close.
2025-01-05 17:37:52.111 | Historical data download thread signaled to stop.
2025-01-05 17:37:52.111 | HD Request # 31 | Received 1 Intraday data record from 2025-01-03 16:59:52.448000 to 2025-01-03 16:59:52.448000 (0.0 seconds. Delay: 2.0 days) and wrote 0 records for SILH5.COMEX
2025-01-05 17:37:52.111 | HD Request # 31 | Add time&sales data | Remembered last file record date-time: 2025-01-03 21:59:52.448000
2025-01-05 17:37:52.111 | HD Request # 31 | Completion time: 3s.
2025-01-05 17:37:52.111 | HD Request # 31 | Intraday data download complete for SILH5.COMEX. Unique request ID: 31
2025-01-05 17:37:52.111 | Removing historical data download ID 31.
2025-01-05 17:37:52.111 | Real-time Intraday chart data file updates started for SILH5.COMEX
2025-01-05 17:37:52.111 | Intraday chart data file opened for SILH5.COMEX
2025-01-05 17:37:52.111 | HD Request # 31 | Enabling Intraday chart updating for symbol.
2025-01-05 17:37:52.111 | No download requests in the queue to start downloads for.
2025-01-05 17:37:52.323 | Socket (4) | Socket gracefully closed by remote side.
2025-01-05 17:37:52.323 | Socket (4) | Closed.
2025-01-05 17:45:00.055 | Added historical Daily data request for 6AH5.CME to the queue.
2025-01-05 17:45:00.055 | Triggering next historical data download in queue.
2025-01-05 17:45:00.056 | HD Request # 32 | Downloading Historical Daily chart data for 6AH5.CME. Starting date: 2024-12-31. Service: rithmic.trading
2025-01-05 17:45:00.069 | Added historical Daily data request for SIH5.COMEX to the queue.
2025-01-05 17:45:00.069 | Triggering next historical data download in queue.
2025-01-05 17:45:00.070 | Added historical Daily data request for USDX to the queue.
2025-01-05 17:45:00.070 | Triggering next historical data download in queue.
2025-01-05 17:45:00.071 | HD Request # 33 | Downloading Historical Daily chart data for USDX. Starting date: 2024-12-31. Service: fxstatscalc
2025-01-05 17:45:00.071 | HD Request # 33 | Using server: ds12.sierracharts.com port 10149
2025-01-05 17:45:00.083 | Added historical Daily data request for ESH5.CME to the queue.
2025-01-05 17:45:00.083 | Triggering next historical data download in queue.
2025-01-05 17:45:00.182 | Socket (4) | Creating socket.
2025-01-05 17:45:00.182 | Socket (4) | New receive buffer size: 0
2025-01-05 17:45:00.182 | Socket (4) | Connecting to IP: 69.39.70.241.
2025-01-05 17:45:00.203 | Added historical Daily data request for NQH5.CME to the queue.
2025-01-05 17:45:00.203 | Triggering next historical data download in queue.
2025-01-05 17:45:00.250 | Added historical Daily data request for GCG5.COMEX to the queue.
2025-01-05 17:45:00.250 | Triggering next historical data download in queue.
2025-01-05 17:45:00.687 | HD Request # 33 | Setting DTC encoding to Binary VLS
2025-01-05 17:45:00.687 | HD Request # 33 | Sending historical data logon request message.
2025-01-05 17:45:01.125 | HD Request # 32 | Requesting historical Daily data for A6H25 starting at 2024-12-30. SC External HD service.
2025-01-05 17:45:01.697 | HD Request # 33 | Requesting historical Daily data starting at 2024-12-31.
2025-01-05 17:45:01.934 | HD Request # 33 | Decompressing data.
2025-01-05 17:45:01.956 | HD Request # 33 | Receiving historical Daily data for USDX starting at 2024-12-31.
2025-01-05 17:45:01.956 | HD Request # 33 | Writing historical Daily data to the file USDX.dly.
2025-01-05 17:45:01.974 | Socket (4) | CloseSocket call.
2025-01-05 17:45:01.974 | Socket (4) | Shutdown started. Waiting for graceful close.
2025-01-05 17:45:02.017 | Historical data download thread signaled to stop.
2025-01-05 17:45:02.017 | HD Request # 33 | Received 4 Daily data records from 2024-12-31 00:00:00 to 2025-01-06 00:00:00 (7.0 days) and wrote 4 records for USDX
2025-01-05 17:45:02.017 | HD Request # 33 | Completion time: 2s.
2025-01-05 17:45:02.017 | HD Request # 33 | Daily data download complete for USDX. Unique request ID: 34
2025-01-05 17:45:02.017 | Removing historical data download ID 34.
2025-01-05 17:45:02.017 | No download requests in the queue to start downloads for.
2025-01-05 17:45:02.065 | USDX[M] Daily #19 | Reloading chart.
2025-01-05 17:45:02.125 | HD Request # 32 | Receiving historical Daily data for 6AH5.CME starting at 2024-12-31.
2025-01-05 17:45:02.125 | HD Request # 32 | Writing historical Daily data to the file 6AH5.CME.dly.
2025-01-05 17:45:02.129 | HD Request # 32 | Bytes received: 237
2025-01-05 17:45:02.129 | HD Request # 32 | Received 4 Daily data records from 2024-12-31 00:00:00 to 2025-01-03 00:00:00 (4.0 days) and wrote 3 records for 6AH5.CME
2025-01-05 17:45:02.129 | HD Request # 32 | Completion time: 2s.
2025-01-05 17:45:02.129 | HD Request # 32 | Daily data download complete for 6AH5.CME. Unique request ID: 32
2025-01-05 17:45:02.129 | Removing historical data download ID 32.
2025-01-05 17:45:02.129 | Triggering next historical data download in queue.
2025-01-05 17:45:02.130 | USDX[M] Daily #19 | StartDateTimeForLoadingOrderFills: 2023-12-31 00:00:00
2025-01-05 17:45:02.131 | USDX[M] Daily #19 | Chart data loading complete.
2025-01-05 17:45:02.131 | HD Request # 34 | Downloading Historical Daily chart data for SIH5.COMEX. Starting date: 2024-12-31. Service: rithmic.trading
2025-01-05 17:45:02.210 | Socket (4) | Socket gracefully closed by remote side.
2025-01-05 17:45:02.210 | Socket (4) | Closed.
2025-01-05 17:45:02.801 | 6AH5.CME [CBV][M] Weekly #5 | Reloading chart.
2025-01-05 17:45:02.801 | 6AH5.CME [CBV][M] Weekly #5 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2025-01-05 17:45:02.801 | 6AH5.CME [CBV][M] Weekly #5 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2025-01-05 17:45:03.498 | HD Request # 34 | Requesting historical Daily data for SIH25 starting at 2024-12-30. SC External HD service.
2025-01-05 17:45:03.531 | 6AH5.CME [CBV][M] Daily #6 | Reloading chart.
2025-01-05 17:45:03.531 | 6AH5.CME [CBV][M] Daily #6 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2025-01-05 17:45:03.531 | 6AH5.CME [CBV][M] Daily #6 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2025-01-05 17:45:04.248 | 6AH5.CME [CBV][M] Weekly #5 | Chart data loading complete.
2025-01-05 17:45:04.250 | 6AH5.CME [CBV][M] Monthly #4 | Reloading chart.
2025-01-05 17:45:04.250 | 6AH5.CME [CBV][M] Monthly #4 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2025-01-05 17:45:04.250 | 6AH5.CME [CBV][M] Monthly #4 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2025-01-05 17:45:04.978 | 6AH5.CME [CBV][M] Daily #6 | Chart data loading complete.
2025-01-05 17:45:04.978 | HD Request # 34 | Receiving historical Daily data for SIH5.COMEX starting at 2024-12-31.
2025-01-05 17:45:04.978 | HD Request # 34 | Writing historical Daily data to the file SIH5.COMEX.dly.
2025-01-05 17:45:04.980 | HD Request # 34 | Bytes received: 219
2025-01-05 17:45:04.980 | HD Request # 34 | Received 4 Daily data records from 2024-12-31 00:00:00 to 2025-01-03 00:00:00 (4.0 days) and wrote 3 records for SIH5.COMEX
2025-01-05 17:45:04.980 | HD Request # 34 | Completion time: 2s.
2025-01-05 17:45:04.980 | HD Request # 34 | Daily data download complete for SIH5.COMEX. Unique request ID: 33
2025-01-05 17:45:04.981 | Removing historical data download ID 33.
2025-01-05 17:45:04.981 | Triggering next historical data download in queue.
2025-01-05 17:45:04.982 | HD Request # 35 | Downloading Historical Daily chart data for ESH5.CME. Starting date: 2024-12-31. Service: rithmic.trading
2025-01-05 17:45:05.020 | SIH5.COMEX [CBV][M] Monthly #4 | Reloading chart.
2025-01-05 17:45:05.020 | SIH5.COMEX [CBV][M] Monthly #4 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2025-01-05 17:45:05.020 | SIH5.COMEX [CBV][M] Monthly #4 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2025-01-05 17:45:05.636 | 6AH5.CME [CBV][M] Monthly #4 | Chart data loading complete.
2025-01-05 17:45:05.739 | SIH5.COMEX [CBV][M] Monthly #4 | Chart data loading complete.
2025-01-05 17:45:06.004 | SIH5.COMEX [CBV][M] Daily #6 | Reloading chart.
2025-01-05 17:45:06.004 | SIH5.COMEX [CBV][M] Daily #6 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2025-01-05 17:45:06.004 | SIH5.COMEX [CBV][M] Daily #6 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2025-01-05 17:45:06.602 | HD Request # 35 | Requesting historical Daily data for ESH25 starting at 2024-12-30. SC External HD service.
2025-01-05 17:45:06.603 | SIH5.COMEX [CBV][M] Weekly #5 | Reloading chart.
2025-01-05 17:45:06.603 | SIH5.COMEX [CBV][M] Weekly #5 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2025-01-05 17:45:06.603 | SIH5.COMEX [CBV][M] Weekly #5 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2025-01-05 17:45:07.224 | SIH5.COMEX [CBV][M] Daily #6 | Chart data loading complete.
2025-01-05 17:45:07.364 | SIH5.COMEX [CBV][M] Weekly #5 | Chart data loading complete.
2025-01-05 17:45:07.869 | HD Request # 35 | Receiving historical Daily data for ESH5.CME starting at 2024-12-31.
2025-01-05 17:45:07.869 | HD Request # 35 | Writing historical Daily data to the file ESH5.CME.dly.
2025-01-05 17:45:07.870 | HD Request # 35 | Bytes received: 252
2025-01-05 17:45:07.870 | HD Request # 35 | Received 4 Daily data records from 2024-12-31 00:00:00 to 2025-01-03 00:00:00 (4.0 days) and wrote 3 records for ESH5.CME
2025-01-05 17:45:07.871 | HD Request # 35 | Completion time: 3s.
2025-01-05 17:45:07.871 | HD Request # 35 | Daily data download complete for ESH5.CME. Unique request ID: 35
2025-01-05 17:45:07.871 | Removing historical data download ID 35.
2025-01-05 17:45:07.871 | Triggering next historical data download in queue.
2025-01-05 17:45:07.872 | HD Request # 36 | Downloading Historical Daily chart data for NQH5.CME. Starting date: 2024-12-31. Service: rithmic.trading
2025-01-05 17:45:08.032 | ESH5.CME [CBV][M] Weekly #5 | Reloading chart.
2025-01-05 17:45:08.032 | ESH5.CME [CBV][M] Weekly #5 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2025-01-05 17:45:08.032 | ESH5.CME [CBV][M] Weekly #5 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2025-01-05 17:45:08.515 | ESH5.CME [CBV][M] Weekly #5 | Chart data loading complete.
2025-01-05 17:45:08.579 | ESH5.CME [CBV][M] Daily #6 | Reloading chart.
2025-01-05 17:45:08.579 | ESH5.CME [CBV][M] Daily #6 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2025-01-05 17:45:08.579 | ESH5.CME [CBV][M] Daily #6 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2025-01-05 17:45:08.912 | ESH5.CME [CBV][M] Monthly #4 | Reloading chart.
2025-01-05 17:45:08.912 | ESH5.CME [CBV][M] Monthly #4 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2025-01-05 17:45:08.912 | ESH5.CME [CBV][M] Monthly #4 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2025-01-05 17:45:09.279 | ESH5.CME [CBV][M] Daily #6 | Chart data loading complete.
2025-01-05 17:45:09.279 | HD Request # 36 | Requesting historical Daily data for NQH25 starting at 2024-12-30. SC External HD service.
2025-01-05 17:45:09.338 | ESH5.CME [CBV][M] Monthly #4 | Chart data loading complete.
2025-01-05 17:45:10.170 | HD Request # 36 | Receiving historical Daily data for NQH5.CME starting at 2024-12-31.
2025-01-05 17:45:10.170 | HD Request # 36 | Writing historical Daily data to the file NQH5.CME.dly.
2025-01-05 17:45:10.171 | HD Request # 36 | Bytes received: 249
2025-01-05 17:45:10.171 | HD Request # 36 | Received 4 Daily data records from 2024-12-31 00:00:00 to 2025-01-03 00:00:00 (4.0 days) and wrote 3 records for NQH5.CME
2025-01-05 17:45:10.171 | HD Request # 36 | Completion time: 3s.
2025-01-05 17:45:10.171 | HD Request # 36 | Daily data download complete for NQH5.CME. Unique request ID: 36
2025-01-05 17:45:10.171 | Removing historical data download ID 36.
2025-01-05 17:45:10.171 | Triggering next historical data download in queue.
2025-01-05 17:45:10.172 | HD Request # 37 | Downloading Historical Daily chart data for GCG5.COMEX. Starting date: 2024-12-31. Service: rithmic.trading
2025-01-05 17:45:10.189 | NQH5.CME [CBV][M] Weekly #5 | Reloading chart.
2025-01-05 17:45:10.189 | NQH5.CME [CBV][M] Weekly #5 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2025-01-05 17:45:10.189 | NQH5.CME [CBV][M] Weekly #5 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2025-01-05 17:45:10.620 | NQH5.CME [CBV][M] Weekly #5 | Chart data loading complete.
2025-01-05 17:45:10.894 | NQH5.CME [CBV][M] Monthly #4 | Reloading chart.
2025-01-05 17:45:10.894 | NQH5.CME [CBV][M] Monthly #4 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2025-01-05 17:45:10.894 | NQH5.CME [CBV][M] Monthly #4 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2025-01-05 17:45:11.250 | NQH5.CME [CBV][M] Monthly #4 | Chart data loading complete.
2025-01-05 17:45:11.316 | NQH5.CME [CBV][M] Daily #6 | Reloading chart.
2025-01-05 17:45:11.316 | NQH5.CME [CBV][M] Daily #6 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2025-01-05 17:45:11.316 | NQH5.CME [CBV][M] Daily #6 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2025-01-05 17:45:11.611 | HD Request # 37 | Requesting historical Daily data for GCG25 starting at 2024-12-30. SC External HD service.
2025-01-05 17:45:11.696 | NQH5.CME [CBV][M] Daily #6 | Chart data loading complete.
2025-01-05 17:45:12.514 | HD Request # 37 | Receiving historical Daily data for GCG5.COMEX starting at 2024-12-31.
2025-01-05 17:45:12.514 | HD Request # 37 | Writing historical Daily data to the file GCG5.COMEX.dly.
2025-01-05 17:45:12.515 | HD Request # 37 | Bytes received: 223
2025-01-05 17:45:12.515 | HD Request # 37 | Received 4 Daily data records from 2024-12-31 00:00:00 to 2025-01-03 00:00:00 (4.0 days) and wrote 3 records for GCG5.COMEX
2025-01-05 17:45:12.515 | HD Request # 37 | Completion time: 2s.
2025-01-05 17:45:12.515 | HD Request # 37 | Daily data download complete for GCG5.COMEX. Unique request ID: 37
2025-01-05 17:45:12.515 | Removing historical data download ID 37.
2025-01-05 17:45:12.515 | No download requests in the queue to start downloads for.
2025-01-05 17:45:12.686 | GCG5.COMEX [CBV][M] Weekly #5 | Reloading chart.
2025-01-05 17:45:12.686 | GCG5.COMEX [CBV][M] Weekly #5 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2025-01-05 17:45:12.686 | GCG5.COMEX [CBV][M] Weekly #5 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2025-01-05 17:45:13.344 | GCG5.COMEX [CBV][M] Monthly #4 | Reloading chart.
2025-01-05 17:45:13.344 | GCG5.COMEX [CBV][M] Monthly #4 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2025-01-05 17:45:13.344 | GCG5.COMEX [CBV][M] Monthly #4 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2025-01-05 17:45:14.021 | GCG5.COMEX [CBV][M] Weekly #5 | Chart data loading complete.
2025-01-05 17:45:14.077 | GCG5.COMEX [CBV][M] Daily #6 | Reloading chart.
2025-01-05 17:45:14.077 | GCG5.COMEX [CBV][M] Daily #6 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2025-01-05 17:45:14.077 | GCG5.COMEX [CBV][M] Daily #6 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2025-01-05 17:45:14.739 | GCG5.COMEX [CBV][M] Monthly #4 | Chart data loading complete.
2025-01-05 17:45:14.904 | GCG5.COMEX [CBV][M] Daily #6 | Chart data loading complete.
2025-01-05 18:00:00.096 | Opened cached Intraday file: C:\SierraChart - TopStep\Data\ESH5.CME.scid. Thread ID: 16528
2025-01-05 18:00:00.096 | Opened cached Intraday file: C:\SierraChart - TopStep\Data\SPX500.scid. Thread ID: 16528
2025-01-05 18:00:00.096 | Opened cached Intraday file: C:\SierraChart - TopStep\Data\6AH5.CME.scid. Thread ID: 16528
2025-01-05 18:00:00.096 | Opened cached Intraday file: C:\SierraChart - TopStep\Data\M6AH5.CME.scid. Thread ID: 16528
2025-01-05 18:00:05.142 | Opened cached Intraday file: C:\SierraChart - TopStep\Data\MESH5.CME.scid. Thread ID: 16528
2025-01-05 18:00:05.142 | Opened cached Intraday file: C:\SierraChart - TopStep\Data\NQH5.CME.scid. Thread ID: 16528
2025-01-05 18:00:05.142 | Opened cached Intraday file: C:\SierraChart - TopStep\Data\MNQH5.CME.scid. Thread ID: 16528
2025-01-05 18:00:05.143 | Opened cached Intraday file: C:\SierraChart - TopStep\Data\GCG5.COMEX.scid. Thread ID: 16528
2025-01-05 18:00:05.143 | Opened cached Intraday file: C:\SierraChart - TopStep\Data\MGCG5.COMEX.scid. Thread ID: 16528
2025-01-05 18:00:05.143 | Opened cached Intraday file: C:\SierraChart - TopStep\Data\SIH5.COMEX.scid. Thread ID: 16528
2025-01-05 18:00:05.143 | Opened cached Intraday file: C:\SierraChart - TopStep\Data\SILH5.COMEX.scid. Thread ID: 16528
2025-01-05 18:31:52.962 | HTTPS connection ID:3 to downloads.rithmic.com:443 for request ID:3 (3) | Creating socket. Using TLS 1.2.
2025-01-05 18:31:52.962 | HTTPS connection ID:3 to downloads.rithmic.com:443 for request ID:3 (3) | New receive buffer size: 0
2025-01-05 18:31:52.962 | HTTPS connection ID:3 to downloads.rithmic.com:443 for request ID:3 (3) | Connecting to IP: 216.66.0.130.
2025-01-05 18:31:54.450 | Rithmic Direct - DTC | Wrote file: C:\SierraChart - TopStep\RithmicConnections.json. Size: 81131
2025-01-05 18:31:54.450 | Rithmic Direct - DTC | Processed connection points. Count: 347
2025-01-05 18:31:55.112 | HTTPS connection ID:3 to downloads.rithmic.com:443 for request ID:3 (3) | CloseSocket call.
2025-01-05 18:31:55.113 | HTTPS connection ID:3 to downloads.rithmic.com:443 for request ID:3 (3) | Shutdown started. Waiting for graceful close.
2025-01-05 18:31:55.346 | HTTPS connection ID:3 to downloads.rithmic.com:443 for request ID:3 (3) | Socket gracefully closed by remote side.
2025-01-05 18:31:55.346 | HTTPS connection ID:3 to downloads.rithmic.com:443 for request ID:3 (3) | Closed.
2025-01-05 18:47:28.425 | Chat | Message response. Chat ID: 429. Request ID: 1134629340
2025-01-05 19:00:00.165 | ESH5.CME [CBV][M] Daily #6 | Reloading Historical Daily chart due to current quote data for new date received.
2025-01-05 19:00:00.166 | Added historical Daily data request for GCG5.COMEX to the queue.
2025-01-05 19:00:00.166 | Triggering next historical data download in queue.
2025-01-05 19:00:00.167 | HD Request # 38 | Downloading Historical Daily chart data for GCG5.COMEX. Starting date: 2024-12-31. Service: rithmic.trading
2025-01-05 19:00:00.243 | Added historical Daily data request for NQH5.CME to the queue.
2025-01-05 19:00:00.243 | Triggering next historical data download in queue.
2025-01-05 19:00:00.243 | NQH5.CME [CBV][M] Daily #6 | Reloading Historical Daily chart due to current quote data for new date received.
2025-01-05 19:00:00.244 | Added historical Daily data request for ESH5.CME to the queue.
2025-01-05 19:00:00.244 | Triggering next historical data download in queue.
2025-01-05 19:00:00.245 | Added historical Daily data request for SIH5.COMEX to the queue.
2025-01-05 19:00:00.245 | Triggering next historical data download in queue.
2025-01-05 19:00:01.044 | ESH5.CME [CBV][M] Daily #6 | Reloading chart.
2025-01-05 19:00:01.044 | ESH5.CME [CBV][M] Daily #6 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2025-01-05 19:00:01.044 | ESH5.CME [CBV][M] Daily #6 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2025-01-05 19:00:01.220 | ESH5.CME [CBV][M] Daily #6 | Waiting for historical downloads to complete with the IDs: 40,
2025-01-05 19:00:01.297 | Added historical Daily data request for 6AH5.CME to the queue.
2025-01-05 19:00:01.297 | Triggering next historical data download in queue.
2025-01-05 19:00:01.299 | NQH5.CME [CBV][M] Daily #6 | Reloading chart.
2025-01-05 19:00:01.299 | NQH5.CME [CBV][M] Daily #6 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2025-01-05 19:00:01.299 | NQH5.CME [CBV][M] Daily #6 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2025-01-05 19:00:01.479 | NQH5.CME [CBV][M] Daily #6 | Waiting for historical downloads to complete with the IDs: 39,
2025-01-05 19:00:01.479 | HD Request # 38 | JSON parse error of SC External HD service: Invalid value.
2025-01-05 19:00:01.479 | HD Request # 38 | Error downloading historical Daily data for GCG5.COMEX. The server returned an error.
2025-01-05 19:00:01.479 | HD Request # 38 | Received 0 Daily data records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for GCG5.COMEX
2025-01-05 19:00:01.479 | HD Request # 38 | Completion time: 1s.
2025-01-05 19:00:01.479 | HD Request # 38 | Daily data download complete for GCG5.COMEX. Unique request ID: 38
2025-01-05 19:00:01.479 | Removing historical data download ID 38.
2025-01-05 19:00:01.479 | Triggering next historical data download in queue.
2025-01-05 19:00:01.480 | HD Request # 39 | Downloading Historical Daily chart data for NQH5.CME. Starting date: 2024-12-31. Service: rithmic.trading
2025-01-05 19:00:01.481 | GCG5.COMEX [CBV][M] Monthly #4 | Reloading chart.
2025-01-05 19:00:01.481 | GCG5.COMEX [CBV][M] Monthly #4 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2025-01-05 19:00:01.481 | GCG5.COMEX [CBV][M] Monthly #4 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2025-01-05 19:00:02.208 | GCG5.COMEX [CBV][M] Monthly #4 | Chart data loading complete.
2025-01-05 19:00:02.890 | HD Request # 39 | JSON parse error of SC External HD service: The document root must not be followed by other values.
2025-01-05 19:00:02.890 | HD Request # 39 | Error downloading historical Daily data for NQH5.CME. The server returned an error.
2025-01-05 19:00:02.890 | HD Request # 39 | Received 0 Daily data records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for NQH5.CME
2025-01-05 19:00:02.890 | HD Request # 39 | Completion time: 1s.
2025-01-05 19:00:02.890 | HD Request # 39 | Daily data download complete for NQH5.CME. Unique request ID: 39
2025-01-05 19:00:02.890 | Removing historical data download ID 39.
2025-01-05 19:00:02.890 | Triggering next historical data download in queue.
2025-01-05 19:00:02.891 | HD Request # 40 | Downloading Historical Daily chart data for ESH5.CME. Starting date: 2024-12-31. Service: rithmic.trading
2025-01-05 19:00:02.892 | GCG5.COMEX [CBV][M] Daily #6 | Reloading chart.
2025-01-05 19:00:02.892 | GCG5.COMEX [CBV][M] Daily #6 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2025-01-05 19:00:02.892 | GCG5.COMEX [CBV][M] Daily #6 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2025-01-05 19:00:03.530 | NQH5.CME [CBV][M] Weekly #5 | Reloading chart.
2025-01-05 19:00:03.530 | NQH5.CME [CBV][M] Weekly #5 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2025-01-05 19:00:03.530 | NQH5.CME [CBV][M] Weekly #5 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2025-01-05 19:00:03.815 | GCG5.COMEX [CBV][M] Daily #6 | Chart data loading complete.
2025-01-05 19:00:03.816 | GCG5.COMEX [CBV][M] Weekly #5 | Reloading chart.
2025-01-05 19:00:03.816 | GCG5.COMEX [CBV][M] Weekly #5 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2025-01-05 19:00:03.816 | GCG5.COMEX [CBV][M] Weekly #5 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2025-01-05 19:00:04.452 | NQH5.CME [CBV][M] Weekly #5 | Chart data loading complete.
2025-01-05 19:00:04.452 | HD Request # 40 | Requesting historical Daily data for ESH25 starting at 2024-12-30. SC External HD service.
2025-01-05 19:00:04.525 | NQH5.CME [CBV][M] Daily #6 | Download is complete for all contract months in chart. Proceeding with data load.
2025-01-05 19:00:04.526 | NQH5.CME [CBV][M] Daily #6 | Reloading chart.
2025-01-05 19:00:04.633 | GCG5.COMEX [CBV][M] Weekly #5 | Chart data loading complete.
2025-01-05 19:00:04.634 | NQH5.CME [CBV][M] Monthly #4 | Reloading chart.
2025-01-05 19:00:04.634 | NQH5.CME [CBV][M] Monthly #4 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2025-01-05 19:00:04.634 | NQH5.CME [CBV][M] Monthly #4 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2025-01-05 19:00:04.919 | NQH5.CME [CBV][M] Daily #6 | Chart data loading complete.
2025-01-05 19:00:04.920 | 6AH5.CME [CBV][M] Daily #6 | Reloading Historical Daily chart due to current quote data for new date received.
2025-01-05 19:00:04.957 | NQH5.CME [CBV][M] Monthly #4 | Chart data loading complete.
2025-01-05 19:00:05.585 | HD Request # 40 | Receiving historical Daily data for ESH5.CME starting at 2024-12-31.
2025-01-05 19:00:05.585 | HD Request # 40 | Writing historical Daily data to the file ESH5.CME.dly.
2025-01-05 19:00:05.586 | HD Request # 40 | Bytes received: 252
2025-01-05 19:00:05.586 | HD Request # 40 | Received 4 Daily data records from 2024-12-31 00:00:00 to 2025-01-03 00:00:00 (4.0 days) and wrote 3 records for ESH5.CME
2025-01-05 19:00:05.587 | HD Request # 40 | Completion time: 3s.
2025-01-05 19:00:05.587 | HD Request # 40 | Daily data download complete for ESH5.CME. Unique request ID: 40
2025-01-05 19:00:05.587 | Removing historical data download ID 40.
2025-01-05 19:00:05.587 | Triggering next historical data download in queue.
2025-01-05 19:00:05.588 | HD Request # 41 | Downloading Historical Daily chart data for SIH5.COMEX. Starting date: 2024-12-31. Service: rithmic.trading
2025-01-05 19:00:05.697 | ESH5.CME [CBV][M] Daily #6 | Download is complete for all contract months in chart. Proceeding with data load.
2025-01-05 19:00:05.697 | ESH5.CME [CBV][M] Daily #6 | Reloading chart.
2025-01-05 19:00:05.927 | ESH5.CME [CBV][M] Daily #6 | Chart data loading complete.
2025-01-05 19:00:05.928 | ESH5.CME [CBV][M] Monthly #4 | Reloading chart.
2025-01-05 19:00:05.928 | ESH5.CME [CBV][M] Monthly #4 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2025-01-05 19:00:05.928 | ESH5.CME [CBV][M] Monthly #4 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2025-01-05 19:00:06.250 | ESH5.CME [CBV][M] Weekly #5 | Reloading chart.
2025-01-05 19:00:06.250 | ESH5.CME [CBV][M] Weekly #5 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2025-01-05 19:00:06.250 | ESH5.CME [CBV][M] Weekly #5 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2025-01-05 19:00:06.576 | ESH5.CME [CBV][M] Monthly #4 | Chart data loading complete.
2025-01-05 19:00:06.578 | 6AH5.CME [CBV][M] Daily #6 | Reloading chart.
2025-01-05 19:00:06.578 | 6AH5.CME [CBV][M] Daily #6 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2025-01-05 19:00:06.578 | 6AH5.CME [CBV][M] Daily #6 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2025-01-05 19:00:06.735 | 6AH5.CME [CBV][M] Daily #6 | Waiting for historical downloads to complete with the IDs: 42,
2025-01-05 19:00:06.737 | ESH5.CME [CBV][M] Weekly #5 | Chart data loading complete.
2025-01-05 19:00:06.737 | HD Request # 41 | Requesting historical Daily data for SIH25 starting at 2024-12-30. SC External HD service.
2025-01-05 19:00:06.793 | NQH5.CME [CBV][M] Daily #6 | Reloading chart.
2025-01-05 19:00:06.793 | NQH5.CME [CBV][M] Daily #6 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2025-01-05 19:00:06.793 | NQH5.CME [CBV][M] Daily #6 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2025-01-05 19:00:07.118 | NQH5.CME [CBV][M] Daily #6 | Chart data loading complete.
2025-01-05 19:00:07.697 | HD Request # 41 | Receiving historical Daily data for SIH5.COMEX starting at 2024-12-31.
2025-01-05 19:00:07.698 | HD Request # 41 | Writing historical Daily data to the file SIH5.COMEX.dly.
2025-01-05 19:00:07.699 | HD Request # 41 | Bytes received: 219
2025-01-05 19:00:07.699 | HD Request # 41 | Received 4 Daily data records from 2024-12-31 00:00:00 to 2025-01-03 00:00:00 (4.0 days) and wrote 3 records for SIH5.COMEX
2025-01-05 19:00:07.699 | HD Request # 41 | Completion time: 2s.
2025-01-05 19:00:07.699 | HD Request # 41 | Daily data download complete for SIH5.COMEX. Unique request ID: 41
2025-01-05 19:00:07.699 | Removing historical data download ID 41.
2025-01-05 19:00:07.699 | Triggering next historical data download in queue.
2025-01-05 19:00:07.700 | HD Request # 42 | Downloading Historical Daily chart data for 6AH5.CME. Starting date: 2024-12-31. Service: rithmic.trading
2025-01-05 19:00:07.809 | SIH5.COMEX [CBV][M] Weekly #5 | Reloading chart.
2025-01-05 19:00:07.809 | SIH5.COMEX [CBV][M] Weekly #5 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2025-01-05 19:00:07.809 | SIH5.COMEX [CBV][M] Weekly #5 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2025-01-05 19:00:08.471 | SIH5.COMEX [CBV][M] Weekly #5 | Chart data loading complete.
2025-01-05 19:00:08.473 | ESH5.CME [CBV][M] Daily #6 | Reloading chart.
2025-01-05 19:00:08.473 | ESH5.CME [CBV][M] Daily #6 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2025-01-05 19:00:08.473 | ESH5.CME [CBV][M] Daily #6 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2025-01-05 19:00:08.797 | SIH5.COMEX [CBV][M] Daily #6 | Reloading chart.
2025-01-05 19:00:08.797 | SIH5.COMEX [CBV][M] Daily #6 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2025-01-05 19:00:08.797 | SIH5.COMEX [CBV][M] Daily #6 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2025-01-05 19:00:09.387 | ESH5.CME [CBV][M] Daily #6 | Chart data loading complete.
2025-01-05 19:00:09.387 | HD Request # 42 | Requesting historical Daily data for A6H25 starting at 2024-12-30. SC External HD service.
2025-01-05 19:00:09.387 | SIH5.COMEX [CBV][M] Monthly #4 | Reloading chart.
2025-01-05 19:00:09.387 | SIH5.COMEX [CBV][M] Monthly #4 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2025-01-05 19:00:09.387 | SIH5.COMEX [CBV][M] Monthly #4 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2025-01-05 19:00:09.967 | SIH5.COMEX [CBV][M] Daily #6 | Chart data loading complete.
2025-01-05 19:00:10.055 | SIH5.COMEX [CBV][M] Monthly #4 | Chart data loading complete.
2025-01-05 19:00:10.770 | HD Request # 42 | Receiving historical Daily data for 6AH5.CME starting at 2024-12-31.
2025-01-05 19:00:10.770 | HD Request # 42 | Writing historical Daily data to the file 6AH5.CME.dly.
2025-01-05 19:00:10.774 | HD Request # 42 | Bytes received: 237
2025-01-05 19:00:10.774 | HD Request # 42 | Received 4 Daily data records from 2024-12-31 00:00:00 to 2025-01-03 00:00:00 (4.0 days) and wrote 3 records for 6AH5.CME
2025-01-05 19:00:10.774 | HD Request # 42 | Completion time: 3s.
2025-01-05 19:00:10.774 | HD Request # 42 | Daily data download complete for 6AH5.CME. Unique request ID: 42
2025-01-05 19:00:10.774 | Removing historical data download ID 42.
2025-01-05 19:00:10.774 | No download requests in the queue to start downloads for.
2025-01-05 19:00:10.852 | 6AH5.CME [CBV][M] Monthly #4 | Reloading chart.
2025-01-05 19:00:10.852 | 6AH5.CME [CBV][M] Monthly #4 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2025-01-05 19:00:10.852 | 6AH5.CME [CBV][M] Monthly #4 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2025-01-05 19:00:11.534 | 6AH5.CME [CBV][M] Weekly #5 | Reloading chart.
2025-01-05 19:00:11.534 | 6AH5.CME [CBV][M] Weekly #5 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2025-01-05 19:00:11.534 | 6AH5.CME [CBV][M] Weekly #5 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2025-01-05 19:00:12.220 | 6AH5.CME [CBV][M] Monthly #4 | Chart data loading complete.
2025-01-05 19:00:12.223 | 6AH5.CME [CBV][M] Daily #6 | Download is complete for all contract months in chart. Proceeding with data load.
2025-01-05 19:00:12.224 | 6AH5.CME [CBV][M] Daily #6 | Reloading chart.
2025-01-05 19:00:12.757 | 6AH5.CME [CBV][M] Weekly #5 | Chart data loading complete.
2025-01-05 19:00:12.847 | 6AH5.CME [CBV][M] Daily #6 | Chart data loading complete.
2025-01-05 19:00:13.618 | 6AH5.CME [CBV][M] Daily #6 | Reloading chart.
2025-01-05 19:00:13.618 | 6AH5.CME [CBV][M] Daily #6 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2025-01-05 19:00:13.618 | 6AH5.CME [CBV][M] Daily #6 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2025-01-05 19:00:14.398 | 6AH5.CME [CBV][M] Daily #6 | Chart data loading complete.
2025-01-05 19:02:51.496 | Rithmic Direct - DTC | There has been no activity on the network socket for 44s. Will reconnect.
2025-01-05 19:02:51.496 | Connection to the external service has been lost.
2025-01-05 19:02:52.156 | Rithmic Direct - DTC | Waiting for socket receive thread to end
2025-01-05 19:02:52.156 | DTC Client socket (1) | CloseSocket call.
2025-01-05 19:02:52.156 | DTC Client socket (1) | Max send buffers used during socket life: 4
2025-01-05 19:02:52.156 | DTC Client socket (1) | Max send buffer size during socket life: 464
2025-01-05 19:02:52.156 | DTC Client socket (1) | Shutdown started. Waiting for graceful close.
2025-01-05 19:02:52.157 | Rithmic Direct - DTC | Disconnected.
2025-01-05 19:02:52.157 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2025-01-05 19:02:52.399 | DTC Client socket (1) | Socket gracefully closed by remote side.
2025-01-05 19:02:52.399 | DTC Client socket (1) | Closed.
2025-01-05 19:02:56.470 |
2025-01-05 19:02:56.470 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated
2025-01-05 19:02:56.470 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50508
2025-01-05 19:02:56.470 | Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50508
2025-01-05 19:02:56.784 | DTC Client socket (1) | Creating socket. Using TLS 1.2.
2025-01-05 19:02:56.784 | DTC Client socket (1) | New receive buffer size: 0
2025-01-05 19:02:56.784 | DTC Client socket (1) | Connecting to IP: 216.57.156.163.
2025-01-05 19:02:57.187 | Rithmic Direct - DTC | Network connection to server complete.
2025-01-05 19:02:57.187 | Rithmic Direct - DTC | Starting socket receive thread.
2025-01-05 19:02:57.187 | Rithmic Direct - DTC | Setting DTC encoding to Binary
2025-01-05 19:02:57.187 | Rithmic Direct - DTC | Sending logon request message.
2025-01-05 19:02:58.094 | Rithmic Direct - DTC | Received logon response.
2025-01-05 19:02:58.094 | Rithmic Direct - DTC | Server Name: .
2025-01-05 19:02:58.094 | Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8
2025-01-05 19:02:58.094 | Rithmic Direct - DTC | Successfully connected.
2025-01-05 19:02:58.094 | Rithmic Direct - DTC | Trading is supported.
2025-01-05 19:02:58.094 | Rithmic Direct - DTC | Order cancel and replace is supported.
2025-01-05 19:02:58.094 | Rithmic Direct - DTC | OCO Orders supported.
2025-01-05 19:02:58.094 | Rithmic Direct - DTC | Symbol and Exchange Delimiter: .
2025-01-05 19:02:58.094 | Rithmic Direct - DTC | MarketDepthIsSupported: 0
2025-01-05 19:02:58.094 | Rithmic Direct - DTC | Connected to server complete.
2025-01-05 19:02:58.094 | Denali Data Feed | Waiting for socket receive thread to end
2025-01-05 19:02:58.095 | DTC Client socket (2) | CloseSocket call.
2025-01-05 19:02:58.095 | DTC Client socket (2) | Max send buffers used during socket life: 3
2025-01-05 19:02:58.095 | DTC Client socket (2) | Max send buffer size during socket life: 292
2025-01-05 19:02:58.095 | Denali Data Feed | Disconnected from the server.
2025-01-05 19:02:58.095 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-05 19:02:58.095 | SC Data with Depth | Waiting for socket receive thread to end
2025-01-05 19:02:58.095 | DTC Client socket (5) | CloseSocket call.
2025-01-05 19:02:58.095 | SC Data with Depth | Disconnected from the server.
2025-01-05 19:02:58.095 | DTC Client socket (5) | Shutdown started. Waiting for graceful close.
2025-01-05 19:02:58.096 | No download requests in the queue to start downloads for. | Number times message added: 3
2025-01-05 19:02:58.096 | Subscribing to symbol for symbol alert. NQZ4.CME
2025-01-05 19:02:58.096 | Mapping NQZ4.CME to NQZ24. Service code: cme
2025-01-05 19:02:58.096 | Using symbol data fast lookup vector
2025-01-05 19:02:58.096 | Denali Data Feed | Starting real-time market data updates for: NQZ4.CME (NQZ24). ID: 1 Service code: cme
2025-01-05 19:02:58.096 | Denali Data Feed | Connecting to the server ds28.sierracharts.com. Port 443
2025-01-05 19:02:58.096 | Denali Data Feed | Requesting security definition data for: NQZ4.CME (NQZ24). ID: 1
2025-01-05 19:02:58.096 | Subscribing to symbol for symbol alert. GCZ4.COMEX
2025-01-05 19:02:58.096 | Mapping GCZ4.COMEX to GCZ24. Service code: comex
2025-01-05 19:02:58.096 | Denali Data Feed | Starting real-time market data updates for: GCZ4.COMEX (GCZ24). ID: 2 Service code: comex
2025-01-05 19:02:58.096 | Denali Data Feed | Requesting security definition data for: GCZ4.COMEX (GCZ24). ID: 2
2025-01-05 19:02:58.238 | DTC Client socket (3) | Creating socket.
2025-01-05 19:02:58.238 | DTC Client socket (3) | New receive buffer size: 0
2025-01-05 19:02:58.238 | DTC Client socket (3) | Connecting to IP: 67.214.125.5.
2025-01-05 19:02:58.307 | Denali Data Feed | Failed connections: 1
2025-01-05 19:02:58.307 | DTC Client socket (3) | CloseSocket call.
2025-01-05 19:02:58.307 | Denali Data Feed | Disconnected from the server.
2025-01-05 19:02:58.307 | Denali Data Feed | Data feed disconnected. Will reconnect in 3 seconds.
2025-01-05 19:02:58.307 | DTC Client socket (3) | Closed.
2025-01-05 19:02:58.307 | Mapping SIH5.COMEX to SIH25. Service code: comex
2025-01-05 19:02:58.307 | Denali Data Feed | Starting real-time market data updates for: SIH5.COMEX (SIH25). ID: 3 Service code: comex
2025-01-05 19:02:58.307 | Denali Data Feed | Requesting security definition data for: SIH5.COMEX (SIH25). ID: 3
2025-01-05 19:02:58.307 | Added historical Intraday data request for SIH5.COMEX to the queue.
2025-01-05 19:02:58.307 | Intraday data recording state for symbol SIH5.COMEX is set to download 'Pending'.
2025-01-05 19:02:58.307 | Triggering next historical data download in queue.
2025-01-05 19:02:58.317 | Delaying start of download for SIH5.COMEX.
2025-01-05 19:02:58.317 | Mapping ESH5.CME to ESH25. Service code: cme
2025-01-05 19:02:58.317 | Denali Data Feed | Starting real-time market data updates for: ESH5.CME (ESH25). ID: 4 Service code: cme
2025-01-05 19:02:58.317 | Denali Data Feed | Requesting security definition data for: ESH5.CME (ESH25). ID: 4
2025-01-05 19:02:58.317 | Added historical Intraday data request for ESH5.CME to the queue.
2025-01-05 19:02:58.317 | Intraday data recording state for symbol ESH5.CME is set to download 'Pending'.
2025-01-05 19:02:58.317 | Triggering next historical data download in queue.
2025-01-05 19:02:58.467 | Mapping MGCG5.COMEX to MGCG25. Service code: comex
2025-01-05 19:02:58.467 | Denali Data Feed | Starting real-time market data updates for: MGCG5.COMEX (MGCG25). ID: 5 Service code: comex
2025-01-05 19:02:58.467 | Denali Data Feed | Requesting security definition data for: MGCG5.COMEX (MGCG25). ID: 5
2025-01-05 19:02:58.467 | Added historical Intraday data request for MGCG5.COMEX to the queue.
2025-01-05 19:02:58.467 | Intraday data recording state for symbol MGCG5.COMEX is set to download 'Pending'.
2025-01-05 19:02:58.467 | Triggering next historical data download in queue.
2025-01-05 19:02:58.468 | Mapping MNQH5.CME to MNQH25. Service code: cme
2025-01-05 19:02:58.468 | Denali Data Feed | Starting real-time market data updates for: MNQH5.CME (MNQH25). ID: 6 Service code: cme
2025-01-05 19:02:58.468 | Denali Data Feed | Requesting security definition data for: MNQH5.CME (MNQH25). ID: 6
2025-01-05 19:02:58.468 | Added historical Intraday data request for MNQH5.CME to the queue.
2025-01-05 19:02:58.468 | Intraday data recording state for symbol MNQH5.CME is set to download 'Pending'.
2025-01-05 19:02:58.468 | Triggering next historical data download in queue.
2025-01-05 19:02:58.507 | DTC Client socket (5) | Socket gracefully closed by remote side.
2025-01-05 19:02:58.507 | DTC Client socket (5) | Closed.
2025-01-05 19:02:58.530 | SC Data with Depth | Starting real-time market data updates for: USDX. ID: 7 Service code: fxstatscalc
2025-01-05 19:02:58.530 | SC Data with Depth | Connecting to the server ds4.sierracharts.com. Port 443
2025-01-05 19:02:58.530 | SC Data with Depth | Requesting security definition data for: USDX. ID: 7
2025-01-05 19:02:58.531 | Mapping NQH5.CME to NQH25. Service code: cme
2025-01-05 19:02:58.531 | Denali Data Feed | Starting real-time market data updates for: NQH5.CME (NQH25). ID: 8 Service code: cme
2025-01-05 19:02:58.531 | Denali Data Feed | Requesting security definition data for: NQH5.CME (NQH25). ID: 8
2025-01-05 19:02:58.531 | Added historical Intraday data request for NQH5.CME to the queue.
2025-01-05 19:02:58.531 | Intraday data recording state for symbol NQH5.CME is set to download 'Pending'.
2025-01-05 19:02:58.531 | Triggering next historical data download in queue.
2025-01-05 19:02:58.542 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-05 19:02:58.542 | DTC Client socket (2) | Closed.
2025-01-05 19:02:58.610 | Mapping GCG5.COMEX to GCG25. Service code: comex
2025-01-05 19:02:58.610 | Denali Data Feed | Starting real-time market data updates for: GCG5.COMEX (GCG25). ID: 9 Service code: comex
2025-01-05 19:02:58.610 | Denali Data Feed | Requesting security definition data for: GCG5.COMEX (GCG25). ID: 9
2025-01-05 19:02:58.610 | Added historical Intraday data request for GCG5.COMEX to the queue.
2025-01-05 19:02:58.610 | Intraday data recording state for symbol GCG5.COMEX is set to download 'Pending'.
2025-01-05 19:02:58.610 | Triggering next historical data download in queue.
2025-01-05 19:02:58.648 | DTC Client socket (3) | Creating socket.
2025-01-05 19:02:58.648 | DTC Client socket (3) | New receive buffer size: 0
2025-01-05 19:02:58.648 | DTC Client socket (3) | Connecting to IP: 67.214.125.7.
2025-01-05 19:02:58.669 | Using Bid/Ask average for last trade price for SPX500
2025-01-05 19:02:58.669 | SC Data with Depth | Starting real-time market data updates for: SPX500. ID: 10 Service code: fxcm
2025-01-05 19:02:58.669 | SC Data with Depth | Requesting security definition data for: SPX500. ID: 10
2025-01-05 19:02:58.669 | Added historical Intraday data request for SPX500 to the queue.
2025-01-05 19:02:58.669 | Intraday data recording state for symbol SPX500 is set to download 'Pending'.
2025-01-05 19:02:58.669 | Triggering next historical data download in queue.
2025-01-05 19:02:58.669 | Mapping MESH5.CME to MESH25. Service code: cme
2025-01-05 19:02:58.669 | Denali Data Feed | Starting real-time market data updates for: MESH5.CME (MESH25). ID: 11 Service code: cme
2025-01-05 19:02:58.669 | Denali Data Feed | Requesting security definition data for: MESH5.CME (MESH25). ID: 11
2025-01-05 19:02:58.669 | Added historical Intraday data request for MESH5.CME to the queue.
2025-01-05 19:02:58.669 | Intraday data recording state for symbol MESH5.CME is set to download 'Pending'.
2025-01-05 19:02:58.811 | Mapping 6AH5.CME to 6AH25. Service code: cme
2025-01-05 19:02:58.811 | Denali Data Feed | Starting real-time market data updates for: 6AH5.CME (6AH25). ID: 12 Service code: cme
2025-01-05 19:02:58.811 | Denali Data Feed | Requesting security definition data for: 6AH5.CME (6AH25). ID: 12
2025-01-05 19:02:58.811 | Added historical Intraday data request for 6AH5.CME to the queue.
2025-01-05 19:02:58.811 | Intraday data recording state for symbol 6AH5.CME is set to download 'Pending'.
2025-01-05 19:02:58.811 | Triggering next historical data download in queue.
2025-01-05 19:02:58.859 | Mapping M6AH5.CME to M6AH25. Service code: cme
2025-01-05 19:02:58.859 | Denali Data Feed | Starting real-time market data updates for: M6AH5.CME (M6AH25). ID: 13 Service code: cme
2025-01-05 19:02:58.859 | Denali Data Feed | Requesting security definition data for: M6AH5.CME (M6AH25). ID: 13
2025-01-05 19:02:58.859 | Added historical Intraday data request for M6AH5.CME to the queue.
2025-01-05 19:02:58.859 | Intraday data recording state for symbol M6AH5.CME is set to download 'Pending'.
2025-01-05 19:02:58.859 | Triggering next historical data download in queue.
2025-01-05 19:02:58.881 | Mapping SILH5.COMEX to SILH25. Service code: comex
2025-01-05 19:02:58.881 | Denali Data Feed | Starting real-time market data updates for: SILH5.COMEX (SILH25). ID: 14 Service code: comex
2025-01-05 19:02:58.881 | Denali Data Feed | Requesting security definition data for: SILH5.COMEX (SILH25). ID: 14
2025-01-05 19:02:58.881 | Added historical Intraday data request for SILH5.COMEX to the queue.
2025-01-05 19:02:58.881 | Intraday data recording state for symbol SILH5.COMEX is set to download 'Pending'.
2025-01-05 19:02:58.881 | Triggering next historical data download in queue.
2025-01-05 19:02:58.881 | Mapping ESU4.CME to ESU24. Service code: cme
2025-01-05 19:02:58.881 | Denali Data Feed | Starting real-time market data updates for: ESU4.CME (ESU24). ID: 15 Service code: cme
2025-01-05 19:02:58.881 | Denali Data Feed | Requesting security definition data for: ESU4.CME (ESU24). ID: 15
2025-01-05 19:02:58.881 | Added historical Intraday data request for ESU4.CME to the queue.
2025-01-05 19:02:58.881 | Intraday data recording state for symbol ESU4.CME is set to download 'Pending'.
2025-01-05 19:02:58.883 | Added historical Intraday data request for USDX to the queue.
2025-01-05 19:02:58.883 | Intraday data recording state for symbol USDX is set to download 'Pending'.
2025-01-05 19:02:58.883 | Triggering next historical data download in queue.
2025-01-05 19:02:58.899 | SC Data with Depth | Network connection to server complete.
2025-01-05 19:02:58.899 | SC Data with Depth | Starting socket receive thread.
2025-01-05 19:02:58.899 | SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: high
2025-01-05 19:02:59.240 | SC Data with Depth | Setting DTC encoding to Binary VLS
2025-01-05 19:02:59.240 | SC Data with Depth | Sending logon request message.
2025-01-05 19:02:59.985 | SC Data with Depth | Received logon response.
2025-01-05 19:02:59.985 | SC Data with Depth | Server Name: SC Realtime Server.
2025-01-05 19:02:59.985 | SC Data with Depth | Server protocol version: 8. Client protocol version: 8
2025-01-05 19:02:59.985 | SC Data with Depth | Successfully connected.
2025-01-05 19:02:59.985 | SC Data with Depth | Trading is not supported.
2025-01-05 19:02:59.985 | SC Data with Depth | MarketDepthIsSupported: 1
2025-01-05 19:02:59.985 | SC Data with Depth | Restarting real-time data updates for symbol: SPX500
2025-01-05 19:02:59.985 | SC Data with Depth | Restarting real-time data updates for symbol: USDX
2025-01-05 19:03:00.729 | SC Data with Depth | Setting external service identifier for symbol SPX500 to 55
2025-01-05 19:03:00.729 | SC Data with Depth | Received security definition for symbol SPX500
2025-01-05 19:03:00.729 | SC Data with Depth | Setting external service identifier for symbol USDX to 1
2025-01-05 19:03:00.729 | SC Data with Depth | Received security definition for symbol USDX
2025-01-05 19:03:01.307 | Denali Data Feed | Connecting to the server ds28.sierracharts.com. Port 443
2025-01-05 19:03:01.307 | DTC Client socket (2) | Creating socket.
2025-01-05 19:03:01.307 | DTC Client socket (2) | New receive buffer size: 0
2025-01-05 19:03:01.307 | DTC Client socket (2) | Connecting to IP: 67.214.125.5.
2025-01-05 19:03:01.616 | Denali Data Feed | Network connection to server complete.
2025-01-05 19:03:01.616 | Denali Data Feed | Starting socket receive thread.
2025-01-05 19:03:01.616 | Denali Data Feed | Sending encoding request to server: Binary VLS. Compression: high
2025-01-05 19:03:01.886 | Denali Data Feed | Setting DTC encoding to Binary VLS
2025-01-05 19:03:01.886 | Denali Data Feed | Sending logon request message.
2025-01-05 19:03:02.640 | Denali Data Feed | Received logon response.
2025-01-05 19:03:02.640 | Denali Data Feed | Server Name: SC Realtime Server.
2025-01-05 19:03:02.640 | Denali Data Feed | Server protocol version: 8. Client protocol version: 8
2025-01-05 19:03:02.640 | Denali Data Feed | Successfully connected.
2025-01-05 19:03:02.640 | Denali Data Feed | Trading is not supported.
2025-01-05 19:03:02.640 | Denali Data Feed | MarketDepthIsSupported: 1
2025-01-05 19:03:02.640 | Denali Data Feed | Restarting real-time data updates for symbol: 6AH5.CME -> 6AH25
2025-01-05 19:03:02.640 | Denali Data Feed | Restarting real-time data updates for symbol: ESH5.CME -> ESH25
2025-01-05 19:03:02.640 | Denali Data Feed | Restarting real-time data updates for symbol: ESU4.CME -> ESU24
2025-01-05 19:03:02.640 | Denali Data Feed | Restarting real-time data updates for symbol: GCG5.COMEX -> GCG25
2025-01-05 19:03:02.640 | Denali Data Feed | Restarting real-time data updates for symbol: GCZ4.COMEX -> GCZ24
2025-01-05 19:03:02.640 | Denali Data Feed | Restarting real-time data updates for symbol: M6AH5.CME -> M6AH25
2025-01-05 19:03:02.640 | Denali Data Feed | Restarting real-time data updates for symbol: MESH5.CME -> MESH25
2025-01-05 19:03:02.640 | Denali Data Feed | Restarting real-time data updates for symbol: MGCG5.COMEX -> MGCG25
2025-01-05 19:03:02.640 | Denali Data Feed | Restarting real-time data updates for symbol: MNQH5.CME -> MNQH25
2025-01-05 19:03:02.640 | Denali Data Feed | Restarting real-time data updates for symbol: NQH5.CME -> NQH25
2025-01-05 19:03:02.640 | Denali Data Feed | Restarting real-time data updates for symbol: NQZ4.CME -> NQZ24
2025-01-05 19:03:02.640 | Denali Data Feed | Restarting real-time data updates for symbol: SIH5.COMEX -> SIH25
2025-01-05 19:03:02.640 | Denali Data Feed | Restarting real-time data updates for symbol: SILH5.COMEX -> SILH25
2025-01-05 19:03:03.158 | Requesting market depth updates for: 6AH5.CME if supported. NumLevels=50
2025-01-05 19:03:03.158 | Requesting market depth updates for: ESH5.CME if supported. NumLevels=50
2025-01-05 19:03:03.158 | Requesting market depth updates for: ESU4.CME if supported. NumLevels=50
2025-01-05 19:03:03.158 | Requesting market depth updates for: GCG5.COMEX if supported. NumLevels=50
2025-01-05 19:03:03.158 | Requesting market depth updates for: MESH5.CME if supported. NumLevels=50
2025-01-05 19:03:03.158 | Requesting market depth updates for: MGCG5.COMEX if supported. NumLevels=50
2025-01-05 19:03:03.158 | Requesting market depth updates for: MNQH5.CME if supported. NumLevels=50
2025-01-05 19:03:03.158 | Requesting market depth updates for: NQH5.CME if supported. NumLevels=50
2025-01-05 19:03:03.158 | Requesting market depth updates for: SIH5.COMEX if supported. NumLevels=50
2025-01-05 19:03:03.414 | Denali Data Feed | Setting external service identifier for symbol 6AH5.CME to 52126
2025-01-05 19:03:03.414 | Denali Data Feed | Received security definition for symbol 6AH5.CME
2025-01-05 19:03:03.414 | Denali Data Feed | Setting external service identifier for symbol ESH5.CME to 5002
2025-01-05 19:03:03.414 | Denali Data Feed | Received security definition for symbol ESH5.CME
2025-01-05 19:03:03.414 | Denali Data Feed | Real-time data for symbol ESU4.CME is currently unavailable.
2025-01-05 19:03:03.414 | Denali Data Feed | Received security definition for symbol ESU4.CME
2025-01-05 19:03:03.414 | Denali Data Feed | Setting external service identifier for symbol GCG5.COMEX to 1551
2025-01-05 19:03:03.414 | Denali Data Feed | Received security definition for symbol GCG5.COMEX
2025-01-05 19:03:03.414 | Denali Data Feed | Real-time data for symbol GCZ4.COMEX is currently unavailable.
2025-01-05 19:03:03.414 | Denali Data Feed | Received security definition for symbol GCZ4.COMEX
2025-01-05 19:03:03.414 | Denali Data Feed | Setting external service identifier for symbol M6AH5.CME to 42185124
2025-01-05 19:03:03.414 | Denali Data Feed | Received security definition for symbol M6AH5.CME
2025-01-05 19:03:03.414 | Denali Data Feed | Setting external service identifier for symbol MESH5.CME to 42005347
2025-01-05 19:03:03.414 | Denali Data Feed | Received security definition for symbol MESH5.CME
2025-01-05 19:03:03.414 | Denali Data Feed | Setting external service identifier for symbol MGCG5.COMEX to 69
2025-01-05 19:03:03.414 | Denali Data Feed | Received security definition for symbol MGCG5.COMEX
2025-01-05 19:03:03.414 | Denali Data Feed | Setting external service identifier for symbol MNQH5.CME to 42003617
2025-01-05 19:03:03.414 | Denali Data Feed | Received security definition for symbol MNQH5.CME
2025-01-05 19:03:03.414 | Denali Data Feed | Setting external service identifier for symbol NQH5.CME to 42288528
2025-01-05 19:03:03.414 | Denali Data Feed | Received security definition for symbol NQH5.CME
2025-01-05 19:03:03.414 | Denali Data Feed | Real-time data for symbol NQZ4.CME is currently unavailable.
2025-01-05 19:03:03.414 | Denali Data Feed | Received security definition for symbol NQZ4.CME
2025-01-05 19:03:03.414 | Denali Data Feed | Setting external service identifier for symbol SIH5.COMEX to 5556
2025-01-05 19:03:03.414 | Denali Data Feed | Received security definition for symbol SIH5.COMEX
2025-01-05 19:03:03.414 | Denali Data Feed | Setting external service identifier for symbol SILH5.COMEX to 42007667
2025-01-05 19:03:03.414 | Denali Data Feed | Received security definition for symbol SILH5.COMEX
2025-01-05 19:03:03.934 | Denali Data Feed | Clearing market depth for 6AH5.CME
2025-01-05 19:03:03.934 | Denali Data Feed | Clearing market depth for ESH5.CME
2025-01-05 19:03:03.934 | Denali Data Feed | Clearing market depth for ESU4.CME
2025-01-05 19:03:03.934 | Denali Data Feed | Clearing market depth for GCG5.COMEX
2025-01-05 19:03:03.934 | Denali Data Feed | Clearing market depth for MESH5.CME
2025-01-05 19:03:03.934 | Denali Data Feed | Clearing market depth for MGCG5.COMEX
2025-01-05 19:03:03.934 | Denali Data Feed | Clearing market depth for MNQH5.CME
2025-01-05 19:03:03.934 | Denali Data Feed | Clearing market depth for NQH5.CME
2025-01-05 19:03:03.934 | Denali Data Feed | Clearing market depth for SIH5.COMEX
2025-01-05 19:03:08.690 | HD Request # 43 | Downloading Intraday chart data for SIH5.COMEX to the file SIH5.COMEX.scid. Service: comex
2025-01-05 19:03:08.691 | HD Request # 43 | Download start date-time: 2025-01-05 19:02:11.000000. File last date-time: 2025-01-05 19:02:11.323003
2025-01-05 19:03:08.691 | HD Request # 43 | Using server: ds32.sierracharts.com port 10150
2025-01-05 19:03:08.837 | Socket (4) | Creating socket.
2025-01-05 19:03:08.837 | Socket (4) | New receive buffer size: 0
2025-01-05 19:03:08.837 | Socket (4) | Connecting to IP: 67.214.125.3.
2025-01-05 19:03:09.374 | HD Request # 43 | Setting DTC encoding to Binary VLS
2025-01-05 19:03:09.374 | HD Request # 43 | Sending historical data logon request message.
2025-01-05 19:03:09.706 | HD Request # 43 | Requesting Intraday data. Start date-time: 2025-01-05 19:02:11. Record interval: 0. Symbol: SIH25
2025-01-05 19:03:09.957 | HD Request # 43 | Decompressing data.
2025-01-05 19:03:10.255 | HD Request # 43 | Receiving Intraday data for SIH5.COMEX starting at 2025-01-05 19:02:11.323000
2025-01-05 19:03:10.255 | Socket (4) | CloseSocket call.
2025-01-05 19:03:10.255 | Socket (4) | Shutdown started. Waiting for graceful close.
2025-01-05 19:03:10.260 | Historical data download thread signaled to stop.
2025-01-05 19:03:10.260 | HD Request # 43 | Timestamp of first Intraday data file record written: 2025-01-05 19:03:05.176000.
2025-01-05 19:03:10.260 | HD Request # 43 | Received 6 Intraday data records from 2025-01-05 19:02:11.323000 to 2025-01-05 19:03:05.176001 (53.9 seconds. Delay: 5.1 seconds) and wrote 2 records for SIH5.COMEX
2025-01-05 19:03:10.261 | HD Request # 43 | Add time&sales data | Remembered last file record date-time: 2025-01-06 00:03:05.176001
2025-01-05 19:03:10.261 | HD Request # 43 | Completion time: 2s.
2025-01-05 19:03:10.261 | HD Request # 43 | Intraday data download complete for SIH5.COMEX. Unique request ID: 43
2025-01-05 19:03:10.261 | Removing historical data download ID 43.
2025-01-05 19:03:10.261 | Real-time Intraday chart data file updates started for SIH5.COMEX
2025-01-05 19:03:10.261 | Intraday chart data file opened for SIH5.COMEX
2025-01-05 19:03:10.261 | HD Request # 43 | Enabling Intraday chart updating for symbol.
2025-01-05 19:03:10.261 | Triggering next historical data download in queue.
2025-01-05 19:03:10.261 | HD Request # 44 | Downloading Intraday chart data for ESH5.CME to the file ESH5.CME.scid. Service: cme
2025-01-05 19:03:10.261 | HD Request # 44 | Download start date-time: 2025-01-05 19:02:50.000000. File last date-time: 2025-01-05 19:02:50.184000
2025-01-05 19:03:10.261 | HD Request # 44 | Using server: ds32.sierracharts.com port 10149
2025-01-05 19:03:10.261 | Socket (5) | Creating socket.
2025-01-05 19:03:10.261 | Socket (5) | New receive buffer size: 0
2025-01-05 19:03:10.261 | Socket (5) | Connecting to IP: 67.214.125.3.
2025-01-05 19:03:10.508 | Socket (4) | Socket gracefully closed by remote side.
2025-01-05 19:03:10.508 | Socket (4) | Closed.
2025-01-05 19:03:10.773 | HD Request # 44 | Setting DTC encoding to Binary VLS
2025-01-05 19:03:10.773 | HD Request # 44 | Sending historical data logon request message.
2025-01-05 19:03:11.114 | HD Request # 44 | Requesting Intraday data. Start date-time: 2025-01-05 19:02:50. Record interval: 0. Symbol: ESH25
2025-01-05 19:03:11.352 | HD Request # 44 | Decompressing data.
2025-01-05 19:03:11.592 | HD Request # 44 | Receiving Intraday data for ESH5.CME starting at 2025-01-05 19:02:50.184000
2025-01-05 19:03:11.592 | Socket (5) | CloseSocket call.
2025-01-05 19:03:11.592 | Socket (5) | Shutdown started. Waiting for graceful close.
2025-01-05 19:03:11.666 | Historical data download thread signaled to stop.
2025-01-05 19:03:11.666 | HD Request # 44 | Timestamp of first Intraday data file record written: 2025-01-05 19:02:52.565000.
2025-01-05 19:03:11.666 | HD Request # 44 | Received 23 Intraday data records from 2025-01-05 19:02:50.184000 to 2025-01-05 19:03:06.170005 (16.0 seconds. Delay: 5.5 seconds) and wrote 22 records for ESH5.CME
2025-01-05 19:03:11.666 | HD Request # 44 | Add time&sales data | Remembered last file record date-time: 2025-01-06 00:03:06.170005
2025-01-05 19:03:11.666 | HD Request # 44 | Completion time: 1s.
2025-01-05 19:03:11.666 | HD Request # 44 | Intraday data download complete for ESH5.CME. Unique request ID: 44
2025-01-05 19:03:11.666 | Removing historical data download ID 44.
2025-01-05 19:03:11.666 | Real-time Intraday chart data file updates started for ESH5.CME
2025-01-05 19:03:11.666 | Intraday chart data file opened for ESH5.CME
2025-01-05 19:03:11.666 | HD Request # 44 | Enabling Intraday chart updating for symbol.
2025-01-05 19:03:11.666 | Triggering next historical data download in queue.
2025-01-05 19:03:11.666 | HD Request # 45 | Downloading Intraday chart data for MGCG5.COMEX to the file MGCG5.COMEX.scid. Service: comex
2025-01-05 19:03:11.666 | HD Request # 45 | Download start date-time: 2025-01-05 19:02:39.000000. File last date-time: 2025-01-05 19:02:39.428000
2025-01-05 19:03:11.666 | HD Request # 45 | Using server: ds32.sierracharts.com port 10150
2025-01-05 19:03:11.667 | Socket (4) | Creating socket.
2025-01-05 19:03:11.667 | Socket (4) | New receive buffer size: 0
2025-01-05 19:03:11.667 | Socket (4) | Connecting to IP: 67.214.125.3.
2025-01-05 19:03:11.832 | Socket (5) | Socket gracefully closed by remote side.
2025-01-05 19:03:11.832 | Socket (5) | Closed.
2025-01-05 19:03:12.158 | HD Request # 45 | Setting DTC encoding to Binary VLS
2025-01-05 19:03:12.158 | HD Request # 45 | Sending historical data logon request message.
2025-01-05 19:03:12.402 | HD Request # 45 | Requesting Intraday data. Start date-time: 2025-01-05 19:02:39. Record interval: 0. Symbol: MGCG25
2025-01-05 19:03:12.639 | HD Request # 45 | Decompressing data.
2025-01-05 19:03:12.875 | HD Request # 45 | Receiving Intraday data for MGCG5.COMEX starting at 2025-01-05 19:02:39.428000
2025-01-05 19:03:12.875 | Socket (4) | CloseSocket call.
2025-01-05 19:03:12.875 | Socket (4) | Shutdown started. Waiting for graceful close.
2025-01-05 19:03:13.000 | Historical data download thread signaled to stop.
2025-01-05 19:03:13.000 | HD Request # 45 | Timestamp of first Intraday data file record written: 2025-01-05 19:03:05.308000.
2025-01-05 19:03:13.000 | HD Request # 45 | Received 6 Intraday data records from 2025-01-05 19:02:39.428000 to 2025-01-05 19:03:08.030000 (28.6 seconds. Delay: 5.0 seconds) and wrote 5 records for MGCG5.COMEX
2025-01-05 19:03:13.000 | HD Request # 45 | Add time&sales data | Remembered last file record date-time: 2025-01-06 00:03:08.030000
2025-01-05 19:03:13.000 | Added 6 Time and Sales records to Intraday data file for MGCG5.COMEX after download.
2025-01-05 19:03:13.001 | HD Request # 45 | Completion time: 2s.
2025-01-05 19:03:13.001 | HD Request # 45 | Intraday data download complete for MGCG5.COMEX. Unique request ID: 45
2025-01-05 19:03:13.001 | Removing historical data download ID 45.
2025-01-05 19:03:13.001 | Real-time Intraday chart data file updates started for MGCG5.COMEX
2025-01-05 19:03:13.001 | Intraday chart data file opened for MGCG5.COMEX
2025-01-05 19:03:13.001 | HD Request # 45 | Enabling Intraday chart updating for symbol.
2025-01-05 19:03:13.001 | Triggering next historical data download in queue.
2025-01-05 19:03:13.001 | HD Request # 46 | Downloading Intraday chart data for MNQH5.CME to the file MNQH5.CME.scid. Service: cme
2025-01-05 19:03:13.001 | HD Request # 46 | Download start date-time: 2025-01-05 19:02:50.000000. File last date-time: 2025-01-05 19:02:50.955000
2025-01-05 19:03:13.001 | HD Request # 46 | Using server: ds32.sierracharts.com port 10149
2025-01-05 19:03:13.001 | Socket (5) | Creating socket.
2025-01-05 19:03:13.001 | Socket (5) | New receive buffer size: 0
2025-01-05 19:03:13.001 | Socket (5) | Connecting to IP: 67.214.125.3.
2025-01-05 19:03:13.118 | Socket (4) | Socket gracefully closed by remote side.
2025-01-05 19:03:13.118 | Socket (4) | Closed.
2025-01-05 19:03:13.530 | HD Request # 46 | Setting DTC encoding to Binary VLS
2025-01-05 19:03:13.530 | HD Request # 46 | Sending historical data logon request message.
2025-01-05 19:03:13.788 | HD Request # 46 | Requesting Intraday data. Start date-time: 2025-01-05 19:02:50. Record interval: 0. Symbol: MNQH25
2025-01-05 19:03:14.024 | HD Request # 46 | Decompressing data.
2025-01-05 19:03:14.267 | HD Request # 46 | Receiving Intraday data for MNQH5.CME starting at 2025-01-05 19:02:50.184000
2025-01-05 19:03:14.267 | Socket (5) | CloseSocket call.
2025-01-05 19:03:14.268 | Socket (5) | Shutdown started. Waiting for graceful close.
2025-01-05 19:03:14.270 | Historical data download thread signaled to stop.
2025-01-05 19:03:14.270 | HD Request # 46 | Timestamp of first Intraday data file record written: 2025-01-05 19:02:52.566000.
2025-01-05 19:03:14.270 | HD Request # 46 | Received 109 Intraday data records from 2025-01-05 19:02:50.184000 to 2025-01-05 19:03:12.443001 (22.3 seconds. Delay: 1.8 seconds) and wrote 104 records for MNQH5.CME
2025-01-05 19:03:14.270 | HD Request # 46 | Add time&sales data | Remembered last file record date-time: 2025-01-06 00:03:12.443001
2025-01-05 19:03:14.270 | Added 6 Time and Sales records to Intraday data file for MNQH5.CME after download.
2025-01-05 19:03:14.271 | HD Request # 46 | Completion time: 1s.
2025-01-05 19:03:14.271 | HD Request # 46 | Intraday data download complete for MNQH5.CME. Unique request ID: 46
2025-01-05 19:03:14.271 | Removing historical data download ID 46.
2025-01-05 19:03:14.271 | Real-time Intraday chart data file updates started for MNQH5.CME
2025-01-05 19:03:14.271 | Intraday chart data file opened for MNQH5.CME
2025-01-05 19:03:14.271 | HD Request # 46 | Enabling Intraday chart updating for symbol.
2025-01-05 19:03:14.271 | Triggering next historical data download in queue.
2025-01-05 19:03:14.271 | HD Request # 47 | Downloading Intraday chart data for NQH5.CME to the file NQH5.CME.scid. Service: cme
2025-01-05 19:03:14.271 | HD Request # 47 | Download start date-time: 2025-01-05 19:02:47.000000. File last date-time: 2025-01-05 19:02:47.279000
2025-01-05 19:03:14.271 | HD Request # 47 | Using server: ds32.sierracharts.com port 10150
2025-01-05 19:03:14.271 | Socket (4) | Creating socket.
2025-01-05 19:03:14.271 | Socket (4) | New receive buffer size: 0
2025-01-05 19:03:14.271 | Socket (4) | Connecting to IP: 67.214.125.3.
2025-01-05 19:03:14.503 | Socket (5) | Socket gracefully closed by remote side.
2025-01-05 19:03:14.504 | Socket (5) | Closed.
2025-01-05 19:03:14.689 | Opened cached Intraday file: C:\SierraChart - TopStep\Data\ESH5.CME.scid. Thread ID: 16528
2025-01-05 19:03:14.690 | Opened cached Intraday file: C:\SierraChart - TopStep\Data\MNQH5.CME.scid. Thread ID: 16528
2025-01-05 19:03:14.761 | HD Request # 47 | Setting DTC encoding to Binary VLS
2025-01-05 19:03:14.761 | HD Request # 47 | Sending historical data logon request message.
2025-01-05 19:03:14.995 | HD Request # 47 | Requesting Intraday data. Start date-time: 2025-01-05 19:02:47. Record interval: 0. Symbol: NQH25
2025-01-05 19:03:15.230 | HD Request # 47 | Decompressing data.
2025-01-05 19:03:15.469 | HD Request # 47 | Receiving Intraday data for NQH5.CME starting at 2025-01-05 19:02:47.279000
2025-01-05 19:03:15.469 | Socket (4) | CloseSocket call.
2025-01-05 19:03:15.469 | Socket (4) | Shutdown started. Waiting for graceful close.
2025-01-05 19:03:15.504 | Historical data download thread signaled to stop.
2025-01-05 19:03:15.504 | HD Request # 47 | Timestamp of first Intraday data file record written: 2025-01-05 19:02:53.358000.
2025-01-05 19:03:15.504 | HD Request # 47 | Received 9 Intraday data records from 2025-01-05 19:02:47.279000 to 2025-01-05 19:03:12.441003 (25.2 seconds. Delay: 3.1 seconds) and wrote 8 records for NQH5.CME
2025-01-05 19:03:15.505 | HD Request # 47 | Add time&sales data | Remembered last file record date-time: 2025-01-06 00:03:12.441003
2025-01-05 19:03:15.505 | Added 2 Time and Sales records to Intraday data file for NQH5.CME after download.
2025-01-05 19:03:15.505 | HD Request # 47 | Completion time: 1s.
2025-01-05 19:03:15.505 | HD Request # 47 | Intraday data download complete for NQH5.CME. Unique request ID: 47
2025-01-05 19:03:15.505 | Removing historical data download ID 47.
2025-01-05 19:03:15.505 | Real-time Intraday chart data file updates started for NQH5.CME
2025-01-05 19:03:15.505 | Intraday chart data file opened for NQH5.CME
2025-01-05 19:03:15.505 | HD Request # 47 | Enabling Intraday chart updating for symbol.
2025-01-05 19:03:15.505 | Triggering next historical data download in queue.
2025-01-05 19:03:15.505 | HD Request # 48 | Downloading Intraday chart data for GCG5.COMEX to the file GCG5.COMEX.scid. Service: comex
2025-01-05 19:03:15.505 | HD Request # 48 | Download start date-time: 2025-01-05 19:02:46.000000. File last date-time: 2025-01-05 19:02:46.106000
2025-01-05 19:03:15.505 | HD Request # 48 | Using server: ds32.sierracharts.com port 10149
2025-01-05 19:03:15.505 | Socket (5) | Creating socket.
2025-01-05 19:03:15.505 | Socket (5) | New receive buffer size: 0
2025-01-05 19:03:15.505 | Socket (5) | Connecting to IP: 67.214.125.3.
2025-01-05 19:03:15.726 | Socket (4) | Socket gracefully closed by remote side.
2025-01-05 19:03:15.726 | Socket (4) | Closed.
2025-01-05 19:03:16.015 | HD Request # 48 | Setting DTC encoding to Binary VLS
2025-01-05 19:03:16.015 | HD Request # 48 | Sending historical data logon request message.
2025-01-05 19:03:16.268 | HD Request # 48 | Requesting Intraday data. Start date-time: 2025-01-05 19:02:46. Record interval: 0. Symbol: GCG25
2025-01-05 19:03:16.504 | HD Request # 48 | Decompressing data.
2025-01-05 19:03:16.751 | HD Request # 48 | Receiving Intraday data for GCG5.COMEX starting at 2025-01-05 19:02:46.106000
2025-01-05 19:03:16.751 | Socket (5) | CloseSocket call.
2025-01-05 19:03:16.751 | Socket (5) | Shutdown started. Waiting for graceful close.
2025-01-05 19:03:16.870 | Historical data download thread signaled to stop.
2025-01-05 19:03:16.870 | HD Request # 48 | Timestamp of first Intraday data file record written: 2025-01-05 19:03:05.261000.
2025-01-05 19:03:16.870 | HD Request # 48 | Received 11 Intraday data records from 2025-01-05 19:02:46.106000 to 2025-01-05 19:03:09.708000 (23.6 seconds. Delay: 7.2 seconds) and wrote 10 records for GCG5.COMEX
2025-01-05 19:03:16.870 | HD Request # 48 | Add time&sales data | Remembered last file record date-time: 2025-01-06 00:03:09.708000
2025-01-05 19:03:16.870 | HD Request # 48 | Completion time: 1s.
2025-01-05 19:03:16.871 | HD Request # 48 | Intraday data download complete for GCG5.COMEX. Unique request ID: 48
2025-01-05 19:03:16.871 | Removing historical data download ID 48.
2025-01-05 19:03:16.871 | Real-time Intraday chart data file updates started for GCG5.COMEX
2025-01-05 19:03:16.871 | Intraday chart data file opened for GCG5.COMEX
2025-01-05 19:03:16.871 | HD Request # 48 | Enabling Intraday chart updating for symbol.
2025-01-05 19:03:16.871 | Triggering next historical data download in queue.
2025-01-05 19:03:16.871 | HD Request # 49 | Downloading Intraday chart data for SPX500 to the file SPX500.scid. Service: fxcm
2025-01-05 19:03:16.871 | HD Request # 49 | Download start date-time: 2025-01-05 19:02:50.000000. File last date-time: 2025-01-05 19:02:50.220001
2025-01-05 19:03:16.871 | HD Request # 49 | Using server: ds4.sierracharts.com port 10150
2025-01-05 19:03:16.871 | Socket (4) | Creating socket.
2025-01-05 19:03:16.871 | Socket (4) | New receive buffer size: 0
2025-01-05 19:03:16.871 | Socket (4) | Connecting to IP: 67.214.125.7.
2025-01-05 19:03:17.002 | Socket (5) | Socket gracefully closed by remote side.
2025-01-05 19:03:17.002 | Socket (5) | Closed.
2025-01-05 19:03:17.375 | HD Request # 49 | Setting DTC encoding to Binary VLS
2025-01-05 19:03:17.375 | HD Request # 49 | Sending historical data logon request message.
2025-01-05 19:03:17.655 | HD Request # 49 | Requesting Intraday data. Start date-time: 2025-01-05 19:02:50. Record interval: 0. Symbol: SPX500
2025-01-05 19:03:17.740 | HTTPS connection ID:4 to downloads.rithmic.com:443 for request ID:4 (5) | Creating socket. Using TLS 1.2.
2025-01-05 19:03:17.740 | HTTPS connection ID:4 to downloads.rithmic.com:443 for request ID:4 (5) | New receive buffer size: 0
2025-01-05 19:03:17.740 | HTTPS connection ID:4 to downloads.rithmic.com:443 for request ID:4 (5) | Connecting to IP: 216.66.0.130.
2025-01-05 19:03:17.903 | HD Request # 49 | Decompressing data.
2025-01-05 19:03:18.152 | HD Request # 49 | Receiving Intraday data for SPX500 starting at 2025-01-05 19:02:50.220000
2025-01-05 19:03:18.152 | Socket (4) | CloseSocket call.
2025-01-05 19:03:18.152 | Socket (4) | Shutdown started. Waiting for graceful close.
2025-01-05 19:03:18.192 | Historical data download thread signaled to stop.
2025-01-05 19:03:18.192 | HD Request # 49 | Timestamp of first Intraday data file record written: 2025-01-05 19:02:52.577000.
2025-01-05 19:03:18.192 | HD Request # 49 | Received 30 Intraday data records from 2025-01-05 19:02:50.220000 to 2025-01-05 19:03:16.347000 (26.1 seconds. Delay: 1.8 seconds) and wrote 28 records for SPX500
2025-01-05 19:03:18.192 | HD Request # 49 | Add time&sales data | Remembered last file record date-time: 2025-01-06 00:03:16.347000
2025-01-05 19:03:18.192 | HD Request # 49 | Completion time: 2s.
2025-01-05 19:03:18.192 | HD Request # 49 | Intraday data download complete for SPX500. Unique request ID: 49
2025-01-05 19:03:18.192 | Removing historical data download ID 49.
2025-01-05 19:03:18.192 | Real-time Intraday chart data file updates started for SPX500
2025-01-05 19:03:18.192 | Intraday chart data file opened for SPX500
2025-01-05 19:03:18.192 | HD Request # 49 | Enabling Intraday chart updating for symbol.
2025-01-05 19:03:18.192 | Triggering next historical data download in queue.
2025-01-05 19:03:18.192 | HD Request # 50 | Downloading Intraday chart data for MESH5.CME to the file MESH5.CME.scid. Service: cme
2025-01-05 19:03:18.192 | HD Request # 50 | Download start date-time: 2025-01-05 19:02:50.000000. File last date-time: 2025-01-05 19:02:50.404000
2025-01-05 19:03:18.192 | HD Request # 50 | Using server: ds32.sierracharts.com port 10149
2025-01-05 19:03:18.192 | Socket (7) | Creating socket.
2025-01-05 19:03:18.193 | Socket (7) | New receive buffer size: 0
2025-01-05 19:03:18.193 | Socket (7) | Connecting to IP: 67.214.125.3.
2025-01-05 19:03:18.400 | Socket (4) | Socket gracefully closed by remote side.
2025-01-05 19:03:18.400 | Socket (4) | Closed.
2025-01-05 19:03:18.725 | HD Request # 50 | Setting DTC encoding to Binary VLS
2025-01-05 19:03:18.725 | HD Request # 50 | Sending historical data logon request message.
2025-01-05 19:03:18.974 | HD Request # 50 | Requesting Intraday data. Start date-time: 2025-01-05 19:02:50. Record interval: 0. Symbol: MESH25
2025-01-05 19:03:19.197 | Rithmic Direct - DTC | Wrote file: C:\SierraChart - TopStep\RithmicConnections.json. Size: 81131
2025-01-05 19:03:19.198 | Rithmic Direct - DTC | Processed connection points. Count: 347
2025-01-05 19:03:19.218 | HD Request # 50 | Decompressing data.
2025-01-05 19:03:19.459 | HD Request # 50 | Receiving Intraday data for MESH5.CME starting at 2025-01-05 19:02:50.404000
2025-01-05 19:03:19.459 | Socket (7) | CloseSocket call.
2025-01-05 19:03:19.459 | Socket (7) | Shutdown started. Waiting for graceful close.
2025-01-05 19:03:19.470 | Historical data download thread signaled to stop.
2025-01-05 19:03:19.470 | HD Request # 50 | Timestamp of first Intraday data file record written: 2025-01-05 19:02:53.358000.
2025-01-05 19:03:19.470 | HD Request # 50 | Received 34 Intraday data records from 2025-01-05 19:02:50.404000 to 2025-01-05 19:03:16.325002 (25.9 seconds. Delay: 3.1 seconds) and wrote 33 records for MESH5.CME
2025-01-05 19:03:19.471 | HD Request # 50 | Add time&sales data | Remembered last file record date-time: 2025-01-06 00:03:16.325002
2025-01-05 19:03:19.471 | HD Request # 50 | Completion time: 1s.
2025-01-05 19:03:19.471 | HD Request # 50 | Intraday data download complete for MESH5.CME. Unique request ID: 50
2025-01-05 19:03:19.471 | Removing historical data download ID 50.
2025-01-05 19:03:19.471 | Real-time Intraday chart data file updates started for MESH5.CME
2025-01-05 19:03:19.471 | Intraday chart data file opened for MESH5.CME
2025-01-05 19:03:19.471 | HD Request # 50 | Enabling Intraday chart updating for symbol.
2025-01-05 19:03:19.471 | Triggering next historical data download in queue.
2025-01-05 19:03:19.471 | HD Request # 51 | Downloading Intraday chart data for 6AH5.CME to the file 6AH5.CME.scid. Service: cme
2025-01-05 19:03:19.471 | HD Request # 51 | Download start date-time: 2025-01-05 19:02:48.000000. File last date-time: 2025-01-05 19:02:48.248003
2025-01-05 19:03:19.471 | HD Request # 51 | Using server: ds32.sierracharts.com port 10150
2025-01-05 19:03:19.471 | Socket (4) | Creating socket.
2025-01-05 19:03:19.471 | Socket (4) | New receive buffer size: 0
2025-01-05 19:03:19.471 | Socket (4) | Connecting to IP: 67.214.125.3.
2025-01-05 19:03:19.704 | Socket (7) | Socket gracefully closed by remote side.
2025-01-05 19:03:19.705 | Socket (7) | Closed.
2025-01-05 19:03:19.727 | Opened cached Intraday file: C:\SierraChart - TopStep\Data\SIH5.COMEX.scid. Thread ID: 16528
2025-01-05 19:03:19.728 | Opened cached Intraday file: C:\SierraChart - TopStep\Data\MGCG5.COMEX.scid. Thread ID: 16528
2025-01-05 19:03:19.728 | Opened cached Intraday file: C:\SierraChart - TopStep\Data\NQH5.CME.scid. Thread ID: 16528
2025-01-05 19:03:19.728 | Opened cached Intraday file: C:\SierraChart - TopStep\Data\GCG5.COMEX.scid. Thread ID: 16528
2025-01-05 19:03:20.008 | HD Request # 51 | Setting DTC encoding to Binary VLS
2025-01-05 19:03:20.008 | HD Request # 51 | Sending historical data logon request message.
2025-01-05 19:03:20.258 | HD Request # 51 | Requesting Intraday data. Start date-time: 2025-01-05 19:02:48. Record interval: 0. Symbol: 6AH25
2025-01-05 19:03:20.303 | HTTPS connection ID:4 to downloads.rithmic.com:443 for request ID:4 (5) | CloseSocket call.
2025-01-05 19:03:20.303 | HTTPS connection ID:4 to downloads.rithmic.com:443 for request ID:4 (5) | Shutdown started. Waiting for graceful close.
2025-01-05 19:03:20.509 | HD Request # 51 | Decompressing data.
2025-01-05 19:03:20.536 | HTTPS connection ID:4 to downloads.rithmic.com:443 for request ID:4 (5) | Socket gracefully closed by remote side.
2025-01-05 19:03:20.536 | HTTPS connection ID:4 to downloads.rithmic.com:443 for request ID:4 (5) | Closed.
2025-01-05 19:03:20.762 | HD Request # 51 | Receiving Intraday data for 6AH5.CME starting at 2025-01-05 19:02:48.248000
2025-01-05 19:03:20.762 | Socket (4) | CloseSocket call.
2025-01-05 19:03:20.762 | Socket (4) | Shutdown started. Waiting for graceful close.
2025-01-05 19:03:20.833 | Historical data download thread signaled to stop.
2025-01-05 19:03:20.833 | HD Request # 51 | Timestamp of first Intraday data file record written: 2025-01-05 19:03:04.459000.
2025-01-05 19:03:20.833 | HD Request # 51 | Received 14 Intraday data records from 2025-01-05 19:02:48.248000 to 2025-01-05 19:03:16.317003 (28.1 seconds. Delay: 4.5 seconds) and wrote 10 records for 6AH5.CME
2025-01-05 19:03:20.834 | HD Request # 51 | Add time&sales data | Remembered last file record date-time: 2025-01-06 00:03:16.317003
2025-01-05 19:03:20.834 | HD Request # 51 | Completion time: 1s.
2025-01-05 19:03:20.834 | HD Request # 51 | Intraday data download complete for 6AH5.CME. Unique request ID: 51
2025-01-05 19:03:20.834 | Removing historical data download ID 51.
2025-01-05 19:03:20.834 | Real-time Intraday chart data file updates started for 6AH5.CME
2025-01-05 19:03:20.834 | Intraday chart data file opened for 6AH5.CME
2025-01-05 19:03:20.834 | HD Request # 51 | Enabling Intraday chart updating for symbol.
2025-01-05 19:03:20.834 | Triggering next historical data download in queue.
2025-01-05 19:03:20.834 | HD Request # 52 | Downloading Intraday chart data for M6AH5.CME to the file M6AH5.CME.scid. Service: cme
2025-01-05 19:03:20.834 | HD Request # 52 | Download start date-time: 2025-01-05 19:02:19.000000. File last date-time: 2025-01-05 19:02:19.686002
2025-01-05 19:03:20.834 | HD Request # 52 | Using server: ds32.sierracharts.com port 10149
2025-01-05 19:03:20.834 | Socket (5) | Creating socket.
2025-01-05 19:03:20.834 | Socket (5) | New receive buffer size: 0
2025-01-05 19:03:20.834 | Socket (5) | Connecting to IP: 67.214.125.3.
2025-01-05 19:03:21.014 | Socket (4) | Socket gracefully closed by remote side.
2025-01-05 19:03:21.014 | Socket (4) | Closed.
2025-01-05 19:03:21.368 | HD Request # 52 | Setting DTC encoding to Binary VLS
2025-01-05 19:03:21.368 | HD Request # 52 | Sending historical data logon request message.
2025-01-05 19:03:21.631 | HD Request # 52 | Requesting Intraday data. Start date-time: 2025-01-05 19:02:19. Record interval: 0. Symbol: M6AH25
2025-01-05 19:03:21.873 | HD Request # 52 | Decompressing data.
2025-01-05 19:03:22.160 | HD Request # 52 | Receiving Intraday data for M6AH5.CME starting at 2025-01-05 19:02:19.686000
2025-01-05 19:03:22.160 | Socket (5) | CloseSocket call.
2025-01-05 19:03:22.160 | Socket (5) | Shutdown started. Waiting for graceful close.
2025-01-05 19:03:22.198 | Historical data download thread signaled to stop.
2025-01-05 19:03:22.198 | HD Request # 52 | Timestamp of first Intraday data file record written: 2025-01-05 19:03:04.595000.
2025-01-05 19:03:22.198 | HD Request # 52 | Received 5 Intraday data records from 2025-01-05 19:02:19.686000 to 2025-01-05 19:03:04.596000 (44.9 seconds. Delay: 17.6 seconds) and wrote 2 records for M6AH5.CME
2025-01-05 19:03:22.199 | HD Request # 52 | Add time&sales data | Remembered last file record date-time: 2025-01-06 00:03:04.596000
2025-01-05 19:03:22.199 | HD Request # 52 | Completion time: 2s.
2025-01-05 19:03:22.199 | HD Request # 52 | Intraday data download complete for M6AH5.CME. Unique request ID: 52
2025-01-05 19:03:22.199 | Removing historical data download ID 52.
2025-01-05 19:03:22.199 | Real-time Intraday chart data file updates started for M6AH5.CME
2025-01-05 19:03:22.199 | Intraday chart data file opened for M6AH5.CME
2025-01-05 19:03:22.199 | HD Request # 52 | Enabling Intraday chart updating for symbol.
2025-01-05 19:03:22.199 | Triggering next historical data download in queue.
2025-01-05 19:03:22.199 | HD Request # 53 | Downloading Intraday chart data for SILH5.COMEX to the file SILH5.COMEX.scid. Service: comex
2025-01-05 19:03:22.199 | HD Request # 53 | Download start date-time: 2025-01-05 19:02:17.000000. File last date-time: 2025-01-05 19:02:17.374000
2025-01-05 19:03:22.199 | HD Request # 53 | Using server: ds32.sierracharts.com port 10150
2025-01-05 19:03:22.199 | Socket (4) | Creating socket.
2025-01-05 19:03:22.199 | Socket (4) | New receive buffer size: 0
2025-01-05 19:03:22.199 | Socket (4) | Connecting to IP: 67.214.125.3.
2025-01-05 19:03:22.402 | Socket (5) | Socket gracefully closed by remote side.
2025-01-05 19:03:22.402 | Socket (5) | Closed.
2025-01-05 19:03:22.720 | HD Request # 53 | Setting DTC encoding to Binary VLS
2025-01-05 19:03:22.720 | HD Request # 53 | Sending historical data logon request message.
2025-01-05 19:03:22.973 | HD Request # 53 | Requesting Intraday data. Start date-time: 2025-01-05 19:02:17. Record interval: 0. Symbol: SILH25
2025-01-05 19:03:23.204 | HD Request # 53 | Decompressing data.
2025-01-05 19:03:23.493 | HD Request # 53 | Receiving Intraday data for SILH5.COMEX starting at 2025-01-05 19:02:17.374000
2025-01-05 19:03:23.493 | Socket (4) | CloseSocket call.
2025-01-05 19:03:23.493 | Socket (4) | Shutdown started. Waiting for graceful close.
2025-01-05 19:03:23.558 | Historical data download thread signaled to stop.
2025-01-05 19:03:23.558 | HD Request # 53 | Received 1 Intraday data record from 2025-01-05 19:02:17.374000 to 2025-01-05 19:02:17.374000 (0.0 seconds. Delay: 66.2 seconds) and wrote 0 records for SILH5.COMEX
2025-01-05 19:03:23.558 | HD Request # 53 | Add time&sales data | Remembered last file record date-time: 2025-01-06 00:02:17.374000
2025-01-05 19:03:23.558 | HD Request # 53 | Completion time: 1s.
2025-01-05 19:03:23.558 | HD Request # 53 | Intraday data download complete for SILH5.COMEX. Unique request ID: 53
2025-01-05 19:03:23.558 | Removing historical data download ID 53.
2025-01-05 19:03:23.558 | Real-time Intraday chart data file updates started for SILH5.COMEX
2025-01-05 19:03:23.558 | Intraday chart data file opened for SILH5.COMEX
2025-01-05 19:03:23.558 | HD Request # 53 | Enabling Intraday chart updating for symbol.
2025-01-05 19:03:23.558 | Triggering next historical data download in queue.
2025-01-05 19:03:23.558 | HD Request # 54 | Downloading Intraday chart data for ESU4.CME to the file ESU4.CME.scid. Service: cme
2025-01-05 19:03:23.560 | HD Request # 54 | Download start date-time: 2024-09-20 09:29:59.000000. File last date-time: 2024-09-20 09:29:59.856000
2025-01-05 19:03:23.560 | HD Request # 54 | Using server: ds32.sierracharts.com port 10149
2025-01-05 19:03:23.560 | Socket (5) | Creating socket.
2025-01-05 19:03:23.560 | Socket (5) | New receive buffer size: 0
2025-01-05 19:03:23.560 | Socket (5) | Connecting to IP: 67.214.125.3.
2025-01-05 19:03:23.730 | Socket (4) | Socket gracefully closed by remote side.
2025-01-05 19:03:23.730 | Socket (4) | Closed.
2025-01-05 19:03:24.066 | HD Request # 54 | Setting DTC encoding to Binary VLS
2025-01-05 19:03:24.066 | HD Request # 54 | Sending historical data logon request message.
2025-01-05 19:03:24.301 | HD Request # 54 | Requesting Intraday data. Start date-time: 2024-09-20 09:29:59. Record interval: 0. Symbol: ESU24
2025-01-05 19:03:24.533 | HD Request # 54 | Decompressing data.
2025-01-05 19:03:24.769 | HD Request # 54 | Receiving Intraday data for ESU4.CME starting at 2024-09-20 09:29:59.011000
2025-01-05 19:03:24.769 | Socket (5) | CloseSocket call.
2025-01-05 19:03:24.770 | Socket (5) | Shutdown started. Waiting for graceful close.
2025-01-05 19:03:24.779 | Opened cached Intraday file: C:\SierraChart - TopStep\Data\SPX500.scid. Thread ID: 16528
2025-01-05 19:03:24.779 | Opened cached Intraday file: C:\SierraChart - TopStep\Data\MESH5.CME.scid. Thread ID: 16528
2025-01-05 19:03:24.794 | Historical data download thread signaled to stop.
2025-01-05 19:03:24.794 | HD Request # 54 | Received 12 Intraday data records from 2024-09-20 09:29:59.011000 to 2024-09-20 09:29:59.856000 (0.8 seconds. Delay: 107.4 days) and wrote 0 records for ESU4.CME
2025-01-05 19:03:24.794 | HD Request # 54 | Add time&sales data | Remembered last file record date-time: 2024-09-20 13:29:59.856000
2025-01-05 19:03:24.794 | HD Request # 54 | Completion time: 1s.
2025-01-05 19:03:24.794 | HD Request # 54 | Intraday data download complete for ESU4.CME. Unique request ID: 54
2025-01-05 19:03:24.794 | Removing historical data download ID 54.
2025-01-05 19:03:24.794 | Real-time Intraday chart data file updates started for ESU4.CME
2025-01-05 19:03:24.794 | Intraday chart data file opened for ESU4.CME
2025-01-05 19:03:24.794 | HD Request # 54 | Enabling Intraday chart updating for symbol.
2025-01-05 19:03:24.794 | Triggering next historical data download in queue.
2025-01-05 19:03:24.794 | HD Request # 55 | Downloading Intraday chart data for USDX to the file USDX.scid. Service: fxstatscalc
2025-01-05 19:03:24.794 | HD Request # 55 | Download start date-time: 2025-01-05 19:02:51.000000. File last date-time: 2025-01-05 19:02:51.000001
2025-01-05 19:03:24.794 | HD Request # 55 | Using server: ds12.sierracharts.com port 10150
2025-01-05 19:03:24.905 | Socket (4) | Creating socket.
2025-01-05 19:03:24.905 | Socket (4) | New receive buffer size: 0
2025-01-05 19:03:24.905 | Socket (4) | Connecting to IP: 69.39.70.241.
2025-01-05 19:03:25.009 | Socket (5) | Socket gracefully closed by remote side.
2025-01-05 19:03:25.009 | Socket (5) | Closed.
2025-01-05 19:03:25.391 | HD Request # 55 | Setting DTC encoding to Binary VLS
2025-01-05 19:03:25.391 | HD Request # 55 | Sending historical data logon request message.
2025-01-05 19:03:25.680 | HD Request # 55 | Requesting Intraday data. Start date-time: 2025-01-05 19:02:51. Record interval: 0. Symbol: USDX
2025-01-05 19:03:25.915 | HD Request # 55 | Decompressing data.
2025-01-05 19:03:26.149 | HD Request # 55 | Receiving Intraday data for USDX starting at 2025-01-05 19:02:51.000000
2025-01-05 19:03:26.149 | Socket (4) | CloseSocket call.
2025-01-05 19:03:26.149 | Socket (4) | Shutdown started. Waiting for graceful close.
2025-01-05 19:03:26.158 | Historical data download thread signaled to stop.
2025-01-05 19:03:26.158 | HD Request # 55 | Timestamp of first Intraday data file record written: 2025-01-05 19:02:52.000000.
2025-01-05 19:03:26.158 | HD Request # 55 | Received 32 Intraday data records from 2025-01-05 19:02:51.000000 to 2025-01-05 19:03:24.000000 (33.0 seconds. Delay: 2.2 seconds) and wrote 31 records for USDX
2025-01-05 19:03:26.159 | HD Request # 55 | Add time&sales data | Remembered last file record date-time: 2025-01-06 00:03:24.000000
2025-01-05 19:03:26.159 | Added 4 Time and Sales records to Intraday data file for USDX after download.
2025-01-05 19:03:26.159 | HD Request # 55 | Completion time: 2s.
2025-01-05 19:03:26.159 | HD Request # 55 | Intraday data download complete for USDX. Unique request ID: 55
2025-01-05 19:03:26.159 | Removing historical data download ID 55.
2025-01-05 19:03:26.159 | Real-time Intraday chart data file updates started for USDX
2025-01-05 19:03:26.159 | Intraday chart data file opened for USDX
2025-01-05 19:03:26.159 | HD Request # 55 | Enabling Intraday chart updating for symbol.
2025-01-05 19:03:26.159 | No download requests in the queue to start downloads for.
2025-01-05 19:03:26.382 | Socket (4) | Socket gracefully closed by remote side.
2025-01-05 19:03:26.382 | Socket (4) | Closed.
2025-01-05 19:03:29.811 | Opened cached Intraday file: C:\SierraChart - TopStep\Data\USDX.scid. Thread ID: 16528
2025-01-05 19:03:44.915 | Opened cached Intraday file: C:\SierraChart - TopStep\Data\SILH5.COMEX.scid. Thread ID: 16528
2025-01-05 19:04:05.073 | Opened cached Intraday file: C:\SierraChart - TopStep\Data\6AH5.CME.scid. Thread ID: 16528
2025-01-05 19:04:10.126 | Opened cached Intraday file: C:\SierraChart - TopStep\Data\M6AH5.CME.scid. Thread ID: 16528
2025-01-05 21:59:59.676 | Chat | Server has requested a logoff. Reason: Chat server is backing up
2025-01-05 21:59:59.676 | Chat | Waiting for socket receive thread to end
2025-01-05 21:59:59.677 | DTC Client socket (6) | CloseSocket call.
2025-01-05 21:59:59.677 | DTC Client socket (6) | Shutdown started. Waiting for graceful close.
2025-01-05 21:59:59.677 | Chat | Disconnected from the server.
2025-01-05 21:59:59.677 | Chat | Data feed disconnected. Will reconnect in 5 seconds.
2025-01-05 22:00:02.385 | DTC Client socket (6) | Socket gracefully closed by remote side.
2025-01-05 22:00:02.385 | DTC Client socket (6) | Closed.
2025-01-05 22:00:04.680 | WSACleanup called.
2025-01-05 22:00:04.680 | Chat | Connecting to the server chat2.sierracharts.com. Port 10065
2025-01-05 22:00:04.806 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2025-01-05 22:00:04.806 | DTC Client socket (4) | New receive buffer size: 0
2025-01-05 22:00:04.806 | DTC Client socket (4) | Connecting to IP: 64.152.155.20.
2025-01-05 22:00:05.049 | Chat | Network connection to server complete.
2025-01-05 22:00:05.049 | Chat | Starting socket receive thread.
2025-01-05 22:00:05.049 | Chat | Sending encoding request to server: Binary VLS. Compression: none
2025-01-05 22:00:05.778 | Chat | Setting DTC encoding to Binary VLS
2025-01-05 22:00:05.778 | Chat | Sending logon request message.
2025-01-05 22:00:10.411 | Chat | Received logon response.
2025-01-05 22:00:10.411 | Chat | Server Name: SC DTC Server. Build=52080.
2025-01-05 22:00:10.411 | Chat | Server protocol version: 8. Client protocol version: 8
2025-01-05 22:00:10.411 | Chat | Successfully connected. Connected to SC DTC Protocol server. Service=chat_server.data|SymbolSettings=chat_server.data.
2025-01-05 22:00:10.411 | Chat | Trading is not supported.
2025-01-05 22:00:10.411 | Chat | MarketDepthIsSupported: 1
2025-01-05 23:03:19.767 | HTTPS connection ID:5 to downloads.rithmic.com:443 for request ID:5 (5) | Creating socket. Using TLS 1.2.
2025-01-05 23:03:19.767 | HTTPS connection ID:5 to downloads.rithmic.com:443 for request ID:5 (5) | New receive buffer size: 0
2025-01-05 23:03:19.767 | HTTPS connection ID:5 to downloads.rithmic.com:443 for request ID:5 (5) | Connecting to IP: 216.66.0.130.
2025-01-05 23:03:21.188 | Rithmic Direct - DTC | Wrote file: C:\SierraChart - TopStep\RithmicConnections.json. Size: 81131
2025-01-05 23:03:21.189 | Rithmic Direct - DTC | Processed connection points. Count: 347
2025-01-05 23:03:21.437 | HTTPS connection ID:5 to downloads.rithmic.com:443 for request ID:5 (5) | CloseSocket call.
2025-01-05 23:03:21.438 | HTTPS connection ID:5 to downloads.rithmic.com:443 for request ID:5 (5) | Shutdown started. Waiting for graceful close.
2025-01-05 23:03:21.672 | HTTPS connection ID:5 to downloads.rithmic.com:443 for request ID:5 (5) | Socket gracefully closed by remote side.
2025-01-05 23:03:21.672 | HTTPS connection ID:5 to downloads.rithmic.com:443 for request ID:5 (5) | Closed.
2025-01-06 00:00:00.378 | Added historical Daily data request for GCG5.COMEX to the queue.
2025-01-06 00:00:00.378 | Triggering next historical data download in queue.
2025-01-06 00:00:00.379 | HD Request # 56 | Downloading Historical Daily chart data for GCG5.COMEX. Starting date: 2024-12-31. Service: rithmic.trading
2025-01-06 00:00:00.379 | Added historical Daily data request for SIH5.COMEX to the queue.
2025-01-06 00:00:00.379 | Triggering next historical data download in queue.
2025-01-06 00:00:00.379 | Added historical Daily data request for 6AH5.CME to the queue.
2025-01-06 00:00:00.380 | Added historical Daily data request for ESH5.CME to the queue.
2025-01-06 00:00:00.380 | Triggering next historical data download in queue.
2025-01-06 00:00:00.380 | Added historical Daily data request for NQH5.CME to the queue.
2025-01-06 00:00:00.656 | Added historical Daily data request for USDX to the queue.
2025-01-06 00:00:00.656 | Triggering next historical data download in queue.
2025-01-06 00:00:00.658 | HD Request # 57 | Downloading Historical Daily chart data for USDX. Starting date: 2025-01-02. Service: fxstatscalc
2025-01-06 00:00:00.658 | HD Request # 57 | Using server: ds4.sierracharts.com port 10149
2025-01-06 00:00:00.801 | Socket (6) | Creating socket.
2025-01-06 00:00:00.801 | Socket (6) | New receive buffer size: 0
2025-01-06 00:00:00.801 | Socket (6) | Connecting to IP: 67.214.125.7.
2025-01-06 00:00:01.299 | HD Request # 57 | Setting DTC encoding to Binary VLS
2025-01-06 00:00:01.299 | HD Request # 57 | Sending historical data logon request message.
2025-01-06 00:00:01.517 | HD Request # 56 | Requesting historical Daily data for GCG25 starting at 2024-12-30. SC External HD service.
2025-01-06 00:00:01.573 | HD Request # 57 | Requesting historical Daily data starting at 2025-01-02.
2025-01-06 00:00:01.811 | HD Request # 57 | Decompressing data.
2025-01-06 00:00:01.845 | HD Request # 57 | Receiving historical Daily data for USDX starting at 2025-01-02.
2025-01-06 00:00:01.845 | HD Request # 57 | Writing historical Daily data to the file USDX.dly.
2025-01-06 00:00:01.858 | Socket (6) | CloseSocket call.
2025-01-06 00:00:01.858 | Socket (6) | Shutdown started. Waiting for graceful close.
2025-01-06 00:00:01.860 | Historical data download thread signaled to stop.
2025-01-06 00:00:01.860 | HD Request # 57 | Received 3 Daily data records from 2025-01-02 00:00:00 to 2025-01-06 00:00:00 (5.0 days) and wrote 3 records for USDX
2025-01-06 00:00:01.860 | HD Request # 57 | Completion time: 1s.
2025-01-06 00:00:01.860 | HD Request # 57 | Daily data download complete for USDX. Unique request ID: 61
2025-01-06 00:00:01.860 | Removing historical data download ID 61.
2025-01-06 00:00:01.860 | No download requests in the queue to start downloads for.
2025-01-06 00:00:02.096 | Socket (6) | Socket gracefully closed by remote side.
2025-01-06 00:00:02.096 | Socket (6) | Closed.
2025-01-06 00:00:02.334 | USDX[M] Daily #19 | Reloading chart.
2025-01-06 00:00:02.415 | USDX[M] Daily #19 | StartDateTimeForLoadingOrderFills: 2023-12-31 00:00:00
2025-01-06 00:00:02.415 | USDX[M] Daily #19 | Chart data loading complete.
2025-01-06 00:00:02.448 | HD Request # 56 | Receiving historical Daily data for GCG5.COMEX starting at 2024-12-31.
2025-01-06 00:00:02.448 | HD Request # 56 | Writing historical Daily data to the file GCG5.COMEX.dly.
2025-01-06 00:00:02.449 | HD Request # 56 | Bytes received: 223
2025-01-06 00:00:02.449 | HD Request # 56 | Received 4 Daily data records from 2024-12-31 00:00:00 to 2025-01-03 00:00:00 (4.0 days) and wrote 3 records for GCG5.COMEX
2025-01-06 00:00:02.449 | HD Request # 56 | Completion time: 2s.
2025-01-06 00:00:02.449 | HD Request # 56 | Daily data download complete for GCG5.COMEX. Unique request ID: 56
2025-01-06 00:00:02.449 | Removing historical data download ID 56.
2025-01-06 00:00:02.449 | Triggering next historical data download in queue.
2025-01-06 00:00:02.450 | HD Request # 58 | Downloading Historical Daily chart data for SIH5.COMEX. Starting date: 2024-12-31. Service: rithmic.trading
2025-01-06 00:00:02.900 | GCG5.COMEX [CBV][M] Weekly #5 | Reloading chart.
2025-01-06 00:00:02.900 | GCG5.COMEX [CBV][M] Weekly #5 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2025-01-06 00:00:02.900 | GCG5.COMEX [CBV][M] Weekly #5 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2025-01-06 00:00:03.535 | GCG5.COMEX [CBV][M] Daily #6 | Reloading chart.
2025-01-06 00:00:03.535 | GCG5.COMEX [CBV][M] Daily #6 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2025-01-06 00:00:03.535 | GCG5.COMEX [CBV][M] Daily #6 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2025-01-06 00:00:04.173 | HD Request # 58 | Requesting historical Daily data for SIH25 starting at 2024-12-30. SC External HD service.
2025-01-06 00:00:04.174 | GCG5.COMEX [CBV][M] Weekly #5 | Chart data loading complete.
2025-01-06 00:00:04.279 | GCG5.COMEX [CBV][M] Daily #6 | Chart data loading complete.
2025-01-06 00:00:04.280 | GCG5.COMEX [CBV][M] Monthly #4 | Reloading chart.
2025-01-06 00:00:04.280 | GCG5.COMEX [CBV][M] Monthly #4 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2025-01-06 00:00:04.280 | GCG5.COMEX [CBV][M] Monthly #4 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2025-01-06 00:00:04.999 | GCG5.COMEX [CBV][M] Monthly #4 | Chart data loading complete.
2025-01-06 00:00:05.624 | HD Request # 58 | Receiving historical Daily data for SIH5.COMEX starting at 2024-12-31.
2025-01-06 00:00:05.624 | HD Request # 58 | Writing historical Daily data to the file SIH5.COMEX.dly.
2025-01-06 00:00:05.626 | HD Request # 58 | Bytes received: 219
2025-01-06 00:00:05.626 | HD Request # 58 | Received 4 Daily data records from 2024-12-31 00:00:00 to 2025-01-03 00:00:00 (4.0 days) and wrote 3 records for SIH5.COMEX
2025-01-06 00:00:05.626 | HD Request # 58 | Completion time: 3s.
2025-01-06 00:00:05.626 | HD Request # 58 | Daily data download complete for SIH5.COMEX. Unique request ID: 57
2025-01-06 00:00:05.626 | Removing historical data download ID 57.
2025-01-06 00:00:05.626 | Triggering next historical data download in queue.
2025-01-06 00:00:05.627 | HD Request # 59 | Downloading Historical Daily chart data for 6AH5.CME. Starting date: 2024-12-31. Service: rithmic.trading
2025-01-06 00:00:05.628 | SIH5.COMEX [CBV][M] Weekly #5 | Reloading chart.
2025-01-06 00:00:05.628 | SIH5.COMEX [CBV][M] Weekly #5 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2025-01-06 00:00:05.628 | SIH5.COMEX [CBV][M] Weekly #5 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2025-01-06 00:00:06.209 | SIH5.COMEX [CBV][M] Monthly #4 | Reloading chart.
2025-01-06 00:00:06.209 | SIH5.COMEX [CBV][M] Monthly #4 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2025-01-06 00:00:06.209 | SIH5.COMEX [CBV][M] Monthly #4 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2025-01-06 00:00:06.787 | SIH5.COMEX [CBV][M] Weekly #5 | Chart data loading complete.
2025-01-06 00:00:06.789 | SIH5.COMEX [CBV][M] Daily #6 | Reloading chart.
2025-01-06 00:00:06.789 | SIH5.COMEX [CBV][M] Daily #6 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2025-01-06 00:00:06.789 | SIH5.COMEX [CBV][M] Daily #6 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2025-01-06 00:00:07.369 | SIH5.COMEX [CBV][M] Monthly #4 | Chart data loading complete.
2025-01-06 00:00:07.369 | HD Request # 59 | Requesting historical Daily data for A6H25 starting at 2024-12-30. SC External HD service.
2025-01-06 00:00:07.478 | SIH5.COMEX [CBV][M] Daily #6 | Chart data loading complete.
2025-01-06 00:00:08.253 | HD Request # 59 | Receiving historical Daily data for 6AH5.CME starting at 2024-12-31.
2025-01-06 00:00:08.254 | HD Request # 59 | Writing historical Daily data to the file 6AH5.CME.dly.
2025-01-06 00:00:08.258 | HD Request # 59 | Bytes received: 237
2025-01-06 00:00:08.258 | HD Request # 59 | Received 4 Daily data records from 2024-12-31 00:00:00 to 2025-01-03 00:00:00 (4.0 days) and wrote 3 records for 6AH5.CME
2025-01-06 00:00:08.258 | HD Request # 59 | Completion time: 3s.
2025-01-06 00:00:08.258 | HD Request # 59 | Daily data download complete for 6AH5.CME. Unique request ID: 58
2025-01-06 00:00:08.258 | Removing historical data download ID 58.
2025-01-06 00:00:08.258 | Triggering next historical data download in queue.
2025-01-06 00:00:08.259 | HD Request # 60 | Downloading Historical Daily chart data for ESH5.CME. Starting date: 2024-12-31. Service: rithmic.trading
2025-01-06 00:00:08.782 | 6AH5.CME [CBV][M] Monthly #4 | Reloading chart.
2025-01-06 00:00:08.782 | 6AH5.CME [CBV][M] Monthly #4 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2025-01-06 00:00:08.782 | 6AH5.CME [CBV][M] Monthly #4 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2025-01-06 00:00:09.481 | HD Request # 60 | Requesting historical Daily data for ESH25 starting at 2024-12-30. SC External HD service.
2025-01-06 00:00:09.482 | 6AH5.CME [CBV][M] Daily #6 | Reloading chart.
2025-01-06 00:00:09.482 | 6AH5.CME [CBV][M] Daily #6 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2025-01-06 00:00:09.482 | 6AH5.CME [CBV][M] Daily #6 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2025-01-06 00:00:10.164 | 6AH5.CME [CBV][M] Monthly #4 | Chart data loading complete.
2025-01-06 00:00:10.166 | 6AH5.CME [CBV][M] Weekly #5 | Reloading chart.
2025-01-06 00:00:10.166 | 6AH5.CME [CBV][M] Weekly #5 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2025-01-06 00:00:10.166 | 6AH5.CME [CBV][M] Weekly #5 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2025-01-06 00:00:10.855 | 6AH5.CME [CBV][M] Daily #6 | Chart data loading complete.
2025-01-06 00:00:10.962 | HD Request # 60 | Receiving historical Daily data for ESH5.CME starting at 2024-12-31.
2025-01-06 00:00:10.962 | HD Request # 60 | Writing historical Daily data to the file ESH5.CME.dly.
2025-01-06 00:00:10.963 | HD Request # 60 | Bytes received: 252
2025-01-06 00:00:10.963 | HD Request # 60 | Received 4 Daily data records from 2024-12-31 00:00:00 to 2025-01-03 00:00:00 (4.0 days) and wrote 3 records for ESH5.CME
2025-01-06 00:00:10.964 | HD Request # 60 | Completion time: 2s.
2025-01-06 00:00:10.964 | HD Request # 60 | Daily data download complete for ESH5.CME. Unique request ID: 59
2025-01-06 00:00:10.964 | Removing historical data download ID 59.
2025-01-06 00:00:10.964 | Triggering next historical data download in queue.
2025-01-06 00:00:10.965 | 6AH5.CME [CBV][M] Weekly #5 | Chart data loading complete.
2025-01-06 00:00:10.966 | HD Request # 61 | Downloading Historical Daily chart data for NQH5.CME. Starting date: 2024-12-31. Service: rithmic.trading
2025-01-06 00:00:11.211 | ESH5.CME [CBV][M] Daily #6 | Reloading chart.
2025-01-06 00:00:11.211 | ESH5.CME [CBV][M] Daily #6 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2025-01-06 00:00:11.211 | ESH5.CME [CBV][M] Daily #6 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2025-01-06 00:00:11.599 | ESH5.CME [CBV][M] Daily #6 | Chart data loading complete.
2025-01-06 00:00:12.073 | ESH5.CME [CBV][M] Monthly #4 | Reloading chart.
2025-01-06 00:00:12.073 | ESH5.CME [CBV][M] Monthly #4 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2025-01-06 00:00:12.073 | ESH5.CME [CBV][M] Monthly #4 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2025-01-06 00:00:12.394 | HD Request # 61 | Requesting historical Daily data for NQH25 starting at 2024-12-30. SC External HD service.
2025-01-06 00:00:12.396 | ESH5.CME [CBV][M] Weekly #5 | Reloading chart.
2025-01-06 00:00:12.396 | ESH5.CME [CBV][M] Weekly #5 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2025-01-06 00:00:12.396 | ESH5.CME [CBV][M] Weekly #5 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2025-01-06 00:00:12.718 | ESH5.CME [CBV][M] Monthly #4 | Chart data loading complete.
2025-01-06 00:00:12.753 | ESH5.CME [CBV][M] Weekly #5 | Chart data loading complete.
2025-01-06 00:00:13.382 | HD Request # 61 | Receiving historical Daily data for NQH5.CME starting at 2024-12-31.
2025-01-06 00:00:13.382 | HD Request # 61 | Writing historical Daily data to the file NQH5.CME.dly.
2025-01-06 00:00:13.383 | HD Request # 61 | Bytes received: 249
2025-01-06 00:00:13.383 | HD Request # 61 | Received 4 Daily data records from 2024-12-31 00:00:00 to 2025-01-03 00:00:00 (4.0 days) and wrote 3 records for NQH5.CME
2025-01-06 00:00:13.383 | HD Request # 61 | Completion time: 3s.
2025-01-06 00:00:13.383 | HD Request # 61 | Daily data download complete for NQH5.CME. Unique request ID: 60
2025-01-06 00:00:13.383 | Removing historical data download ID 60.
2025-01-06 00:00:13.383 | No download requests in the queue to start downloads for.
2025-01-06 00:00:13.555 | NQH5.CME [CBV][M] Monthly #4 | Reloading chart.
2025-01-06 00:00:13.555 | NQH5.CME [CBV][M] Monthly #4 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2025-01-06 00:00:13.555 | NQH5.CME [CBV][M] Monthly #4 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2025-01-06 00:00:13.841 | NQH5.CME [CBV][M] Daily #6 | Reloading chart.
2025-01-06 00:00:13.841 | NQH5.CME [CBV][M] Daily #6 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2025-01-06 00:00:13.841 | NQH5.CME [CBV][M] Daily #6 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2025-01-06 00:00:14.126 | NQH5.CME [CBV][M] Monthly #4 | Chart data loading complete.
2025-01-06 00:00:14.127 | NQH5.CME [CBV][M] Weekly #5 | Reloading chart.
2025-01-06 00:00:14.127 | NQH5.CME [CBV][M] Weekly #5 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2025-01-06 00:00:14.127 | NQH5.CME [CBV][M] Weekly #5 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2025-01-06 00:00:14.413 | NQH5.CME [CBV][M] Daily #6 | Chart data loading complete.
2025-01-06 00:00:14.521 | NQH5.CME [CBV][M] Weekly #5 | Chart data loading complete.
2025-01-06 03:03:22.148 | HTTPS connection ID:6 to downloads.rithmic.com:443 for request ID:6 (5) | Creating socket. Using TLS 1.2.
2025-01-06 03:03:22.148 | HTTPS connection ID:6 to downloads.rithmic.com:443 for request ID:6 (5) | New receive buffer size: 0
2025-01-06 03:03:22.148 | HTTPS connection ID:6 to downloads.rithmic.com:443 for request ID:6 (5) | Connecting to IP: 216.66.0.130.
2025-01-06 03:03:23.602 | Rithmic Direct - DTC | Wrote file: C:\SierraChart - TopStep\RithmicConnections.json. Size: 81131
2025-01-06 03:03:23.602 | Rithmic Direct - DTC | Processed connection points. Count: 347
2025-01-06 03:03:24.142 | HTTPS connection ID:6 to downloads.rithmic.com:443 for request ID:6 (5) | CloseSocket call.
2025-01-06 03:03:24.142 | HTTPS connection ID:6 to downloads.rithmic.com:443 for request ID:6 (5) | Shutdown started. Waiting for graceful close.
2025-01-06 03:03:24.374 | HTTPS connection ID:6 to downloads.rithmic.com:443 for request ID:6 (5) | Socket gracefully closed by remote side.
2025-01-06 03:03:24.374 | HTTPS connection ID:6 to downloads.rithmic.com:443 for request ID:6 (5) | Closed.
2025-01-06 06:22:24.990 | Chat | Message response. Chat ID: 429. Request ID: 1134629346
2025-01-06 07:03:24.545 | HTTPS connection ID:7 to downloads.rithmic.com:443 for request ID:7 (5) | Creating socket. Using TLS 1.2.
2025-01-06 07:03:24.545 | HTTPS connection ID:7 to downloads.rithmic.com:443 for request ID:7 (5) | New receive buffer size: 0
2025-01-06 07:03:24.545 | HTTPS connection ID:7 to downloads.rithmic.com:443 for request ID:7 (5) | Connecting to IP: 216.66.0.130.
2025-01-06 07:03:25.965 | Rithmic Direct - DTC | Wrote file: C:\SierraChart - TopStep\RithmicConnections.json. Size: 81131
2025-01-06 07:03:25.965 | Rithmic Direct - DTC | Processed connection points. Count: 347
2025-01-06 07:03:26.598 | HTTPS connection ID:7 to downloads.rithmic.com:443 for request ID:7 (5) | CloseSocket call.
2025-01-06 07:03:26.598 | HTTPS connection ID:7 to downloads.rithmic.com:443 for request ID:7 (5) | Shutdown started. Waiting for graceful close.
2025-01-06 07:03:26.834 | HTTPS connection ID:7 to downloads.rithmic.com:443 for request ID:7 (5) | Socket gracefully closed by remote side.
2025-01-06 07:03:26.834 | HTTPS connection ID:7 to downloads.rithmic.com:443 for request ID:7 (5) | Closed.
2025-01-06 07:44:55.348 | GCG5.COMEX [CBV][M] 30 Min #17 | StartDateTimeForLoadingOrderFills: 2023-12-31 00:00:00
2025-01-06 07:45:26.890 | GCG5.COMEX [CBV][M] 30 Min #17 | StartDateTimeForLoadingOrderFills: 2023-12-31 00:00:00
2025-01-06 08:37:35.935 | Chat | Message response. Chat ID: 429. Request ID: 1134629347
2025-01-06 10:09:07.393 | Chat | Message response. Chat ID: 429. Request ID: 1134629348
2025-01-06 10:35:11.727 | Chat | Message response. Chat ID: 429. Request ID: 1134629349
2025-01-06 11:00:06.231 | Chat | Message response. Chat ID: 429. Request ID: 1134629350
2025-01-06 11:03:27.047 | HTTPS connection ID:8 to downloads.rithmic.com:443 for request ID:8 (5) | Creating socket. Using TLS 1.2.
2025-01-06 11:03:27.047 | HTTPS connection ID:8 to downloads.rithmic.com:443 for request ID:8 (5) | New receive buffer size: 0
2025-01-06 11:03:27.047 | HTTPS connection ID:8 to downloads.rithmic.com:443 for request ID:8 (5) | Connecting to IP: 216.66.0.130.
2025-01-06 11:03:28.516 | Rithmic Direct - DTC | Wrote file: C:\SierraChart - TopStep\RithmicConnections.json. Size: 81131
2025-01-06 11:03:28.517 | Rithmic Direct - DTC | Processed connection points. Count: 347
2025-01-06 11:03:29.276 | HTTPS connection ID:8 to downloads.rithmic.com:443 for request ID:8 (5) | CloseSocket call.
2025-01-06 11:03:29.276 | HTTPS connection ID:8 to downloads.rithmic.com:443 for request ID:8 (5) | Shutdown started. Waiting for graceful close.
2025-01-06 11:03:29.509 | HTTPS connection ID:8 to downloads.rithmic.com:443 for request ID:8 (5) | Socket gracefully closed by remote side.
2025-01-06 11:03:29.509 | HTTPS connection ID:8 to downloads.rithmic.com:443 for request ID:8 (5) | Closed.
2025-01-06 12:22:33.970 | Chat | Message response. Chat ID: 429. Request ID: 1134629351
2025-01-06 14:50:49.153 | SPX500[M] 240 Min #16 | Reloading chart.
2025-01-06 14:50:49.589 | SPX500[M] 240 Min #16 | StartDateTimeForLoadingOrderFills: 2023-12-31 00:00:00
2025-01-06 14:50:49.599 | SPX500[M] 240 Min #16 | Chart data loading complete.
2025-01-06 15:03:31.904 | HTTPS connection ID:9 to downloads.rithmic.com:443 for request ID:9 (5) | Creating socket. Using TLS 1.2.
2025-01-06 15:03:31.904 | HTTPS connection ID:9 to downloads.rithmic.com:443 for request ID:9 (5) | New receive buffer size: 0
2025-01-06 15:03:31.904 | HTTPS connection ID:9 to downloads.rithmic.com:443 for request ID:9 (5) | Connecting to IP: 216.66.0.130.
2025-01-06 15:03:33.520 | Rithmic Direct - DTC | Wrote file: C:\SierraChart - TopStep\RithmicConnections.json. Size: 81131
2025-01-06 15:03:33.521 | Rithmic Direct - DTC | Processed connection points. Count: 347
2025-01-06 15:03:34.633 | HTTPS connection ID:9 to downloads.rithmic.com:443 for request ID:9 (5) | CloseSocket call.
2025-01-06 15:03:34.633 | HTTPS connection ID:9 to downloads.rithmic.com:443 for request ID:9 (5) | Shutdown started. Waiting for graceful close.
2025-01-06 15:03:34.869 | HTTPS connection ID:9 to downloads.rithmic.com:443 for request ID:9 (5) | Socket gracefully closed by remote side.
2025-01-06 15:03:34.869 | HTTPS connection ID:9 to downloads.rithmic.com:443 for request ID:9 (5) | Closed.
2025-01-06 15:51:11.120 | Saved Chartbook: ES.Cht. Time: 0.0521 seconds.
2025-01-06 15:51:11.182 | Saved Chartbook: NQ.Cht. Time: 0.0609 seconds.
2025-01-06 15:51:11.241 | Saved Chartbook: GC.Cht. Time: 0.0568 seconds.
2025-01-06 15:51:11.283 | Saved Chartbook: SI.Cht. Time: 0.0415 seconds.
2025-01-06 15:51:11.323 | Saved Chartbook: 6A.Cht. Time: 0.0387 seconds.
2025-01-06 15:54:06.739 | Saved Chartbook: ES.Cht. Time: 0.0513 seconds.
2025-01-06 15:54:06.806 | Saved Chartbook: NQ.Cht. Time: 0.0666 seconds.
2025-01-06 15:54:06.861 | Saved Chartbook: GC.Cht. Time: 0.0542 seconds.
2025-01-06 15:54:06.901 | Saved Chartbook: SI.Cht. Time: 0.0389 seconds.
2025-01-06 15:54:06.941 | Saved Chartbook: 6A.Cht. Time: 0.0394 seconds.
2025-01-06 17:20:42.884 | SC Data with Depth | Real-time data for symbol SPX500 is currently unavailable.
2025-01-06 17:21:11.959 | SC Data with Depth | Setting external service identifier for symbol SPX500 to 55
2025-01-06 17:21:11.959 | SC Data with Depth | Received security definition for symbol SPX500
2025-01-06 17:21:11.959 | SC Data with Depth | Real-time data for symbol SPX500 has been restored.
2025-01-06 17:21:11.959 | Added historical Intraday data request for SPX500 to the queue.
2025-01-06 17:21:11.959 | Intraday data recording state for symbol SPX500 is set to download 'Pending'.
2025-01-06 17:21:11.959 | Triggering next historical data download in queue.
2025-01-06 17:21:11.959 | HD Request # 62 | Downloading Intraday chart data for SPX500 to the file SPX500.scid. Service: fxcm
2025-01-06 17:21:11.959 | HD Request # 62 | Download start date-time: 2025-01-06 16:59:59.000000. File last date-time: 2025-01-06 16:59:59.489000
2025-01-06 17:21:11.959 | HD Request # 62 | Using server: ds12.sierracharts.com port 10150
2025-01-06 17:21:12.106 | Socket (5) | Creating socket.
2025-01-06 17:21:12.106 | Socket (5) | New receive buffer size: 0
2025-01-06 17:21:12.106 | Socket (5) | Connecting to IP: 69.39.70.241.
2025-01-06 17:21:12.607 | HD Request # 62 | Setting DTC encoding to Binary VLS
2025-01-06 17:21:12.607 | HD Request # 62 | Sending historical data logon request message.
2025-01-06 17:21:15.966 | HD Request # 62 | Requesting Intraday data. Start date-time: 2025-01-06 16:59:59. Record interval: 0. Symbol: SPX500
2025-01-06 17:21:16.219 | HD Request # 62 | Decompressing data.
2025-01-06 17:21:16.500 | HD Request # 62 | Receiving Intraday data for SPX500 starting at 2025-01-06 16:59:59.489000
2025-01-06 17:21:16.500 | Socket (5) | CloseSocket call.
2025-01-06 17:21:16.500 | Socket (5) | Shutdown started. Waiting for graceful close.
2025-01-06 17:21:16.500 | Historical data download thread signaled to stop.
2025-01-06 17:21:16.500 | HD Request # 62 | Received 1 Intraday data record from 2025-01-06 16:59:59.489000 to 2025-01-06 16:59:59.489000 (0.0 seconds. Delay: 21.3 minutes) and wrote 0 records for SPX500
2025-01-06 17:21:16.500 | HD Request # 62 | Add time&sales data | Remembered last file record date-time: 2025-01-06 21:59:59.489000
2025-01-06 17:21:16.500 | HD Request # 62 | Completion time: 5s.
2025-01-06 17:21:16.500 | HD Request # 62 | Intraday data download complete for SPX500. Unique request ID: 62
2025-01-06 17:21:16.500 | Removing historical data download ID 62.
2025-01-06 17:21:16.500 | Real-time Intraday chart data file updates started for SPX500
2025-01-06 17:21:16.500 | Intraday chart data file opened for SPX500
2025-01-06 17:21:16.500 | HD Request # 62 | Enabling Intraday chart updating for symbol.
2025-01-06 17:21:16.500 | No download requests in the queue to start downloads for.
2025-01-06 17:21:16.744 | Socket (5) | Socket gracefully closed by remote side.
2025-01-06 17:21:16.744 | Socket (5) | Closed.
2025-01-06 17:30:44.625 | SC Data with Depth | Real-time data for symbol SPX500 is currently unavailable.
2025-01-06 17:31:26.718 | SC Data with Depth | Setting external service identifier for symbol SPX500 to 55
2025-01-06 17:31:26.718 | SC Data with Depth | Received security definition for symbol SPX500
2025-01-06 17:31:26.718 | SC Data with Depth | Real-time data for symbol SPX500 has been restored.
2025-01-06 17:31:26.718 | Added historical Intraday data request for SPX500 to the queue.
2025-01-06 17:31:26.718 | Intraday data recording state for symbol SPX500 is set to download 'Pending'.
2025-01-06 17:31:26.718 | Triggering next historical data download in queue.
2025-01-06 17:31:26.718 | HD Request # 63 | Downloading Intraday chart data for SPX500 to the file SPX500.scid. Service: fxcm
2025-01-06 17:31:26.718 | HD Request # 63 | Download start date-time: 2025-01-06 16:59:59.000000. File last date-time: 2025-01-06 16:59:59.489000
2025-01-06 17:31:26.719 | HD Request # 63 | Using server: ds4.sierracharts.com port 10149
2025-01-06 17:31:26.799 | Socket (5) | Creating socket.
2025-01-06 17:31:26.799 | Socket (5) | New receive buffer size: 0
2025-01-06 17:31:26.799 | Socket (5) | Connecting to IP: 67.214.125.7.
2025-01-06 17:31:27.302 | HD Request # 63 | Setting DTC encoding to Binary VLS
2025-01-06 17:31:27.302 | HD Request # 63 | Sending historical data logon request message.
2025-01-06 17:31:30.124 | HD Request # 63 | Requesting Intraday data. Start date-time: 2025-01-06 16:59:59. Record interval: 0. Symbol: SPX500
2025-01-06 17:31:30.381 | HD Request # 63 | Decompressing data.
2025-01-06 17:31:30.672 | HD Request # 63 | Receiving Intraday data for SPX500 starting at 2025-01-06 16:59:59.489000
2025-01-06 17:31:30.672 | Socket (5) | CloseSocket call.
2025-01-06 17:31:30.672 | Historical data download thread signaled to stop.
2025-01-06 17:31:30.672 | HD Request # 63 | Received 1 Intraday data record from 2025-01-06 16:59:59.489000 to 2025-01-06 16:59:59.489000 (0.0 seconds. Delay: 31.5 minutes) and wrote 0 records for SPX500
2025-01-06 17:31:30.672 | Socket (5) | Shutdown started. Waiting for graceful close.
2025-01-06 17:31:30.672 | HD Request # 63 | Add time&sales data | Remembered last file record date-time: 2025-01-06 21:59:59.489000
2025-01-06 17:31:30.672 | HD Request # 63 | Completion time: 4s.
2025-01-06 17:31:30.672 | HD Request # 63 | Intraday data download complete for SPX500. Unique request ID: 63
2025-01-06 17:31:30.672 | Removing historical data download ID 63.
2025-01-06 17:31:30.672 | Real-time Intraday chart data file updates started for SPX500
2025-01-06 17:31:30.672 | Intraday chart data file opened for SPX500
2025-01-06 17:31:30.672 | HD Request # 63 | Enabling Intraday chart updating for symbol.
2025-01-06 17:31:30.672 | No download requests in the queue to start downloads for.
2025-01-06 17:31:30.917 | Socket (5) | Socket gracefully closed by remote side.
2025-01-06 17:31:30.917 | Socket (5) | Closed.
2025-01-06 17:45:00.033 | Added historical Daily data request for ESH5.CME to the queue.
2025-01-06 17:45:00.033 | Triggering next historical data download in queue.
2025-01-06 17:45:00.034 | HD Request # 64 | Downloading Historical Daily chart data for ESH5.CME. Starting date: 2024-12-31. Service: rithmic.trading
2025-01-06 17:45:00.034 | Added historical Daily data request for 6AH5.CME to the queue.
2025-01-06 17:45:00.034 | Triggering next historical data download in queue.
2025-01-06 17:45:00.034 | Added historical Daily data request for NQH5.CME to the queue.
2025-01-06 17:45:00.035 | Added historical Daily data request for GCG5.COMEX to the queue.
2025-01-06 17:45:00.035 | Triggering next historical data download in queue.
2025-01-06 17:45:00.035 | Added historical Daily data request for SIH5.COMEX to the queue.
2025-01-06 17:45:00.108 | Added historical Daily data request for USDX to the queue.
2025-01-06 17:45:00.108 | Triggering next historical data download in queue.
2025-01-06 17:45:00.109 | HD Request # 65 | Downloading Historical Daily chart data for USDX. Starting date: 2025-01-02. Service: fxstatscalc
2025-01-06 17:45:00.110 | HD Request # 65 | Using server: ds12.sierracharts.com port 10150
2025-01-06 17:45:00.193 | Socket (6) | Creating socket.
2025-01-06 17:45:00.193 | Socket (6) | New receive buffer size: 0
2025-01-06 17:45:00.193 | Socket (6) | Connecting to IP: 69.39.70.241.
2025-01-06 17:45:00.706 | HD Request # 65 | Setting DTC encoding to Binary VLS
2025-01-06 17:45:00.706 | HD Request # 65 | Sending historical data logon request message.
2025-01-06 17:45:01.117 | HD Request # 64 | Requesting historical Daily data for ESH25 starting at 2024-12-30. SC External HD service.
2025-01-06 17:45:02.088 | HD Request # 64 | Receiving historical Daily data for ESH5.CME starting at 2024-12-31.
2025-01-06 17:45:02.088 | HD Request # 64 | Writing historical Daily data to the file ESH5.CME.dly.
2025-01-06 17:45:02.090 | HD Request # 64 | Bytes received: 315
2025-01-06 17:45:02.090 | HD Request # 64 | Received 5 Daily data records from 2024-12-31 00:00:00 to 2025-01-06 00:00:00 (7.0 days) and wrote 4 records for ESH5.CME
2025-01-06 17:45:02.090 | HD Request # 64 | Completion time: 2s.
2025-01-06 17:45:02.090 | HD Request # 64 | Daily data download complete for ESH5.CME. Unique request ID: 64
2025-01-06 17:45:02.090 | Removing historical data download ID 64.
2025-01-06 17:45:02.090 | Triggering next historical data download in queue.
2025-01-06 17:45:02.091 | HD Request # 66 | Downloading Historical Daily chart data for 6AH5.CME. Starting date: 2024-12-31. Service: rithmic.trading
2025-01-06 17:45:02.650 | ESH5.CME [CBV][M] Daily #6 | Reloading chart.
2025-01-06 17:45:02.650 | ESH5.CME [CBV][M] Daily #6 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2025-01-06 17:45:02.650 | ESH5.CME [CBV][M] Daily #6 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2025-01-06 17:45:02.684 | HD Request # 65 | Requesting historical Daily data starting at 2025-01-02.
2025-01-06 17:45:02.918 | HD Request # 65 | Decompressing data.
2025-01-06 17:45:02.950 | HD Request # 65 | Receiving historical Daily data for USDX starting at 2025-01-02.
2025-01-06 17:45:02.950 | HD Request # 65 | Writing historical Daily data to the file USDX.dly.
2025-01-06 17:45:02.963 | Socket (6) | CloseSocket call.
2025-01-06 17:45:02.963 | Socket (6) | Shutdown started. Waiting for graceful close.
2025-01-06 17:45:02.978 | Historical data download thread signaled to stop.
2025-01-06 17:45:02.978 | HD Request # 65 | Received 4 Daily data records from 2025-01-02 00:00:00 to 2025-01-07 00:00:00 (6.0 days) and wrote 4 records for USDX
2025-01-06 17:45:02.978 | HD Request # 65 | Completion time: 2s.
2025-01-06 17:45:02.978 | HD Request # 65 | Daily data download complete for USDX. Unique request ID: 69
2025-01-06 17:45:02.978 | Removing historical data download ID 69.
2025-01-06 17:45:02.978 | No download requests in the queue to start downloads for.
2025-01-06 17:45:02.979 | ESH5.CME [CBV][M] Monthly #4 | Reloading chart.
2025-01-06 17:45:02.979 | ESH5.CME [CBV][M] Monthly #4 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2025-01-06 17:45:02.979 | ESH5.CME [CBV][M] Monthly #4 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2025-01-06 17:45:03.196 | Socket (6) | Socket gracefully closed by remote side.
2025-01-06 17:45:03.196 | Socket (6) | Closed.
2025-01-06 17:45:03.304 | ESH5.CME [CBV][M] Daily #6 | Chart data loading complete.
2025-01-06 17:45:03.304 | HD Request # 66 | Requesting historical Daily data for A6H25 starting at 2024-12-30. SC External HD service.
2025-01-06 17:45:03.339 | ESH5.CME [CBV][M] Monthly #4 | Chart data loading complete.
2025-01-06 17:45:03.413 | USDX[M] Daily #19 | Reloading chart.
2025-01-06 17:45:03.418 | ESH5.CME [CBV][M] Weekly #5 | Reloading chart.
2025-01-06 17:45:03.419 | ESH5.CME [CBV][M] Weekly #5 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2025-01-06 17:45:03.419 | ESH5.CME [CBV][M] Weekly #5 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2025-01-06 17:45:03.742 | USDX[M] Daily #19 | StartDateTimeForLoadingOrderFills: 2024-01-01 00:00:00
2025-01-06 17:45:03.742 | USDX[M] Daily #19 | Chart data loading complete.
2025-01-06 17:45:03.804 | ESH5.CME [CBV][M] Weekly #5 | Chart data loading complete.
2025-01-06 17:45:04.550 | HD Request # 66 | Receiving historical Daily data for 6AH5.CME starting at 2024-12-31.
2025-01-06 17:45:04.550 | HD Request # 66 | Writing historical Daily data to the file 6AH5.CME.dly.
2025-01-06 17:45:04.554 | HD Request # 66 | Bytes received: 298
2025-01-06 17:45:04.554 | HD Request # 66 | Received 5 Daily data records from 2024-12-31 00:00:00 to 2025-01-06 00:00:00 (7.0 days) and wrote 4 records for 6AH5.CME
2025-01-06 17:45:04.554 | HD Request # 66 | Completion time: 2s.
2025-01-06 17:45:04.554 | HD Request # 66 | Daily data download complete for 6AH5.CME. Unique request ID: 65
2025-01-06 17:45:04.554 | Removing historical data download ID 65.
2025-01-06 17:45:04.554 | Triggering next historical data download in queue.
2025-01-06 17:45:04.555 | HD Request # 67 | Downloading Historical Daily chart data for NQH5.CME. Starting date: 2024-12-31. Service: rithmic.trading
2025-01-06 17:45:04.556 | 6AH5.CME [CBV][M] Daily #6 | Reloading chart.
2025-01-06 17:45:04.557 | 6AH5.CME [CBV][M] Daily #6 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2025-01-06 17:45:04.557 | 6AH5.CME [CBV][M] Daily #6 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2025-01-06 17:45:05.248 | 6AH5.CME [CBV][M] Weekly #5 | Reloading chart.
2025-01-06 17:45:05.248 | 6AH5.CME [CBV][M] Weekly #5 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2025-01-06 17:45:05.248 | 6AH5.CME [CBV][M] Weekly #5 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2025-01-06 17:45:05.987 | 6AH5.CME [CBV][M] Daily #6 | Chart data loading complete.
2025-01-06 17:45:06.095 | HD Request # 67 | Requesting historical Daily data for NQH25 starting at 2024-12-30. SC External HD service.
2025-01-06 17:45:06.097 | 6AH5.CME [CBV][M] Weekly #5 | Chart data loading complete.
2025-01-06 17:45:06.098 | 6AH5.CME [CBV][M] Monthly #4 | Reloading chart.
2025-01-06 17:45:06.098 | 6AH5.CME [CBV][M] Monthly #4 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2025-01-06 17:45:06.098 | 6AH5.CME [CBV][M] Monthly #4 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2025-01-06 17:45:06.882 | 6AH5.CME [CBV][M] Monthly #4 | Chart data loading complete.
2025-01-06 17:45:07.391 | HD Request # 67 | Receiving historical Daily data for NQH5.CME starting at 2024-12-31.
2025-01-06 17:45:07.391 | HD Request # 67 | Writing historical Daily data to the file NQH5.CME.dly.
2025-01-06 17:45:07.392 | HD Request # 67 | Bytes received: 315
2025-01-06 17:45:07.392 | HD Request # 67 | Received 5 Daily data records from 2024-12-31 00:00:00 to 2025-01-06 00:00:00 (7.0 days) and wrote 4 records for NQH5.CME
2025-01-06 17:45:07.392 | HD Request # 67 | Completion time: 3s.
2025-01-06 17:45:07.392 | HD Request # 67 | Daily data download complete for NQH5.CME. Unique request ID: 66
2025-01-06 17:45:07.392 | Removing historical data download ID 66.
2025-01-06 17:45:07.392 | Triggering next historical data download in queue.
2025-01-06 17:45:07.393 | HD Request # 68 | Downloading Historical Daily chart data for GCG5.COMEX. Starting date: 2024-12-31. Service: rithmic.trading
2025-01-06 17:45:07.610 | NQH5.CME [CBV][M] Monthly #4 | Reloading chart.
2025-01-06 17:45:07.610 | NQH5.CME [CBV][M] Monthly #4 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2025-01-06 17:45:07.610 | NQH5.CME [CBV][M] Monthly #4 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2025-01-06 17:45:07.899 | NQH5.CME [CBV][M] Weekly #5 | Reloading chart.
2025-01-06 17:45:07.899 | NQH5.CME [CBV][M] Weekly #5 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2025-01-06 17:45:07.899 | NQH5.CME [CBV][M] Weekly #5 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2025-01-06 17:45:08.185 | NQH5.CME [CBV][M] Monthly #4 | Chart data loading complete.
2025-01-06 17:45:08.304 | NQH5.CME [CBV][M] Weekly #5 | Chart data loading complete.
2025-01-06 17:45:08.306 | NQH5.CME [CBV][M] Daily #6 | Reloading chart.
2025-01-06 17:45:08.306 | NQH5.CME [CBV][M] Daily #6 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2025-01-06 17:45:08.306 | NQH5.CME [CBV][M] Daily #6 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2025-01-06 17:45:08.662 | NQH5.CME [CBV][M] Daily #6 | Chart data loading complete.
2025-01-06 17:45:08.776 | HD Request # 68 | Requesting historical Daily data for GCG25 starting at 2024-12-30. SC External HD service.
2025-01-06 17:45:09.586 | HD Request # 68 | Receiving historical Daily data for GCG5.COMEX starting at 2024-12-31.
2025-01-06 17:45:09.587 | HD Request # 68 | Writing historical Daily data to the file GCG5.COMEX.dly.
2025-01-06 17:45:09.588 | HD Request # 68 | Bytes received: 282
2025-01-06 17:45:09.588 | HD Request # 68 | Received 5 Daily data records from 2024-12-31 00:00:00 to 2025-01-06 00:00:00 (7.0 days) and wrote 4 records for GCG5.COMEX
2025-01-06 17:45:09.588 | HD Request # 68 | Completion time: 2s.
2025-01-06 17:45:09.588 | HD Request # 68 | Daily data download complete for GCG5.COMEX. Unique request ID: 67
2025-01-06 17:45:09.588 | Removing historical data download ID 67.
2025-01-06 17:45:09.588 | Triggering next historical data download in queue.
2025-01-06 17:45:09.589 | HD Request # 69 | Downloading Historical Daily chart data for SIH5.COMEX. Starting date: 2024-12-31. Service: rithmic.trading
2025-01-06 17:45:10.267 | GCG5.COMEX [CBV][M] Daily #6 | Reloading chart.
2025-01-06 17:45:10.267 | GCG5.COMEX [CBV][M] Daily #6 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2025-01-06 17:45:10.267 | GCG5.COMEX [CBV][M] Daily #6 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2025-01-06 17:45:10.910 | HD Request # 69 | Requesting historical Daily data for SIH25 starting at 2024-12-30. SC External HD service.
2025-01-06 17:45:11.017 | GCG5.COMEX [CBV][M] Daily #6 | Chart data loading complete.
2025-01-06 17:45:11.018 | GCG5.COMEX [CBV][M] Monthly #4 | Reloading chart.
2025-01-06 17:45:11.018 | GCG5.COMEX [CBV][M] Monthly #4 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2025-01-06 17:45:11.018 | GCG5.COMEX [CBV][M] Monthly #4 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2025-01-06 17:45:11.668 | GCG5.COMEX [CBV][M] Weekly #5 | Reloading chart.
2025-01-06 17:45:11.668 | GCG5.COMEX [CBV][M] Weekly #5 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2025-01-06 17:45:11.669 | GCG5.COMEX [CBV][M] Weekly #5 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2025-01-06 17:45:12.305 | GCG5.COMEX [CBV][M] Monthly #4 | Chart data loading complete.
2025-01-06 17:45:12.305 | HD Request # 69 | Receiving historical Daily data for SIH5.COMEX starting at 2024-12-31.
2025-01-06 17:45:12.305 | HD Request # 69 | Writing historical Daily data to the file SIH5.COMEX.dly.
2025-01-06 17:45:12.306 | HD Request # 69 | Bytes received: 276
2025-01-06 17:45:12.306 | HD Request # 69 | Received 5 Daily data records from 2024-12-31 00:00:00 to 2025-01-06 00:00:00 (7.0 days) and wrote 4 records for SIH5.COMEX
2025-01-06 17:45:12.306 | HD Request # 69 | Completion time: 3s.
2025-01-06 17:45:12.306 | HD Request # 69 | Daily data download complete for SIH5.COMEX. Unique request ID: 68
2025-01-06 17:45:12.306 | Removing historical data download ID 68.
2025-01-06 17:45:12.306 | No download requests in the queue to start downloads for.
2025-01-06 17:45:12.411 | GCG5.COMEX [CBV][M] Weekly #5 | Chart data loading complete.
2025-01-06 17:45:12.788 | SIH5.COMEX [CBV][M] Weekly #5 | Reloading chart.
2025-01-06 17:45:12.788 | SIH5.COMEX [CBV][M] Weekly #5 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2025-01-06 17:45:12.788 | SIH5.COMEX [CBV][M] Weekly #5 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2025-01-06 17:45:13.384 | SIH5.COMEX [CBV][M] Monthly #4 | Reloading chart.
2025-01-06 17:45:13.384 | SIH5.COMEX [CBV][M] Monthly #4 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2025-01-06 17:45:13.384 | SIH5.COMEX [CBV][M] Monthly #4 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2025-01-06 17:45:13.965 | SIH5.COMEX [CBV][M] Weekly #5 | Chart data loading complete.
2025-01-06 17:45:14.073 | SIH5.COMEX [CBV][M] Monthly #4 | Chart data loading complete.
2025-01-06 17:45:14.074 | SIH5.COMEX [CBV][M] Daily #6 | Reloading chart.
2025-01-06 17:45:14.074 | SIH5.COMEX [CBV][M] Daily #6 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2025-01-06 17:45:14.074 | SIH5.COMEX [CBV][M] Daily #6 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2025-01-06 17:45:14.739 | SIH5.COMEX [CBV][M] Daily #6 | Chart data loading complete.
2025-01-06 18:00:03.872 | Opened cached Intraday file: C:\SierraChart - TopStep\Data\SPX500.scid. Thread ID: 16528
2025-01-06 18:00:30.288 | Added historical Daily data request for ESH5.CME to the queue.
2025-01-06 18:00:30.288 | Triggering next historical data download in queue.
2025-01-06 18:00:30.289 | HD Request # 70 | Downloading Historical Daily chart data for ESH5.CME. Starting date: 2025-01-02. Service: rithmic.trading
2025-01-06 18:00:30.290 | Added historical Daily data request for GCG5.COMEX to the queue.
2025-01-06 18:00:30.290 | Triggering next historical data download in queue.
2025-01-06 18:00:31.299 | Added historical Daily data request for NQH5.CME to the queue.
2025-01-06 18:00:31.299 | Triggering next historical data download in queue.
2025-01-06 18:00:31.403 | HD Request # 70 | Requesting historical Daily data for ESH25 starting at 2025-01-01. SC External HD service.
2025-01-06 18:00:31.636 | Added historical Daily data request for SIH5.COMEX to the queue.
2025-01-06 18:00:31.636 | Triggering next historical data download in queue.
2025-01-06 18:00:32.386 | HD Request # 70 | Receiving historical Daily data for ESH5.CME starting at 2025-01-02.
2025-01-06 18:00:32.386 | HD Request # 70 | Writing historical Daily data to the file ESH5.CME.dly.
2025-01-06 18:00:32.387 | HD Request # 70 | Bytes received: 188
2025-01-06 18:00:32.387 | HD Request # 70 | Received 3 Daily data records from 2025-01-02 00:00:00 to 2025-01-06 00:00:00 (5.0 days) and wrote 3 records for ESH5.CME
2025-01-06 18:00:32.388 | HD Request # 70 | Completion time: 2s.
2025-01-06 18:00:32.388 | HD Request # 70 | Daily data download complete for ESH5.CME. Unique request ID: 70
2025-01-06 18:00:32.388 | Removing historical data download ID 70.
2025-01-06 18:00:32.388 | Triggering next historical data download in queue.
2025-01-06 18:00:32.388 | HD Request # 71 | Downloading Historical Daily chart data for GCG5.COMEX. Starting date: 2025-01-02. Service: rithmic.trading
2025-01-06 18:00:33.063 | Added historical Daily data request for 6AH5.CME to the queue.
2025-01-06 18:00:33.063 | Triggering next historical data download in queue.
2025-01-06 18:00:33.064 | ESH5.CME [CBV][M] Daily #6 | Reloading chart.
2025-01-06 18:00:33.064 | ESH5.CME [CBV][M] Daily #6 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2025-01-06 18:00:33.064 | ESH5.CME [CBV][M] Daily #6 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2025-01-06 18:00:33.387 | ESH5.CME [CBV][M] Weekly #5 | Reloading chart.
2025-01-06 18:00:33.387 | ESH5.CME [CBV][M] Weekly #5 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2025-01-06 18:00:33.387 | ESH5.CME [CBV][M] Weekly #5 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2025-01-06 18:00:33.726 | ESH5.CME [CBV][M] Daily #6 | Chart data loading complete.
2025-01-06 18:00:33.726 | HD Request # 71 | Requesting historical Daily data for GCG25 starting at 2025-01-01. SC External HD service.
2025-01-06 18:00:33.726 | ESH5.CME [CBV][M] Monthly #4 | Reloading chart.
2025-01-06 18:00:33.726 | ESH5.CME [CBV][M] Monthly #4 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2025-01-06 18:00:33.726 | ESH5.CME [CBV][M] Monthly #4 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2025-01-06 18:00:34.050 | ESH5.CME [CBV][M] Weekly #5 | Chart data loading complete.
2025-01-06 18:00:34.084 | ESH5.CME [CBV][M] Monthly #4 | Chart data loading complete.
2025-01-06 18:00:34.653 | HD Request # 71 | Receiving historical Daily data for GCG5.COMEX starting at 2025-01-02.
2025-01-06 18:00:34.653 | HD Request # 71 | Writing historical Daily data to the file GCG5.COMEX.dly.
2025-01-06 18:00:34.655 | HD Request # 71 | Bytes received: 171
2025-01-06 18:00:34.655 | HD Request # 71 | Received 3 Daily data records from 2025-01-02 00:00:00 to 2025-01-06 00:00:00 (5.0 days) and wrote 3 records for GCG5.COMEX
2025-01-06 18:00:34.655 | HD Request # 71 | Completion time: 2s.
2025-01-06 18:00:34.655 | HD Request # 71 | Daily data download complete for GCG5.COMEX. Unique request ID: 71
2025-01-06 18:00:34.655 | Removing historical data download ID 71.
2025-01-06 18:00:34.655 | Triggering next historical data download in queue.
2025-01-06 18:00:34.656 | HD Request # 72 | Downloading Historical Daily chart data for NQH5.CME. Starting date: 2025-01-02. Service: rithmic.trading
2025-01-06 18:00:35.028 | GCG5.COMEX [CBV][M] Weekly #5 | Reloading chart.
2025-01-06 18:00:35.028 | GCG5.COMEX [CBV][M] Weekly #5 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2025-01-06 18:00:35.028 | GCG5.COMEX [CBV][M] Weekly #5 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2025-01-06 18:00:35.706 | GCG5.COMEX [CBV][M] Monthly #4 | Reloading chart.
2025-01-06 18:00:35.706 | GCG5.COMEX [CBV][M] Monthly #4 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2025-01-06 18:00:35.706 | GCG5.COMEX [CBV][M] Monthly #4 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2025-01-06 18:00:36.362 | GCG5.COMEX [CBV][M] Weekly #5 | Chart data loading complete.
2025-01-06 18:00:36.362 | HD Request # 72 | Requesting historical Daily data for NQH25 starting at 2025-01-01. SC External HD service.
2025-01-06 18:00:36.473 | GCG5.COMEX [CBV][M] Monthly #4 | Chart data loading complete.
2025-01-06 18:00:36.817 | GCG5.COMEX [CBV][M] Daily #6 | Reloading chart.
2025-01-06 18:00:36.817 | GCG5.COMEX [CBV][M] Daily #6 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2025-01-06 18:00:36.817 | GCG5.COMEX [CBV][M] Daily #6 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2025-01-06 18:00:37.450 | HD Request # 72 | Receiving historical Daily data for NQH5.CME starting at 2025-01-02.
2025-01-06 18:00:37.450 | HD Request # 72 | Writing historical Daily data to the file NQH5.CME.dly.
2025-01-06 18:00:37.451 | HD Request # 72 | Bytes received: 191
2025-01-06 18:00:37.451 | HD Request # 72 | Received 3 Daily data records from 2025-01-02 00:00:00 to 2025-01-06 00:00:00 (5.0 days) and wrote 3 records for NQH5.CME
2025-01-06 18:00:37.451 | HD Request # 72 | Completion time: 3s.
2025-01-06 18:00:37.451 | HD Request # 72 | Daily data download complete for NQH5.CME. Unique request ID: 72
2025-01-06 18:00:37.451 | Removing historical data download ID 72.
2025-01-06 18:00:37.452 |
2025-01-06 18:00:37.452 | Triggering next historical data download in queue.
2025-01-06 18:00:37.453 | HD Request # 73 | Downloading Historical Daily chart data for SIH5.COMEX. Starting date: 2025-01-02. Service: rithmic.trading
2025-01-06 18:00:37.556 | GCG5.COMEX [CBV][M] Daily #6 | Chart data loading complete.
2025-01-06 18:00:37.979 | NQH5.CME [CBV][M] Monthly #4 | Reloading chart.
2025-01-06 18:00:37.979 | NQH5.CME [CBV][M] Monthly #4 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2025-01-06 18:00:37.979 | NQH5.CME [CBV][M] Monthly #4 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2025-01-06 18:00:38.379 | NQH5.CME [CBV][M] Monthly #4 | Chart data loading complete.
2025-01-06 18:00:38.381 | NQH5.CME [CBV][M] Weekly #5 | Reloading chart.
2025-01-06 18:00:38.381 | NQH5.CME [CBV][M] Weekly #5 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2025-01-06 18:00:38.381 | NQH5.CME [CBV][M] Weekly #5 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2025-01-06 18:00:38.666 | HD Request # 73 | Requesting historical Daily data for SIH25 starting at 2025-01-01. SC External HD service.
2025-01-06 18:00:38.667 | NQH5.CME [CBV][M] Daily #6 | Reloading chart.
2025-01-06 18:00:38.667 | NQH5.CME [CBV][M] Daily #6 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2025-01-06 18:00:38.667 | NQH5.CME [CBV][M] Daily #6 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2025-01-06 18:00:38.953 | NQH5.CME [CBV][M] Weekly #5 | Chart data loading complete.
2025-01-06 18:00:39.021 | NQH5.CME [CBV][M] Daily #6 | Chart data loading complete.
2025-01-06 18:00:39.589 | HD Request # 73 | Receiving historical Daily data for SIH5.COMEX starting at 2025-01-02.
2025-01-06 18:00:39.589 | HD Request # 73 | Writing historical Daily data to the file SIH5.COMEX.dly.
2025-01-06 18:00:39.591 | HD Request # 73 | Bytes received: 167
2025-01-06 18:00:39.591 | HD Request # 73 | Received 3 Daily data records from 2025-01-02 00:00:00 to 2025-01-06 00:00:00 (5.0 days) and wrote 3 records for SIH5.COMEX
2025-01-06 18:00:39.591 | HD Request # 73 | Completion time: 2s.
2025-01-06 18:00:39.591 | HD Request # 73 | Daily data download complete for SIH5.COMEX. Unique request ID: 73
2025-01-06 18:00:39.591 | Removing historical data download ID 73.
2025-01-06 18:00:39.591 | Triggering next historical data download in queue.
2025-01-06 18:00:39.592 | HD Request # 74 | Downloading Historical Daily chart data for 6AH5.CME. Starting date: 2025-01-02. Service: rithmic.trading
2025-01-06 18:00:39.809 | SIH5.COMEX [CBV][M] Daily #6 | Reloading chart.
2025-01-06 18:00:39.809 | SIH5.COMEX [CBV][M] Daily #6 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2025-01-06 18:00:39.809 | SIH5.COMEX [CBV][M] Daily #6 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2025-01-06 18:00:40.509 | SIH5.COMEX [CBV][M] Daily #6 | Chart data loading complete.
2025-01-06 18:00:40.509 | SIH5.COMEX [CBV][M] Monthly #4 | Reloading chart.
2025-01-06 18:00:40.509 | SIH5.COMEX [CBV][M] Monthly #4 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2025-01-06 18:00:40.509 | SIH5.COMEX [CBV][M] Monthly #4 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2025-01-06 18:00:41.179 | SIH5.COMEX [CBV][M] Monthly #4 | Chart data loading complete.
2025-01-06 18:00:41.269 | HD Request # 74 | Requesting historical Daily data for A6H25 starting at 2025-01-01. SC External HD service.
2025-01-06 18:00:41.436 | SIH5.COMEX [CBV][M] Weekly #5 | Reloading chart.
2025-01-06 18:00:41.436 | SIH5.COMEX [CBV][M] Weekly #5 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2025-01-06 18:00:41.436 | SIH5.COMEX [CBV][M] Weekly #5 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2025-01-06 18:00:42.140 | SIH5.COMEX [CBV][M] Weekly #5 | Chart data loading complete.
2025-01-06 18:00:42.733 | HD Request # 74 | Receiving historical Daily data for 6AH5.CME starting at 2025-01-02.
2025-01-06 18:00:42.733 | HD Request # 74 | Writing historical Daily data to the file 6AH5.CME.dly.
2025-01-06 18:00:42.737 | HD Request # 74 | Bytes received: 181
2025-01-06 18:00:42.737 | HD Request # 74 | Received 3 Daily data records from 2025-01-02 00:00:00 to 2025-01-06 00:00:00 (5.0 days) and wrote 3 records for 6AH5.CME
2025-01-06 18:00:42.737 | HD Request # 74 | Completion time: 3s.
2025-01-06 18:00:42.737 | HD Request # 74 | Daily data download complete for 6AH5.CME. Unique request ID: 74
2025-01-06 18:00:42.737 | Removing historical data download ID 74.
2025-01-06 18:00:42.737 | No download requests in the queue to start downloads for.
2025-01-06 18:00:42.993 | 6AH5.CME [CBV][M] Weekly #5 | Reloading chart.
2025-01-06 18:00:42.993 | 6AH5.CME [CBV][M] Weekly #5 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2025-01-06 18:00:42.993 | 6AH5.CME [CBV][M] Weekly #5 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2025-01-06 18:00:43.775 | 6AH5.CME [CBV][M] Weekly #5 | Chart data loading complete.
2025-01-06 18:00:44.180 | 6AH5.CME [CBV][M] Daily #6 | Reloading chart.
2025-01-06 18:00:44.180 | 6AH5.CME [CBV][M] Daily #6 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2025-01-06 18:00:44.180 | 6AH5.CME [CBV][M] Daily #6 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2025-01-06 18:00:44.880 | 6AH5.CME [CBV][M] Monthly #4 | Reloading chart.
2025-01-06 18:00:44.880 | 6AH5.CME [CBV][M] Monthly #4 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2025-01-06 18:00:44.880 | 6AH5.CME [CBV][M] Monthly #4 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2025-01-06 18:00:45.582 | 6AH5.CME [CBV][M] Daily #6 | Chart data loading complete.
2025-01-06 18:00:45.689 | 6AH5.CME [CBV][M] Monthly #4 | Chart data loading complete.
2025-01-06 19:03:34.049 | HTTPS connection ID:10 to downloads.rithmic.com:443 for request ID:10 (5) | Creating socket. Using TLS 1.2.
2025-01-06 19:03:34.049 | HTTPS connection ID:10 to downloads.rithmic.com:443 for request ID:10 (5) | New receive buffer size: 0
2025-01-06 19:03:34.049 | HTTPS connection ID:10 to downloads.rithmic.com:443 for request ID:10 (5) | Connecting to IP: 216.66.0.130.
2025-01-06 19:03:35.521 | Rithmic Direct - DTC | Wrote file: C:\SierraChart - TopStep\RithmicConnections.json. Size: 81131
2025-01-06 19:03:35.521 | Rithmic Direct - DTC | Processed connection points. Count: 347
2025-01-06 19:03:36.653 | HTTPS connection ID:10 to downloads.rithmic.com:443 for request ID:10 (5) | CloseSocket call.
2025-01-06 19:03:36.653 | HTTPS connection ID:10 to downloads.rithmic.com:443 for request ID:10 (5) | Shutdown started. Waiting for graceful close.
2025-01-06 19:03:36.887 | HTTPS connection ID:10 to downloads.rithmic.com:443 for request ID:10 (5) | Socket gracefully closed by remote side.
2025-01-06 19:03:36.887 | HTTPS connection ID:10 to downloads.rithmic.com:443 for request ID:10 (5) | Closed.
2025-01-06 19:03:45.799 | SC Data with Depth | Message from server: Authorization data verified.
2025-01-06 19:03:53.800 | Denali Data Feed | Message from server: Authorization data verified.
2025-01-06 21:59:59.892 | Chat | Server has requested a logoff. Reason: Chat server is backing up
2025-01-06 21:59:59.892 | Chat | Waiting for socket receive thread to end
2025-01-06 21:59:59.893 | DTC Client socket (4) | CloseSocket call.
2025-01-06 21:59:59.893 | DTC Client socket (4) | Shutdown started. Waiting for graceful close.
2025-01-06 21:59:59.893 | Chat | Disconnected from the server.
2025-01-06 21:59:59.893 | Chat | Data feed disconnected. Will reconnect in 5 seconds.
2025-01-06 22:00:02.629 | DTC Client socket (4) | Socket gracefully closed by remote side.
2025-01-06 22:00:02.629 | DTC Client socket (4) | Closed.
2025-01-06 22:00:04.894 | WSACleanup called.
2025-01-06 22:00:04.894 | Chat | Connecting to the server chat2.sierracharts.com. Port 10065
2025-01-06 22:00:05.052 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2025-01-06 22:00:05.052 | DTC Client socket (4) | New receive buffer size: 0
2025-01-06 22:00:05.052 | DTC Client socket (4) | Connecting to IP: 64.152.155.20.
2025-01-06 22:00:05.294 | Chat | Network connection to server complete.
2025-01-06 22:00:05.294 | Chat | Starting socket receive thread.
2025-01-06 22:00:05.294 | Chat | Sending encoding request to server: Binary VLS. Compression: none
2025-01-06 22:00:06.024 | Chat | Setting DTC encoding to Binary VLS
2025-01-06 22:00:06.024 | Chat | Sending logon request message.
2025-01-06 22:00:11.116 | Chat | Received logon response.
2025-01-06 22:00:11.116 | Chat | Server Name: SC DTC Server. Build=52080.
2025-01-06 22:00:11.116 | Chat | Server protocol version: 8. Client protocol version: 8
2025-01-06 22:00:11.116 | Chat | Successfully connected. Connected to SC DTC Protocol server. Service=chat_server.data|SymbolSettings=chat_server.data.
2025-01-06 22:00:11.116 | Chat | Trading is not supported.
2025-01-06 22:00:11.116 | Chat | MarketDepthIsSupported: 1
2025-01-06 23:03:36.122 | HTTPS connection ID:11 to downloads.rithmic.com:443 for request ID:11 (5) | Creating socket. Using TLS 1.2.
2025-01-06 23:03:36.122 | HTTPS connection ID:11 to downloads.rithmic.com:443 for request ID:11 (5) | New receive buffer size: 0
2025-01-06 23:03:36.122 | HTTPS connection ID:11 to downloads.rithmic.com:443 for request ID:11 (5) | Connecting to IP: 216.66.0.130.
2025-01-06 23:03:37.581 | Rithmic Direct - DTC | Wrote file: C:\SierraChart - TopStep\RithmicConnections.json. Size: 81131
2025-01-06 23:03:37.581 | Rithmic Direct - DTC | Processed connection points. Count: 347
2025-01-06 23:03:38.316 | HTTPS connection ID:11 to downloads.rithmic.com:443 for request ID:11 (5) | CloseSocket call.
2025-01-06 23:03:38.316 | HTTPS connection ID:11 to downloads.rithmic.com:443 for request ID:11 (5) | Shutdown started. Waiting for graceful close.
2025-01-06 23:03:38.554 | HTTPS connection ID:11 to downloads.rithmic.com:443 for request ID:11 (5) | Socket gracefully closed by remote side.
2025-01-06 23:03:38.554 | HTTPS connection ID:11 to downloads.rithmic.com:443 for request ID:11 (5) | Closed.
2025-01-07 00:00:00.317 | Added historical Daily data request for ESH5.CME to the queue.
2025-01-07 00:00:00.317 | Triggering next historical data download in queue.
2025-01-07 00:00:00.318 | HD Request # 75 | Downloading Historical Daily chart data for ESH5.CME. Starting date: 2025-01-02. Service: rithmic.trading
2025-01-07 00:00:00.319 | Added historical Daily data request for USDX to the queue.
2025-01-07 00:00:00.319 | Triggering next historical data download in queue.
2025-01-07 00:00:00.320 | HD Request # 76 | Downloading Historical Daily chart data for USDX. Starting date: 2025-01-03. Service: fxstatscalc
2025-01-07 00:00:00.320 | HD Request # 76 | Using server: ds4.sierracharts.com port 10149
2025-01-07 00:00:00.426 | Added historical Daily data request for SIH5.COMEX to the queue.
2025-01-07 00:00:00.426 | Triggering next historical data download in queue.
2025-01-07 00:00:00.426 | Added historical Daily data request for NQH5.CME to the queue.
2025-01-07 00:00:00.468 | Socket (6) | Creating socket.
2025-01-07 00:00:00.468 | Socket (6) | New receive buffer size: 0
2025-01-07 00:00:00.468 | Socket (6) | Connecting to IP: 67.214.125.7.
2025-01-07 00:00:00.854 | Added historical Daily data request for 6AH5.CME to the queue.
2025-01-07 00:00:00.854 | Triggering next historical data download in queue.
2025-01-07 00:00:00.854 | Added historical Daily data request for GCG5.COMEX to the queue.
2025-01-07 00:00:00.944 | HD Request # 76 | Setting DTC encoding to Binary VLS
2025-01-07 00:00:00.944 | HD Request # 76 | Sending historical data logon request message.
2025-01-07 00:00:01.204 | HD Request # 76 | Requesting historical Daily data starting at 2025-01-03.
2025-01-07 00:00:01.428 | HD Request # 75 | Requesting historical Daily data for ESH25 starting at 2025-01-01. SC External HD service.
2025-01-07 00:00:01.437 | HD Request # 76 | Decompressing data.
2025-01-07 00:00:01.470 | HD Request # 76 | Receiving historical Daily data for USDX starting at 2025-01-03.
2025-01-07 00:00:01.471 | HD Request # 76 | Writing historical Daily data to the file USDX.dly.
2025-01-07 00:00:01.484 | Socket (6) | CloseSocket call.
2025-01-07 00:00:01.484 | Socket (6) | Shutdown started. Waiting for graceful close.
2025-01-07 00:00:01.497 | Historical data download thread signaled to stop.
2025-01-07 00:00:01.497 | HD Request # 76 | Received 3 Daily data records from 2025-01-03 00:00:00 to 2025-01-07 00:00:00 (5.0 days) and wrote 3 records for USDX
2025-01-07 00:00:01.497 | HD Request # 76 | Completion time: 1s.
2025-01-07 00:00:01.497 | HD Request # 76 | Daily data download complete for USDX. Unique request ID: 76
2025-01-07 00:00:01.497 | Removing historical data download ID 76.
2025-01-07 00:00:01.497 | No download requests in the queue to start downloads for.
2025-01-07 00:00:01.716 | Socket (6) | Socket gracefully closed by remote side.
2025-01-07 00:00:01.716 | Socket (6) | Closed.
2025-01-07 00:00:02.115 | USDX[M] Daily #19 | Reloading chart.
2025-01-07 00:00:02.154 | USDX[M] Daily #19 | StartDateTimeForLoadingOrderFills: 2024-01-01 00:00:00
2025-01-07 00:00:02.154 | USDX[M] Daily #19 | Chart data loading complete.
2025-01-07 00:00:02.388 | HD Request # 75 | Receiving historical Daily data for ESH5.CME starting at 2025-01-02.
2025-01-07 00:00:02.388 | HD Request # 75 | Writing historical Daily data to the file ESH5.CME.dly.
2025-01-07 00:00:02.390 | HD Request # 75 | Bytes received: 188
2025-01-07 00:00:02.390 | HD Request # 75 | Received 3 Daily data records from 2025-01-02 00:00:00 to 2025-01-06 00:00:00 (5.0 days) and wrote 3 records for ESH5.CME
2025-01-07 00:00:02.390 | HD Request # 75 | Completion time: 2s.
2025-01-07 00:00:02.390 | HD Request # 75 | Daily data download complete for ESH5.CME. Unique request ID: 75
2025-01-07 00:00:02.390 | Removing historical data download ID 75.
2025-01-07 00:00:02.390 | Triggering next historical data download in queue.
2025-01-07 00:00:02.391 | HD Request # 77 | Downloading Historical Daily chart data for SIH5.COMEX. Starting date: 2025-01-02. Service: rithmic.trading
2025-01-07 00:00:02.656 | ESH5.CME [CBV][M] Daily #6 | Reloading chart.
2025-01-07 00:00:02.656 | ESH5.CME [CBV][M] Daily #6 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2025-01-07 00:00:02.656 | ESH5.CME [CBV][M] Daily #6 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2025-01-07 00:00:02.988 | ESH5.CME [CBV][M] Monthly #4 | Reloading chart.
2025-01-07 00:00:02.988 | ESH5.CME [CBV][M] Monthly #4 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2025-01-07 00:00:02.988 | ESH5.CME [CBV][M] Monthly #4 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2025-01-07 00:00:03.313 | ESH5.CME [CBV][M] Daily #6 | Chart data loading complete.
2025-01-07 00:00:03.356 | ESH5.CME [CBV][M] Monthly #4 | Chart data loading complete.
2025-01-07 00:00:03.499 | HD Request # 77 | Requesting historical Daily data for SIH25 starting at 2025-01-01. SC External HD service.
2025-01-07 00:00:03.719 | ESH5.CME [CBV][M] Weekly #5 | Reloading chart.
2025-01-07 00:00:03.719 | ESH5.CME [CBV][M] Weekly #5 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2025-01-07 00:00:03.719 | ESH5.CME [CBV][M] Weekly #5 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2025-01-07 00:00:04.079 | ESH5.CME [CBV][M] Weekly #5 | Chart data loading complete.
2025-01-07 00:00:04.724 | HD Request # 77 | Receiving historical Daily data for SIH5.COMEX starting at 2025-01-02.
2025-01-07 00:00:04.724 | HD Request # 77 | Writing historical Daily data to the file SIH5.COMEX.dly.
2025-01-07 00:00:04.725 | HD Request # 77 | Bytes received: 167
2025-01-07 00:00:04.725 | HD Request # 77 | Received 3 Daily data records from 2025-01-02 00:00:00 to 2025-01-06 00:00:00 (5.0 days) and wrote 3 records for SIH5.COMEX
2025-01-07 00:00:04.726 | HD Request # 77 | Completion time: 2s.
2025-01-07 00:00:04.726 | HD Request # 77 | Daily data download complete for SIH5.COMEX. Unique request ID: 77
2025-01-07 00:00:04.726 | Removing historical data download ID 77.
2025-01-07 00:00:04.726 | Triggering next historical data download in queue.
2025-01-07 00:00:04.727 | HD Request # 78 | Downloading Historical Daily chart data for NQH5.CME. Starting date: 2025-01-02. Service: rithmic.trading
2025-01-07 00:00:05.095 | SIH5.COMEX [CBV][M] Weekly #5 | Reloading chart.
2025-01-07 00:00:05.095 | SIH5.COMEX [CBV][M] Weekly #5 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2025-01-07 00:00:05.095 | SIH5.COMEX [CBV][M] Weekly #5 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2025-01-07 00:00:05.756 | SIH5.COMEX [CBV][M] Weekly #5 | Chart data loading complete.
2025-01-07 00:00:05.843 | HD Request # 78 | Requesting historical Daily data for NQH25 starting at 2025-01-01. SC External HD service.
2025-01-07 00:00:06.089 | SIH5.COMEX [CBV][M] Monthly #4 | Reloading chart.
2025-01-07 00:00:06.089 | SIH5.COMEX [CBV][M] Monthly #4 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2025-01-07 00:00:06.089 | SIH5.COMEX [CBV][M] Monthly #4 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2025-01-07 00:00:06.671 | SIH5.COMEX [CBV][M] Daily #6 | Reloading chart.
2025-01-07 00:00:06.671 | SIH5.COMEX [CBV][M] Daily #6 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2025-01-07 00:00:06.671 | SIH5.COMEX [CBV][M] Daily #6 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2025-01-07 00:00:07.252 | SIH5.COMEX [CBV][M] Monthly #4 | Chart data loading complete.
2025-01-07 00:00:07.252 | HD Request # 78 | Receiving historical Daily data for NQH5.CME starting at 2025-01-02.
2025-01-07 00:00:07.252 | HD Request # 78 | Writing historical Daily data to the file NQH5.CME.dly.
2025-01-07 00:00:07.253 | HD Request # 78 | Bytes received: 191
2025-01-07 00:00:07.253 | HD Request # 78 | Received 3 Daily data records from 2025-01-02 00:00:00 to 2025-01-06 00:00:00 (5.0 days) and wrote 3 records for NQH5.CME
2025-01-07 00:00:07.253 | HD Request # 78 | Completion time: 3s.
2025-01-07 00:00:07.253 | HD Request # 78 | Daily data download complete for NQH5.CME. Unique request ID: 78
2025-01-07 00:00:07.253 | Removing historical data download ID 78.
2025-01-07 00:00:07.253 | Triggering next historical data download in queue.
2025-01-07 00:00:07.254 | HD Request # 79 | Downloading Historical Daily chart data for 6AH5.CME. Starting date: 2025-01-02. Service: rithmic.trading
2025-01-07 00:00:07.322 | SIH5.COMEX [CBV][M] Daily #6 | Chart data loading complete.
2025-01-07 00:00:07.762 | NQH5.CME [CBV][M] Weekly #5 | Reloading chart.
2025-01-07 00:00:07.762 | NQH5.CME [CBV][M] Weekly #5 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2025-01-07 00:00:07.762 | NQH5.CME [CBV][M] Weekly #5 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2025-01-07 00:00:08.113 | NQH5.CME [CBV][M] Weekly #5 | Chart data loading complete.
2025-01-07 00:00:08.442 | NQH5.CME [CBV][M] Monthly #4 | Reloading chart.
2025-01-07 00:00:08.442 | NQH5.CME [CBV][M] Monthly #4 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2025-01-07 00:00:08.442 | NQH5.CME [CBV][M] Monthly #4 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2025-01-07 00:00:08.726 | HD Request # 79 | Requesting historical Daily data for A6H25 starting at 2025-01-01. SC External HD service.
2025-01-07 00:00:08.727 | NQH5.CME [CBV][M] Daily #6 | Reloading chart.
2025-01-07 00:00:08.727 | NQH5.CME [CBV][M] Daily #6 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2025-01-07 00:00:08.727 | NQH5.CME [CBV][M] Daily #6 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2025-01-07 00:00:09.012 | NQH5.CME [CBV][M] Monthly #4 | Chart data loading complete.
2025-01-07 00:00:09.059 | NQH5.CME [CBV][M] Daily #6 | Chart data loading complete.
2025-01-07 00:00:09.754 | HD Request # 79 | Receiving historical Daily data for 6AH5.CME starting at 2025-01-02.
2025-01-07 00:00:09.754 | HD Request # 79 | Writing historical Daily data to the file 6AH5.CME.dly.
2025-01-07 00:00:09.758 | HD Request # 79 | Bytes received: 181
2025-01-07 00:00:09.758 | HD Request # 79 | Received 3 Daily data records from 2025-01-02 00:00:00 to 2025-01-06 00:00:00 (5.0 days) and wrote 3 records for 6AH5.CME
2025-01-07 00:00:09.758 | HD Request # 79 | Completion time: 2s.
2025-01-07 00:00:09.758 | HD Request # 79 | Daily data download complete for 6AH5.CME. Unique request ID: 79
2025-01-07 00:00:09.758 | Removing historical data download ID 79.
2025-01-07 00:00:09.758 | Triggering next historical data download in queue.
2025-01-07 00:00:09.759 | HD Request # 80 | Downloading Historical Daily chart data for GCG5.COMEX. Starting date: 2025-01-02. Service: rithmic.trading
2025-01-07 00:00:09.934 | 6AH5.CME [CBV][M] Weekly #5 | Reloading chart.
2025-01-07 00:00:09.934 | 6AH5.CME [CBV][M] Weekly #5 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2025-01-07 00:00:09.934 | 6AH5.CME [CBV][M] Weekly #5 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2025-01-07 00:00:10.621 | 6AH5.CME [CBV][M] Daily #6 | Reloading chart.
2025-01-07 00:00:10.621 | 6AH5.CME [CBV][M] Daily #6 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2025-01-07 00:00:10.621 | 6AH5.CME [CBV][M] Daily #6 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2025-01-07 00:00:11.306 | 6AH5.CME [CBV][M] Weekly #5 | Chart data loading complete.
2025-01-07 00:00:11.307 | 6AH5.CME [CBV][M] Monthly #4 | Reloading chart.
2025-01-07 00:00:11.307 | 6AH5.CME [CBV][M] Monthly #4 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2025-01-07 00:00:11.307 | 6AH5.CME [CBV][M] Monthly #4 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2025-01-07 00:00:12.001 | 6AH5.CME [CBV][M] Daily #6 | Chart data loading complete.
2025-01-07 00:00:12.001 | HD Request # 80 | Requesting historical Daily data for GCG25 starting at 2025-01-01. SC External HD service.
2025-01-07 00:00:12.124 | 6AH5.CME [CBV][M] Monthly #4 | Chart data loading complete.
2025-01-07 00:00:13.226 | HD Request # 80 | Receiving historical Daily data for GCG5.COMEX starting at 2025-01-02.
2025-01-07 00:00:13.226 | HD Request # 80 | Writing historical Daily data to the file GCG5.COMEX.dly.
2025-01-07 00:00:13.227 | HD Request # 80 | Bytes received: 171
2025-01-07 00:00:13.227 | HD Request # 80 | Received 3 Daily data records from 2025-01-02 00:00:00 to 2025-01-06 00:00:00 (5.0 days) and wrote 3 records for GCG5.COMEX
2025-01-07 00:00:13.227 | HD Request # 80 | Completion time: 4s.
2025-01-07 00:00:13.227 | HD Request # 80 | Daily data download complete for GCG5.COMEX. Unique request ID: 80
2025-01-07 00:00:13.227 | Removing historical data download ID 80.
2025-01-07 00:00:13.228 |
2025-01-07 00:00:13.228 | No download requests in the queue to start downloads for.
2025-01-07 00:00:13.720 | GCG5.COMEX [CBV][M] Weekly #5 | Reloading chart.
2025-01-07 00:00:13.720 | GCG5.COMEX [CBV][M] Weekly #5 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2025-01-07 00:00:13.720 | GCG5.COMEX [CBV][M] Weekly #5 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2025-01-07 00:00:14.358 | GCG5.COMEX [CBV][M] Monthly #4 | Reloading chart.
2025-01-07 00:00:14.358 | GCG5.COMEX [CBV][M] Monthly #4 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2025-01-07 00:00:14.358 | GCG5.COMEX [CBV][M] Monthly #4 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2025-01-07 00:00:14.992 | GCG5.COMEX [CBV][M] Weekly #5 | Chart data loading complete.
2025-01-07 00:00:14.993 | GCG5.COMEX [CBV][M] Daily #6 | Reloading chart.
2025-01-07 00:00:14.993 | GCG5.COMEX [CBV][M] Daily #6 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2025-01-07 00:00:14.993 | GCG5.COMEX [CBV][M] Daily #6 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2025-01-07 00:00:15.630 | GCG5.COMEX [CBV][M] Monthly #4 | Chart data loading complete.
2025-01-07 00:00:15.712 | GCG5.COMEX [CBV][M] Daily #6 | Chart data loading complete.
2025-01-07 00:06:14.775 | ESH5.CME [CBV][M] 15 Min #10 | Enable trading keyboard shortcuts with 'Trade >> Trading Keyboard Shortcuts Enabled'.
2025-01-07 00:22:38.201 | Chat | Message response. Chat ID: 429. Request ID: 1134629357
2025-01-07 01:42:05.516 | Chat | Message response. Chat ID: 429. Request ID: 1134629358
2025-01-07 01:45:00.088 | Chat | Message response. Chat ID: 429. Request ID: 1134629359
2025-01-07 03:03:38.977 | HTTPS connection ID:12 to downloads.rithmic.com:443 for request ID:12 (5) | Creating socket. Using TLS 1.2.
2025-01-07 03:03:38.978 | HTTPS connection ID:12 to downloads.rithmic.com:443 for request ID:12 (5) | New receive buffer size: 0
2025-01-07 03:03:38.978 | HTTPS connection ID:12 to downloads.rithmic.com:443 for request ID:12 (5) | Connecting to IP: 216.66.0.130.
2025-01-07 03:03:40.452 | Rithmic Direct - DTC | Wrote file: C:\SierraChart - TopStep\RithmicConnections.json. Size: 81131
2025-01-07 03:03:40.453 | Rithmic Direct - DTC | Processed connection points. Count: 347
2025-01-07 03:03:41.435 | HTTPS connection ID:12 to downloads.rithmic.com:443 for request ID:12 (5) | CloseSocket call.
2025-01-07 03:03:41.435 | HTTPS connection ID:12 to downloads.rithmic.com:443 for request ID:12 (5) | Shutdown started. Waiting for graceful close.
2025-01-07 03:03:41.670 | HTTPS connection ID:12 to downloads.rithmic.com:443 for request ID:12 (5) | Socket gracefully closed by remote side.
2025-01-07 03:03:41.670 | HTTPS connection ID:12 to downloads.rithmic.com:443 for request ID:12 (5) | Closed.
2025-01-07 07:03:41.111 | HTTPS connection ID:13 to downloads.rithmic.com:443 for request ID:13 (5) | Creating socket. Using TLS 1.2.
2025-01-07 07:03:41.111 | HTTPS connection ID:13 to downloads.rithmic.com:443 for request ID:13 (5) | New receive buffer size: 0
2025-01-07 07:03:41.111 | HTTPS connection ID:13 to downloads.rithmic.com:443 for request ID:13 (5) | Connecting to IP: 216.66.0.130.
2025-01-07 07:03:42.552 | Rithmic Direct - DTC | Wrote file: C:\SierraChart - TopStep\RithmicConnections.json. Size: 81131
2025-01-07 07:03:42.553 | Rithmic Direct - DTC | Processed connection points. Count: 347
2025-01-07 07:03:43.460 | HTTPS connection ID:13 to downloads.rithmic.com:443 for request ID:13 (5) | CloseSocket call.
2025-01-07 07:03:43.461 | HTTPS connection ID:13 to downloads.rithmic.com:443 for request ID:13 (5) | Shutdown started. Waiting for graceful close.
2025-01-07 07:03:43.697 | HTTPS connection ID:13 to downloads.rithmic.com:443 for request ID:13 (5) | Socket gracefully closed by remote side.
2025-01-07 07:03:43.697 | HTTPS connection ID:13 to downloads.rithmic.com:443 for request ID:13 (5) | Closed.
2025-01-07 07:51:59.349 | Chat | Message response. Chat ID: 429. Request ID: 1134629360
2025-01-07 08:03:24.671 | GCG5.COMEX [CBV][M] 15 Min #10 | StartDateTimeForLoadingOrderFills: 2024-01-01 00:00:00
2025-01-07 08:19:50.630 | Chat | Message response. Chat ID: 429. Request ID: 1134629361
2025-01-07 08:54:00.963 | Chat | Message response. Chat ID: 429. Request ID: 1134629362
2025-01-07 09:24:09.349 | Chat | Message response. Chat ID: 429. Request ID: 1134629363
2025-01-07 09:33:32.233 | Chat | Message response. Chat ID: 429. Request ID: 1134629364
2025-01-07 10:02:06.724 | Chat | Message response. Chat ID: 429. Request ID: 1134629365
2025-01-07 10:04:59.787 | Chat | Message response. Chat ID: 429. Request ID: 1134629366
2025-01-07 10:16:20.999 | Chat | Message response. Chat ID: 429. Request ID: 1134629367
2025-01-07 11:03:43.754 | HTTPS connection ID:14 to downloads.rithmic.com:443 for request ID:14 (5) | Creating socket. Using TLS 1.2.
2025-01-07 11:03:43.754 | HTTPS connection ID:14 to downloads.rithmic.com:443 for request ID:14 (5) | New receive buffer size: 0
2025-01-07 11:03:43.754 | HTTPS connection ID:14 to downloads.rithmic.com:443 for request ID:14 (5) | Connecting to IP: 216.66.0.130.
2025-01-07 11:03:45.245 | Rithmic Direct - DTC | Wrote file: C:\SierraChart - TopStep\RithmicConnections.json. Size: 81131
2025-01-07 11:03:45.246 | Rithmic Direct - DTC | Processed connection points. Count: 347
2025-01-07 11:03:46.263 | HTTPS connection ID:14 to downloads.rithmic.com:443 for request ID:14 (5) | CloseSocket call.
2025-01-07 11:03:46.263 | HTTPS connection ID:14 to downloads.rithmic.com:443 for request ID:14 (5) | Shutdown started. Waiting for graceful close.
2025-01-07 11:03:46.503 | HTTPS connection ID:14 to downloads.rithmic.com:443 for request ID:14 (5) | Socket gracefully closed by remote side.
2025-01-07 11:03:46.503 | HTTPS connection ID:14 to downloads.rithmic.com:443 for request ID:14 (5) | Closed.
2025-01-07 12:23:14.594 | Chat | Message response. Chat ID: 429. Request ID: 1134629368
2025-01-07 12:46:48.629 | Chat | Message response. Chat ID: 429. Request ID: 1134629369
2025-01-07 13:34:18.387 | Chat | Market data feed reported to be lost.
2025-01-07 13:34:19.282 | Chat | Server has requested a logoff. Reason: Server is being shut down
2025-01-07 13:34:19.282 | Chat | Waiting for socket receive thread to end
2025-01-07 13:34:19.283 | DTC Client socket (4) | CloseSocket call.
2025-01-07 13:34:19.283 | DTC Client socket (4) | Max send buffers used during socket life: 3
2025-01-07 13:34:19.283 | DTC Client socket (4) | Max send buffer size during socket life: 325
2025-01-07 13:34:19.283 | DTC Client socket (4) | Shutdown started. Waiting for graceful close.
2025-01-07 13:34:19.283 | Chat | Disconnected from the server.
2025-01-07 13:34:19.283 | Chat | Data feed disconnected. Will reconnect in 5 seconds.
2025-01-07 13:34:19.531 | DTC Client socket (4) | Socket gracefully closed by remote side.
2025-01-07 13:34:19.531 | DTC Client socket (4) | Closed.
2025-01-07 13:34:24.273 | WSACleanup called.
2025-01-07 13:34:24.273 | Chat | Connecting to the server chat2.sierracharts.com. Port 10065
2025-01-07 13:34:24.403 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2025-01-07 13:34:24.403 | DTC Client socket (4) | New receive buffer size: 0
2025-01-07 13:34:24.403 | DTC Client socket (4) | Connecting to IP: 64.152.155.20.
2025-01-07 13:34:27.643 | DTC Client socket (4) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it.
2025-01-07 13:34:27.643 | DTC Client socket (4) | CloseSocket call.
2025-01-07 13:34:27.643 | Chat | Failed connections: 1
2025-01-07 13:34:27.643 | DTC Client socket (4) | Closed.
2025-01-07 13:34:27.643 | DTC Client socket (0) | CloseSocket call.
2025-01-07 13:34:27.643 | Chat | Disconnected from the server.
2025-01-07 13:34:27.643 | Chat | Data feed disconnected. Will reconnect in 5 seconds.
2025-01-07 13:34:32.630 | WSACleanup called.
2025-01-07 13:34:32.630 | Chat | Connecting to the server chat2.sierracharts.com. Port 10065
2025-01-07 13:34:32.635 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2025-01-07 13:34:32.635 | DTC Client socket (4) | New receive buffer size: 0
2025-01-07 13:34:32.635 | DTC Client socket (4) | Connecting to IP: 64.152.155.20.
2025-01-07 13:34:32.878 | Chat | Network connection to server complete.
2025-01-07 13:34:32.878 | Chat | Starting socket receive thread.
2025-01-07 13:34:32.878 | Chat | Sending encoding request to server: Binary VLS. Compression: none
2025-01-07 13:34:33.608 | Chat | Setting DTC encoding to Binary VLS
2025-01-07 13:34:33.608 | Chat | Sending logon request message.
2025-01-07 13:34:39.547 | Chat | Received logon response.
2025-01-07 13:34:39.547 | Chat | Server Name: SC DTC Server. Build=52153.
2025-01-07 13:34:39.547 | Chat | Server protocol version: 8. Client protocol version: 8
2025-01-07 13:34:39.547 | Chat | Successfully connected. Connected to SC DTC Protocol server. Service=chat_server.data|SymbolSettings=chat_server.data.
2025-01-07 13:34:39.547 | Chat | Trading is not supported.
2025-01-07 13:34:39.547 | Chat | MarketDepthIsSupported: 1
2025-01-07 13:45:49.132 | Chat | Message response. Chat ID: 429. Request ID: 1134629375
2025-01-07 14:15:59.660 | Chat | Message response. Chat ID: 429. Request ID: 1134629376
2025-01-07 14:20:08.876 | ESH5.CME[M] #9 | StartDateTimeForLoadingOrderFills: 2024-01-01 00:00:00
2025-01-07 15:03:49.176 | HTTPS connection ID:15 to downloads.rithmic.com:443 for request ID:15 (5) | Creating socket. Using TLS 1.2.
2025-01-07 15:03:49.177 | HTTPS connection ID:15 to downloads.rithmic.com:443 for request ID:15 (5) | New receive buffer size: 0
2025-01-07 15:03:49.177 | HTTPS connection ID:15 to downloads.rithmic.com:443 for request ID:15 (5) | Connecting to IP: 216.66.0.130.
2025-01-07 15:03:50.765 | Rithmic Direct - DTC | Wrote file: C:\SierraChart - TopStep\RithmicConnections.json. Size: 81131
2025-01-07 15:03:50.765 | Rithmic Direct - DTC | Processed connection points. Count: 347
2025-01-07 15:03:51.919 | HTTPS connection ID:15 to downloads.rithmic.com:443 for request ID:15 (5) | CloseSocket call.
2025-01-07 15:03:51.919 | HTTPS connection ID:15 to downloads.rithmic.com:443 for request ID:15 (5) | Shutdown started. Waiting for graceful close.
2025-01-07 15:03:52.152 | HTTPS connection ID:15 to downloads.rithmic.com:443 for request ID:15 (5) | Socket gracefully closed by remote side.
2025-01-07 15:03:52.153 | HTTPS connection ID:15 to downloads.rithmic.com:443 for request ID:15 (5) | Closed.
2025-01-07 15:15:51.610 | Performing login for updated account information.
2025-01-07 15:15:53.583 | Rithmic Direct - DTC | Waiting for socket receive thread to end
2025-01-07 15:15:53.583 | DTC Client socket (1) | CloseSocket call.
2025-01-07 15:15:53.583 | DTC Client socket (1) | Max send buffers used during socket life: 4
2025-01-07 15:15:53.583 | DTC Client socket (1) | Max send buffer size during socket life: 1546
2025-01-07 15:15:53.583 | DTC Client socket (1) | Shutdown started. Waiting for graceful close.
2025-01-07 15:15:53.584 | Denali Data Feed | Waiting for socket receive thread to end
2025-01-07 15:15:53.585 | DTC Client socket (2) | CloseSocket call.
2025-01-07 15:15:53.585 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-07 15:15:53.585 | Denali Data Feed | Disconnected from the server.
2025-01-07 15:15:53.585 | SC Data with Depth | Waiting for socket receive thread to end
2025-01-07 15:15:53.585 | DTC Client socket (3) | CloseSocket call.
2025-01-07 15:15:53.585 | DTC Client socket (3) | Shutdown started. Waiting for graceful close.
2025-01-07 15:15:53.585 | SC Data with Depth | Disconnected from the server.
2025-01-07 15:15:53.585 | Rithmic Direct - DTC | Disconnected.
2025-01-07 15:15:53.585 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2025-01-07 15:15:53.585 | Successfully processed Sierra Chart account data.
2025-01-07 15:15:53.585 | Requested user files to download.
2025-01-07 15:15:53.883 | DTC Client socket (1) | Socket gracefully closed by remote side.
2025-01-07 15:15:53.883 | DTC Client socket (1) | Closed.
2025-01-07 15:15:54.076 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-07 15:15:54.076 | DTC Client socket (2) | Closed.
2025-01-07 15:15:54.124 | DTC Client socket (3) | Socket gracefully closed by remote side.
2025-01-07 15:15:54.124 | DTC Client socket (3) | Closed.
2025-01-07 15:15:57.601 |
2025-01-07 15:15:57.601 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated
2025-01-07 15:15:57.601 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50508
2025-01-07 15:15:57.601 | Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50508
2025-01-07 15:15:57.953 | DTC Client socket (1) | Creating socket. Using TLS 1.2.
2025-01-07 15:15:57.953 | DTC Client socket (1) | New receive buffer size: 0
2025-01-07 15:15:57.953 | DTC Client socket (1) | Connecting to IP: 216.57.156.163.
2025-01-07 15:15:58.343 | Rithmic Direct - DTC | Network connection to server complete.
2025-01-07 15:15:58.343 | Rithmic Direct - DTC | Starting socket receive thread.
2025-01-07 15:15:58.343 | Rithmic Direct - DTC | Setting DTC encoding to Binary
2025-01-07 15:15:58.343 | Rithmic Direct - DTC | Sending logon request message.
2025-01-07 15:15:59.506 | Rithmic Direct - DTC | Received logon response.
2025-01-07 15:15:59.506 | Rithmic Direct - DTC | Server Name: .
2025-01-07 15:15:59.506 | Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8
2025-01-07 15:15:59.506 | Rithmic Direct - DTC | Successfully connected.
2025-01-07 15:15:59.506 | Rithmic Direct - DTC | Trading is supported.
2025-01-07 15:15:59.506 | Rithmic Direct - DTC | Order cancel and replace is supported.
2025-01-07 15:15:59.506 | Rithmic Direct - DTC | OCO Orders supported.
2025-01-07 15:15:59.506 | Rithmic Direct - DTC | Symbol and Exchange Delimiter: .
2025-01-07 15:15:59.506 | Rithmic Direct - DTC | MarketDepthIsSupported: 0
2025-01-07 15:15:59.506 | Rithmic Direct - DTC | Connected to server complete.
2025-01-07 15:15:59.509 | No download requests in the queue to start downloads for. | Number times message added: 3
2025-01-07 15:15:59.509 | Subscribing to symbol for symbol alert. NQZ4.CME
2025-01-07 15:15:59.509 | Mapping NQZ4.CME to NQZ24. Service code: cme
2025-01-07 15:15:59.509 | Using symbol data fast lookup vector
2025-01-07 15:15:59.509 | Denali Data Feed | Starting real-time market data updates for: NQZ4.CME (NQZ24). ID: 1 Service code: cme
2025-01-07 15:15:59.509 | Denali Data Feed | Connecting to the server ds26-2.sierracharts.com. Port 443
2025-01-07 15:15:59.509 | Denali Data Feed | Requesting security definition data for: NQZ4.CME (NQZ24). ID: 1
2025-01-07 15:15:59.509 | Subscribing to symbol for symbol alert. GCZ4.COMEX
2025-01-07 15:15:59.509 | Mapping GCZ4.COMEX to GCZ24. Service code: comex
2025-01-07 15:15:59.509 | Denali Data Feed | Starting real-time market data updates for: GCZ4.COMEX (GCZ24). ID: 2 Service code: comex
2025-01-07 15:15:59.509 | Denali Data Feed | Requesting security definition data for: GCZ4.COMEX (GCZ24). ID: 2
2025-01-07 15:15:59.625 | DTC Client socket (2) | Creating socket.
2025-01-07 15:15:59.625 | DTC Client socket (2) | New receive buffer size: 0
2025-01-07 15:15:59.625 | DTC Client socket (2) | Connecting to IP: 64.152.155.18.
2025-01-07 15:15:59.737 | Mapping ESH5.CME to ESH25. Service code: cme
2025-01-07 15:15:59.737 | Denali Data Feed | Starting real-time market data updates for: ESH5.CME (ESH25). ID: 3 Service code: cme
2025-01-07 15:15:59.737 | Denali Data Feed | Requesting security definition data for: ESH5.CME (ESH25). ID: 3
2025-01-07 15:15:59.737 | Added historical Intraday data request for ESH5.CME to the queue.
2025-01-07 15:15:59.737 | Intraday data recording state for symbol ESH5.CME is set to download 'Pending'.
2025-01-07 15:15:59.737 | Triggering next historical data download in queue.
2025-01-07 15:15:59.754 | Delaying start of download for ESH5.CME.
2025-01-07 15:15:59.912 | Denali Data Feed | Network connection to server complete.
2025-01-07 15:15:59.912 | Denali Data Feed | Starting socket receive thread.
2025-01-07 15:15:59.912 | Denali Data Feed | Sending encoding request to server: Binary VLS. Compression: high
2025-01-07 15:15:59.912 | Mapping MNQH5.CME to MNQH25. Service code: cme
2025-01-07 15:15:59.912 | Denali Data Feed | Starting real-time market data updates for: MNQH5.CME (MNQH25). ID: 4 Service code: cme
2025-01-07 15:15:59.912 | Denali Data Feed | Requesting security definition data for: MNQH5.CME (MNQH25). ID: 4
2025-01-07 15:15:59.912 | Added historical Intraday data request for MNQH5.CME to the queue.
2025-01-07 15:15:59.912 | Intraday data recording state for symbol MNQH5.CME is set to download 'Pending'.
2025-01-07 15:15:59.912 | Triggering next historical data download in queue.
2025-01-07 15:15:59.914 | Mapping MGCG5.COMEX to MGCG25. Service code: comex
2025-01-07 15:15:59.914 | Denali Data Feed | Starting real-time market data updates for: MGCG5.COMEX (MGCG25). ID: 5 Service code: comex
2025-01-07 15:15:59.914 | Denali Data Feed | Requesting security definition data for: MGCG5.COMEX (MGCG25). ID: 5
2025-01-07 15:15:59.914 | Added historical Intraday data request for MGCG5.COMEX to the queue.
2025-01-07 15:15:59.914 | Intraday data recording state for symbol MGCG5.COMEX is set to download 'Pending'.
2025-01-07 15:15:59.914 | Triggering next historical data download in queue.
2025-01-07 15:15:59.915 | Mapping ESU4.CME to ESU24. Service code: cme
2025-01-07 15:15:59.915 | Denali Data Feed | Starting real-time market data updates for: ESU4.CME (ESU24). ID: 6 Service code: cme
2025-01-07 15:15:59.915 | Denali Data Feed | Requesting security definition data for: ESU4.CME (ESU24). ID: 6
2025-01-07 15:15:59.915 | Added historical Intraday data request for ESU4.CME to the queue.
2025-01-07 15:15:59.915 | Intraday data recording state for symbol ESU4.CME is set to download 'Pending'.
2025-01-07 15:15:59.915 | Triggering next historical data download in queue.
2025-01-07 15:15:59.915 | Mapping SIH5.COMEX to SIH25. Service code: comex
2025-01-07 15:15:59.915 | Denali Data Feed | Starting real-time market data updates for: SIH5.COMEX (SIH25). ID: 7 Service code: comex
2025-01-07 15:15:59.915 | Denali Data Feed | Requesting security definition data for: SIH5.COMEX (SIH25). ID: 7
2025-01-07 15:15:59.915 | Added historical Intraday data request for SIH5.COMEX to the queue.
2025-01-07 15:15:59.915 | Intraday data recording state for symbol SIH5.COMEX is set to download 'Pending'.
2025-01-07 15:15:59.971 | Mapping NQH5.CME to NQH25. Service code: cme
2025-01-07 15:15:59.971 | Denali Data Feed | Starting real-time market data updates for: NQH5.CME (NQH25). ID: 8 Service code: cme
2025-01-07 15:15:59.971 | Denali Data Feed | Requesting security definition data for: NQH5.CME (NQH25). ID: 8
2025-01-07 15:15:59.971 | Added historical Intraday data request for NQH5.CME to the queue.
2025-01-07 15:15:59.971 | Intraday data recording state for symbol NQH5.CME is set to download 'Pending'.
2025-01-07 15:15:59.971 | Triggering next historical data download in queue.
2025-01-07 15:15:59.994 | Mapping 6AH5.CME to 6AH25. Service code: cme
2025-01-07 15:15:59.994 | Denali Data Feed | Starting real-time market data updates for: 6AH5.CME (6AH25). ID: 9 Service code: cme
2025-01-07 15:15:59.994 | Denali Data Feed | Requesting security definition data for: 6AH5.CME (6AH25). ID: 9
2025-01-07 15:15:59.994 | Added historical Intraday data request for 6AH5.CME to the queue.
2025-01-07 15:15:59.994 | Intraday data recording state for symbol 6AH5.CME is set to download 'Pending'.
2025-01-07 15:15:59.994 | Triggering next historical data download in queue.
2025-01-07 15:16:00.187 | Denali Data Feed | Setting DTC encoding to Binary VLS
2025-01-07 15:16:00.187 | Denali Data Feed | Sending logon request message.
2025-01-07 15:16:00.188 | Mapping GCG5.COMEX to GCG25. Service code: comex
2025-01-07 15:16:00.188 | Denali Data Feed | Starting real-time market data updates for: GCG5.COMEX (GCG25). ID: 10 Service code: comex
2025-01-07 15:16:00.188 | Denali Data Feed | Requesting security definition data for: GCG5.COMEX (GCG25). ID: 10
2025-01-07 15:16:00.188 | Added historical Intraday data request for GCG5.COMEX to the queue.
2025-01-07 15:16:00.188 | Intraday data recording state for symbol GCG5.COMEX is set to download 'Pending'.
2025-01-07 15:16:00.188 | Triggering next historical data download in queue.
2025-01-07 15:16:00.268 | Mapping MESH5.CME to MESH25. Service code: cme
2025-01-07 15:16:00.268 | Denali Data Feed | Starting real-time market data updates for: MESH5.CME (MESH25). ID: 11 Service code: cme
2025-01-07 15:16:00.268 | Denali Data Feed | Requesting security definition data for: MESH5.CME (MESH25). ID: 11
2025-01-07 15:16:00.268 | Added historical Intraday data request for MESH5.CME to the queue.
2025-01-07 15:16:00.268 | Intraday data recording state for symbol MESH5.CME is set to download 'Pending'.
2025-01-07 15:16:00.268 | Triggering next historical data download in queue.
2025-01-07 15:16:00.450 | SC Data with Depth | Starting real-time market data updates for: USDX. ID: 12 Service code: fxstatscalc
2025-01-07 15:16:00.450 | SC Data with Depth | Connecting to the server ds12.sierracharts.com. Port 443
2025-01-07 15:16:00.450 | SC Data with Depth | Requesting security definition data for: USDX. ID: 12
2025-01-07 15:16:00.515 | Mapping M6AH5.CME to M6AH25. Service code: cme
2025-01-07 15:16:00.515 | Denali Data Feed | Starting real-time market data updates for: M6AH5.CME (M6AH25). ID: 13 Service code: cme
2025-01-07 15:16:00.515 | Denali Data Feed | Requesting security definition data for: M6AH5.CME (M6AH25). ID: 13
2025-01-07 15:16:00.515 | Added historical Intraday data request for M6AH5.CME to the queue.
2025-01-07 15:16:00.515 | Intraday data recording state for symbol M6AH5.CME is set to download 'Pending'.
2025-01-07 15:16:00.515 | Triggering next historical data download in queue.
2025-01-07 15:16:00.543 | Mapping SILH5.COMEX to SILH25. Service code: comex
2025-01-07 15:16:00.543 | Denali Data Feed | Starting real-time market data updates for: SILH5.COMEX (SILH25). ID: 14 Service code: comex
2025-01-07 15:16:00.543 | Denali Data Feed | Requesting security definition data for: SILH5.COMEX (SILH25). ID: 14
2025-01-07 15:16:00.543 | Added historical Intraday data request for SILH5.COMEX to the queue.
2025-01-07 15:16:00.543 | Intraday data recording state for symbol SILH5.COMEX is set to download 'Pending'.
2025-01-07 15:16:00.543 | Triggering next historical data download in queue.
2025-01-07 15:16:00.546 | Added historical Intraday data request for USDX to the queue.
2025-01-07 15:16:00.546 | Intraday data recording state for symbol USDX is set to download 'Pending'.
2025-01-07 15:16:00.546 | Triggering next historical data download in queue.
2025-01-07 15:16:00.588 | DTC Client socket (3) | Creating socket.
2025-01-07 15:16:00.588 | DTC Client socket (3) | New receive buffer size: 0
2025-01-07 15:16:00.588 | DTC Client socket (3) | Connecting to IP: 69.39.70.241.
2025-01-07 15:16:00.938 | SC Data with Depth | Network connection to server complete.
2025-01-07 15:16:00.938 | SC Data with Depth | Starting socket receive thread.
2025-01-07 15:16:00.938 | SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: high
2025-01-07 15:16:00.938 | Using Bid/Ask average for last trade price for SPX500
2025-01-07 15:16:00.938 | SC Data with Depth | Starting real-time market data updates for: SPX500. ID: 15 Service code: fxcm
2025-01-07 15:16:00.938 | SC Data with Depth | Requesting security definition data for: SPX500. ID: 15
2025-01-07 15:16:00.938 | Added historical Intraday data request for SPX500 to the queue.
2025-01-07 15:16:00.938 | Intraday data recording state for symbol SPX500 is set to download 'Pending'.
2025-01-07 15:16:00.938 | Triggering next historical data download in queue.
2025-01-07 15:16:00.938 | Denali Data Feed | Received logon response.
2025-01-07 15:16:00.938 | Denali Data Feed | Server Name: SC Realtime Server.
2025-01-07 15:16:00.938 | Denali Data Feed | Server protocol version: 8. Client protocol version: 8
2025-01-07 15:16:00.939 | Denali Data Feed | Successfully connected.
2025-01-07 15:16:00.939 | Denali Data Feed | Trading is not supported.
2025-01-07 15:16:00.939 | Denali Data Feed | MarketDepthIsSupported: 1
2025-01-07 15:16:00.939 | Denali Data Feed | Restarting real-time data updates for symbol: 6AH5.CME -> 6AH25
2025-01-07 15:16:00.939 | Denali Data Feed | Restarting real-time data updates for symbol: ESH5.CME -> ESH25
2025-01-07 15:16:00.939 | Denali Data Feed | Restarting real-time data updates for symbol: ESU4.CME -> ESU24
2025-01-07 15:16:00.939 | Denali Data Feed | Restarting real-time data updates for symbol: GCG5.COMEX -> GCG25
2025-01-07 15:16:00.939 | Denali Data Feed | Restarting real-time data updates for symbol: GCZ4.COMEX -> GCZ24
2025-01-07 15:16:00.939 | Denali Data Feed | Restarting real-time data updates for symbol: M6AH5.CME -> M6AH25
2025-01-07 15:16:00.939 | Denali Data Feed | Restarting real-time data updates for symbol: MESH5.CME -> MESH25
2025-01-07 15:16:00.939 | Denali Data Feed | Restarting real-time data updates for symbol: MGCG5.COMEX -> MGCG25
2025-01-07 15:16:00.939 | Denali Data Feed | Restarting real-time data updates for symbol: MNQH5.CME -> MNQH25
2025-01-07 15:16:00.939 | Denali Data Feed | Restarting real-time data updates for symbol: NQH5.CME -> NQH25
2025-01-07 15:16:00.939 | Denali Data Feed | Restarting real-time data updates for symbol: NQZ4.CME -> NQZ24
2025-01-07 15:16:00.939 | Denali Data Feed | Restarting real-time data updates for symbol: SIH5.COMEX -> SIH25
2025-01-07 15:16:00.939 | Denali Data Feed | Restarting real-time data updates for symbol: SILH5.COMEX -> SILH25
2025-01-07 15:16:01.266 | SC Data with Depth | Setting DTC encoding to Binary VLS
2025-01-07 15:16:01.266 | SC Data with Depth | Sending logon request message.
2025-01-07 15:16:01.681 | Denali Data Feed | Setting external service identifier for symbol 6AH5.CME to 52126
2025-01-07 15:16:01.681 | Denali Data Feed | Received security definition for symbol 6AH5.CME
2025-01-07 15:16:01.681 | Denali Data Feed | Setting external service identifier for symbol ESH5.CME to 5002
2025-01-07 15:16:01.681 | Denali Data Feed | Received security definition for symbol ESH5.CME
2025-01-07 15:16:01.681 | Denali Data Feed | Real-time data for symbol ESU4.CME is currently unavailable.
2025-01-07 15:16:01.681 | Denali Data Feed | Received security definition for symbol ESU4.CME
2025-01-07 15:16:01.681 | Denali Data Feed | Setting external service identifier for symbol GCG5.COMEX to 1551
2025-01-07 15:16:01.681 | Denali Data Feed | Received security definition for symbol GCG5.COMEX
2025-01-07 15:16:01.681 | Denali Data Feed | Real-time data for symbol GCZ4.COMEX is currently unavailable.
2025-01-07 15:16:01.681 | Denali Data Feed | Received security definition for symbol GCZ4.COMEX
2025-01-07 15:16:01.681 | Denali Data Feed | Setting external service identifier for symbol M6AH5.CME to 42185124
2025-01-07 15:16:01.681 | Denali Data Feed | Received security definition for symbol M6AH5.CME
2025-01-07 15:16:01.681 | Denali Data Feed | Setting external service identifier for symbol MESH5.CME to 42005347
2025-01-07 15:16:01.681 | Denali Data Feed | Received security definition for symbol MESH5.CME
2025-01-07 15:16:01.681 | Denali Data Feed | Setting external service identifier for symbol MGCG5.COMEX to 69
2025-01-07 15:16:01.681 | Denali Data Feed | Received security definition for symbol MGCG5.COMEX
2025-01-07 15:16:01.681 | Denali Data Feed | Setting external service identifier for symbol MNQH5.CME to 42003617
2025-01-07 15:16:01.681 | Denali Data Feed | Received security definition for symbol MNQH5.CME
2025-01-07 15:16:01.681 | Denali Data Feed | Setting external service identifier for symbol NQH5.CME to 42288528
2025-01-07 15:16:01.681 | Denali Data Feed | Received security definition for symbol NQH5.CME
2025-01-07 15:16:01.681 | Denali Data Feed | Real-time data for symbol NQZ4.CME is currently unavailable.
2025-01-07 15:16:01.681 | Denali Data Feed | Received security definition for symbol NQZ4.CME
2025-01-07 15:16:01.681 | Denali Data Feed | Setting external service identifier for symbol SIH5.COMEX to 5556
2025-01-07 15:16:01.681 | Denali Data Feed | Received security definition for symbol SIH5.COMEX
2025-01-07 15:16:01.681 | Denali Data Feed | Setting external service identifier for symbol SILH5.COMEX to 42007667
2025-01-07 15:16:01.681 | Denali Data Feed | Received security definition for symbol SILH5.COMEX
2025-01-07 15:16:02.166 | SC Data with Depth | Received logon response.
2025-01-07 15:16:02.166 | SC Data with Depth | Server Name: SC Realtime Server.
2025-01-07 15:16:02.166 | SC Data with Depth | Server protocol version: 8. Client protocol version: 8
2025-01-07 15:16:02.166 | SC Data with Depth | Successfully connected.
2025-01-07 15:16:02.166 | SC Data with Depth | Trading is not supported.
2025-01-07 15:16:02.166 | SC Data with Depth | MarketDepthIsSupported: 1
2025-01-07 15:16:02.166 | SC Data with Depth | Restarting real-time data updates for symbol: SPX500
2025-01-07 15:16:02.166 | SC Data with Depth | Restarting real-time data updates for symbol: USDX
2025-01-07 15:16:02.898 | SC Data with Depth | Setting external service identifier for symbol SPX500 to 55
2025-01-07 15:16:02.898 | SC Data with Depth | Received security definition for symbol SPX500
2025-01-07 15:16:02.898 | SC Data with Depth | Setting external service identifier for symbol USDX to 1
2025-01-07 15:16:02.898 | SC Data with Depth | Received security definition for symbol USDX
2025-01-07 15:16:05.229 | Requesting market depth updates for: 6AH5.CME if supported. NumLevels=50
2025-01-07 15:16:05.229 | Requesting market depth updates for: ESH5.CME if supported. NumLevels=50
2025-01-07 15:16:05.229 | Requesting market depth updates for: ESU4.CME if supported. NumLevels=50
2025-01-07 15:16:05.229 | Requesting market depth updates for: GCG5.COMEX if supported. NumLevels=50
2025-01-07 15:16:05.229 | Requesting market depth updates for: MESH5.CME if supported. NumLevels=50
2025-01-07 15:16:05.229 | Requesting market depth updates for: MGCG5.COMEX if supported. NumLevels=50
2025-01-07 15:16:05.229 | Requesting market depth updates for: MNQH5.CME if supported. NumLevels=50
2025-01-07 15:16:05.229 | Requesting market depth updates for: NQH5.CME if supported. NumLevels=50
2025-01-07 15:16:05.229 | Requesting market depth updates for: SIH5.COMEX if supported. NumLevels=50
2025-01-07 15:16:05.620 | Denali Data Feed | Clearing market depth for 6AH5.CME
2025-01-07 15:16:05.620 | Denali Data Feed | Clearing market depth for ESH5.CME
2025-01-07 15:16:05.620 | Denali Data Feed | Clearing market depth for ESU4.CME
2025-01-07 15:16:05.620 | Denali Data Feed | Clearing market depth for GCG5.COMEX
2025-01-07 15:16:05.620 | Denali Data Feed | Clearing market depth for MESH5.CME
2025-01-07 15:16:05.620 | Denali Data Feed | Clearing market depth for MGCG5.COMEX
2025-01-07 15:16:05.620 | Denali Data Feed | Clearing market depth for MNQH5.CME
2025-01-07 15:16:05.621 | Denali Data Feed | Clearing market depth for NQH5.CME
2025-01-07 15:16:05.621 | Denali Data Feed | Clearing market depth for SIH5.COMEX
2025-01-07 15:16:06.837 | HD Request # 81 | Downloading Intraday chart data for ESH5.CME to the file ESH5.CME.scid. Service: cme
2025-01-07 15:16:06.837 | HD Request # 81 | Download start date-time: 2025-01-07 15:15:52.000000. File last date-time: 2025-01-07 15:15:52.841000
2025-01-07 15:16:06.837 | HD Request # 81 | Using server: ds32.sierracharts.com port 10150
2025-01-07 15:16:06.960 | Socket (5) | Creating socket.
2025-01-07 15:16:06.960 | Socket (5) | New receive buffer size: 0
2025-01-07 15:16:06.960 | Socket (5) | Connecting to IP: 67.214.125.3.
2025-01-07 15:16:07.451 | HD Request # 81 | Setting DTC encoding to Binary VLS
2025-01-07 15:16:07.451 | HD Request # 81 | Sending historical data logon request message.
2025-01-07 15:16:07.738 | HD Request # 81 | Requesting Intraday data. Start date-time: 2025-01-07 15:15:52. Record interval: 0. Symbol: ESH25
2025-01-07 15:16:07.979 | HD Request # 81 | Decompressing data.
2025-01-07 15:16:08.221 | HD Request # 81 | Receiving Intraday data for ESH5.CME starting at 2025-01-07 15:15:52.015000
2025-01-07 15:16:08.221 | Socket (5) | CloseSocket call.
2025-01-07 15:16:08.221 | Socket (5) | Shutdown started. Waiting for graceful close.
2025-01-07 15:16:08.408 | Historical data download thread signaled to stop.
2025-01-07 15:16:08.408 | HD Request # 81 | Timestamp of first Intraday data file record written: 2025-01-07 15:15:53.819000.
2025-01-07 15:16:08.408 | HD Request # 81 | Received 551 Intraday data records from 2025-01-07 15:15:52.015000 to 2025-01-07 15:16:06.934004 (14.9 seconds. Delay: 1.5 seconds) and wrote 529 records for ESH5.CME
2025-01-07 15:16:08.409 | HD Request # 81 | Add time&sales data | Remembered last file record date-time: 2025-01-07 20:16:06.934004
2025-01-07 15:16:08.409 | Added 54 Time and Sales records to Intraday data file for ESH5.CME after download.
2025-01-07 15:16:08.409 | HD Request # 81 | Completion time: 2s.
2025-01-07 15:16:08.409 | HD Request # 81 | Intraday data download complete for ESH5.CME. Unique request ID: 81
2025-01-07 15:16:08.409 | Removing historical data download ID 81.
2025-01-07 15:16:08.409 | Real-time Intraday chart data file updates started for ESH5.CME
2025-01-07 15:16:08.409 | Intraday chart data file opened for ESH5.CME
2025-01-07 15:16:08.409 | HD Request # 81 | Enabling Intraday chart updating for symbol.
2025-01-07 15:16:08.409 | Triggering next historical data download in queue.
2025-01-07 15:16:08.409 | HD Request # 82 | Downloading Intraday chart data for MNQH5.CME to the file MNQH5.CME.scid. Service: cme
2025-01-07 15:16:08.409 | HD Request # 82 | Download start date-time: 2025-01-07 15:15:52.000000. File last date-time: 2025-01-07 15:15:52.966000
2025-01-07 15:16:08.409 | HD Request # 82 | Using server: ds32.sierracharts.com port 10149
2025-01-07 15:16:08.409 | Socket (6) | Creating socket.
2025-01-07 15:16:08.409 | Socket (6) | New receive buffer size: 0
2025-01-07 15:16:08.409 | Socket (6) | Connecting to IP: 67.214.125.3.
2025-01-07 15:16:08.463 | Socket (5) | Socket gracefully closed by remote side.
2025-01-07 15:16:08.463 | Socket (5) | Closed.
2025-01-07 15:16:08.903 | HD Request # 82 | Setting DTC encoding to Binary VLS
2025-01-07 15:16:08.903 | HD Request # 82 | Sending historical data logon request message.
2025-01-07 15:16:09.187 | HD Request # 82 | Requesting Intraday data. Start date-time: 2025-01-07 15:15:52. Record interval: 0. Symbol: MNQH25
2025-01-07 15:16:09.430 | HD Request # 82 | Decompressing data.
2025-01-07 15:16:09.674 | HD Request # 82 | Receiving Intraday data for MNQH5.CME starting at 2025-01-07 15:15:52.044000
2025-01-07 15:16:09.675 | Socket (6) | CloseSocket call.
2025-01-07 15:16:09.675 | Socket (6) | Shutdown started. Waiting for graceful close.
2025-01-07 15:16:09.678 | Historical data download thread signaled to stop.
2025-01-07 15:16:09.678 | HD Request # 82 | Timestamp of first Intraday data file record written: 2025-01-07 15:15:53.337000.
2025-01-07 15:16:09.678 | HD Request # 82 | Received 394 Intraday data records from 2025-01-07 15:15:52.044000 to 2025-01-07 15:16:06.934000 (14.9 seconds. Delay: 2.7 seconds) and wrote 380 records for MNQH5.CME
2025-01-07 15:16:09.678 | HD Request # 82 | Add time&sales data | Remembered last file record date-time: 2025-01-07 20:16:06.934000
2025-01-07 15:16:09.678 | Added 51 Time and Sales records to Intraday data file for MNQH5.CME after download.
2025-01-07 15:16:09.678 | HD Request # 82 | Completion time: 1s.
2025-01-07 15:16:09.678 | HD Request # 82 | Intraday data download complete for MNQH5.CME. Unique request ID: 82
2025-01-07 15:16:09.678 | Removing historical data download ID 82.
2025-01-07 15:16:09.678 | Real-time Intraday chart data file updates started for MNQH5.CME
2025-01-07 15:16:09.678 | Intraday chart data file opened for MNQH5.CME
2025-01-07 15:16:09.678 | HD Request # 82 | Enabling Intraday chart updating for symbol.
2025-01-07 15:16:09.678 | Triggering next historical data download in queue.
2025-01-07 15:16:09.678 | HD Request # 83 | Downloading Intraday chart data for MGCG5.COMEX to the file MGCG5.COMEX.scid. Service: comex
2025-01-07 15:16:09.678 | HD Request # 83 | Download start date-time: 2025-01-07 15:15:19.000000. File last date-time: 2025-01-07 15:15:19.764000
2025-01-07 15:16:09.679 | HD Request # 83 | Using server: ds32.sierracharts.com port 10150
2025-01-07 15:16:09.679 | Socket (5) | Creating socket.
2025-01-07 15:16:09.679 | Socket (5) | New receive buffer size: 0
2025-01-07 15:16:09.679 | Socket (5) | Connecting to IP: 67.214.125.3.
2025-01-07 15:16:09.922 | Socket (6) | Socket gracefully closed by remote side.
2025-01-07 15:16:09.922 | Socket (6) | Closed.
2025-01-07 15:16:10.169 | HD Request # 83 | Setting DTC encoding to Binary VLS
2025-01-07 15:16:10.169 | HD Request # 83 | Sending historical data logon request message.
2025-01-07 15:16:10.407 | HD Request # 83 | Requesting Intraday data. Start date-time: 2025-01-07 15:15:19. Record interval: 0. Symbol: MGCG25
2025-01-07 15:16:10.646 | HD Request # 83 | Decompressing data.
2025-01-07 15:16:10.885 | HD Request # 83 | Receiving Intraday data for MGCG5.COMEX starting at 2025-01-07 15:15:19.764000
2025-01-07 15:16:10.885 | Socket (5) | CloseSocket call.
2025-01-07 15:16:10.885 | Socket (5) | Shutdown started. Waiting for graceful close.
2025-01-07 15:16:10.951 | Historical data download thread signaled to stop.
2025-01-07 15:16:10.951 | HD Request # 83 | Timestamp of first Intraday data file record written: 2025-01-07 15:16:00.275000.
2025-01-07 15:16:10.951 | HD Request # 83 | Received 3 Intraday data records from 2025-01-07 15:15:19.764000 to 2025-01-07 15:16:07.565000 (47.8 seconds. Delay: 3.4 seconds) and wrote 2 records for MGCG5.COMEX
2025-01-07 15:16:10.951 | HD Request # 83 | Add time&sales data | Remembered last file record date-time: 2025-01-07 20:16:07.565000
2025-01-07 15:16:10.951 | HD Request # 83 | Completion time: 1s.
2025-01-07 15:16:10.951 | HD Request # 83 | Intraday data download complete for MGCG5.COMEX. Unique request ID: 83
2025-01-07 15:16:10.951 | Removing historical data download ID 83.
2025-01-07 15:16:10.951 | Real-time Intraday chart data file updates started for MGCG5.COMEX
2025-01-07 15:16:10.951 | Intraday chart data file opened for MGCG5.COMEX
2025-01-07 15:16:10.951 | HD Request # 83 | Enabling Intraday chart updating for symbol.
2025-01-07 15:16:10.951 | Triggering next historical data download in queue.
2025-01-07 15:16:10.951 | HD Request # 84 | Downloading Intraday chart data for ESU4.CME to the file ESU4.CME.scid. Service: cme
2025-01-07 15:16:10.952 | HD Request # 84 | Download start date-time: 2024-09-20 09:29:59.000000. File last date-time: 2024-09-20 09:29:59.856000
2025-01-07 15:16:10.952 | HD Request # 84 | Using server: ds32.sierracharts.com port 10149
2025-01-07 15:16:10.952 | Socket (6) | Creating socket.
2025-01-07 15:16:10.952 | Socket (6) | New receive buffer size: 0
2025-01-07 15:16:10.952 | Socket (6) | Connecting to IP: 67.214.125.3.
2025-01-07 15:16:11.125 | Socket (5) | Socket gracefully closed by remote side.
2025-01-07 15:16:11.125 | Socket (5) | Closed.
2025-01-07 15:16:11.430 | HD Request # 84 | Setting DTC encoding to Binary VLS
2025-01-07 15:16:11.430 | HD Request # 84 | Sending historical data logon request message.
2025-01-07 15:16:11.667 | HD Request # 84 | Requesting Intraday data. Start date-time: 2024-09-20 09:29:59. Record interval: 0. Symbol: ESU24
2025-01-07 15:16:11.903 | HD Request # 84 | Decompressing data.
2025-01-07 15:16:12.138 | HD Request # 84 | Receiving Intraday data for ESU4.CME starting at 2024-09-20 09:29:59.011000
2025-01-07 15:16:12.138 | Socket (6) | CloseSocket call.
2025-01-07 15:16:12.139 | Socket (6) | Shutdown started. Waiting for graceful close.
2025-01-07 15:16:12.160 | Historical data download thread signaled to stop.
2025-01-07 15:16:12.160 | HD Request # 84 | Received 12 Intraday data records from 2024-09-20 09:29:59.011000 to 2024-09-20 09:29:59.856000 (0.8 seconds. Delay: 109.3 days) and wrote 0 records for ESU4.CME
2025-01-07 15:16:12.161 | HD Request # 84 | Add time&sales data | Remembered last file record date-time: 2024-09-20 13:29:59.856000
2025-01-07 15:16:12.161 | HD Request # 84 | Completion time: 2s.
2025-01-07 15:16:12.161 | HD Request # 84 | Intraday data download complete for ESU4.CME. Unique request ID: 84
2025-01-07 15:16:12.161 | Removing historical data download ID 84.
2025-01-07 15:16:12.161 | Real-time Intraday chart data file updates started for ESU4.CME
2025-01-07 15:16:12.161 | Intraday chart data file opened for ESU4.CME
2025-01-07 15:16:12.161 | HD Request # 84 | Enabling Intraday chart updating for symbol.
2025-01-07 15:16:12.161 | Triggering next historical data download in queue.
2025-01-07 15:16:12.161 | HD Request # 85 | Downloading Intraday chart data for SIH5.COMEX to the file SIH5.COMEX.scid. Service: comex
2025-01-07 15:16:12.161 | HD Request # 85 | Download start date-time: 2025-01-07 15:15:23.000000. File last date-time: 2025-01-07 15:15:23.029000
2025-01-07 15:16:12.161 | HD Request # 85 | Using server: ds32.sierracharts.com port 10150
2025-01-07 15:16:12.161 | Socket (5) | Creating socket.
2025-01-07 15:16:12.161 | Socket (5) | New receive buffer size: 0
2025-01-07 15:16:12.161 | Socket (5) | Connecting to IP: 67.214.125.3.
2025-01-07 15:16:12.374 | Socket (6) | Socket gracefully closed by remote side.
2025-01-07 15:16:12.374 | Socket (6) | Closed.
2025-01-07 15:16:12.512 | Opened cached Intraday file: C:\SierraChart - TopStep\Data\ESH5.CME.scid. Thread ID: 16528
2025-01-07 15:16:12.512 | Opened cached Intraday file: C:\SierraChart - TopStep\Data\MNQH5.CME.scid. Thread ID: 16528
2025-01-07 15:16:12.641 | HD Request # 85 | Setting DTC encoding to Binary VLS
2025-01-07 15:16:12.641 | HD Request # 85 | Sending historical data logon request message.
2025-01-07 15:16:12.876 | HD Request # 85 | Requesting Intraday data. Start date-time: 2025-01-07 15:15:23. Record interval: 0. Symbol: SIH25
2025-01-07 15:16:13.112 | HD Request # 85 | Decompressing data.
2025-01-07 15:16:13.346 | HD Request # 85 | Receiving Intraday data for SIH5.COMEX starting at 2025-01-07 15:15:23.029000
2025-01-07 15:16:13.346 | Socket (5) | CloseSocket call.
2025-01-07 15:16:13.346 | Socket (5) | Shutdown started. Waiting for graceful close.
2025-01-07 15:16:13.357 | Historical data download thread signaled to stop.
2025-01-07 15:16:13.357 | HD Request # 85 | Timestamp of first Intraday data file record written: 2025-01-07 15:15:54.030000.
2025-01-07 15:16:13.357 | HD Request # 85 | Received 6 Intraday data records from 2025-01-07 15:15:23.029000 to 2025-01-07 15:16:00.276002 (37.2 seconds. Delay: 13.1 seconds) and wrote 5 records for SIH5.COMEX
2025-01-07 15:16:13.357 | HD Request # 85 | Add time&sales data | Remembered last file record date-time: 2025-01-07 20:16:00.276002
2025-01-07 15:16:13.357 | HD Request # 85 | Completion time: 1s.
2025-01-07 15:16:13.357 | HD Request # 85 | Intraday data download complete for SIH5.COMEX. Unique request ID: 85
2025-01-07 15:16:13.357 | Removing historical data download ID 85.
2025-01-07 15:16:13.358 | Real-time Intraday chart data file updates started for SIH5.COMEX
2025-01-07 15:16:13.358 | Intraday chart data file opened for SIH5.COMEX
2025-01-07 15:16:13.358 | HD Request # 85 | Enabling Intraday chart updating for symbol.
2025-01-07 15:16:13.358 | Triggering next historical data download in queue.
2025-01-07 15:16:13.358 | HD Request # 86 | Downloading Intraday chart data for NQH5.CME to the file NQH5.CME.scid. Service: cme
2025-01-07 15:16:13.358 | HD Request # 86 | Download start date-time: 2025-01-07 15:15:52.000000. File last date-time: 2025-01-07 15:15:52.918000
2025-01-07 15:16:13.358 | HD Request # 86 | Using server: ds32.sierracharts.com port 10149
2025-01-07 15:16:13.358 | Socket (6) | Creating socket.
2025-01-07 15:16:13.358 | Socket (6) | New receive buffer size: 0
2025-01-07 15:16:13.358 | Socket (6) | Connecting to IP: 67.214.125.3.
2025-01-07 15:16:13.582 | Socket (5) | Socket gracefully closed by remote side.
2025-01-07 15:16:13.582 | Socket (5) | Closed.
2025-01-07 15:16:13.853 | HD Request # 86 | Setting DTC encoding to Binary VLS
2025-01-07 15:16:13.853 | HD Request # 86 | Sending historical data logon request message.
2025-01-07 15:16:14.096 | HD Request # 86 | Requesting Intraday data. Start date-time: 2025-01-07 15:15:52. Record interval: 0. Symbol: NQH25
2025-01-07 15:16:14.339 | HD Request # 86 | Decompressing data.
2025-01-07 15:16:14.582 | HD Request # 86 | Receiving Intraday data for NQH5.CME starting at 2025-01-07 15:15:52.145000
2025-01-07 15:16:14.582 | Socket (6) | CloseSocket call.
2025-01-07 15:16:14.582 | Socket (6) | Shutdown started. Waiting for graceful close.
2025-01-07 15:16:14.604 | Historical data download thread signaled to stop.
2025-01-07 15:16:14.604 | HD Request # 86 | Timestamp of first Intraday data file record written: 2025-01-07 15:15:53.524000.
2025-01-07 15:16:14.604 | HD Request # 86 | Received 209 Intraday data records from 2025-01-07 15:15:52.145000 to 2025-01-07 15:16:10.595000 (18.4 seconds. Delay: 4.0 seconds) and wrote 199 records for NQH5.CME
2025-01-07 15:16:14.604 | HD Request # 86 | Add time&sales data | Remembered last file record date-time: 2025-01-07 20:16:10.595000
2025-01-07 15:16:14.604 | Added 39 Time and Sales records to Intraday data file for NQH5.CME after download.
2025-01-07 15:16:14.604 | HD Request # 86 | Completion time: 1s.
2025-01-07 15:16:14.604 | HD Request # 86 | Intraday data download complete for NQH5.CME. Unique request ID: 86
2025-01-07 15:16:14.604 | Removing historical data download ID 86.
2025-01-07 15:16:14.604 | Real-time Intraday chart data file updates started for NQH5.CME
2025-01-07 15:16:14.604 | Intraday chart data file opened for NQH5.CME
2025-01-07 15:16:14.604 | HD Request # 86 | Enabling Intraday chart updating for symbol.
2025-01-07 15:16:14.604 | Triggering next historical data download in queue.
2025-01-07 15:16:14.604 | HD Request # 87 | Downloading Intraday chart data for 6AH5.CME to the file 6AH5.CME.scid. Service: cme
2025-01-07 15:16:14.604 | HD Request # 87 | Download start date-time: 2025-01-07 15:15:52.000000. File last date-time: 2025-01-07 15:15:52.146002
2025-01-07 15:16:14.604 | HD Request # 87 | Using server: ds32.sierracharts.com port 10150
2025-01-07 15:16:14.604 | Socket (5) | Creating socket.
2025-01-07 15:16:14.604 | Socket (5) | New receive buffer size: 0
2025-01-07 15:16:14.604 | Socket (5) | Connecting to IP: 67.214.125.3.
2025-01-07 15:16:14.826 | Socket (6) | Socket gracefully closed by remote side.
2025-01-07 15:16:14.826 | Socket (6) | Closed.
2025-01-07 15:16:15.077 | HD Request # 87 | Setting DTC encoding to Binary VLS
2025-01-07 15:16:15.077 | HD Request # 87 | Sending historical data logon request message.
2025-01-07 15:16:15.309 | HD Request # 87 | Requesting Intraday data. Start date-time: 2025-01-07 15:15:52. Record interval: 0. Symbol: 6AH25
2025-01-07 15:16:15.541 | HD Request # 87 | Decompressing data.
2025-01-07 15:16:15.772 | HD Request # 87 | Receiving Intraday data for 6AH5.CME starting at 2025-01-07 15:15:52.146000
2025-01-07 15:16:15.772 | Socket (5) | CloseSocket call.
2025-01-07 15:16:15.772 | Socket (5) | Shutdown started. Waiting for graceful close.
2025-01-07 15:16:15.789 | Historical data download thread signaled to stop.
2025-01-07 15:16:15.789 | HD Request # 87 | Timestamp of first Intraday data file record written: 2025-01-07 15:16:06.934000.
2025-01-07 15:16:15.789 | HD Request # 87 | Received 4 Intraday data records from 2025-01-07 15:15:52.146000 to 2025-01-07 15:16:06.934000 (14.8 seconds. Delay: 8.9 seconds) and wrote 1 record for 6AH5.CME
2025-01-07 15:16:15.790 | HD Request # 87 | Add time&sales data | Remembered last file record date-time: 2025-01-07 20:16:06.934000
2025-01-07 15:16:15.790 | HD Request # 87 | Completion time: 1s.
2025-01-07 15:16:15.790 | HD Request # 87 | Intraday data download complete for 6AH5.CME. Unique request ID: 87
2025-01-07 15:16:15.790 | Removing historical data download ID 87.
2025-01-07 15:16:15.790 | Real-time Intraday chart data file updates started for 6AH5.CME
2025-01-07 15:16:15.790 | Intraday chart data file opened for 6AH5.CME
2025-01-07 15:16:15.790 | HD Request # 87 | Enabling Intraday chart updating for symbol.
2025-01-07 15:16:15.790 | Triggering next historical data download in queue.
2025-01-07 15:16:15.790 | HD Request # 88 | Downloading Intraday chart data for GCG5.COMEX to the file GCG5.COMEX.scid. Service: comex
2025-01-07 15:16:15.790 | HD Request # 88 | Download start date-time: 2025-01-07 15:15:34.000000. File last date-time: 2025-01-07 15:15:34.004000
2025-01-07 15:16:15.790 | HD Request # 88 | Using server: ds32.sierracharts.com port 10149
2025-01-07 15:16:15.790 | Socket (6) | Creating socket.
2025-01-07 15:16:15.790 | Socket (6) | New receive buffer size: 0
2025-01-07 15:16:15.790 | Socket (6) | Connecting to IP: 67.214.125.3.
2025-01-07 15:16:16.005 | Socket (5) | Socket gracefully closed by remote side.
2025-01-07 15:16:16.005 | Socket (5) | Closed.
2025-01-07 15:16:16.262 | HD Request # 88 | Setting DTC encoding to Binary VLS
2025-01-07 15:16:16.262 | HD Request # 88 | Sending historical data logon request message.
2025-01-07 15:16:16.495 | HD Request # 88 | Requesting Intraday data. Start date-time: 2025-01-07 15:15:34. Record interval: 0. Symbol: GCG25
2025-01-07 15:16:16.726 | HD Request # 88 | Decompressing data.
2025-01-07 15:16:16.958 | HD Request # 88 | Receiving Intraday data for GCG5.COMEX starting at 2025-01-07 15:15:34.004000
2025-01-07 15:16:16.959 | Socket (6) | CloseSocket call.
2025-01-07 15:16:16.959 | Socket (6) | Shutdown started. Waiting for graceful close.
2025-01-07 15:16:17.028 | Historical data download thread signaled to stop.
2025-01-07 15:16:17.028 | HD Request # 88 | Timestamp of first Intraday data file record written: 2025-01-07 15:16:00.152000.
2025-01-07 15:16:17.028 | HD Request # 88 | Received 4 Intraday data records from 2025-01-07 15:15:34.004000 to 2025-01-07 15:16:00.276001 (26.3 seconds. Delay: 16.8 seconds) and wrote 3 records for GCG5.COMEX
2025-01-07 15:16:17.028 | HD Request # 88 | Add time&sales data | Remembered last file record date-time: 2025-01-07 20:16:00.276001
2025-01-07 15:16:17.028 | Added 1 Time and Sales records to Intraday data file for GCG5.COMEX after download.
2025-01-07 15:16:17.028 | HD Request # 88 | Completion time: 2s.
2025-01-07 15:16:17.028 | HD Request # 88 | Intraday data download complete for GCG5.COMEX. Unique request ID: 88
2025-01-07 15:16:17.028 | Removing historical data download ID 88.
2025-01-07 15:16:17.028 | Real-time Intraday chart data file updates started for GCG5.COMEX
2025-01-07 15:16:17.028 | Intraday chart data file opened for GCG5.COMEX
2025-01-07 15:16:17.028 | HD Request # 88 | Enabling Intraday chart updating for symbol.
2025-01-07 15:16:17.028 | Triggering next historical data download in queue.
2025-01-07 15:16:17.028 | HD Request # 89 | Downloading Intraday chart data for MESH5.CME to the file MESH5.CME.scid. Service: cme
2025-01-07 15:16:17.028 | HD Request # 89 | Download start date-time: 2025-01-07 15:15:52.000000. File last date-time: 2025-01-07 15:15:52.994000
2025-01-07 15:16:17.029 | HD Request # 89 | Using server: ds32.sierracharts.com port 10150
2025-01-07 15:16:17.029 | Socket (5) | Creating socket.
2025-01-07 15:16:17.029 | Socket (5) | New receive buffer size: 0
2025-01-07 15:16:17.029 | Socket (5) | Connecting to IP: 67.214.125.3.
2025-01-07 15:16:17.194 | Socket (6) | Socket gracefully closed by remote side.
2025-01-07 15:16:17.194 | Socket (6) | Closed.
2025-01-07 15:16:17.531 | HD Request # 89 | Setting DTC encoding to Binary VLS
2025-01-07 15:16:17.531 | HD Request # 89 | Sending historical data logon request message.
2025-01-07 15:16:17.549 | Opened cached Intraday file: C:\SierraChart - TopStep\Data\MGCG5.COMEX.scid. Thread ID: 16528
2025-01-07 15:16:17.549 | Opened cached Intraday file: C:\SierraChart - TopStep\Data\SIH5.COMEX.scid. Thread ID: 16528
2025-01-07 15:16:17.550 | Opened cached Intraday file: C:\SierraChart - TopStep\Data\NQH5.CME.scid. Thread ID: 16528
2025-01-07 15:16:17.550 | Opened cached Intraday file: C:\SierraChart - TopStep\Data\6AH5.CME.scid. Thread ID: 16528
2025-01-07 15:16:17.780 | HD Request # 89 | Requesting Intraday data. Start date-time: 2025-01-07 15:15:52. Record interval: 0. Symbol: MESH25
2025-01-07 15:16:18.029 | HD Request # 89 | Decompressing data.
2025-01-07 15:16:18.279 | HD Request # 89 | Receiving Intraday data for MESH5.CME starting at 2025-01-07 15:15:52.813000
2025-01-07 15:16:18.280 | Socket (5) | CloseSocket call.
2025-01-07 15:16:18.280 | Socket (5) | Shutdown started. Waiting for graceful close.
2025-01-07 15:16:18.300 | Historical data download thread signaled to stop.
2025-01-07 15:16:18.300 | HD Request # 89 | Timestamp of first Intraday data file record written: 2025-01-07 15:15:53.426000.
2025-01-07 15:16:18.300 | HD Request # 89 | Received 259 Intraday data records from 2025-01-07 15:15:52.813000 to 2025-01-07 15:16:14.404001 (21.6 seconds. Delay: 3.9 seconds) and wrote 256 records for MESH5.CME
2025-01-07 15:16:18.300 | HD Request # 89 | Add time&sales data | Remembered last file record date-time: 2025-01-07 20:16:14.404001
2025-01-07 15:16:18.300 | Added 20 Time and Sales records to Intraday data file for MESH5.CME after download.
2025-01-07 15:16:18.300 | HD Request # 89 | Completion time: 1s.
2025-01-07 15:16:18.300 | HD Request # 89 | Intraday data download complete for MESH5.CME. Unique request ID: 89
2025-01-07 15:16:18.300 | Removing historical data download ID 89.
2025-01-07 15:16:18.300 | Real-time Intraday chart data file updates started for MESH5.CME
2025-01-07 15:16:18.300 | Intraday chart data file opened for MESH5.CME
2025-01-07 15:16:18.300 | HD Request # 89 | Enabling Intraday chart updating for symbol.
2025-01-07 15:16:18.300 | Triggering next historical data download in queue.
2025-01-07 15:16:18.301 | HD Request # 90 | Downloading Intraday chart data for M6AH5.CME to the file M6AH5.CME.scid. Service: cme
2025-01-07 15:16:18.301 | HD Request # 90 | Download start date-time: 2025-01-07 15:14:41.000000. File last date-time: 2025-01-07 15:14:41.170000
2025-01-07 15:16:18.301 | HD Request # 90 | Using server: ds32.sierracharts.com port 10149
2025-01-07 15:16:18.301 | Socket (6) | Creating socket.
2025-01-07 15:16:18.301 | Socket (6) | New receive buffer size: 0
2025-01-07 15:16:18.301 | Socket (6) | Connecting to IP: 67.214.125.3.
2025-01-07 15:16:18.528 | Socket (5) | Socket gracefully closed by remote side.
2025-01-07 15:16:18.528 | Socket (5) | Closed.
2025-01-07 15:16:18.794 | HD Request # 90 | Setting DTC encoding to Binary VLS
2025-01-07 15:16:18.794 | HD Request # 90 | Sending historical data logon request message.
2025-01-07 15:16:18.845 | HTTPS connection ID:16 to downloads.rithmic.com:443 for request ID:16 (5) | Creating socket. Using TLS 1.2.
2025-01-07 15:16:18.845 | HTTPS connection ID:16 to downloads.rithmic.com:443 for request ID:16 (5) | New receive buffer size: 0
2025-01-07 15:16:18.845 | HTTPS connection ID:16 to downloads.rithmic.com:443 for request ID:16 (5) | Connecting to IP: 216.66.0.130.
2025-01-07 15:16:19.037 | HD Request # 90 | Requesting Intraday data. Start date-time: 2025-01-07 15:14:41. Record interval: 0. Symbol: M6AH25
2025-01-07 15:16:19.278 | HD Request # 90 | Decompressing data.
2025-01-07 15:16:19.519 | HD Request # 90 | Receiving Intraday data for M6AH5.CME starting at 2025-01-07 15:14:41.170000
2025-01-07 15:16:19.519 | Socket (6) | CloseSocket call.
2025-01-07 15:16:19.519 | Socket (6) | Shutdown started. Waiting for graceful close.
2025-01-07 15:16:19.533 | Historical data download thread signaled to stop.
2025-01-07 15:16:19.533 | HD Request # 90 | Received 1 Intraday data record from 2025-01-07 15:14:41.170000 to 2025-01-07 15:14:41.170000 (0.0 seconds. Delay: 98.4 seconds) and wrote 0 records for M6AH5.CME
2025-01-07 15:16:19.533 | HD Request # 90 | Add time&sales data | Remembered last file record date-time: 2025-01-07 20:14:41.170000
2025-01-07 15:16:19.533 | HD Request # 90 | Completion time: 1s.
2025-01-07 15:16:19.533 | HD Request # 90 | Intraday data download complete for M6AH5.CME. Unique request ID: 90
2025-01-07 15:16:19.533 | Removing historical data download ID 90.
2025-01-07 15:16:19.533 | Real-time Intraday chart data file updates started for M6AH5.CME
2025-01-07 15:16:19.533 | Intraday chart data file opened for M6AH5.CME
2025-01-07 15:16:19.533 | HD Request # 90 | Enabling Intraday chart updating for symbol.
2025-01-07 15:16:19.533 | Triggering next historical data download in queue.
2025-01-07 15:16:19.533 | HD Request # 91 | Downloading Intraday chart data for SILH5.COMEX to the file SILH5.COMEX.scid. Service: comex
2025-01-07 15:16:19.534 | HD Request # 91 | Download start date-time: 2025-01-07 15:15:23.000000. File last date-time: 2025-01-07 15:15:23.030000
2025-01-07 15:16:19.534 | HD Request # 91 | Using server: ds32.sierracharts.com port 10150
2025-01-07 15:16:19.534 | Socket (7) | Creating socket.
2025-01-07 15:16:19.534 | Socket (7) | New receive buffer size: 0
2025-01-07 15:16:19.534 | Socket (7) | Connecting to IP: 67.214.125.3.
2025-01-07 15:16:19.761 | Socket (6) | Socket gracefully closed by remote side.
2025-01-07 15:16:19.761 | Socket (6) | Closed.
2025-01-07 15:16:20.005 | HD Request # 91 | Setting DTC encoding to Binary VLS
2025-01-07 15:16:20.005 | HD Request # 91 | Sending historical data logon request message.
2025-01-07 15:16:20.235 | HD Request # 91 | Requesting Intraday data. Start date-time: 2025-01-07 15:15:23. Record interval: 0. Symbol: SILH25
2025-01-07 15:16:20.292 | Rithmic Direct - DTC | Wrote file: C:\SierraChart - TopStep\RithmicConnections.json. Size: 81131
2025-01-07 15:16:20.293 | Rithmic Direct - DTC | Processed connection points. Count: 347
2025-01-07 15:16:20.466 | HD Request # 91 | Decompressing data.
2025-01-07 15:16:20.697 | HD Request # 91 | Receiving Intraday data for SILH5.COMEX starting at 2025-01-07 15:15:23.030000
2025-01-07 15:16:20.697 | Socket (7) | CloseSocket call.
2025-01-07 15:16:20.697 | Socket (7) | Shutdown started. Waiting for graceful close.
2025-01-07 15:16:20.707 | Historical data download thread signaled to stop.
2025-01-07 15:16:20.707 | HD Request # 91 | Timestamp of first Intraday data file record written: 2025-01-07 15:16:00.275000.
2025-01-07 15:16:20.707 | HD Request # 91 | Received 2 Intraday data records from 2025-01-07 15:15:23.030000 to 2025-01-07 15:16:00.275000 (37.2 seconds. Delay: 20.4 seconds) and wrote 1 record for SILH5.COMEX
2025-01-07 15:16:20.707 | HD Request # 91 | Add time&sales data | Remembered last file record date-time: 2025-01-07 20:16:00.275000
2025-01-07 15:16:20.707 | HD Request # 91 | Completion time: 1s.
2025-01-07 15:16:20.707 | HD Request # 91 | Intraday data download complete for SILH5.COMEX. Unique request ID: 91
2025-01-07 15:16:20.707 | Removing historical data download ID 91.
2025-01-07 15:16:20.707 | Real-time Intraday chart data file updates started for SILH5.COMEX
2025-01-07 15:16:20.707 | Intraday chart data file opened for SILH5.COMEX
2025-01-07 15:16:20.707 | HD Request # 91 | Enabling Intraday chart updating for symbol.
2025-01-07 15:16:20.707 | Triggering next historical data download in queue.
2025-01-07 15:16:20.707 | HD Request # 92 | Downloading Intraday chart data for USDX to the file USDX.scid. Service: fxstatscalc
2025-01-07 15:16:20.707 | HD Request # 92 | Download start date-time: 2025-01-07 15:15:53.000000. File last date-time: 2025-01-07 15:15:53.000000
2025-01-07 15:16:20.707 | HD Request # 92 | Using server: ds12.sierracharts.com port 10149
2025-01-07 15:16:20.707 | Socket (6) | Creating socket.
2025-01-07 15:16:20.708 | Socket (6) | New receive buffer size: 0
2025-01-07 15:16:20.708 | Socket (6) | Connecting to IP: 69.39.70.241.
2025-01-07 15:16:20.931 | Socket (7) | Socket gracefully closed by remote side.
2025-01-07 15:16:20.931 | Socket (7) | Closed.
2025-01-07 15:16:21.229 | HD Request # 92 | Setting DTC encoding to Binary VLS
2025-01-07 15:16:21.229 | HD Request # 92 | Sending historical data logon request message.
2025-01-07 15:16:21.431 | HTTPS connection ID:16 to downloads.rithmic.com:443 for request ID:16 (5) | CloseSocket call.
2025-01-07 15:16:21.431 | HTTPS connection ID:16 to downloads.rithmic.com:443 for request ID:16 (5) | Shutdown started. Waiting for graceful close.
2025-01-07 15:16:21.514 | HD Request # 92 | Requesting Intraday data. Start date-time: 2025-01-07 15:15:53. Record interval: 0. Symbol: USDX
2025-01-07 15:16:21.665 | HTTPS connection ID:16 to downloads.rithmic.com:443 for request ID:16 (5) | Socket gracefully closed by remote side.
2025-01-07 15:16:21.665 | HTTPS connection ID:16 to downloads.rithmic.com:443 for request ID:16 (5) | Closed.
2025-01-07 15:16:21.764 | HD Request # 92 | Decompressing data.
2025-01-07 15:16:22.011 | HD Request # 92 | Receiving Intraday data for USDX starting at 2025-01-07 15:15:53.000000
2025-01-07 15:16:22.012 | Socket (6) | CloseSocket call.
2025-01-07 15:16:22.012 | Socket (6) | Shutdown started. Waiting for graceful close.
2025-01-07 15:16:22.049 | Historical data download thread signaled to stop.
2025-01-07 15:16:22.049 | HD Request # 92 | Timestamp of first Intraday data file record written: 2025-01-07 15:15:54.000000.
2025-01-07 15:16:22.049 | HD Request # 92 | Received 28 Intraday data records from 2025-01-07 15:15:53.000000 to 2025-01-07 15:16:20.000000 (27.0 seconds. Delay: 2.0 seconds) and wrote 27 records for USDX
2025-01-07 15:16:22.049 | HD Request # 92 | Add time&sales data | Remembered last file record date-time: 2025-01-07 20:16:20.000000
2025-01-07 15:16:22.049 | Added 3 Time and Sales records to Intraday data file for USDX after download.
2025-01-07 15:16:22.049 | HD Request # 92 | Completion time: 2s.
2025-01-07 15:16:22.049 | HD Request # 92 | Intraday data download complete for USDX. Unique request ID: 92
2025-01-07 15:16:22.049 | Removing historical data download ID 92.
2025-01-07 15:16:22.049 | Real-time Intraday chart data file updates started for USDX
2025-01-07 15:16:22.049 | Intraday chart data file opened for USDX
2025-01-07 15:16:22.049 | HD Request # 92 | Enabling Intraday chart updating for symbol.
2025-01-07 15:16:22.049 | Triggering next historical data download in queue.
2025-01-07 15:16:22.049 | HD Request # 93 | Downloading Intraday chart data for SPX500 to the file SPX500.scid. Service: fxcm
2025-01-07 15:16:22.049 | HD Request # 93 | Download start date-time: 2025-01-07 15:15:52.000000. File last date-time: 2025-01-07 15:15:52.845000
2025-01-07 15:16:22.050 | HD Request # 93 | Using server: ds4.sierracharts.com port 10150
2025-01-07 15:16:22.181 | Socket (5) | Creating socket.
2025-01-07 15:16:22.181 | Socket (5) | New receive buffer size: 0
2025-01-07 15:16:22.181 | Socket (5) | Connecting to IP: 67.214.125.7.
2025-01-07 15:16:22.260 | Socket (6) | Socket gracefully closed by remote side.
2025-01-07 15:16:22.260 | Socket (6) | Closed.
2025-01-07 15:16:22.583 | Opened cached Intraday file: C:\SierraChart - TopStep\Data\GCG5.COMEX.scid. Thread ID: 16528
2025-01-07 15:16:22.583 | Opened cached Intraday file: C:\SierraChart - TopStep\Data\MESH5.CME.scid. Thread ID: 16528
2025-01-07 15:16:22.583 | Opened cached Intraday file: C:\SierraChart - TopStep\Data\USDX.scid. Thread ID: 16528
2025-01-07 15:16:22.689 | HD Request # 93 | Setting DTC encoding to Binary VLS
2025-01-07 15:16:22.689 | HD Request # 93 | Sending historical data logon request message.
2025-01-07 15:16:22.966 | HD Request # 93 | Requesting Intraday data. Start date-time: 2025-01-07 15:15:52. Record interval: 0. Symbol: SPX500
2025-01-07 15:16:23.210 | HD Request # 93 | Decompressing data.
2025-01-07 15:16:23.455 | HD Request # 93 | Receiving Intraday data for SPX500 starting at 2025-01-07 15:15:52.022000
2025-01-07 15:16:23.455 | Socket (5) | CloseSocket call.
2025-01-07 15:16:23.455 | Socket (5) | Shutdown started. Waiting for graceful close.
2025-01-07 15:16:23.456 | Historical data download thread signaled to stop.
2025-01-07 15:16:23.456 | HD Request # 93 | Timestamp of first Intraday data file record written: 2025-01-07 15:15:57.681000.
2025-01-07 15:16:23.456 | HD Request # 93 | Received 114 Intraday data records from 2025-01-07 15:15:52.022000 to 2025-01-07 15:16:21.761000 (29.7 seconds. Delay: 1.7 seconds) and wrote 110 records for SPX500
2025-01-07 15:16:23.457 | HD Request # 93 | Add time&sales data | Remembered last file record date-time: 2025-01-07 20:16:21.761000
2025-01-07 15:16:23.457 | HD Request # 93 | Completion time: 1s.
2025-01-07 15:16:23.457 | HD Request # 93 | Intraday data download complete for SPX500. Unique request ID: 93
2025-01-07 15:16:23.457 | Removing historical data download ID 93.
2025-01-07 15:16:23.457 | Real-time Intraday chart data file updates started for SPX500
2025-01-07 15:16:23.457 | Intraday chart data file opened for SPX500
2025-01-07 15:16:23.457 | HD Request # 93 | Enabling Intraday chart updating for symbol.
2025-01-07 15:16:23.457 | No download requests in the queue to start downloads for.
2025-01-07 15:16:23.698 | Socket (5) | Socket gracefully closed by remote side.
2025-01-07 15:16:23.698 | Socket (5) | Closed.
2025-01-07 15:16:27.611 | Opened cached Intraday file: C:\SierraChart - TopStep\Data\SPX500.scid. Thread ID: 16528
2025-01-07 15:16:52.767 | Opened cached Intraday file: C:\SierraChart - TopStep\Data\M6AH5.CME.scid. Thread ID: 16528
2025-01-07 15:16:57.785 | Opened cached Intraday file: C:\SierraChart - TopStep\Data\SILH5.COMEX.scid. Thread ID: 16528
2025-01-07 15:22:25.164 | Chat | Message response. Chat ID: 429. Request ID: 1134629377
2025-01-07 15:57:23.184 | SPX500[M] 240 Min #16 | Reloading chart.
2025-01-07 15:57:23.706 | SPX500[M] 240 Min #16 | StartDateTimeForLoadingOrderFills: 2024-01-01 00:00:00
2025-01-07 15:57:23.717 | SPX500[M] 240 Min #16 | Chart data loading complete.
2025-01-07 15:57:43.374 | SPX500[M] Daily #16 | Reloading chart.
2025-01-07 15:57:43.444 | SPX500[M] Daily #16 | StartDateTimeForLoadingOrderFills: 2023-12-13 00:00:00
2025-01-07 15:57:43.452 | SPX500[M] Daily #16 | Chart data loading complete.
2025-01-07 15:57:44.564 | Added historical Daily data request for SPX500 to the queue.
2025-01-07 15:57:44.564 | Triggering next historical data download in queue.
2025-01-07 15:57:44.571 | HD Request # 94 | Downloading Historical Daily chart data for SPX500. Starting date: 2024-12-17. Service: fxcm
2025-01-07 15:57:44.571 | HD Request # 94 | Using server: ds12.sierracharts.com port 10149
2025-01-07 15:57:44.693 | Socket (5) | Creating socket.
2025-01-07 15:57:44.693 | Socket (5) | New receive buffer size: 0
2025-01-07 15:57:44.693 | Socket (5) | Connecting to IP: 69.39.70.241.
2025-01-07 15:57:45.214 | HD Request # 94 | Setting DTC encoding to Binary VLS
2025-01-07 15:57:45.214 | HD Request # 94 | Sending historical data logon request message.
2025-01-07 15:57:45.503 | HD Request # 94 | Requesting historical Daily data starting at 2024-12-17.
2025-01-07 15:57:45.755 | HD Request # 94 | Decompressing data.
2025-01-07 15:57:45.786 | HD Request # 94 | Receiving historical Daily data for SPX500 starting at 2024-12-17.
2025-01-07 15:57:45.786 | HD Request # 94 | Writing historical Daily data to the file SPX500.dly.
2025-01-07 15:57:45.814 | Socket (5) | CloseSocket call.
2025-01-07 15:57:45.814 | Socket (5) | Shutdown started. Waiting for graceful close.
2025-01-07 15:57:45.815 | Historical data download thread signaled to stop.
2025-01-07 15:57:45.815 | HD Request # 94 | Received 14 Daily data records from 2024-12-17 00:00:00 to 2025-01-07 00:00:00 (22.0 days) and wrote 14 records for SPX500
2025-01-07 15:57:45.815 | HD Request # 94 | Completion time: 1s.
2025-01-07 15:57:45.815 | HD Request # 94 | Daily data download complete for SPX500. Unique request ID: 94
2025-01-07 15:57:45.815 | Removing historical data download ID 94.
2025-01-07 15:57:45.815 | No download requests in the queue to start downloads for.
2025-01-07 15:57:46.064 | Socket (5) | Socket gracefully closed by remote side.
2025-01-07 15:57:46.065 | Socket (5) | Closed.
2025-01-07 15:57:46.520 | SPX500[M] Daily #16 | Reloading chart.
2025-01-07 15:57:46.633 | SPX500[M] Daily #16 | StartDateTimeForLoadingOrderFills: 2024-01-01 00:00:00
2025-01-07 15:57:46.640 | SPX500[M] Daily #16 | Chart data loading complete.
2025-01-07 15:57:51.167 | SPX500[M] 60 Min #16 | Reloading chart.
2025-01-07 15:57:51.704 | SPX500[M] 60 Min #16 | StartDateTimeForLoadingOrderFills: 2024-01-01 00:00:00
2025-01-07 15:57:51.716 | SPX500[M] 60 Min #16 | Chart data loading complete.
2025-01-07 15:57:55.500 | SPX500[M] 240 Min #16 | Reloading chart.
2025-01-07 15:57:56.132 | SPX500[M] 240 Min #16 | StartDateTimeForLoadingOrderFills: 2024-01-01 00:00:00
2025-01-07 15:57:56.145 | SPX500[M] 240 Min #16 | Chart data loading complete.
2025-01-07 17:30:51.881 | SC Data with Depth | Real-time data for symbol SPX500 is currently unavailable.
2025-01-07 17:31:21.032 | SC Data with Depth | Setting external service identifier for symbol SPX500 to 55
2025-01-07 17:31:21.032 | SC Data with Depth | Received security definition for symbol SPX500
2025-01-07 17:31:21.032 | SC Data with Depth | Real-time data for symbol SPX500 has been restored.
2025-01-07 17:31:21.032 | Added historical Intraday data request for SPX500 to the queue.
2025-01-07 17:31:21.032 | Intraday data recording state for symbol SPX500 is set to download 'Pending'.
2025-01-07 17:31:21.032 | Triggering next historical data download in queue.
2025-01-07 17:31:21.032 | HD Request # 95 | Downloading Intraday chart data for SPX500 to the file SPX500.scid. Service: fxcm
2025-01-07 17:31:21.033 | HD Request # 95 | Download start date-time: 2025-01-07 16:59:59.000000. File last date-time: 2025-01-07 16:59:59.028000
2025-01-07 17:31:21.033 | HD Request # 95 | Using server: ds4.sierracharts.com port 10150
2025-01-07 17:31:21.154 | Socket (5) | Creating socket.
2025-01-07 17:31:21.154 | Socket (5) | New receive buffer size: 0
2025-01-07 17:31:21.154 | Socket (5) | Connecting to IP: 67.214.125.7.
2025-01-07 17:31:21.700 | HD Request # 95 | Setting DTC encoding to Binary VLS
2025-01-07 17:31:21.700 | HD Request # 95 | Sending historical data logon request message.
2025-01-07 17:31:29.323 | HD Request # 95 | Requesting Intraday data. Start date-time: 2025-01-07 16:59:59. Record interval: 0. Symbol: SPX500
2025-01-07 17:31:29.569 | HD Request # 95 | Decompressing data.
2025-01-07 17:31:29.813 | HD Request # 95 | Receiving Intraday data for SPX500 starting at 2025-01-07 16:59:59.028000
2025-01-07 17:31:29.813 | Socket (5) | CloseSocket call.
2025-01-07 17:31:29.813 | Socket (5) | Shutdown started. Waiting for graceful close.
2025-01-07 17:31:29.815 | Historical data download thread signaled to stop.
2025-01-07 17:31:29.815 | HD Request # 95 | Received 1 Intraday data record from 2025-01-07 16:59:59.028000 to 2025-01-07 16:59:59.028000 (0.0 seconds. Delay: 31.5 minutes) and wrote 0 records for SPX500
2025-01-07 17:31:29.815 | HD Request # 95 | Add time&sales data | Remembered last file record date-time: 2025-01-07 21:59:59.028000
2025-01-07 17:31:29.815 | HD Request # 95 | Completion time: 8s.
2025-01-07 17:31:29.815 | HD Request # 95 | Intraday data download complete for SPX500. Unique request ID: 95
2025-01-07 17:31:29.815 | Removing historical data download ID 95.
2025-01-07 17:31:29.815 | Real-time Intraday chart data file updates started for SPX500
2025-01-07 17:31:29.815 | Intraday chart data file opened for SPX500
2025-01-07 17:31:29.815 | HD Request # 95 | Enabling Intraday chart updating for symbol.
2025-01-07 17:31:29.815 | No download requests in the queue to start downloads for.
2025-01-07 17:31:30.077 | Socket (5) | Socket gracefully closed by remote side.
2025-01-07 17:31:30.077 | Socket (5) | Closed.
2025-01-07 17:45:00.063 | Added historical Daily data request for ESH5.CME to the queue.
2025-01-07 17:45:00.063 | Triggering next historical data download in queue.
2025-01-07 17:45:00.064 | HD Request # 96 | Downloading Historical Daily chart data for ESH5.CME. Starting date: 2025-01-02. Service: rithmic.trading
2025-01-07 17:45:00.065 | Added historical Daily data request for GCG5.COMEX to the queue.
2025-01-07 17:45:00.065 | Triggering next historical data download in queue.
2025-01-07 17:45:00.065 | Added historical Daily data request for NQH5.CME to the queue.
2025-01-07 17:45:00.065 | Added historical Daily data request for 6AH5.CME to the queue.
2025-01-07 17:45:00.065 | Added historical Daily data request for USDX to the queue.
2025-01-07 17:45:00.066 | HD Request # 97 | Downloading Historical Daily chart data for USDX. Starting date: 2025-01-03. Service: fxstatscalc
2025-01-07 17:45:00.066 | HD Request # 97 | Using server: ds12.sierracharts.com port 10149
2025-01-07 17:45:00.066 | Added historical Daily data request for SIH5.COMEX to the queue.
2025-01-07 17:45:00.066 | Triggering next historical data download in queue.
2025-01-07 17:45:00.191 | Socket (6) | Creating socket.
2025-01-07 17:45:00.191 | Socket (6) | New receive buffer size: 0
2025-01-07 17:45:00.191 | Socket (6) | Connecting to IP: 69.39.70.241.
2025-01-07 17:45:00.716 | HD Request # 97 | Setting DTC encoding to Binary VLS
2025-01-07 17:45:00.716 | HD Request # 97 | Sending historical data logon request message.
2025-01-07 17:45:01.112 | HD Request # 96 | Requesting historical Daily data for ESH25 starting at 2025-01-01. SC External HD service.
2025-01-07 17:45:02.057 | HD Request # 96 | Receiving historical Daily data for ESH5.CME starting at 2025-01-02.
2025-01-07 17:45:02.057 | HD Request # 96 | Writing historical Daily data to the file ESH5.CME.dly.
2025-01-07 17:45:02.059 | HD Request # 96 | Bytes received: 246
2025-01-07 17:45:02.059 | HD Request # 96 | Received 4 Daily data records from 2025-01-02 00:00:00 to 2025-01-07 00:00:00 (6.0 days) and wrote 4 records for ESH5.CME
2025-01-07 17:45:02.059 | HD Request # 96 | Completion time: 2s.
2025-01-07 17:45:02.059 | HD Request # 96 | Daily data download complete for ESH5.CME. Unique request ID: 96
2025-01-07 17:45:02.059 | Removing historical data download ID 96.
2025-01-07 17:45:02.059 | Triggering next historical data download in queue.
2025-01-07 17:45:02.061 | HD Request # 98 | Downloading Historical Daily chart data for GCG5.COMEX. Starting date: 2025-01-02. Service: rithmic.trading
2025-01-07 17:45:02.478 | ESH5.CME [CBV][M] Monthly #4 | Reloading chart.
2025-01-07 17:45:02.478 | ESH5.CME [CBV][M] Monthly #4 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2025-01-07 17:45:02.478 | ESH5.CME [CBV][M] Monthly #4 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2025-01-07 17:45:02.748 | HD Request # 97 | Requesting historical Daily data starting at 2025-01-03.
2025-01-07 17:45:02.817 | ESH5.CME [CBV][M] Daily #6 | Reloading chart.
2025-01-07 17:45:02.817 | ESH5.CME [CBV][M] Daily #6 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2025-01-07 17:45:02.817 | ESH5.CME [CBV][M] Daily #6 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2025-01-07 17:45:03.008 | HD Request # 97 | Decompressing data.
2025-01-07 17:45:03.035 | HD Request # 97 | Receiving historical Daily data for USDX starting at 2025-01-03.
2025-01-07 17:45:03.035 | HD Request # 97 | Writing historical Daily data to the file USDX.dly.
2025-01-07 17:45:03.048 | Socket (6) | CloseSocket call.
2025-01-07 17:45:03.048 | Socket (6) | Shutdown started. Waiting for graceful close.
2025-01-07 17:45:03.158 | ESH5.CME [CBV][M] Monthly #4 | Chart data loading complete.
2025-01-07 17:45:03.158 | Historical data download thread signaled to stop.
2025-01-07 17:45:03.158 | HD Request # 97 | Received 4 Daily data records from 2025-01-03 00:00:00 to 2025-01-08 00:00:00 (6.0 days) and wrote 4 records for USDX
2025-01-07 17:45:03.158 | HD Request # 97 | Completion time: 3s.
2025-01-07 17:45:03.158 | HD Request # 97 | Daily data download complete for USDX. Unique request ID: 100
2025-01-07 17:45:03.158 | Removing historical data download ID 100.
2025-01-07 17:45:03.158 | No download requests in the queue to start downloads for.
2025-01-07 17:45:03.184 | HD Request # 98 | Requesting historical Daily data for GCG25 starting at 2025-01-01. SC External HD service.
2025-01-07 17:45:03.214 | ESH5.CME [CBV][M] Daily #6 | Chart data loading complete.
2025-01-07 17:45:03.298 | Socket (6) | Socket gracefully closed by remote side.
2025-01-07 17:45:03.298 | Socket (6) | Closed.
2025-01-07 17:45:03.335 | ESH5.CME [CBV][M] Weekly #5 | Reloading chart.
2025-01-07 17:45:03.335 | ESH5.CME [CBV][M] Weekly #5 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2025-01-07 17:45:03.335 | ESH5.CME [CBV][M] Weekly #5 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2025-01-07 17:45:03.730 | ESH5.CME [CBV][M] Weekly #5 | Chart data loading complete.
2025-01-07 17:45:04.349 | HD Request # 98 | Receiving historical Daily data for GCG5.COMEX starting at 2025-01-02.
2025-01-07 17:45:04.349 | HD Request # 98 | Writing historical Daily data to the file GCG5.COMEX.dly.
2025-01-07 17:45:04.351 | HD Request # 98 | Bytes received: 230
2025-01-07 17:45:04.351 | HD Request # 98 | Received 4 Daily data records from 2025-01-02 00:00:00 to 2025-01-07 00:00:00 (6.0 days) and wrote 4 records for GCG5.COMEX
2025-01-07 17:45:04.351 | HD Request # 98 | Completion time: 2s.
2025-01-07 17:45:04.351 | HD Request # 98 | Daily data download complete for GCG5.COMEX. Unique request ID: 97
2025-01-07 17:45:04.351 | Removing historical data download ID 97.
2025-01-07 17:45:04.351 | Triggering next historical data download in queue.
2025-01-07 17:45:04.352 | HD Request # 99 | Downloading Historical Daily chart data for NQH5.CME. Starting date: 2025-01-02. Service: rithmic.trading
2025-01-07 17:45:04.469 | GCG5.COMEX [CBV][M] Daily #6 | Reloading chart.
2025-01-07 17:45:04.469 | GCG5.COMEX [CBV][M] Daily #6 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2025-01-07 17:45:04.469 | GCG5.COMEX [CBV][M] Daily #6 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2025-01-07 17:45:05.122 | USDX[M] Daily #19 | Reloading chart.
2025-01-07 17:45:05.147 | USDX[M] Daily #19 | StartDateTimeForLoadingOrderFills: 2024-01-02 00:00:00
2025-01-07 17:45:05.147 | USDX[M] Daily #19 | Chart data loading complete.
2025-01-07 17:45:05.234 | GCG5.COMEX [CBV][M] Daily #6 | Chart data loading complete.
2025-01-07 17:45:05.302 | GCG5.COMEX [CBV][M] Weekly #5 | Reloading chart.
2025-01-07 17:45:05.302 | GCG5.COMEX [CBV][M] Weekly #5 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2025-01-07 17:45:05.302 | GCG5.COMEX [CBV][M] Weekly #5 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2025-01-07 17:45:05.954 | GCG5.COMEX [CBV][M] Monthly #4 | Reloading chart.
2025-01-07 17:45:05.954 | GCG5.COMEX [CBV][M] Monthly #4 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2025-01-07 17:45:05.954 | GCG5.COMEX [CBV][M] Monthly #4 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2025-01-07 17:45:06.608 | HD Request # 99 | Requesting historical Daily data for NQH25 starting at 2025-01-01. SC External HD service.
2025-01-07 17:45:06.610 | GCG5.COMEX [CBV][M] Weekly #5 | Chart data loading complete.
2025-01-07 17:45:06.855 | GCG5.COMEX [CBV][M] Monthly #4 | Chart data loading complete.
2025-01-07 17:45:07.617 | HD Request # 99 | Receiving historical Daily data for NQH5.CME starting at 2025-01-02.
2025-01-07 17:45:07.617 | HD Request # 99 | Writing historical Daily data to the file NQH5.CME.dly.
2025-01-07 17:45:07.618 | HD Request # 99 | Bytes received: 254
2025-01-07 17:45:07.618 | HD Request # 99 | Received 4 Daily data records from 2025-01-02 00:00:00 to 2025-01-07 00:00:00 (6.0 days) and wrote 4 records for NQH5.CME
2025-01-07 17:45:07.618 | HD Request # 99 | Completion time: 3s.
2025-01-07 17:45:07.618 | HD Request # 99 | Daily data download complete for NQH5.CME. Unique request ID: 98
2025-01-07 17:45:07.618 | Removing historical data download ID 98.
2025-01-07 17:45:07.618 | Triggering next historical data download in queue.
2025-01-07 17:45:07.620 | HD Request # 100 | Downloading Historical Daily chart data for 6AH5.CME. Starting date: 2025-01-02. Service: rithmic.trading
2025-01-07 17:45:08.333 | NQH5.CME [CBV][M] Monthly #4 | Reloading chart.
2025-01-07 17:45:08.333 | NQH5.CME [CBV][M] Monthly #4 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2025-01-07 17:45:08.333 | NQH5.CME [CBV][M] Monthly #4 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2025-01-07 17:45:08.682 | NQH5.CME [CBV][M] Monthly #4 | Chart data loading complete.
2025-01-07 17:45:08.725 | NQH5.CME [CBV][M] Daily #6 | Reloading chart.
2025-01-07 17:45:08.725 | NQH5.CME [CBV][M] Daily #6 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2025-01-07 17:45:08.725 | NQH5.CME [CBV][M] Daily #6 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2025-01-07 17:45:09.014 | HD Request # 100 | Requesting historical Daily data for A6H25 starting at 2025-01-01. SC External HD service.
2025-01-07 17:45:09.015 | NQH5.CME [CBV][M] Weekly #5 | Reloading chart.
2025-01-07 17:45:09.015 | NQH5.CME [CBV][M] Weekly #5 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2025-01-07 17:45:09.015 | NQH5.CME [CBV][M] Weekly #5 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2025-01-07 17:45:09.314 | NQH5.CME [CBV][M] Daily #6 | Chart data loading complete.
2025-01-07 17:45:09.377 | NQH5.CME [CBV][M] Weekly #5 | Chart data loading complete.
2025-01-07 17:45:09.960 | HD Request # 100 | Receiving historical Daily data for 6AH5.CME starting at 2025-01-02.
2025-01-07 17:45:09.960 | HD Request # 100 | Writing historical Daily data to the file 6AH5.CME.dly.
2025-01-07 17:45:09.964 | HD Request # 100 | Bytes received: 238
2025-01-07 17:45:09.964 | HD Request # 100 | Received 4 Daily data records from 2025-01-02 00:00:00 to 2025-01-07 00:00:00 (6.0 days) and wrote 4 records for 6AH5.CME
2025-01-07 17:45:09.964 | HD Request # 100 | Completion time: 2s.
2025-01-07 17:45:09.964 | HD Request # 100 | Daily data download complete for 6AH5.CME. Unique request ID: 99
2025-01-07 17:45:09.964 | Removing historical data download ID 99.
2025-01-07 17:45:09.964 | Triggering next historical data download in queue.
2025-01-07 17:45:09.966 | HD Request # 101 | Downloading Historical Daily chart data for SIH5.COMEX. Starting date: 2025-01-02. Service: rithmic.trading
2025-01-07 17:45:09.967 | 6AH5.CME [CBV][M] Weekly #5 | Reloading chart.
2025-01-07 17:45:09.967 | 6AH5.CME [CBV][M] Weekly #5 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2025-01-07 17:45:09.967 | 6AH5.CME [CBV][M] Weekly #5 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2025-01-07 17:45:10.707 | 6AH5.CME [CBV][M] Daily #6 | Reloading chart.
2025-01-07 17:45:10.707 | 6AH5.CME [CBV][M] Daily #6 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2025-01-07 17:45:10.707 | 6AH5.CME [CBV][M] Daily #6 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2025-01-07 17:45:11.427 | 6AH5.CME [CBV][M] Weekly #5 | Chart data loading complete.
2025-01-07 17:45:11.507 | HD Request # 101 | Requesting historical Daily data for SIH25 starting at 2025-01-01. SC External HD service.
2025-01-07 17:45:11.568 | 6AH5.CME [CBV][M] Daily #6 | Chart data loading complete.
2025-01-07 17:45:11.569 | 6AH5.CME [CBV][M] Monthly #4 | Reloading chart.
2025-01-07 17:45:11.569 | 6AH5.CME [CBV][M] Monthly #4 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2025-01-07 17:45:11.569 | 6AH5.CME [CBV][M] Monthly #4 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2025-01-07 17:45:12.530 | 6AH5.CME [CBV][M] Monthly #4 | Chart data loading complete.
2025-01-07 17:45:12.904 | HD Request # 101 | Receiving historical Daily data for SIH5.COMEX starting at 2025-01-02.
2025-01-07 17:45:12.904 | HD Request # 101 | Writing historical Daily data to the file SIH5.COMEX.dly.
2025-01-07 17:45:12.906 | HD Request # 101 | Bytes received: 224
2025-01-07 17:45:12.906 | HD Request # 101 | Received 4 Daily data records from 2025-01-02 00:00:00 to 2025-01-07 00:00:00 (6.0 days) and wrote 4 records for SIH5.COMEX
2025-01-07 17:45:12.906 | HD Request # 101 | Completion time: 3s.
2025-01-07 17:45:12.906 | HD Request # 101 | Daily data download complete for SIH5.COMEX. Unique request ID: 101
2025-01-07 17:45:12.906 | Removing historical data download ID 101.
2025-01-07 17:45:12.906 | No download requests in the queue to start downloads for.
2025-01-07 17:45:13.035 | SIH5.COMEX [CBV][M] Daily #6 | Reloading chart.
2025-01-07 17:45:13.035 | SIH5.COMEX [CBV][M] Daily #6 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2025-01-07 17:45:13.035 | SIH5.COMEX [CBV][M] Daily #6 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2025-01-07 17:45:13.673 | SIH5.COMEX [CBV][M] Monthly #4 | Reloading chart.
2025-01-07 17:45:13.673 | SIH5.COMEX [CBV][M] Monthly #4 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2025-01-07 17:45:13.673 | SIH5.COMEX [CBV][M] Monthly #4 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2025-01-07 17:45:14.331 | SIH5.COMEX [CBV][M] Daily #6 | Chart data loading complete.
2025-01-07 17:45:14.436 | SIH5.COMEX [CBV][M] Monthly #4 | Chart data loading complete.
2025-01-07 17:45:14.563 | SIH5.COMEX [CBV][M] Weekly #5 | Reloading chart.
2025-01-07 17:45:14.563 | SIH5.COMEX [CBV][M] Weekly #5 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2025-01-07 17:45:14.563 | SIH5.COMEX [CBV][M] Weekly #5 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2025-01-07 17:45:15.277 | SIH5.COMEX [CBV][M] Weekly #5 | Chart data loading complete.
2025-01-07 18:00:03.187 | Opened cached Intraday file: C:\SierraChart - TopStep\Data\SPX500.scid. Thread ID: 16528
2025-01-07 18:00:30.307 | Added historical Daily data request for NQH5.CME to the queue.
2025-01-07 18:00:30.307 | Triggering next historical data download in queue.
2025-01-07 18:00:30.308 | HD Request # 102 | Downloading Historical Daily chart data for NQH5.CME. Starting date: 2025-01-03. Service: rithmic.trading
2025-01-07 18:00:30.308 | Added historical Daily data request for ESH5.CME to the queue.
2025-01-07 18:00:30.308 | Triggering next historical data download in queue.
2025-01-07 18:00:31.447 | HD Request # 102 | Requesting historical Daily data for NQH25 starting at 2025-01-02. SC External HD service.
2025-01-07 18:00:31.560 | Added historical Daily data request for 6AH5.CME to the queue.
2025-01-07 18:00:31.560 | Triggering next historical data download in queue.
2025-01-07 18:00:32.209 | Added historical Daily data request for GCG5.COMEX to the queue.
2025-01-07 18:00:32.209 | Triggering next historical data download in queue.
2025-01-07 18:00:32.421 | HD Request # 102 | Receiving historical Daily data for NQH5.CME starting at 2025-01-03.
2025-01-07 18:00:32.422 | HD Request # 102 | Writing historical Daily data to the file NQH5.CME.dly.
2025-01-07 18:00:32.423 | HD Request # 102 | Bytes received: 254
2025-01-07 18:00:32.423 | HD Request # 102 | Received 4 Daily data records from 2025-01-03 00:00:00 to 2025-01-07 00:00:00 (5.0 days) and wrote 3 records for NQH5.CME
2025-01-07 18:00:32.423 | HD Request # 102 | Completion time: 2s.
2025-01-07 18:00:32.423 | HD Request # 102 | Daily data download complete for NQH5.CME. Unique request ID: 102
2025-01-07 18:00:32.423 | Removing historical data download ID 102.
2025-01-07 18:00:32.423 | Triggering next historical data download in queue.
2025-01-07 18:00:32.424 | HD Request # 103 | Downloading Historical Daily chart data for ESH5.CME. Starting date: 2025-01-03. Service: rithmic.trading
2025-01-07 18:00:32.501 | NQH5.CME [CBV][M] Weekly #5 | Reloading chart.
2025-01-07 18:00:32.501 | NQH5.CME [CBV][M] Weekly #5 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2025-01-07 18:00:32.501 | NQH5.CME [CBV][M] Weekly #5 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2025-01-07 18:00:32.794 | Added historical Daily data request for SIH5.COMEX to the queue.
2025-01-07 18:00:32.794 | Triggering next historical data download in queue.
2025-01-07 18:00:32.840 | NQH5.CME [CBV][M] Weekly #5 | Chart data loading complete.
2025-01-07 18:00:33.287 | NQH5.CME [CBV][M] Daily #6 | Reloading chart.
2025-01-07 18:00:33.287 | NQH5.CME [CBV][M] Daily #6 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2025-01-07 18:00:33.287 | NQH5.CME [CBV][M] Daily #6 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2025-01-07 18:00:33.640 | HD Request # 103 | Requesting historical Daily data for ESH25 starting at 2025-01-02. SC External HD service.
2025-01-07 18:00:33.643 | NQH5.CME [CBV][M] Daily #6 | Chart data loading complete.
2025-01-07 18:00:33.808 | NQH5.CME [CBV][M] Monthly #4 | Reloading chart.
2025-01-07 18:00:33.808 | NQH5.CME [CBV][M] Monthly #4 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2025-01-07 18:00:33.808 | NQH5.CME [CBV][M] Monthly #4 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2025-01-07 18:00:34.288 | NQH5.CME [CBV][M] Monthly #4 | Chart data loading complete.
2025-01-07 18:00:34.904 | HD Request # 103 | Receiving historical Daily data for ESH5.CME starting at 2025-01-03.
2025-01-07 18:00:34.905 | HD Request # 103 | Writing historical Daily data to the file ESH5.CME.dly.
2025-01-07 18:00:34.906 | HD Request # 103 | Bytes received: 246
2025-01-07 18:00:34.906 | HD Request # 103 | Received 4 Daily data records from 2025-01-03 00:00:00 to 2025-01-07 00:00:00 (5.0 days) and wrote 3 records for ESH5.CME
2025-01-07 18:00:34.906 | HD Request # 103 | Completion time: 2s.
2025-01-07 18:00:34.906 | HD Request # 103 | Daily data download complete for ESH5.CME. Unique request ID: 103
2025-01-07 18:00:34.906 | Removing historical data download ID 103.
2025-01-07 18:00:34.907 | Triggering next historical data download in queue.
2025-01-07 18:00:34.907 | HD Request # 104 | Downloading Historical Daily chart data for 6AH5.CME. Starting date: 2025-01-03. Service: rithmic.trading
2025-01-07 18:00:35.109 | ESH5.CME [CBV][M] Daily #6 | Reloading chart.
2025-01-07 18:00:35.109 | ESH5.CME [CBV][M] Daily #6 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2025-01-07 18:00:35.109 | ESH5.CME [CBV][M] Daily #6 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2025-01-07 18:00:35.441 | ESH5.CME [CBV][M] Weekly #5 | Reloading chart.
2025-01-07 18:00:35.441 | ESH5.CME [CBV][M] Weekly #5 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2025-01-07 18:00:35.441 | ESH5.CME [CBV][M] Weekly #5 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2025-01-07 18:00:35.782 | ESH5.CME [CBV][M] Daily #6 | Chart data loading complete.
2025-01-07 18:00:35.783 | ESH5.CME [CBV][M] Monthly #4 | Reloading chart.
2025-01-07 18:00:35.783 | ESH5.CME [CBV][M] Monthly #4 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2025-01-07 18:00:35.783 | ESH5.CME [CBV][M] Monthly #4 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2025-01-07 18:00:36.124 | ESH5.CME [CBV][M] Weekly #5 | Chart data loading complete.
2025-01-07 18:00:36.315 | ESH5.CME [CBV][M] Monthly #4 | Chart data loading complete.
2025-01-07 18:00:36.315 | HD Request # 104 | Requesting historical Daily data for A6H25 starting at 2025-01-02. SC External HD service.
2025-01-07 18:00:37.264 | HD Request # 104 | Receiving historical Daily data for 6AH5.CME starting at 2025-01-03.
2025-01-07 18:00:37.264 | HD Request # 104 | Writing historical Daily data to the file 6AH5.CME.dly.
2025-01-07 18:00:37.268 | HD Request # 104 | Bytes received: 238
2025-01-07 18:00:37.268 | HD Request # 104 | Received 4 Daily data records from 2025-01-03 00:00:00 to 2025-01-07 00:00:00 (5.0 days) and wrote 3 records for 6AH5.CME
2025-01-07 18:00:37.268 | HD Request # 104 | Completion time: 3s.
2025-01-07 18:00:37.268 | HD Request # 104 | Daily data download complete for 6AH5.CME. Unique request ID: 104
2025-01-07 18:00:37.268 | Removing historical data download ID 104.
2025-01-07 18:00:37.268 | Triggering next historical data download in queue.
2025-01-07 18:00:37.269 | HD Request # 105 | Downloading Historical Daily chart data for GCG5.COMEX. Starting date: 2025-01-03. Service: rithmic.trading
2025-01-07 18:00:37.379 | 6AH5.CME [CBV][M] Monthly #4 | Reloading chart.
2025-01-07 18:00:37.380 | 6AH5.CME [CBV][M] Monthly #4 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2025-01-07 18:00:37.380 | 6AH5.CME [CBV][M] Monthly #4 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2025-01-07 18:00:38.224 | 6AH5.CME [CBV][M] Monthly #4 | Chart data loading complete.
2025-01-07 18:00:38.572 | 6AH5.CME [CBV][M] Daily #6 | Reloading chart.
2025-01-07 18:00:38.572 | 6AH5.CME [CBV][M] Daily #6 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2025-01-07 18:00:38.572 | 6AH5.CME [CBV][M] Daily #6 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2025-01-07 18:00:39.264 | HD Request # 105 | Requesting historical Daily data for GCG25 starting at 2025-01-02. SC External HD service.
2025-01-07 18:00:39.374 | 6AH5.CME [CBV][M] Daily #6 | Chart data loading complete.
2025-01-07 18:00:39.481 | 6AH5.CME [CBV][M] Weekly #5 | Reloading chart.
2025-01-07 18:00:39.481 | 6AH5.CME [CBV][M] Weekly #5 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2025-01-07 18:00:39.481 | 6AH5.CME [CBV][M] Weekly #5 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2025-01-07 18:00:40.176 | HD Request # 105 | Receiving historical Daily data for GCG5.COMEX starting at 2025-01-03.
2025-01-07 18:00:40.176 | HD Request # 105 | Writing historical Daily data to the file GCG5.COMEX.dly.
2025-01-07 18:00:40.178 | HD Request # 105 | Bytes received: 230
2025-01-07 18:00:40.178 | HD Request # 105 | Received 4 Daily data records from 2025-01-03 00:00:00 to 2025-01-07 00:00:00 (5.0 days) and wrote 3 records for GCG5.COMEX
2025-01-07 18:00:40.178 | HD Request # 105 | Completion time: 3s.
2025-01-07 18:00:40.178 | HD Request # 105 | Daily data download complete for GCG5.COMEX. Unique request ID: 105
2025-01-07 18:00:40.178 | Removing historical data download ID 105.
2025-01-07 18:00:40.178 | Triggering next historical data download in queue.
2025-01-07 18:00:40.179 | HD Request # 106 | Downloading Historical Daily chart data for SIH5.COMEX. Starting date: 2025-01-03. Service: rithmic.trading
2025-01-07 18:00:40.180 | GCG5.COMEX [CBV][M] Monthly #4 | Reloading chart.
2025-01-07 18:00:40.180 | GCG5.COMEX [CBV][M] Monthly #4 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2025-01-07 18:00:40.180 | GCG5.COMEX [CBV][M] Monthly #4 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2025-01-07 18:00:40.848 | 6AH5.CME [CBV][M] Weekly #5 | Chart data loading complete.
2025-01-07 18:00:40.849 | GCG5.COMEX [CBV][M] Daily #6 | Reloading chart.
2025-01-07 18:00:40.849 | GCG5.COMEX [CBV][M] Daily #6 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2025-01-07 18:00:40.849 | GCG5.COMEX [CBV][M] Daily #6 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2025-01-07 18:00:41.526 | GCG5.COMEX [CBV][M] Monthly #4 | Chart data loading complete.
2025-01-07 18:00:41.714 | GCG5.COMEX [CBV][M] Daily #6 | Chart data loading complete.
2025-01-07 18:00:41.714 | HD Request # 106 | Requesting historical Daily data for SIH25 starting at 2025-01-02. SC External HD service.
2025-01-07 18:00:42.545 | GCG5.COMEX [CBV][M] Weekly #5 | Reloading chart.
2025-01-07 18:00:42.545 | GCG5.COMEX [CBV][M] Weekly #5 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2025-01-07 18:00:42.545 | GCG5.COMEX [CBV][M] Weekly #5 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2025-01-07 18:00:43.194 | HD Request # 106 | Receiving historical Daily data for SIH5.COMEX starting at 2025-01-03.
2025-01-07 18:00:43.194 | HD Request # 106 | Writing historical Daily data to the file SIH5.COMEX.dly.
2025-01-07 18:00:43.196 | HD Request # 106 | Bytes received: 224
2025-01-07 18:00:43.196 | HD Request # 106 | Received 4 Daily data records from 2025-01-03 00:00:00 to 2025-01-07 00:00:00 (5.0 days) and wrote 3 records for SIH5.COMEX
2025-01-07 18:00:43.196 | HD Request # 106 | Completion time: 3s.
2025-01-07 18:00:43.196 | HD Request # 106 | Daily data download complete for SIH5.COMEX. Unique request ID: 106
2025-01-07 18:00:43.196 | Removing historical data download ID 106.
2025-01-07 18:00:43.196 | No download requests in the queue to start downloads for.
2025-01-07 18:00:43.410 | GCG5.COMEX [CBV][M] Weekly #5 | Chart data loading complete.
2025-01-07 18:00:43.526 | SIH5.COMEX [CBV][M] Daily #6 | Reloading chart.
2025-01-07 18:00:43.526 | SIH5.COMEX [CBV][M] Daily #6 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2025-01-07 18:00:43.526 | SIH5.COMEX [CBV][M] Daily #6 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2025-01-07 18:00:44.126 | SIH5.COMEX [CBV][M] Weekly #5 | Reloading chart.
2025-01-07 18:00:44.126 | SIH5.COMEX [CBV][M] Weekly #5 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2025-01-07 18:00:44.126 | SIH5.COMEX [CBV][M] Weekly #5 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2025-01-07 18:00:44.741 | SIH5.COMEX [CBV][M] Daily #6 | Chart data loading complete.
2025-01-07 18:00:44.886 | SIH5.COMEX [CBV][M] Weekly #5 | Chart data loading complete.
2025-01-07 18:00:45.248 | SIH5.COMEX [CBV][M] Monthly #4 | Reloading chart.
2025-01-07 18:00:45.248 | SIH5.COMEX [CBV][M] Monthly #4 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2025-01-07 18:00:45.248 | SIH5.COMEX [CBV][M] Monthly #4 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2025-01-07 18:00:45.946 | SIH5.COMEX [CBV][M] Monthly #4 | Chart data loading complete.
2025-01-07 18:51:28.700 | File >> Reconnect selected.
2025-01-07 18:51:28.916 | Rithmic Direct - DTC | Waiting for socket receive thread to end
2025-01-07 18:51:28.916 | DTC Client socket (1) | CloseSocket call.
2025-01-07 18:51:28.916 | DTC Client socket (1) | Max send buffers used during socket life: 6
2025-01-07 18:51:28.916 | DTC Client socket (1) | Max send buffer size during socket life: 999
2025-01-07 18:51:28.916 | DTC Client socket (1) | Shutdown started. Waiting for graceful close.
2025-01-07 18:51:28.917 | Denali Data Feed | Waiting for socket receive thread to end
2025-01-07 18:51:28.917 | DTC Client socket (2) | CloseSocket call.
2025-01-07 18:51:28.917 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-07 18:51:28.917 | Denali Data Feed | Disconnected from the server.
2025-01-07 18:51:28.917 | SC Data with Depth | Waiting for socket receive thread to end
2025-01-07 18:51:28.917 | DTC Client socket (3) | CloseSocket call.
2025-01-07 18:51:28.917 | DTC Client socket (3) | Shutdown started. Waiting for graceful close.
2025-01-07 18:51:28.917 | SC Data with Depth | Disconnected from the server.
2025-01-07 18:51:28.917 | Rithmic Direct - DTC | Disconnected.
2025-01-07 18:51:28.917 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2025-01-07 18:51:29.151 | DTC Client socket (3) | Socket gracefully closed by remote side.
2025-01-07 18:51:29.151 | DTC Client socket (3) | Closed.
2025-01-07 18:51:29.207 | DTC Client socket (1) | Socket gracefully closed by remote side.
2025-01-07 18:51:29.207 | DTC Client socket (1) | Closed.
2025-01-07 18:51:29.330 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-07 18:51:29.330 | DTC Client socket (2) | Closed.
2025-01-07 18:51:32.916 |
2025-01-07 18:51:32.916 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated
2025-01-07 18:51:32.916 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50508
2025-01-07 18:51:32.916 | Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50508
2025-01-07 18:51:33.227 | DTC Client socket (1) | Creating socket. Using TLS 1.2.
2025-01-07 18:51:33.227 | DTC Client socket (1) | New receive buffer size: 0
2025-01-07 18:51:33.227 | DTC Client socket (1) | Connecting to IP: 216.57.156.163.
2025-01-07 18:51:33.522 | Rithmic Direct - DTC | Network connection to server complete.
2025-01-07 18:51:33.522 | Rithmic Direct - DTC | Starting socket receive thread.
2025-01-07 18:51:33.522 | Rithmic Direct - DTC | Setting DTC encoding to Binary
2025-01-07 18:51:33.522 | Rithmic Direct - DTC | Sending logon request message.
2025-01-07 18:51:34.403 | Rithmic Direct - DTC | Received logon response.
2025-01-07 18:51:34.403 | Rithmic Direct - DTC | Server Name: .
2025-01-07 18:51:34.403 | Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8
2025-01-07 18:51:34.403 | Rithmic Direct - DTC | Successfully connected.
2025-01-07 18:51:34.403 | Rithmic Direct - DTC | Trading is supported.
2025-01-07 18:51:34.403 | Rithmic Direct - DTC | Order cancel and replace is supported.
2025-01-07 18:51:34.403 | Rithmic Direct - DTC | OCO Orders supported.
2025-01-07 18:51:34.403 | Rithmic Direct - DTC | Symbol and Exchange Delimiter: .
2025-01-07 18:51:34.403 | Rithmic Direct - DTC | MarketDepthIsSupported: 0
2025-01-07 18:51:34.403 | Rithmic Direct - DTC | Connected to server complete.
2025-01-07 18:51:34.405 | No download requests in the queue to start downloads for. | Number times message added: 3
2025-01-07 18:51:34.405 | Subscribing to symbol for symbol alert. NQZ4.CME
2025-01-07 18:51:34.405 | Mapping NQZ4.CME to NQZ24. Service code: cme
2025-01-07 18:51:34.405 | Using symbol data fast lookup vector
2025-01-07 18:51:34.405 | Denali Data Feed | Starting real-time market data updates for: NQZ4.CME (NQZ24). ID: 1 Service code: cme
2025-01-07 18:51:34.405 | Denali Data Feed | Connecting to the server ds28-2.sierracharts.com. Port 443
2025-01-07 18:51:34.405 | Denali Data Feed | Requesting security definition data for: NQZ4.CME (NQZ24). ID: 1
2025-01-07 18:51:34.405 | Subscribing to symbol for symbol alert. GCZ4.COMEX
2025-01-07 18:51:34.405 | Mapping GCZ4.COMEX to GCZ24. Service code: comex
2025-01-07 18:51:34.405 | Denali Data Feed | Starting real-time market data updates for: GCZ4.COMEX (GCZ24). ID: 2 Service code: comex
2025-01-07 18:51:34.405 | Denali Data Feed | Requesting security definition data for: GCZ4.COMEX (GCZ24). ID: 2
2025-01-07 18:51:34.517 | DTC Client socket (2) | Creating socket.
2025-01-07 18:51:34.517 | DTC Client socket (2) | New receive buffer size: 0
2025-01-07 18:51:34.517 | DTC Client socket (2) | Connecting to IP: 67.214.125.6.
2025-01-07 18:51:34.617 | Mapping SIH5.COMEX to SIH25. Service code: comex
2025-01-07 18:51:34.617 | Denali Data Feed | Starting real-time market data updates for: SIH5.COMEX (SIH25). ID: 3 Service code: comex
2025-01-07 18:51:34.617 | Denali Data Feed | Requesting security definition data for: SIH5.COMEX (SIH25). ID: 3
2025-01-07 18:51:34.618 | Mapping GCG5.COMEX to GCG25. Service code: comex
2025-01-07 18:51:34.618 | Denali Data Feed | Starting real-time market data updates for: GCG5.COMEX (GCG25). ID: 4 Service code: comex
2025-01-07 18:51:34.618 | Denali Data Feed | Requesting security definition data for: GCG5.COMEX (GCG25). ID: 4
2025-01-07 18:51:34.618 | Added historical Intraday data request for GCG5.COMEX to the queue.
2025-01-07 18:51:34.618 | Intraday data recording state for symbol GCG5.COMEX is set to download 'Pending'.
2025-01-07 18:51:34.618 | Triggering next historical data download in queue.
2025-01-07 18:51:34.651 | Delaying start of download for GCG5.COMEX.
2025-01-07 18:51:34.726 | SC Data with Depth | Starting real-time market data updates for: USDX. ID: 5 Service code: fxstatscalc
2025-01-07 18:51:34.726 | SC Data with Depth | Connecting to the server ds4.sierracharts.com. Port 443
2025-01-07 18:51:34.726 | SC Data with Depth | Requesting security definition data for: USDX. ID: 5
2025-01-07 18:51:34.727 | Mapping ESH5.CME to ESH25. Service code: cme
2025-01-07 18:51:34.727 | Denali Data Feed | Starting real-time market data updates for: ESH5.CME (ESH25). ID: 6 Service code: cme
2025-01-07 18:51:34.727 | Denali Data Feed | Requesting security definition data for: ESH5.CME (ESH25). ID: 6
2025-01-07 18:51:34.727 | Added historical Intraday data request for ESH5.CME to the queue.
2025-01-07 18:51:34.727 | Intraday data recording state for symbol ESH5.CME is set to download 'Pending'.
2025-01-07 18:51:34.727 | Triggering next historical data download in queue.
2025-01-07 18:51:34.791 | Denali Data Feed | Network connection to server complete.
2025-01-07 18:51:34.791 | Denali Data Feed | Starting socket receive thread.
2025-01-07 18:51:34.791 | Denali Data Feed | Sending encoding request to server: Binary VLS. Compression: high
2025-01-07 18:51:34.843 | DTC Client socket (3) | Creating socket.
2025-01-07 18:51:34.843 | DTC Client socket (3) | New receive buffer size: 0
2025-01-07 18:51:34.843 | DTC Client socket (3) | Connecting to IP: 67.214.125.7.
2025-01-07 18:51:34.883 | Mapping MNQH5.CME to MNQH25. Service code: cme
2025-01-07 18:51:34.883 | Denali Data Feed | Starting real-time market data updates for: MNQH5.CME (MNQH25). ID: 7 Service code: cme
2025-01-07 18:51:34.883 | Denali Data Feed | Requesting security definition data for: MNQH5.CME (MNQH25). ID: 7
2025-01-07 18:51:34.883 | Added historical Intraday data request for MNQH5.CME to the queue.
2025-01-07 18:51:34.883 | Intraday data recording state for symbol MNQH5.CME is set to download 'Pending'.
2025-01-07 18:51:34.883 | Triggering next historical data download in queue.
2025-01-07 18:51:34.885 | Mapping MGCG5.COMEX to MGCG25. Service code: comex
2025-01-07 18:51:34.885 | Denali Data Feed | Starting real-time market data updates for: MGCG5.COMEX (MGCG25). ID: 8 Service code: comex
2025-01-07 18:51:34.885 | Denali Data Feed | Requesting security definition data for: MGCG5.COMEX (MGCG25). ID: 8
2025-01-07 18:51:34.885 | Added historical Intraday data request for MGCG5.COMEX to the queue.
2025-01-07 18:51:34.885 | Intraday data recording state for symbol MGCG5.COMEX is set to download 'Pending'.
2025-01-07 18:51:34.885 | Triggering next historical data download in queue.
2025-01-07 18:51:34.886 | Mapping ESU4.CME to ESU24. Service code: cme
2025-01-07 18:51:34.886 | Denali Data Feed | Starting real-time market data updates for: ESU4.CME (ESU24). ID: 9 Service code: cme
2025-01-07 18:51:34.886 | Denali Data Feed | Requesting security definition data for: ESU4.CME (ESU24). ID: 9
2025-01-07 18:51:34.886 | Added historical Intraday data request for ESU4.CME to the queue.
2025-01-07 18:51:34.886 | Intraday data recording state for symbol ESU4.CME is set to download 'Pending'.
2025-01-07 18:51:34.886 | Triggering next historical data download in queue.
2025-01-07 18:51:34.886 | Added historical Intraday data request for SIH5.COMEX to the queue.
2025-01-07 18:51:34.886 | Intraday data recording state for symbol SIH5.COMEX is set to download 'Pending'.
2025-01-07 18:51:34.939 | Mapping NQH5.CME to NQH25. Service code: cme
2025-01-07 18:51:34.939 | Denali Data Feed | Starting real-time market data updates for: NQH5.CME (NQH25). ID: 10 Service code: cme
2025-01-07 18:51:34.939 | Denali Data Feed | Requesting security definition data for: NQH5.CME (NQH25). ID: 10
2025-01-07 18:51:34.939 | Added historical Intraday data request for NQH5.CME to the queue.
2025-01-07 18:51:34.939 | Intraday data recording state for symbol NQH5.CME is set to download 'Pending'.
2025-01-07 18:51:34.939 | Triggering next historical data download in queue.
2025-01-07 18:51:34.958 | Mapping 6AH5.CME to 6AH25. Service code: cme
2025-01-07 18:51:34.958 | Denali Data Feed | Starting real-time market data updates for: 6AH5.CME (6AH25). ID: 11 Service code: cme
2025-01-07 18:51:34.958 | Denali Data Feed | Requesting security definition data for: 6AH5.CME (6AH25). ID: 11
2025-01-07 18:51:34.959 | Added historical Intraday data request for 6AH5.CME to the queue.
2025-01-07 18:51:34.959 | Intraday data recording state for symbol 6AH5.CME is set to download 'Pending'.
2025-01-07 18:51:34.959 | Triggering next historical data download in queue.
2025-01-07 18:51:35.051 | Denali Data Feed | Setting DTC encoding to Binary VLS
2025-01-07 18:51:35.051 | Denali Data Feed | Sending logon request message.
2025-01-07 18:51:35.126 | SC Data with Depth | Network connection to server complete.
2025-01-07 18:51:35.126 | SC Data with Depth | Starting socket receive thread.
2025-01-07 18:51:35.126 | SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: high
2025-01-07 18:51:35.187 | Mapping MESH5.CME to MESH25. Service code: cme
2025-01-07 18:51:35.187 | Denali Data Feed | Starting real-time market data updates for: MESH5.CME (MESH25). ID: 12 Service code: cme
2025-01-07 18:51:35.187 | Denali Data Feed | Requesting security definition data for: MESH5.CME (MESH25). ID: 12
2025-01-07 18:51:35.187 | Added historical Intraday data request for MESH5.CME to the queue.
2025-01-07 18:51:35.187 | Intraday data recording state for symbol MESH5.CME is set to download 'Pending'.
2025-01-07 18:51:35.187 | Triggering next historical data download in queue.
2025-01-07 18:51:35.388 | SC Data with Depth | Setting DTC encoding to Binary VLS
2025-01-07 18:51:35.388 | SC Data with Depth | Sending logon request message.
2025-01-07 18:51:35.388 | Mapping M6AH5.CME to M6AH25. Service code: cme
2025-01-07 18:51:35.388 | Denali Data Feed | Starting real-time market data updates for: M6AH5.CME (M6AH25). ID: 13 Service code: cme
2025-01-07 18:51:35.388 | Denali Data Feed | Requesting security definition data for: M6AH5.CME (M6AH25). ID: 13
2025-01-07 18:51:35.388 | Added historical Intraday data request for M6AH5.CME to the queue.
2025-01-07 18:51:35.388 | Intraday data recording state for symbol M6AH5.CME is set to download 'Pending'.
2025-01-07 18:51:35.388 | Triggering next historical data download in queue.
2025-01-07 18:51:35.410 | Mapping SILH5.COMEX to SILH25. Service code: comex
2025-01-07 18:51:35.410 | Denali Data Feed | Starting real-time market data updates for: SILH5.COMEX (SILH25). ID: 14 Service code: comex
2025-01-07 18:51:35.410 | Denali Data Feed | Requesting security definition data for: SILH5.COMEX (SILH25). ID: 14
2025-01-07 18:51:35.410 | Added historical Intraday data request for SILH5.COMEX to the queue.
2025-01-07 18:51:35.410 | Intraday data recording state for symbol SILH5.COMEX is set to download 'Pending'.
2025-01-07 18:51:35.410 | Triggering next historical data download in queue.
2025-01-07 18:51:35.412 | Added historical Intraday data request for USDX to the queue.
2025-01-07 18:51:35.412 | Intraday data recording state for symbol USDX is set to download 'Pending'.
2025-01-07 18:51:35.412 | Triggering next historical data download in queue.
2025-01-07 18:51:35.454 | Using Bid/Ask average for last trade price for SPX500
2025-01-07 18:51:35.454 | SC Data with Depth | Starting real-time market data updates for: SPX500. ID: 15 Service code: fxcm
2025-01-07 18:51:35.454 | SC Data with Depth | Requesting security definition data for: SPX500. ID: 15
2025-01-07 18:51:35.454 | Added historical Intraday data request for SPX500 to the queue.
2025-01-07 18:51:35.454 | Intraday data recording state for symbol SPX500 is set to download 'Pending'.
2025-01-07 18:51:35.454 | Triggering next historical data download in queue.
2025-01-07 18:51:35.791 | Denali Data Feed | Received logon response.
2025-01-07 18:51:35.791 | Denali Data Feed | Server Name: SC Realtime Server.
2025-01-07 18:51:35.791 | Denali Data Feed | Server protocol version: 8. Client protocol version: 8
2025-01-07 18:51:35.791 | Denali Data Feed | Successfully connected.
2025-01-07 18:51:35.791 | Denali Data Feed | Trading is not supported.
2025-01-07 18:51:35.791 | Denali Data Feed | MarketDepthIsSupported: 1
2025-01-07 18:51:35.791 | Denali Data Feed | Restarting real-time data updates for symbol: 6AH5.CME -> 6AH25
2025-01-07 18:51:35.791 | Denali Data Feed | Restarting real-time data updates for symbol: ESH5.CME -> ESH25
2025-01-07 18:51:35.791 | Denali Data Feed | Restarting real-time data updates for symbol: ESU4.CME -> ESU24
2025-01-07 18:51:35.791 | Denali Data Feed | Restarting real-time data updates for symbol: GCG5.COMEX -> GCG25
2025-01-07 18:51:35.791 | Denali Data Feed | Restarting real-time data updates for symbol: GCZ4.COMEX -> GCZ24
2025-01-07 18:51:35.791 | Denali Data Feed | Restarting real-time data updates for symbol: M6AH5.CME -> M6AH25
2025-01-07 18:51:35.791 | Denali Data Feed | Restarting real-time data updates for symbol: MESH5.CME -> MESH25
2025-01-07 18:51:35.791 | Denali Data Feed | Restarting real-time data updates for symbol: MGCG5.COMEX -> MGCG25
2025-01-07 18:51:35.791 | Denali Data Feed | Restarting real-time data updates for symbol: MNQH5.CME -> MNQH25
2025-01-07 18:51:35.791 | Denali Data Feed | Restarting real-time data updates for symbol: NQH5.CME -> NQH25
2025-01-07 18:51:35.791 | Denali Data Feed | Restarting real-time data updates for symbol: NQZ4.CME -> NQZ24
2025-01-07 18:51:35.791 | Denali Data Feed | Restarting real-time data updates for symbol: SIH5.COMEX -> SIH25
2025-01-07 18:51:35.791 | Denali Data Feed | Restarting real-time data updates for symbol: SILH5.COMEX -> SILH25
2025-01-07 18:51:36.143 | SC Data with Depth | Received logon response.
2025-01-07 18:51:36.143 | SC Data with Depth | Server Name: SC Realtime Server.
2025-01-07 18:51:36.143 | SC Data with Depth | Server protocol version: 8. Client protocol version: 8
2025-01-07 18:51:36.143 | SC Data with Depth | Successfully connected.
2025-01-07 18:51:36.143 | SC Data with Depth | Trading is not supported.
2025-01-07 18:51:36.143 | SC Data with Depth | MarketDepthIsSupported: 1
2025-01-07 18:51:36.143 | SC Data with Depth | Restarting real-time data updates for symbol: SPX500
2025-01-07 18:51:36.143 | SC Data with Depth | Restarting real-time data updates for symbol: USDX
2025-01-07 18:51:36.589 | Denali Data Feed | Setting external service identifier for symbol 6AH5.CME to 52126
2025-01-07 18:51:36.589 | Denali Data Feed | Received security definition for symbol 6AH5.CME
2025-01-07 18:51:36.589 | Denali Data Feed | Setting external service identifier for symbol ESH5.CME to 5002
2025-01-07 18:51:36.589 | Denali Data Feed | Received security definition for symbol ESH5.CME
2025-01-07 18:51:36.589 | Denali Data Feed | Real-time data for symbol ESU4.CME is currently unavailable.
2025-01-07 18:51:36.589 | Denali Data Feed | Received security definition for symbol ESU4.CME
2025-01-07 18:51:36.589 | Denali Data Feed | Setting external service identifier for symbol GCG5.COMEX to 1551
2025-01-07 18:51:36.589 | Denali Data Feed | Received security definition for symbol GCG5.COMEX
2025-01-07 18:51:36.589 | Denali Data Feed | Real-time data for symbol GCZ4.COMEX is currently unavailable.
2025-01-07 18:51:36.589 | Denali Data Feed | Received security definition for symbol GCZ4.COMEX
2025-01-07 18:51:36.589 | Denali Data Feed | Setting external service identifier for symbol M6AH5.CME to 42185124
2025-01-07 18:51:36.589 | Denali Data Feed | Received security definition for symbol M6AH5.CME
2025-01-07 18:51:36.589 | Denali Data Feed | Setting external service identifier for symbol MESH5.CME to 42005347
2025-01-07 18:51:36.589 | Denali Data Feed | Received security definition for symbol MESH5.CME
2025-01-07 18:51:36.589 | Denali Data Feed | Setting external service identifier for symbol MGCG5.COMEX to 69
2025-01-07 18:51:36.589 | Denali Data Feed | Received security definition for symbol MGCG5.COMEX
2025-01-07 18:51:36.589 | Denali Data Feed | Setting external service identifier for symbol MNQH5.CME to 42003617
2025-01-07 18:51:36.589 | Denali Data Feed | Received security definition for symbol MNQH5.CME
2025-01-07 18:51:36.589 | Denali Data Feed | Setting external service identifier for symbol NQH5.CME to 42288528
2025-01-07 18:51:36.589 | Denali Data Feed | Received security definition for symbol NQH5.CME
2025-01-07 18:51:36.589 | Denali Data Feed | Real-time data for symbol NQZ4.CME is currently unavailable.
2025-01-07 18:51:36.589 | Denali Data Feed | Received security definition for symbol NQZ4.CME
2025-01-07 18:51:36.589 | Denali Data Feed | Setting external service identifier for symbol SIH5.COMEX to 5556
2025-01-07 18:51:36.589 | Denali Data Feed | Received security definition for symbol SIH5.COMEX
2025-01-07 18:51:36.589 | Denali Data Feed | Setting external service identifier for symbol SILH5.COMEX to 42007667
2025-01-07 18:51:36.589 | Denali Data Feed | Received security definition for symbol SILH5.COMEX
2025-01-07 18:51:37.047 | SC Data with Depth | Setting external service identifier for symbol SPX500 to 55
2025-01-07 18:51:37.047 | SC Data with Depth | Received security definition for symbol SPX500
2025-01-07 18:51:37.047 | SC Data with Depth | Setting external service identifier for symbol USDX to 1
2025-01-07 18:51:37.047 | SC Data with Depth | Received security definition for symbol USDX
2025-01-07 18:51:39.613 | Requesting market depth updates for: 6AH5.CME if supported. NumLevels=50
2025-01-07 18:51:39.613 | Requesting market depth updates for: ESH5.CME if supported. NumLevels=50
2025-01-07 18:51:39.613 | Requesting market depth updates for: ESU4.CME if supported. NumLevels=50
2025-01-07 18:51:39.613 | Requesting market depth updates for: GCG5.COMEX if supported. NumLevels=50
2025-01-07 18:51:39.613 | Requesting market depth updates for: MESH5.CME if supported. NumLevels=50
2025-01-07 18:51:39.613 | Requesting market depth updates for: MGCG5.COMEX if supported. NumLevels=50
2025-01-07 18:51:39.613 | Requesting market depth updates for: MNQH5.CME if supported. NumLevels=50
2025-01-07 18:51:39.613 | Requesting market depth updates for: NQH5.CME if supported. NumLevels=50
2025-01-07 18:51:39.613 | Requesting market depth updates for: SIH5.COMEX if supported. NumLevels=50
2025-01-07 18:51:40.229 | Denali Data Feed | Clearing market depth for 6AH5.CME
2025-01-07 18:51:40.229 | Denali Data Feed | Clearing market depth for ESH5.CME
2025-01-07 18:51:40.229 | Denali Data Feed | Clearing market depth for ESU4.CME
2025-01-07 18:51:40.229 | Denali Data Feed | Clearing market depth for GCG5.COMEX
2025-01-07 18:51:40.229 | Denali Data Feed | Clearing market depth for MESH5.CME
2025-01-07 18:51:40.229 | Denali Data Feed | Clearing market depth for MGCG5.COMEX
2025-01-07 18:51:40.229 | Denali Data Feed | Clearing market depth for MNQH5.CME
2025-01-07 18:51:40.229 | Denali Data Feed | Clearing market depth for NQH5.CME
2025-01-07 18:51:40.229 | Denali Data Feed | Clearing market depth for SIH5.COMEX
2025-01-07 18:51:41.919 | HD Request # 107 | Downloading Intraday chart data for GCG5.COMEX to the file GCG5.COMEX.scid. Service: comex
2025-01-07 18:51:41.920 | HD Request # 107 | Download start date-time: 2025-01-07 18:51:25.000000. File last date-time: 2025-01-07 18:51:25.200000
2025-01-07 18:51:41.920 | HD Request # 107 | Using server: ds32.sierracharts.com port 10150
2025-01-07 18:51:42.046 | Socket (5) | Creating socket.
2025-01-07 18:51:42.046 | Socket (5) | New receive buffer size: 0
2025-01-07 18:51:42.046 | Socket (5) | Connecting to IP: 67.214.125.3.
2025-01-07 18:51:42.541 | HD Request # 107 | Setting DTC encoding to Binary VLS
2025-01-07 18:51:42.541 | HD Request # 107 | Sending historical data logon request message.
2025-01-07 18:51:42.885 | HD Request # 107 | Requesting Intraday data. Start date-time: 2025-01-07 18:51:25. Record interval: 0. Symbol: GCG25
2025-01-07 18:51:43.122 | HD Request # 107 | Decompressing data.
2025-01-07 18:51:43.356 | HD Request # 107 | Receiving Intraday data for GCG5.COMEX starting at 2025-01-07 18:51:25.200000
2025-01-07 18:51:43.356 | Socket (5) | CloseSocket call.
2025-01-07 18:51:43.356 | Socket (5) | Shutdown started. Waiting for graceful close.
2025-01-07 18:51:43.383 | Historical data download thread signaled to stop.
2025-01-07 18:51:43.383 | HD Request # 107 | Timestamp of first Intraday data file record written: 2025-01-07 18:51:30.293000.
2025-01-07 18:51:43.383 | HD Request # 107 | Received 8 Intraday data records from 2025-01-07 18:51:25.200000 to 2025-01-07 18:51:37.030001 (11.8 seconds. Delay: 6.4 seconds) and wrote 7 records for GCG5.COMEX
2025-01-07 18:51:43.384 | HD Request # 107 | Add time&sales data | Remembered last file record date-time: 2025-01-07 23:51:37.030001
2025-01-07 18:51:43.384 | Added 6 Time and Sales records to Intraday data file for GCG5.COMEX after download.
2025-01-07 18:51:43.384 | HD Request # 107 | Completion time: 2s.
2025-01-07 18:51:43.384 | HD Request # 107 | Intraday data download complete for GCG5.COMEX. Unique request ID: 107
2025-01-07 18:51:43.384 | Removing historical data download ID 107.
2025-01-07 18:51:43.384 | Real-time Intraday chart data file updates started for GCG5.COMEX
2025-01-07 18:51:43.384 | Intraday chart data file opened for GCG5.COMEX
2025-01-07 18:51:43.384 | HD Request # 107 | Enabling Intraday chart updating for symbol.
2025-01-07 18:51:43.384 | Triggering next historical data download in queue.
2025-01-07 18:51:43.384 | HD Request # 108 | Downloading Intraday chart data for ESH5.CME to the file ESH5.CME.scid. Service: cme
2025-01-07 18:51:43.384 | HD Request # 108 | Download start date-time: 2025-01-07 18:51:17.000000. File last date-time: 2025-01-07 18:51:17.053000
2025-01-07 18:51:43.384 | HD Request # 108 | Using server: ds32.sierracharts.com port 10149
2025-01-07 18:51:43.384 | Socket (7) | Creating socket.
2025-01-07 18:51:43.384 | Socket (7) | New receive buffer size: 0
2025-01-07 18:51:43.384 | Socket (7) | Connecting to IP: 67.214.125.3.
2025-01-07 18:51:43.599 | Socket (5) | Socket gracefully closed by remote side.
2025-01-07 18:51:43.599 | Socket (5) | Closed.
2025-01-07 18:51:43.971 | HD Request # 108 | Setting DTC encoding to Binary VLS
2025-01-07 18:51:43.971 | HD Request # 108 | Sending historical data logon request message.
2025-01-07 18:51:44.283 | HD Request # 108 | Requesting Intraday data. Start date-time: 2025-01-07 18:51:17. Record interval: 0. Symbol: ESH25
2025-01-07 18:51:44.545 | HD Request # 108 | Decompressing data.
2025-01-07 18:51:44.804 | HD Request # 108 | Receiving Intraday data for ESH5.CME starting at 2025-01-07 18:51:17.053000
2025-01-07 18:51:44.804 | Socket (7) | CloseSocket call.
2025-01-07 18:51:44.804 | Socket (7) | Shutdown started. Waiting for graceful close.
2025-01-07 18:51:44.826 | Historical data download thread signaled to stop.
2025-01-07 18:51:44.826 | HD Request # 108 | Timestamp of first Intraday data file record written: 2025-01-07 18:51:37.943000.
2025-01-07 18:51:44.826 | HD Request # 108 | Received 9 Intraday data records from 2025-01-07 18:51:17.053000 to 2025-01-07 18:51:37.944004 (20.9 seconds. Delay: 6.9 seconds) and wrote 8 records for ESH5.CME
2025-01-07 18:51:44.827 | HD Request # 108 | Add time&sales data | Remembered last file record date-time: 2025-01-07 23:51:37.944004
2025-01-07 18:51:44.827 | HD Request # 108 | Completion time: 1s.
2025-01-07 18:51:44.827 | HD Request # 108 | Intraday data download complete for ESH5.CME. Unique request ID: 108
2025-01-07 18:51:44.827 | Removing historical data download ID 108.
2025-01-07 18:51:44.827 | Real-time Intraday chart data file updates started for ESH5.CME
2025-01-07 18:51:44.827 | Intraday chart data file opened for ESH5.CME
2025-01-07 18:51:44.827 | HD Request # 108 | Enabling Intraday chart updating for symbol.
2025-01-07 18:51:44.827 | Triggering next historical data download in queue.
2025-01-07 18:51:44.827 | HD Request # 109 | Downloading Intraday chart data for MNQH5.CME to the file MNQH5.CME.scid. Service: cme
2025-01-07 18:51:44.827 | HD Request # 109 | Download start date-time: 2025-01-07 18:51:23.000000. File last date-time: 2025-01-07 18:51:23.894000
2025-01-07 18:51:44.827 | HD Request # 109 | Using server: ds32.sierracharts.com port 10150
2025-01-07 18:51:44.827 | Socket (5) | Creating socket.
2025-01-07 18:51:44.827 | Socket (5) | New receive buffer size: 0
2025-01-07 18:51:44.827 | Socket (5) | Connecting to IP: 67.214.125.3.
2025-01-07 18:51:45.067 | Socket (7) | Socket gracefully closed by remote side.
2025-01-07 18:51:45.067 | Socket (7) | Closed.
2025-01-07 18:51:45.321 | HD Request # 109 | Setting DTC encoding to Binary VLS
2025-01-07 18:51:45.321 | HD Request # 109 | Sending historical data logon request message.
2025-01-07 18:51:45.592 | HD Request # 109 | Requesting Intraday data. Start date-time: 2025-01-07 18:51:23. Record interval: 0. Symbol: MNQH25
2025-01-07 18:51:45.824 | HD Request # 109 | Decompressing data.
2025-01-07 18:51:46.057 | HD Request # 109 | Receiving Intraday data for MNQH5.CME starting at 2025-01-07 18:51:23.893000
2025-01-07 18:51:46.057 | Socket (5) | CloseSocket call.
2025-01-07 18:51:46.057 | Socket (5) | Shutdown started. Waiting for graceful close.
2025-01-07 18:51:46.179 | Historical data download thread signaled to stop.
2025-01-07 18:51:46.179 | HD Request # 109 | Timestamp of first Intraday data file record written: 2025-01-07 18:51:30.992000.
2025-01-07 18:51:46.179 | HD Request # 109 | Received 30 Intraday data records from 2025-01-07 18:51:23.893000 to 2025-01-07 18:51:42.834004 (18.9 seconds. Delay: 3.3 seconds) and wrote 28 records for MNQH5.CME
2025-01-07 18:51:46.179 | HD Request # 109 | Add time&sales data | Remembered last file record date-time: 2025-01-07 23:51:42.834004
2025-01-07 18:51:46.179 | Added 1 Time and Sales records to Intraday data file for MNQH5.CME after download.
2025-01-07 18:51:46.179 | HD Request # 109 | Completion time: 2s.
2025-01-07 18:51:46.179 | HD Request # 109 | Intraday data download complete for MNQH5.CME. Unique request ID: 109
2025-01-07 18:51:46.179 | Removing historical data download ID 109.
2025-01-07 18:51:46.179 | Real-time Intraday chart data file updates started for MNQH5.CME
2025-01-07 18:51:46.179 | Intraday chart data file opened for MNQH5.CME
2025-01-07 18:51:46.179 | HD Request # 109 | Enabling Intraday chart updating for symbol.
2025-01-07 18:51:46.179 | Triggering next historical data download in queue.
2025-01-07 18:51:46.179 | HD Request # 110 | Downloading Intraday chart data for MGCG5.COMEX to the file MGCG5.COMEX.scid. Service: comex
2025-01-07 18:51:46.179 | HD Request # 110 | Download start date-time: 2025-01-07 18:51:27.000000. File last date-time: 2025-01-07 18:51:27.285004
2025-01-07 18:51:46.179 | HD Request # 110 | Using server: ds32.sierracharts.com port 10149
2025-01-07 18:51:46.179 | Socket (6) | Creating socket.
2025-01-07 18:51:46.180 | Socket (6) | New receive buffer size: 0
2025-01-07 18:51:46.180 | Socket (6) | Connecting to IP: 67.214.125.3.
2025-01-07 18:51:46.291 | Socket (5) | Socket gracefully closed by remote side.
2025-01-07 18:51:46.291 | Socket (5) | Closed.
2025-01-07 18:51:46.738 | HD Request # 110 | Setting DTC encoding to Binary VLS
2025-01-07 18:51:46.738 | HD Request # 110 | Sending historical data logon request message.
2025-01-07 18:51:46.993 | HD Request # 110 | Requesting Intraday data. Start date-time: 2025-01-07 18:51:27. Record interval: 0. Symbol: MGCG25
2025-01-07 18:51:47.250 | HD Request # 110 | Decompressing data.
2025-01-07 18:51:47.502 | HD Request # 110 | Receiving Intraday data for MGCG5.COMEX starting at 2025-01-07 18:51:27.285000
2025-01-07 18:51:47.502 | Socket (6) | CloseSocket call.
2025-01-07 18:51:47.502 | Socket (6) | Shutdown started. Waiting for graceful close.
2025-01-07 18:51:47.504 | Historical data download thread signaled to stop.
2025-01-07 18:51:47.504 | HD Request # 110 | Received 5 Intraday data records from 2025-01-07 18:51:27.285000 to 2025-01-07 18:51:27.285004 (0.0 seconds. Delay: 20.2 seconds) and wrote 0 records for MGCG5.COMEX
2025-01-07 18:51:47.504 | HD Request # 110 | Add time&sales data | Remembered last file record date-time: 2025-01-07 23:51:27.285004
2025-01-07 18:51:47.504 | HD Request # 110 | Completion time: 1s.
2025-01-07 18:51:47.504 | HD Request # 110 | Intraday data download complete for MGCG5.COMEX. Unique request ID: 110
2025-01-07 18:51:47.504 | Removing historical data download ID 110.
2025-01-07 18:51:47.504 | Real-time Intraday chart data file updates started for MGCG5.COMEX
2025-01-07 18:51:47.504 | Intraday chart data file opened for MGCG5.COMEX
2025-01-07 18:51:47.504 | HD Request # 110 | Enabling Intraday chart updating for symbol.
2025-01-07 18:51:47.504 | Triggering next historical data download in queue.
2025-01-07 18:51:47.504 | HD Request # 111 | Downloading Intraday chart data for ESU4.CME to the file ESU4.CME.scid. Service: cme
2025-01-07 18:51:47.504 | HD Request # 111 | Download start date-time: 2024-09-20 09:29:59.000000. File last date-time: 2024-09-20 09:29:59.856000
2025-01-07 18:51:47.504 | HD Request # 111 | Using server: ds32.sierracharts.com port 10150
2025-01-07 18:51:47.504 | Socket (5) | Creating socket.
2025-01-07 18:51:47.504 | Socket (5) | New receive buffer size: 0
2025-01-07 18:51:47.504 | Socket (5) | Connecting to IP: 67.214.125.3.
2025-01-07 18:51:47.761 | Socket (6) | Socket gracefully closed by remote side.
2025-01-07 18:51:47.761 | Socket (6) | Closed.
2025-01-07 18:51:48.020 | HD Request # 111 | Setting DTC encoding to Binary VLS
2025-01-07 18:51:48.020 | HD Request # 111 | Sending historical data logon request message.
2025-01-07 18:51:48.253 | HD Request # 111 | Requesting Intraday data. Start date-time: 2024-09-20 09:29:59. Record interval: 0. Symbol: ESU24
2025-01-07 18:51:48.394 | Opened cached Intraday file: C:\SierraChart - TopStep\Data\ESH5.CME.scid. Thread ID: 16528
2025-01-07 18:51:48.394 | Opened cached Intraday file: C:\SierraChart - TopStep\Data\MNQH5.CME.scid. Thread ID: 16528
2025-01-07 18:51:48.491 | HD Request # 111 | Decompressing data.
2025-01-07 18:51:48.728 | HD Request # 111 | Receiving Intraday data for ESU4.CME starting at 2024-09-20 09:29:59.011000
2025-01-07 18:51:48.728 | Socket (5) | CloseSocket call.
2025-01-07 18:51:48.728 | Socket (5) | Shutdown started. Waiting for graceful close.
2025-01-07 18:51:48.753 | Historical data download thread signaled to stop.
2025-01-07 18:51:48.753 | HD Request # 111 | Received 12 Intraday data records from 2024-09-20 09:29:59.011000 to 2024-09-20 09:29:59.856000 (0.8 seconds. Delay: 109.4 days) and wrote 0 records for ESU4.CME
2025-01-07 18:51:48.753 | HD Request # 111 | Add time&sales data | Remembered last file record date-time: 2024-09-20 13:29:59.856000
2025-01-07 18:51:48.753 | HD Request # 111 | Completion time: 1s.
2025-01-07 18:51:48.753 | HD Request # 111 | Intraday data download complete for ESU4.CME. Unique request ID: 111
2025-01-07 18:51:48.753 | Removing historical data download ID 111.
2025-01-07 18:51:48.753 | Real-time Intraday chart data file updates started for ESU4.CME
2025-01-07 18:51:48.753 | Intraday chart data file opened for ESU4.CME
2025-01-07 18:51:48.753 | HD Request # 111 | Enabling Intraday chart updating for symbol.
2025-01-07 18:51:48.753 | Triggering next historical data download in queue.
2025-01-07 18:51:48.753 | HD Request # 112 | Downloading Intraday chart data for SIH5.COMEX to the file SIH5.COMEX.scid. Service: comex
2025-01-07 18:51:48.753 | HD Request # 112 | Download start date-time: 2025-01-07 18:51:03.000000. File last date-time: 2025-01-07 18:51:03.368000
2025-01-07 18:51:48.753 | HD Request # 112 | Using server: ds32.sierracharts.com port 10149
2025-01-07 18:51:48.753 | Socket (6) | Creating socket.
2025-01-07 18:51:48.753 | Socket (6) | New receive buffer size: 0
2025-01-07 18:51:48.753 | Socket (6) | Connecting to IP: 67.214.125.3.
2025-01-07 18:51:48.985 | Socket (5) | Socket gracefully closed by remote side.
2025-01-07 18:51:48.985 | Socket (5) | Closed.
2025-01-07 18:51:49.321 | HD Request # 112 | Setting DTC encoding to Binary VLS
2025-01-07 18:51:49.321 | HD Request # 112 | Sending historical data logon request message.
2025-01-07 18:51:49.614 | HD Request # 112 | Requesting Intraday data. Start date-time: 2025-01-07 18:51:03. Record interval: 0. Symbol: SIH25
2025-01-07 18:51:49.864 | HD Request # 112 | Decompressing data.
2025-01-07 18:51:50.112 | HD Request # 112 | Receiving Intraday data for SIH5.COMEX starting at 2025-01-07 18:51:03.368000
2025-01-07 18:51:50.112 | Socket (6) | CloseSocket call.
2025-01-07 18:51:50.113 | Socket (6) | Shutdown started. Waiting for graceful close.
2025-01-07 18:51:50.220 | Historical data download thread signaled to stop.
2025-01-07 18:51:50.220 | HD Request # 112 | Received 1 Intraday data record from 2025-01-07 18:51:03.368000 to 2025-01-07 18:51:03.368000 (0.0 seconds. Delay: 46.9 seconds) and wrote 0 records for SIH5.COMEX
2025-01-07 18:51:50.220 | HD Request # 112 | Add time&sales data | Remembered last file record date-time: 2025-01-07 23:51:03.368000
2025-01-07 18:51:50.220 | HD Request # 112 | Completion time: 2s.
2025-01-07 18:51:50.220 | HD Request # 112 | Intraday data download complete for SIH5.COMEX. Unique request ID: 112
2025-01-07 18:51:50.220 | Removing historical data download ID 112.
2025-01-07 18:51:50.220 | Real-time Intraday chart data file updates started for SIH5.COMEX
2025-01-07 18:51:50.220 | Intraday chart data file opened for SIH5.COMEX
2025-01-07 18:51:50.220 | HD Request # 112 | Enabling Intraday chart updating for symbol.
2025-01-07 18:51:50.220 | Triggering next historical data download in queue.
2025-01-07 18:51:50.220 | HD Request # 113 | Downloading Intraday chart data for NQH5.CME to the file NQH5.CME.scid. Service: cme
2025-01-07 18:51:50.220 | HD Request # 113 | Download start date-time: 2025-01-07 18:51:08.000000. File last date-time: 2025-01-07 18:51:08.104000
2025-01-07 18:51:50.220 | HD Request # 113 | Using server: ds32.sierracharts.com port 10150
2025-01-07 18:51:50.221 | Socket (5) | Creating socket.
2025-01-07 18:51:50.221 | Socket (5) | New receive buffer size: 0
2025-01-07 18:51:50.221 | Socket (5) | Connecting to IP: 67.214.125.3.
2025-01-07 18:51:50.368 | Socket (6) | Socket gracefully closed by remote side.
2025-01-07 18:51:50.368 | Socket (6) | Closed.
2025-01-07 18:51:50.787 | HD Request # 113 | Setting DTC encoding to Binary VLS
2025-01-07 18:51:50.787 | HD Request # 113 | Sending historical data logon request message.
2025-01-07 18:51:51.048 | HD Request # 113 | Requesting Intraday data. Start date-time: 2025-01-07 18:51:08. Record interval: 0. Symbol: NQH25
2025-01-07 18:51:51.302 | HD Request # 113 | Decompressing data.
2025-01-07 18:51:51.559 | HD Request # 113 | Receiving Intraday data for NQH5.CME starting at 2025-01-07 18:51:08.104000
2025-01-07 18:51:51.559 | Socket (5) | CloseSocket call.
2025-01-07 18:51:51.559 | Socket (5) | Shutdown started. Waiting for graceful close.
2025-01-07 18:51:51.646 | Historical data download thread signaled to stop.
2025-01-07 18:51:51.646 | HD Request # 113 | Timestamp of first Intraday data file record written: 2025-01-07 18:51:34.266000.
2025-01-07 18:51:51.646 | HD Request # 113 | Received 30 Intraday data records from 2025-01-07 18:51:08.104000 to 2025-01-07 18:51:49.847002 (41.7 seconds. Delay: 1.8 seconds) and wrote 29 records for NQH5.CME
2025-01-07 18:51:51.646 | HD Request # 113 | Add time&sales data | Remembered last file record date-time: 2025-01-07 23:51:49.847002
2025-01-07 18:51:51.646 | HD Request # 113 | Completion time: 1s.
2025-01-07 18:51:51.646 | HD Request # 113 | Intraday data download complete for NQH5.CME. Unique request ID: 113
2025-01-07 18:51:51.646 | Removing historical data download ID 113.
2025-01-07 18:51:51.646 | Real-time Intraday chart data file updates started for NQH5.CME
2025-01-07 18:51:51.646 | Intraday chart data file opened for NQH5.CME
2025-01-07 18:51:51.646 | HD Request # 113 | Enabling Intraday chart updating for symbol.
2025-01-07 18:51:51.646 | Triggering next historical data download in queue.
2025-01-07 18:51:51.646 | HD Request # 114 | Downloading Intraday chart data for 6AH5.CME to the file 6AH5.CME.scid. Service: cme
2025-01-07 18:51:51.647 | HD Request # 114 | Download start date-time: 2025-01-07 18:51:21.000000. File last date-time: 2025-01-07 18:51:21.634002
2025-01-07 18:51:51.647 | HD Request # 114 | Using server: ds32.sierracharts.com port 10149
2025-01-07 18:51:51.647 | Socket (6) | Creating socket.
2025-01-07 18:51:51.647 | Socket (6) | New receive buffer size: 0
2025-01-07 18:51:51.647 | Socket (6) | Connecting to IP: 67.214.125.3.
2025-01-07 18:51:51.814 | Socket (5) | Socket gracefully closed by remote side.
2025-01-07 18:51:51.814 | Socket (5) | Closed.
2025-01-07 18:51:52.147 | HD Request # 114 | Setting DTC encoding to Binary VLS
2025-01-07 18:51:52.147 | HD Request # 114 | Sending historical data logon request message.
2025-01-07 18:51:52.408 | HD Request # 114 | Requesting Intraday data. Start date-time: 2025-01-07 18:51:21. Record interval: 0. Symbol: 6AH25
2025-01-07 18:51:52.651 | HD Request # 114 | Decompressing data.
2025-01-07 18:51:52.885 | HD Request # 114 | Receiving Intraday data for 6AH5.CME starting at 2025-01-07 18:51:21.634000
2025-01-07 18:51:52.886 | Socket (6) | CloseSocket call.
2025-01-07 18:51:52.886 | Socket (6) | Shutdown started. Waiting for graceful close.
2025-01-07 18:51:52.907 | Historical data download thread signaled to stop.
2025-01-07 18:51:52.907 | HD Request # 114 | Timestamp of first Intraday data file record written: 2025-01-07 18:51:21.634003.
2025-01-07 18:51:52.907 | HD Request # 114 | Received 7 Intraday data records from 2025-01-07 18:51:21.634000 to 2025-01-07 18:51:37.933002 (16.3 seconds. Delay: 15.0 seconds) and wrote 5 records for 6AH5.CME
2025-01-07 18:51:52.908 | HD Request # 114 | Add time&sales data | Remembered last file record date-time: 2025-01-07 23:51:37.933002
2025-01-07 18:51:52.908 | HD Request # 114 | Completion time: 1s.
2025-01-07 18:51:52.908 | HD Request # 114 | Intraday data download complete for 6AH5.CME. Unique request ID: 114
2025-01-07 18:51:52.908 | Removing historical data download ID 114.
2025-01-07 18:51:52.908 | Real-time Intraday chart data file updates started for 6AH5.CME
2025-01-07 18:51:52.908 | Intraday chart data file opened for 6AH5.CME
2025-01-07 18:51:52.908 | HD Request # 114 | Enabling Intraday chart updating for symbol.
2025-01-07 18:51:52.908 | Triggering next historical data download in queue.
2025-01-07 18:51:52.908 | HD Request # 115 | Downloading Intraday chart data for MESH5.CME to the file MESH5.CME.scid. Service: cme
2025-01-07 18:51:52.908 | HD Request # 115 | Download start date-time: 2025-01-07 18:51:17.000000. File last date-time: 2025-01-07 18:51:17.053001
2025-01-07 18:51:52.908 | HD Request # 115 | Using server: ds32.sierracharts.com port 10150
2025-01-07 18:51:52.908 | Socket (5) | Creating socket.
2025-01-07 18:51:52.908 | Socket (5) | New receive buffer size: 0
2025-01-07 18:51:52.908 | Socket (5) | Connecting to IP: 67.214.125.3.
2025-01-07 18:51:53.129 | Socket (6) | Socket gracefully closed by remote side.
2025-01-07 18:51:53.130 | Socket (6) | Closed.
2025-01-07 18:51:53.437 | Opened cached Intraday file: C:\SierraChart - TopStep\Data\SIH5.COMEX.scid. Thread ID: 16528
2025-01-07 18:51:53.437 | Opened cached Intraday file: C:\SierraChart - TopStep\Data\GCG5.COMEX.scid. Thread ID: 16528
2025-01-07 18:51:53.437 | Opened cached Intraday file: C:\SierraChart - TopStep\Data\MGCG5.COMEX.scid. Thread ID: 16528
2025-01-07 18:51:53.437 | Opened cached Intraday file: C:\SierraChart - TopStep\Data\NQH5.CME.scid. Thread ID: 16528
2025-01-07 18:51:53.495 | HD Request # 115 | Setting DTC encoding to Binary VLS
2025-01-07 18:51:53.495 | HD Request # 115 | Sending historical data logon request message.
2025-01-07 18:51:53.657 | HTTPS connection ID:17 to downloads.rithmic.com:443 for request ID:17 (6) | Creating socket. Using TLS 1.2.
2025-01-07 18:51:53.657 | HTTPS connection ID:17 to downloads.rithmic.com:443 for request ID:17 (6) | New receive buffer size: 0
2025-01-07 18:51:53.657 | HTTPS connection ID:17 to downloads.rithmic.com:443 for request ID:17 (6) | Connecting to IP: 216.66.0.130.
2025-01-07 18:51:53.756 | HD Request # 115 | Requesting Intraday data. Start date-time: 2025-01-07 18:51:17. Record interval: 0. Symbol: MESH25
2025-01-07 18:51:54.017 | HD Request # 115 | Decompressing data.
2025-01-07 18:51:54.311 | HD Request # 115 | Receiving Intraday data for MESH5.CME starting at 2025-01-07 18:51:17.053000
2025-01-07 18:51:54.311 | Socket (5) | CloseSocket call.
2025-01-07 18:51:54.311 | Socket (5) | Shutdown started. Waiting for graceful close.
2025-01-07 18:51:54.349 | Historical data download thread signaled to stop.
2025-01-07 18:51:54.349 | HD Request # 115 | Timestamp of first Intraday data file record written: 2025-01-07 18:51:31.719000.
2025-01-07 18:51:54.350 | HD Request # 115 | Received 14 Intraday data records from 2025-01-07 18:51:17.053000 to 2025-01-07 18:51:49.300004 (32.2 seconds. Delay: 5.1 seconds) and wrote 12 records for MESH5.CME
2025-01-07 18:51:54.350 | HD Request # 115 | Add time&sales data | Remembered last file record date-time: 2025-01-07 23:51:49.300004
2025-01-07 18:51:54.350 | Added 3 Time and Sales records to Intraday data file for MESH5.CME after download.
2025-01-07 18:51:54.350 | HD Request # 115 | Completion time: 2s.
2025-01-07 18:51:54.350 | HD Request # 115 | Intraday data download complete for MESH5.CME. Unique request ID: 115
2025-01-07 18:51:54.350 | Removing historical data download ID 115.
2025-01-07 18:51:54.350 | Real-time Intraday chart data file updates started for MESH5.CME
2025-01-07 18:51:54.350 | Intraday chart data file opened for MESH5.CME
2025-01-07 18:51:54.350 | HD Request # 115 | Enabling Intraday chart updating for symbol.
2025-01-07 18:51:54.350 | Triggering next historical data download in queue.
2025-01-07 18:51:54.350 | HD Request # 116 | Downloading Intraday chart data for M6AH5.CME to the file M6AH5.CME.scid. Service: cme
2025-01-07 18:51:54.350 | HD Request # 116 | Download start date-time: 2025-01-07 18:49:00.000000. File last date-time: 2025-01-07 18:49:00.114000
2025-01-07 18:51:54.350 | HD Request # 116 | Using server: ds32.sierracharts.com port 10149
2025-01-07 18:51:54.350 | Socket (7) | Creating socket.
2025-01-07 18:51:54.350 | Socket (7) | New receive buffer size: 0
2025-01-07 18:51:54.350 | Socket (7) | Connecting to IP: 67.214.125.3.
2025-01-07 18:51:54.565 | Socket (5) | Socket gracefully closed by remote side.
2025-01-07 18:51:54.565 | Socket (5) | Closed.
2025-01-07 18:51:54.850 | HD Request # 116 | Setting DTC encoding to Binary VLS
2025-01-07 18:51:54.850 | HD Request # 116 | Sending historical data logon request message.
2025-01-07 18:51:55.121 | HD Request # 116 | Requesting Intraday data. Start date-time: 2025-01-07 18:49:00. Record interval: 0. Symbol: M6AH25
2025-01-07 18:51:55.143 | Rithmic Direct - DTC | Wrote file: C:\SierraChart - TopStep\RithmicConnections.json. Size: 81131
2025-01-07 18:51:55.143 | Rithmic Direct - DTC | Processed connection points. Count: 347
2025-01-07 18:51:55.364 | HD Request # 116 | Decompressing data.
2025-01-07 18:51:55.651 | HD Request # 116 | Receiving Intraday data for M6AH5.CME starting at 2025-01-07 18:49:00.114000
2025-01-07 18:51:55.652 | Socket (7) | CloseSocket call.
2025-01-07 18:51:55.652 | Socket (7) | Shutdown started. Waiting for graceful close.
2025-01-07 18:51:55.723 | Historical data download thread signaled to stop.
2025-01-07 18:51:55.723 | HD Request # 116 | Received 1 Intraday data record from 2025-01-07 18:49:00.114000 to 2025-01-07 18:49:00.114000 (0.0 seconds. Delay: 2.9 minutes) and wrote 0 records for M6AH5.CME
2025-01-07 18:51:55.723 | HD Request # 116 | Add time&sales data | Remembered last file record date-time: 2025-01-07 23:49:00.114000
2025-01-07 18:51:55.723 | HD Request # 116 | Completion time: 1s.
2025-01-07 18:51:55.723 | HD Request # 116 | Intraday data download complete for M6AH5.CME. Unique request ID: 116
2025-01-07 18:51:55.723 | Removing historical data download ID 116.
2025-01-07 18:51:55.723 | Real-time Intraday chart data file updates started for M6AH5.CME
2025-01-07 18:51:55.723 | Intraday chart data file opened for M6AH5.CME
2025-01-07 18:51:55.723 | HD Request # 116 | Enabling Intraday chart updating for symbol.
2025-01-07 18:51:55.723 | Triggering next historical data download in queue.
2025-01-07 18:51:55.723 | HD Request # 117 | Downloading Intraday chart data for SILH5.COMEX to the file SILH5.COMEX.scid. Service: comex
2025-01-07 18:51:55.723 | HD Request # 117 | Download start date-time: 2025-01-07 18:50:41.000000. File last date-time: 2025-01-07 18:50:41.732000
2025-01-07 18:51:55.723 | HD Request # 117 | Using server: ds32.sierracharts.com port 10150
2025-01-07 18:51:55.723 | Socket (5) | Creating socket.
2025-01-07 18:51:55.724 | Socket (5) | New receive buffer size: 0
2025-01-07 18:51:55.724 | Socket (5) | Connecting to IP: 67.214.125.3.
2025-01-07 18:51:55.892 | Socket (7) | Socket gracefully closed by remote side.
2025-01-07 18:51:55.892 | Socket (7) | Closed.
2025-01-07 18:51:55.967 | HTTPS connection ID:17 to downloads.rithmic.com:443 for request ID:17 (6) | CloseSocket call.
2025-01-07 18:51:55.967 | HTTPS connection ID:17 to downloads.rithmic.com:443 for request ID:17 (6) | Shutdown started. Waiting for graceful close.
2025-01-07 18:51:56.203 | HTTPS connection ID:17 to downloads.rithmic.com:443 for request ID:17 (6) | Socket gracefully closed by remote side.
2025-01-07 18:51:56.204 | HTTPS connection ID:17 to downloads.rithmic.com:443 for request ID:17 (6) | Closed.
2025-01-07 18:51:56.272 | HD Request # 117 | Setting DTC encoding to Binary VLS
2025-01-07 18:51:56.272 | HD Request # 117 | Sending historical data logon request message.
2025-01-07 18:51:56.545 | HD Request # 117 | Requesting Intraday data. Start date-time: 2025-01-07 18:50:41. Record interval: 0. Symbol: SILH25
2025-01-07 18:51:56.791 | HD Request # 117 | Decompressing data.
2025-01-07 18:51:57.087 | HD Request # 117 | Receiving Intraday data for SILH5.COMEX starting at 2025-01-07 18:50:41.732000
2025-01-07 18:51:57.087 | Socket (5) | CloseSocket call.
2025-01-07 18:51:57.087 | Socket (5) | Shutdown started. Waiting for graceful close.
2025-01-07 18:51:57.102 | Historical data download thread signaled to stop.
2025-01-07 18:51:57.103 | HD Request # 117 | Timestamp of first Intraday data file record written: 2025-01-07 18:51:52.825000.
2025-01-07 18:51:57.103 | HD Request # 117 | Received 3 Intraday data records from 2025-01-07 18:50:41.732000 to 2025-01-07 18:51:52.825001 (71.1 seconds. Delay: 4.3 seconds) and wrote 2 records for SILH5.COMEX
2025-01-07 18:51:57.103 | HD Request # 117 | Add time&sales data | Remembered last file record date-time: 2025-01-07 23:51:52.825001
2025-01-07 18:51:57.103 | HD Request # 117 | Completion time: 2s.
2025-01-07 18:51:57.103 | HD Request # 117 | Intraday data download complete for SILH5.COMEX. Unique request ID: 117
2025-01-07 18:51:57.103 | Removing historical data download ID 117.
2025-01-07 18:51:57.103 | Real-time Intraday chart data file updates started for SILH5.COMEX
2025-01-07 18:51:57.103 | Intraday chart data file opened for SILH5.COMEX
2025-01-07 18:51:57.103 | HD Request # 117 | Enabling Intraday chart updating for symbol.
2025-01-07 18:51:57.103 | Triggering next historical data download in queue.
2025-01-07 18:51:57.103 | HD Request # 118 | Downloading Intraday chart data for USDX to the file USDX.scid. Service: fxstatscalc
2025-01-07 18:51:57.103 | HD Request # 118 | Download start date-time: 2025-01-07 18:51:28.000000. File last date-time: 2025-01-07 18:51:28.000001
2025-01-07 18:51:57.103 | HD Request # 118 | Using server: ds4.sierracharts.com port 10149
2025-01-07 18:51:57.103 | Socket (6) | Creating socket.
2025-01-07 18:51:57.103 | Socket (6) | New receive buffer size: 0
2025-01-07 18:51:57.103 | Socket (6) | Connecting to IP: 67.214.125.7.
2025-01-07 18:51:57.344 | Socket (5) | Socket gracefully closed by remote side.
2025-01-07 18:51:57.344 | Socket (5) | Closed.
2025-01-07 18:51:57.583 | HD Request # 118 | Setting DTC encoding to Binary VLS
2025-01-07 18:51:57.583 | HD Request # 118 | Sending historical data logon request message.
2025-01-07 18:51:57.848 | HD Request # 118 | Requesting Intraday data. Start date-time: 2025-01-07 18:51:28. Record interval: 0. Symbol: USDX
2025-01-07 18:51:58.082 | HD Request # 118 | Decompressing data.
2025-01-07 18:51:58.314 | HD Request # 118 | Receiving Intraday data for USDX starting at 2025-01-07 18:51:28.000000
2025-01-07 18:51:58.314 | Socket (6) | CloseSocket call.
2025-01-07 18:51:58.314 | Socket (6) | Shutdown started. Waiting for graceful close.
2025-01-07 18:51:58.321 | Historical data download thread signaled to stop.
2025-01-07 18:51:58.321 | HD Request # 118 | Timestamp of first Intraday data file record written: 2025-01-07 18:51:29.000000.
2025-01-07 18:51:58.321 | HD Request # 118 | Received 25 Intraday data records from 2025-01-07 18:51:28.000000 to 2025-01-07 18:51:56.000000 (28.0 seconds. Delay: 2.3 seconds) and wrote 24 records for USDX
2025-01-07 18:51:58.322 | HD Request # 118 | Add time&sales data | Remembered last file record date-time: 2025-01-07 23:51:56.000000
2025-01-07 18:51:58.322 | Added 3 Time and Sales records to Intraday data file for USDX after download.
2025-01-07 18:51:58.322 | HD Request # 118 | Completion time: 1s.
2025-01-07 18:51:58.322 | HD Request # 118 | Intraday data download complete for USDX. Unique request ID: 118
2025-01-07 18:51:58.322 | Removing historical data download ID 118.
2025-01-07 18:51:58.322 | Real-time Intraday chart data file updates started for USDX
2025-01-07 18:51:58.322 | Intraday chart data file opened for USDX
2025-01-07 18:51:58.322 | HD Request # 118 | Enabling Intraday chart updating for symbol.
2025-01-07 18:51:58.322 | Triggering next historical data download in queue.
2025-01-07 18:51:58.322 | HD Request # 119 | Downloading Intraday chart data for SPX500 to the file SPX500.scid. Service: fxcm
2025-01-07 18:51:58.322 | HD Request # 119 | Download start date-time: 2025-01-07 18:51:17.000000. File last date-time: 2025-01-07 18:51:17.079000
2025-01-07 18:51:58.322 | HD Request # 119 | Using server: ds12.sierracharts.com port 10150
2025-01-07 18:51:58.431 | Socket (5) | Creating socket.
2025-01-07 18:51:58.431 | Socket (5) | New receive buffer size: 0
2025-01-07 18:51:58.431 | Socket (5) | Connecting to IP: 69.39.70.241.
2025-01-07 18:51:58.480 | Opened cached Intraday file: C:\SierraChart - TopStep\Data\MESH5.CME.scid. Thread ID: 16528
2025-01-07 18:51:58.547 | Socket (6) | Socket gracefully closed by remote side.
2025-01-07 18:51:58.547 | Socket (6) | Closed.
2025-01-07 18:51:58.917 | HD Request # 119 | Setting DTC encoding to Binary VLS
2025-01-07 18:51:58.917 | HD Request # 119 | Sending historical data logon request message.
2025-01-07 18:51:59.185 | HD Request # 119 | Requesting Intraday data. Start date-time: 2025-01-07 18:51:17. Record interval: 0. Symbol: SPX500
2025-01-07 18:51:59.420 | HD Request # 119 | Decompressing data.
2025-01-07 18:51:59.652 | HD Request # 119 | Receiving Intraday data for SPX500 starting at 2025-01-07 18:51:17.079000
2025-01-07 18:51:59.652 | Socket (5) | CloseSocket call.
2025-01-07 18:51:59.652 | Socket (5) | Shutdown started. Waiting for graceful close.
2025-01-07 18:51:59.685 | Historical data download thread signaled to stop.
2025-01-07 18:51:59.685 | HD Request # 119 | Timestamp of first Intraday data file record written: 2025-01-07 18:51:36.679000.
2025-01-07 18:51:59.685 | HD Request # 119 | Received 23 Intraday data records from 2025-01-07 18:51:17.079000 to 2025-01-07 18:51:57.881000 (40.8 seconds. Delay: 1.8 seconds) and wrote 22 records for SPX500
2025-01-07 18:51:59.686 | HD Request # 119 | Add time&sales data | Remembered last file record date-time: 2025-01-07 23:51:57.881000
2025-01-07 18:51:59.686 | HD Request # 119 | Completion time: 1s.
2025-01-07 18:51:59.686 | HD Request # 119 | Intraday data download complete for SPX500. Unique request ID: 119
2025-01-07 18:51:59.686 | Removing historical data download ID 119.
2025-01-07 18:51:59.686 | Real-time Intraday chart data file updates started for SPX500
2025-01-07 18:51:59.686 | Intraday chart data file opened for SPX500
2025-01-07 18:51:59.686 | HD Request # 119 | Enabling Intraday chart updating for symbol.
2025-01-07 18:51:59.686 | No download requests in the queue to start downloads for.
2025-01-07 18:51:59.885 | Socket (5) | Socket gracefully closed by remote side.
2025-01-07 18:51:59.885 | Socket (5) | Closed.
2025-01-07 18:52:03.533 | Opened cached Intraday file: C:\SierraChart - TopStep\Data\USDX.scid. Thread ID: 16528
2025-01-07 18:52:03.533 | Opened cached Intraday file: C:\SierraChart - TopStep\Data\SILH5.COMEX.scid. Thread ID: 16528
2025-01-07 18:52:03.534 | Opened cached Intraday file: C:\SierraChart - TopStep\Data\SPX500.scid. Thread ID: 16528
2025-01-07 18:52:28.736 | Opened cached Intraday file: C:\SierraChart - TopStep\Data\6AH5.CME.scid. Thread ID: 16528
2025-01-07 18:52:28.736 | Opened cached Intraday file: C:\SierraChart - TopStep\Data\M6AH5.CME.scid. Thread ID: 16528
2025-01-07 19:15:40.444 | Chat | Message response. Chat ID: 429. Request ID: 1134629378
2025-01-07 20:46:43.987 | ESH5.CME [CBV] 15 Min #2 | Reloading chart.
2025-01-07 20:46:44.003 | Added historical Intraday data request for ESH5.CME to the queue.
2025-01-07 20:46:44.003 | Intraday data recording state for symbol ESH5.CME is set to download 'Pending'.
2025-01-07 20:46:44.003 | Triggering next historical data download in queue.
2025-01-07 20:46:44.078 | ESH5.CME [CBV] 15 Min #2 | Waiting for historical downloads to complete with the IDs: 120,
2025-01-07 20:46:44.081 | HD Request # 120 | Downloading Intraday chart data for ESH5.CME to the file ESH5.CME.scid. Service: cme
2025-01-07 20:46:44.082 | HD Request # 120 | Download start date-time: 2025-01-07 20:46:37.000000. File last date-time: 2025-01-07 20:46:37.360006
2025-01-07 20:46:44.082 | HD Request # 120 | Using server: ds32.sierracharts.com port 10149
2025-01-07 20:46:44.197 | Socket (6) | Creating socket.
2025-01-07 20:46:44.197 | Socket (6) | New receive buffer size: 0
2025-01-07 20:46:44.197 | Socket (6) | Connecting to IP: 67.214.125.3.
2025-01-07 20:46:44.730 | HD Request # 120 | Setting DTC encoding to Binary VLS
2025-01-07 20:46:44.730 | HD Request # 120 | Sending historical data logon request message.
2025-01-07 20:46:45.043 | HD Request # 120 | Requesting Intraday data. Start date-time: 2025-01-07 20:46:37. Record interval: 0. Symbol: ESH25
2025-01-07 20:46:45.302 | HD Request # 120 | Decompressing data.
2025-01-07 20:46:45.560 | HD Request # 120 | Receiving Intraday data for ESH5.CME starting at 2025-01-07 20:46:37.011000
2025-01-07 20:46:45.560 | Socket (6) | CloseSocket call.
2025-01-07 20:46:45.560 | Socket (6) | Shutdown started. Waiting for graceful close.
2025-01-07 20:46:45.723 | Historical data download thread signaled to stop.
2025-01-07 20:46:45.723 | HD Request # 120 | Received 8 Intraday data records from 2025-01-07 20:46:37.011000 to 2025-01-07 20:46:37.360006 (0.3 seconds. Delay: 8.4 seconds) and wrote 0 records for ESH5.CME
2025-01-07 20:46:45.723 | HD Request # 120 | Add time&sales data | Remembered last file record date-time: 2025-01-08 01:46:37.360006
2025-01-07 20:46:45.723 | Added 14 Time and Sales records to Intraday data file for ESH5.CME after download.
2025-01-07 20:46:45.723 | HD Request # 120 | Timestamp of first Intraday data file record written: 2025-01-07 20:46:45.338000.
2025-01-07 20:46:45.723 | HD Request # 120 | Completion time: 1s.
2025-01-07 20:46:45.723 | HD Request # 120 | Intraday data download complete for ESH5.CME. Unique request ID: 120
2025-01-07 20:46:45.723 | Removing historical data download ID 120.
2025-01-07 20:46:45.723 | Real-time Intraday chart data file updates started for ESH5.CME
2025-01-07 20:46:45.723 | Intraday chart data file opened for ESH5.CME
2025-01-07 20:46:45.723 | HD Request # 120 | Enabling Intraday chart updating for symbol.
2025-01-07 20:46:45.723 | No download requests in the queue to start downloads for.
2025-01-07 20:46:45.819 | Socket (6) | Socket gracefully closed by remote side.
2025-01-07 20:46:45.819 | Socket (6) | Closed.
2025-01-07 20:46:46.352 | ESH5.CME [CBV] 15 Min #2 | Download is complete for all contract months in chart. Proceeding with data load.
2025-01-07 20:46:46.352 | ESH5.CME [CBV] 15 Min #2 | Reloading chart.
2025-01-07 20:46:47.194 | Opened cached Intraday file: C:\SierraChart - TopStep\Data\ESH5.CME.scid. Thread ID: 16528
2025-01-07 20:46:47.285 | ESH5.CME [CBV] 15 Min #2 | Reloading chart.
2025-01-07 20:47:28.101 | ESH5.CME [CBV][M] 15 Min #2 | Reloading chart.
2025-01-07 20:47:28.283 | ESH5.CME [CBV] 15 Min #2 | Chart Data Loading Thread: Load canceled.
2025-01-07 20:47:28.283 | Restarting the loading process.
2025-01-07 20:47:49.037 | ESH5.CME [CBV][M] 420 Min #2 | Reloading chart.
2025-01-07 20:47:49.212 | ESH5.CME [CBV][M] 15 Min #2 | Chart Data Loading Thread: Load canceled.
2025-01-07 20:47:49.214 | Restarting the loading process.
2025-01-07 20:48:43.967 | ESH5.CME [CBV][M] 420 Min #2 | Chart data loading complete.
2025-01-07 22:00:00.226 | Chat | Server has requested a logoff. Reason: Chat server is backing up
2025-01-07 22:00:00.226 | Chat | Waiting for socket receive thread to end
2025-01-07 22:00:00.226 | DTC Client socket (4) | CloseSocket call.
2025-01-07 22:00:00.226 | DTC Client socket (4) | Shutdown started. Waiting for graceful close.
2025-01-07 22:00:00.226 | Chat | Disconnected from the server.
2025-01-07 22:00:00.226 | Chat | Data feed disconnected. Will reconnect in 5 seconds.
2025-01-07 22:00:02.887 | DTC Client socket (4) | Socket gracefully closed by remote side.
2025-01-07 22:00:02.887 | DTC Client socket (4) | Closed.
2025-01-07 22:00:05.216 | WSACleanup called.
2025-01-07 22:00:05.216 | Chat | Connecting to the server chat2.sierracharts.com. Port 10065
2025-01-07 22:00:05.363 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2025-01-07 22:00:05.363 | DTC Client socket (4) | New receive buffer size: 0
2025-01-07 22:00:05.363 | DTC Client socket (4) | Connecting to IP: 64.152.155.20.
2025-01-07 22:00:05.603 | Chat | Network connection to server complete.
2025-01-07 22:00:05.603 | Chat | Starting socket receive thread.
2025-01-07 22:00:05.603 | Chat | Sending encoding request to server: Binary VLS. Compression: none
2025-01-07 22:00:06.324 | Chat | Setting DTC encoding to Binary VLS
2025-01-07 22:00:06.324 | Chat | Sending logon request message.
2025-01-07 22:00:11.692 | Chat | Received logon response.
2025-01-07 22:00:11.692 | Chat | Server Name: SC DTC Server. Build=52153.
2025-01-07 22:00:11.692 | Chat | Server protocol version: 8. Client protocol version: 8
2025-01-07 22:00:11.692 | Chat | Successfully connected. Connected to SC DTC Protocol server. Service=chat_server.data|SymbolSettings=chat_server.data.
2025-01-07 22:00:11.692 | Chat | Trading is not supported.
2025-01-07 22:00:11.692 | Chat | MarketDepthIsSupported: 1
2025-01-07 22:15:14.771 | Chat | Message response. Chat ID: 429. Request ID: 1134629384
2025-01-07 22:40:49.296 | Chat | Message response. Chat ID: 429. Request ID: 1134629385
2025-01-07 22:45:55.592 | Chat | Message response. Chat ID: 429. Request ID: 1134629386
2025-01-07 22:51:55.804 | HTTPS connection ID:18 to downloads.rithmic.com:443 for request ID:18 (5) | Creating socket. Using TLS 1.2.
2025-01-07 22:51:55.804 | HTTPS connection ID:18 to downloads.rithmic.com:443 for request ID:18 (5) | New receive buffer size: 0
2025-01-07 22:51:55.804 | HTTPS connection ID:18 to downloads.rithmic.com:443 for request ID:18 (5) | Connecting to IP: 216.66.0.130.
2025-01-07 22:51:57.328 | Rithmic Direct - DTC | Wrote file: C:\SierraChart - TopStep\RithmicConnections.json. Size: 81131
2025-01-07 22:51:57.329 | Rithmic Direct - DTC | Processed connection points. Count: 347
2025-01-07 22:51:58.179 | HTTPS connection ID:18 to downloads.rithmic.com:443 for request ID:18 (5) | CloseSocket call.
2025-01-07 22:51:58.179 | HTTPS connection ID:18 to downloads.rithmic.com:443 for request ID:18 (5) | Shutdown started. Waiting for graceful close.
2025-01-07 22:51:58.414 | HTTPS connection ID:18 to downloads.rithmic.com:443 for request ID:18 (5) | Socket gracefully closed by remote side.
2025-01-07 22:51:58.414 | HTTPS connection ID:18 to downloads.rithmic.com:443 for request ID:18 (5) | Closed.
2025-01-07 23:35:28.658 | Chat | Message response. Chat ID: 429. Request ID: 1134629387
2025-01-07 23:58:49.232 | Chat | Message response. Chat ID: 429. Request ID: 1134629388
2025-01-08 00:00:00.059 | Added historical Daily data request for NQH5.CME to the queue.
2025-01-08 00:00:00.059 | Triggering next historical data download in queue.
2025-01-08 00:00:00.061 | HD Request # 121 | Downloading Historical Daily chart data for NQH5.CME. Starting date: 2025-01-03. Service: rithmic.trading
2025-01-08 00:00:00.061 | Added historical Daily data request for SIH5.COMEX to the queue.
2025-01-08 00:00:00.061 | Triggering next historical data download in queue.
2025-01-08 00:00:00.061 | Added historical Daily data request for GCG5.COMEX to the queue.
2025-01-08 00:00:00.062 | Added historical Daily data request for 6AH5.CME to the queue.
2025-01-08 00:00:00.062 | Triggering next historical data download in queue.
2025-01-08 00:00:00.427 | Added historical Daily data request for ESH5.CME to the queue.
2025-01-08 00:00:00.427 | Triggering next historical data download in queue.
2025-01-08 00:00:00.908 | Added historical Daily data request for USDX to the queue.
2025-01-08 00:00:00.908 | Triggering next historical data download in queue.
2025-01-08 00:00:00.909 | HD Request # 122 | Downloading Historical Daily chart data for USDX. Starting date: 2025-01-06. Service: fxstatscalc
2025-01-08 00:00:00.909 | HD Request # 122 | Using server: ds4.sierracharts.com port 10150
2025-01-08 00:00:01.019 | Socket (6) | Creating socket.
2025-01-08 00:00:01.019 | Socket (6) | New receive buffer size: 0
2025-01-08 00:00:01.019 | Socket (6) | Connecting to IP: 67.214.125.7.
2025-01-08 00:00:01.156 | HD Request # 121 | Requesting historical Daily data for NQH25 starting at 2025-01-02. SC External HD service.
2025-01-08 00:00:01.505 | HD Request # 122 | Setting DTC encoding to Binary VLS
2025-01-08 00:00:01.505 | HD Request # 122 | Sending historical data logon request message.
2025-01-08 00:00:01.772 | HD Request # 122 | Requesting historical Daily data starting at 2025-01-06.
2025-01-08 00:00:02.011 | HD Request # 122 | Decompressing data.
2025-01-08 00:00:02.043 | HD Request # 122 | Receiving historical Daily data for USDX starting at 2025-01-06.
2025-01-08 00:00:02.044 | HD Request # 122 | Writing historical Daily data to the file USDX.dly.
2025-01-08 00:00:02.056 | Socket (6) | CloseSocket call.
2025-01-08 00:00:02.056 | Socket (6) | Shutdown started. Waiting for graceful close.
2025-01-08 00:00:02.057 | Historical data download thread signaled to stop.
2025-01-08 00:00:02.057 | HD Request # 122 | Received 3 Daily data records from 2025-01-06 00:00:00 to 2025-01-08 00:00:00 (3.0 days) and wrote 3 records for USDX
2025-01-08 00:00:02.057 | HD Request # 122 | Completion time: 2s.
2025-01-08 00:00:02.057 | HD Request # 122 | Daily data download complete for USDX. Unique request ID: 126
2025-01-08 00:00:02.057 | Removing historical data download ID 126.
2025-01-08 00:00:02.057 | No download requests in the queue to start downloads for.
2025-01-08 00:00:02.229 | HD Request # 121 | Receiving historical Daily data for NQH5.CME starting at 2025-01-03.
2025-01-08 00:00:02.229 | HD Request # 121 | Writing historical Daily data to the file NQH5.CME.dly.
2025-01-08 00:00:02.230 | HD Request # 121 | Bytes received: 254
2025-01-08 00:00:02.230 | HD Request # 121 | Received 4 Daily data records from 2025-01-03 00:00:00 to 2025-01-07 00:00:00 (5.0 days) and wrote 3 records for NQH5.CME
2025-01-08 00:00:02.230 | HD Request # 121 | Completion time: 2s.
2025-01-08 00:00:02.230 | HD Request # 121 | Daily data download complete for NQH5.CME. Unique request ID: 121
2025-01-08 00:00:02.230 | Removing historical data download ID 121.
2025-01-08 00:00:02.230 | Triggering next historical data download in queue.
2025-01-08 00:00:02.231 | HD Request # 123 | Downloading Historical Daily chart data for SIH5.COMEX. Starting date: 2025-01-03. Service: rithmic.trading
2025-01-08 00:00:02.232 | NQH5.CME [CBV][M] Daily #6 | Reloading chart.
2025-01-08 00:00:02.232 | NQH5.CME [CBV][M] Daily #6 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2025-01-08 00:00:02.232 | NQH5.CME [CBV][M] Daily #6 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2025-01-08 00:00:02.296 | Socket (6) | Socket gracefully closed by remote side.
2025-01-08 00:00:02.296 | Socket (6) | Closed.
2025-01-08 00:00:02.557 | NQH5.CME [CBV][M] Daily #6 | Chart data loading complete.
2025-01-08 00:00:02.573 | NQH5.CME [CBV][M] Monthly #4 | Reloading chart.
2025-01-08 00:00:02.573 | NQH5.CME [CBV][M] Monthly #4 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2025-01-08 00:00:02.573 | NQH5.CME [CBV][M] Monthly #4 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2025-01-08 00:00:02.913 | NQH5.CME [CBV][M] Monthly #4 | Chart data loading complete.
2025-01-08 00:00:03.236 | USDX[M] Daily #19 | Reloading chart.
2025-01-08 00:00:03.262 | USDX[M] Daily #19 | StartDateTimeForLoadingOrderFills: 2024-01-02 00:00:00
2025-01-08 00:00:03.262 | USDX[M] Daily #19 | Chart data loading complete.
2025-01-08 00:00:03.319 | NQH5.CME [CBV][M] Weekly #5 | Reloading chart.
2025-01-08 00:00:03.319 | NQH5.CME [CBV][M] Weekly #5 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2025-01-08 00:00:03.319 | NQH5.CME [CBV][M] Weekly #5 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2025-01-08 00:00:03.598 | HD Request # 123 | Requesting historical Daily data for SIH25 starting at 2025-01-02. SC External HD service.
2025-01-08 00:00:03.638 | NQH5.CME [CBV][M] Weekly #5 | Chart data loading complete.
2025-01-08 00:00:04.710 | HD Request # 123 | Receiving historical Daily data for SIH5.COMEX starting at 2025-01-03.
2025-01-08 00:00:04.710 | HD Request # 123 | Writing historical Daily data to the file SIH5.COMEX.dly.
2025-01-08 00:00:04.712 | HD Request # 123 | Bytes received: 224
2025-01-08 00:00:04.712 | HD Request # 123 | Received 4 Daily data records from 2025-01-03 00:00:00 to 2025-01-07 00:00:00 (5.0 days) and wrote 3 records for SIH5.COMEX
2025-01-08 00:00:04.712 | HD Request # 123 | Completion time: 2s.
2025-01-08 00:00:04.712 | HD Request # 123 | Daily data download complete for SIH5.COMEX. Unique request ID: 122
2025-01-08 00:00:04.712 | Removing historical data download ID 122.
2025-01-08 00:00:04.712 | Triggering next historical data download in queue.
2025-01-08 00:00:04.713 | HD Request # 124 | Downloading Historical Daily chart data for GCG5.COMEX. Starting date: 2025-01-03. Service: rithmic.trading
2025-01-08 00:00:04.817 | SIH5.COMEX [CBV][M] Weekly #5 | Reloading chart.
2025-01-08 00:00:04.817 | SIH5.COMEX [CBV][M] Weekly #5 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2025-01-08 00:00:04.817 | SIH5.COMEX [CBV][M] Weekly #5 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2025-01-08 00:00:05.564 | SIH5.COMEX [CBV][M] Weekly #5 | Chart data loading complete.
2025-01-08 00:00:05.565 | SIH5.COMEX [CBV][M] Monthly #4 | Reloading chart.
2025-01-08 00:00:05.565 | SIH5.COMEX [CBV][M] Monthly #4 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2025-01-08 00:00:05.565 | SIH5.COMEX [CBV][M] Monthly #4 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2025-01-08 00:00:06.239 | SIH5.COMEX [CBV][M] Monthly #4 | Chart data loading complete.
2025-01-08 00:00:06.239 | HD Request # 124 | Requesting historical Daily data for GCG25 starting at 2025-01-02. SC External HD service.
2025-01-08 00:00:06.317 | SIH5.COMEX [CBV][M] Daily #6 | Reloading chart.
2025-01-08 00:00:06.317 | SIH5.COMEX [CBV][M] Daily #6 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2025-01-08 00:00:06.317 | SIH5.COMEX [CBV][M] Daily #6 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2025-01-08 00:00:06.974 | SIH5.COMEX [CBV][M] Daily #6 | Chart data loading complete.
2025-01-08 00:00:07.604 | HD Request # 124 | Receiving historical Daily data for GCG5.COMEX starting at 2025-01-03.
2025-01-08 00:00:07.604 | HD Request # 124 | Writing historical Daily data to the file GCG5.COMEX.dly.
2025-01-08 00:00:07.606 | HD Request # 124 | Bytes received: 230
2025-01-08 00:00:07.606 | HD Request # 124 | Received 4 Daily data records from 2025-01-03 00:00:00 to 2025-01-07 00:00:00 (5.0 days) and wrote 3 records for GCG5.COMEX
2025-01-08 00:00:07.606 | HD Request # 124 | Completion time: 3s.
2025-01-08 00:00:07.606 | HD Request # 124 | Daily data download complete for GCG5.COMEX. Unique request ID: 123
2025-01-08 00:00:07.606 | Removing historical data download ID 123.
2025-01-08 00:00:07.606 | Triggering next historical data download in queue.
2025-01-08 00:00:07.607 | HD Request # 125 | Downloading Historical Daily chart data for 6AH5.CME. Starting date: 2025-01-03. Service: rithmic.trading
2025-01-08 00:00:07.794 | GCG5.COMEX [CBV][M] Weekly #5 | Reloading chart.
2025-01-08 00:00:07.794 | GCG5.COMEX [CBV][M] Weekly #5 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2025-01-08 00:00:07.794 | GCG5.COMEX [CBV][M] Weekly #5 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2025-01-08 00:00:08.566 | GCG5.COMEX [CBV][M] Weekly #5 | Chart data loading complete.
2025-01-08 00:00:08.809 | GCG5.COMEX [CBV][M] Daily #6 | Reloading chart.
2025-01-08 00:00:08.809 | GCG5.COMEX [CBV][M] Daily #6 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2025-01-08 00:00:08.809 | GCG5.COMEX [CBV][M] Daily #6 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2025-01-08 00:00:09.428 | HD Request # 125 | Requesting historical Daily data for A6H25 starting at 2025-01-02. SC External HD service.
2025-01-08 00:00:09.473 | GCG5.COMEX [CBV][M] Monthly #4 | Reloading chart.
2025-01-08 00:00:09.473 | GCG5.COMEX [CBV][M] Monthly #4 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2025-01-08 00:00:09.473 | GCG5.COMEX [CBV][M] Monthly #4 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2025-01-08 00:00:10.092 | GCG5.COMEX [CBV][M] Daily #6 | Chart data loading complete.
2025-01-08 00:00:10.265 | GCG5.COMEX [CBV][M] Monthly #4 | Chart data loading complete.
2025-01-08 00:00:10.817 | HD Request # 125 | Receiving historical Daily data for 6AH5.CME starting at 2025-01-03.
2025-01-08 00:00:10.817 | HD Request # 125 | Writing historical Daily data to the file 6AH5.CME.dly.
2025-01-08 00:00:10.821 | HD Request # 125 | Bytes received: 238
2025-01-08 00:00:10.821 | HD Request # 125 | Received 4 Daily data records from 2025-01-03 00:00:00 to 2025-01-07 00:00:00 (5.0 days) and wrote 3 records for 6AH5.CME
2025-01-08 00:00:10.821 | HD Request # 125 | Completion time: 3s.
2025-01-08 00:00:10.821 | HD Request # 125 | Daily data download complete for 6AH5.CME. Unique request ID: 124
2025-01-08 00:00:10.821 | Removing historical data download ID 124.
2025-01-08 00:00:10.821 | Triggering next historical data download in queue.
2025-01-08 00:00:10.822 | HD Request # 126 | Downloading Historical Daily chart data for ESH5.CME. Starting date: 2025-01-03. Service: rithmic.trading
2025-01-08 00:00:10.824 | 6AH5.CME [CBV][M] Weekly #5 | Reloading chart.
2025-01-08 00:00:10.824 | 6AH5.CME [CBV][M] Weekly #5 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2025-01-08 00:00:10.824 | 6AH5.CME [CBV][M] Weekly #5 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2025-01-08 00:00:11.591 | 6AH5.CME [CBV][M] Weekly #5 | Chart data loading complete.
2025-01-08 00:00:11.642 | 6AH5.CME [CBV][M] Monthly #4 | Reloading chart.
2025-01-08 00:00:11.642 | 6AH5.CME [CBV][M] Monthly #4 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2025-01-08 00:00:11.642 | 6AH5.CME [CBV][M] Monthly #4 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2025-01-08 00:00:12.351 | HD Request # 126 | Requesting historical Daily data for ESH25 starting at 2025-01-02. SC External HD service.
2025-01-08 00:00:12.522 | 6AH5.CME [CBV][M] Monthly #4 | Chart data loading complete.
2025-01-08 00:00:12.703 | 6AH5.CME [CBV][M] Daily #6 | Reloading chart.
2025-01-08 00:00:12.703 | 6AH5.CME [CBV][M] Daily #6 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2025-01-08 00:00:12.703 | 6AH5.CME [CBV][M] Daily #6 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2025-01-08 00:00:13.376 | HD Request # 126 | Receiving historical Daily data for ESH5.CME starting at 2025-01-03.
2025-01-08 00:00:13.377 | HD Request # 126 | Writing historical Daily data to the file ESH5.CME.dly.
2025-01-08 00:00:13.378 | HD Request # 126 | Bytes received: 246
2025-01-08 00:00:13.378 | HD Request # 126 | Received 4 Daily data records from 2025-01-03 00:00:00 to 2025-01-07 00:00:00 (5.0 days) and wrote 3 records for ESH5.CME
2025-01-08 00:00:13.378 | HD Request # 126 | Completion time: 3s.
2025-01-08 00:00:13.378 | HD Request # 126 | Daily data download complete for ESH5.CME. Unique request ID: 125
2025-01-08 00:00:13.378 | Removing historical data download ID 125.
2025-01-08 00:00:13.378 | No download requests in the queue to start downloads for.
2025-01-08 00:00:13.539 | 6AH5.CME [CBV][M] Daily #6 | Chart data loading complete.
2025-01-08 00:00:13.747 | ESH5.CME [CBV][M] Weekly #5 | Reloading chart.
2025-01-08 00:00:13.747 | ESH5.CME [CBV][M] Weekly #5 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2025-01-08 00:00:13.747 | ESH5.CME [CBV][M] Weekly #5 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2025-01-08 00:00:14.125 | ESH5.CME [CBV][M] Weekly #5 | Chart data loading complete.
2025-01-08 00:00:14.275 | ESH5.CME [CBV][M] Daily #6 | Reloading chart.
2025-01-08 00:00:14.275 | ESH5.CME [CBV][M] Daily #6 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2025-01-08 00:00:14.275 | ESH5.CME [CBV][M] Daily #6 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2025-01-08 00:00:14.593 | ESH5.CME [CBV][M] Monthly #4 | Reloading chart.
2025-01-08 00:00:14.593 | ESH5.CME [CBV][M] Monthly #4 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2025-01-08 00:00:14.593 | ESH5.CME [CBV][M] Monthly #4 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2025-01-08 00:00:14.911 | ESH5.CME [CBV][M] Daily #6 | Chart data loading complete.
2025-01-08 00:00:15.082 | ESH5.CME [CBV][M] Monthly #4 | Chart data loading complete.
2025-01-08 00:20:39.847 | Chat | Message response. Chat ID: 429. Request ID: 1134629389
2025-01-08 02:01:03.214 | Chat | Message response. Chat ID: 429. Request ID: 1134629390
2025-01-08 02:33:03.653 | Chat | Message response. Chat ID: 429. Request ID: 1134629391
2025-01-08 02:45:47.684 | Chat | Message response. Chat ID: 429. Request ID: 1134629392
2025-01-08 02:51:58.431 | HTTPS connection ID:19 to downloads.rithmic.com:443 for request ID:19 (5) | Creating socket. Using TLS 1.2.
2025-01-08 02:51:58.431 | HTTPS connection ID:19 to downloads.rithmic.com:443 for request ID:19 (5) | New receive buffer size: 0
2025-01-08 02:51:58.431 | HTTPS connection ID:19 to downloads.rithmic.com:443 for request ID:19 (5) | Connecting to IP: 216.66.0.130.
2025-01-08 02:51:59.871 | Rithmic Direct - DTC | Wrote file: C:\SierraChart - TopStep\RithmicConnections.json. Size: 81131
2025-01-08 02:51:59.871 | Rithmic Direct - DTC | Processed connection points. Count: 347
2025-01-08 02:52:00.849 | HTTPS connection ID:19 to downloads.rithmic.com:443 for request ID:19 (5) | CloseSocket call.
2025-01-08 02:52:00.849 | HTTPS connection ID:19 to downloads.rithmic.com:443 for request ID:19 (5) | Shutdown started. Waiting for graceful close.
2025-01-08 02:52:01.082 | HTTPS connection ID:19 to downloads.rithmic.com:443 for request ID:19 (5) | Socket gracefully closed by remote side.
2025-01-08 02:52:01.082 | HTTPS connection ID:19 to downloads.rithmic.com:443 for request ID:19 (5) | Closed.
2025-01-08 02:55:13.568 | Chat | Message response. Chat ID: 429. Request ID: 1134629393
2025-01-08 03:00:00.091 | Chat | Message response. Chat ID: 429. Request ID: 1134629394
2025-01-08 03:15:10.880 | Chat | Message response. Chat ID: 429. Request ID: 1134629395
2025-01-08 05:49:59.718 | Chat | Message response. Chat ID: 429. Request ID: 1134629396
2025-01-08 06:02:14.895 | Rithmic Direct - DTC | There has been no activity on the network socket for 1m 19s. Will reconnect.
2025-01-08 06:02:14.895 | Connection to the external service has been lost.
2025-01-08 06:02:15.110 | Rithmic Direct - DTC | Waiting for socket receive thread to end
2025-01-08 06:02:15.111 | DTC Client socket (1) | CloseSocket call.
2025-01-08 06:02:15.111 | DTC Client socket (1) | Max send buffers used during socket life: 4
2025-01-08 06:02:15.111 | DTC Client socket (1) | Max send buffer size during socket life: 666
2025-01-08 06:02:15.111 | DTC Client socket (1) | Shutdown started. Waiting for graceful close.
2025-01-08 06:02:15.111 | Rithmic Direct - DTC | Disconnected.
2025-01-08 06:02:15.111 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2025-01-08 06:02:19.691 |
2025-01-08 06:02:19.691 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated
2025-01-08 06:02:19.691 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50508
2025-01-08 06:02:19.691 | Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50508
2025-01-08 06:02:19.980 | DTC Client socket (5) | Creating socket. Using TLS 1.2.
2025-01-08 06:02:19.980 | DTC Client socket (5) | New receive buffer size: 0
2025-01-08 06:02:19.980 | DTC Client socket (5) | Connecting to IP: 216.57.156.163.
2025-01-08 06:02:20.366 | Rithmic Direct - DTC | Network connection to server complete.
2025-01-08 06:02:20.366 | Rithmic Direct - DTC | Starting socket receive thread.
2025-01-08 06:02:20.366 | Rithmic Direct - DTC | Setting DTC encoding to Binary
2025-01-08 06:02:20.366 | Rithmic Direct - DTC | Sending logon request message.
2025-01-08 06:02:23.842 | Rithmic Direct - DTC | Received logon response.
2025-01-08 06:02:23.842 | Rithmic Direct - DTC | Server Name: .
2025-01-08 06:02:23.842 | Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8
2025-01-08 06:02:23.842 | Rithmic Direct - DTC | Successfully connected.
2025-01-08 06:02:23.842 | Rithmic Direct - DTC | Trading is supported.
2025-01-08 06:02:23.842 | Rithmic Direct - DTC | Order cancel and replace is supported.
2025-01-08 06:02:23.842 | Rithmic Direct - DTC | OCO Orders supported.
2025-01-08 06:02:23.842 | Rithmic Direct - DTC | Symbol and Exchange Delimiter: .
2025-01-08 06:02:23.842 | Rithmic Direct - DTC | MarketDepthIsSupported: 0
2025-01-08 06:02:23.842 | Rithmic Direct - DTC | Connected to server complete.
2025-01-08 06:02:23.842 | Denali Data Feed | Waiting for socket receive thread to end
2025-01-08 06:02:23.842 | DTC Client socket (2) | CloseSocket call.
2025-01-08 06:02:23.842 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 06:02:23.842 | Denali Data Feed | Disconnected from the server.
2025-01-08 06:02:23.842 | SC Data with Depth | Waiting for socket receive thread to end
2025-01-08 06:02:23.843 | DTC Client socket (3) | CloseSocket call.
2025-01-08 06:02:23.843 | DTC Client socket (3) | Write in progress. Shutdown being delayed. PendingSize=0
2025-01-08 06:02:23.843 | SC Data with Depth | Disconnected from the server.
2025-01-08 06:02:23.844 | No download requests in the queue to start downloads for. | Number times message added: 3
2025-01-08 06:02:23.844 | Subscribing to symbol for symbol alert. NQZ4.CME
2025-01-08 06:02:23.844 | Mapping NQZ4.CME to NQZ24. Service code: cme
2025-01-08 06:02:23.844 | Using symbol data fast lookup vector
2025-01-08 06:02:23.844 | Denali Data Feed | Starting real-time market data updates for: NQZ4.CME (NQZ24). ID: 1 Service code: cme
2025-01-08 06:02:23.844 | Denali Data Feed | Connecting to the server ds25-2.sierracharts.com. Port 443
2025-01-08 06:02:23.844 | Denali Data Feed | Requesting security definition data for: NQZ4.CME (NQZ24). ID: 1
2025-01-08 06:02:23.844 | Subscribing to symbol for symbol alert. GCZ4.COMEX
2025-01-08 06:02:23.844 | Mapping GCZ4.COMEX to GCZ24. Service code: comex
2025-01-08 06:02:23.845 | Denali Data Feed | Starting real-time market data updates for: GCZ4.COMEX (GCZ24). ID: 2 Service code: comex
2025-01-08 06:02:23.845 | Denali Data Feed | Requesting security definition data for: GCZ4.COMEX (GCZ24). ID: 2
2025-01-08 06:02:23.924 | DTC Client socket (6) | Creating socket.
2025-01-08 06:02:23.924 | DTC Client socket (6) | New receive buffer size: 0
2025-01-08 06:02:23.924 | DTC Client socket (6) | Connecting to IP: 64.152.155.21.
2025-01-08 06:02:24.002 | DTC Client socket (3) | Write has completed. Shutdown being performed.
2025-01-08 06:02:24.002 | DTC Client socket (3) | Shutdown started. Waiting for graceful close.
2025-01-08 06:02:24.060 | Denali Data Feed | Failed connections: 1
2025-01-08 06:02:24.060 | DTC Client socket (6) | CloseSocket call.
2025-01-08 06:02:24.060 | Denali Data Feed | Disconnected from the server.
2025-01-08 06:02:24.060 | Denali Data Feed | Data feed disconnected. Will reconnect in 3 seconds.
2025-01-08 06:02:24.060 | DTC Client socket (6) | Closed.
2025-01-08 06:02:24.060 | Mapping 6AH5.CME to 6AH25. Service code: cme
2025-01-08 06:02:24.060 | Denali Data Feed | Starting real-time market data updates for: 6AH5.CME (6AH25). ID: 3 Service code: cme
2025-01-08 06:02:24.060 | Denali Data Feed | Requesting security definition data for: 6AH5.CME (6AH25). ID: 3
2025-01-08 06:02:24.060 | Added historical Intraday data request for 6AH5.CME to the queue.
2025-01-08 06:02:24.060 | Intraday data recording state for symbol 6AH5.CME is set to download 'Pending'.
2025-01-08 06:02:24.060 | Triggering next historical data download in queue.
2025-01-08 06:02:24.061 | Delaying start of download for 6AH5.CME.
2025-01-08 06:02:24.107 | Mapping M6AH5.CME to M6AH25. Service code: cme
2025-01-08 06:02:24.107 | Denali Data Feed | Starting real-time market data updates for: M6AH5.CME (M6AH25). ID: 4 Service code: cme
2025-01-08 06:02:24.107 | Denali Data Feed | Requesting security definition data for: M6AH5.CME (M6AH25). ID: 4
2025-01-08 06:02:24.107 | Added historical Intraday data request for M6AH5.CME to the queue.
2025-01-08 06:02:24.107 | Intraday data recording state for symbol M6AH5.CME is set to download 'Pending'.
2025-01-08 06:02:24.107 | Triggering next historical data download in queue.
2025-01-08 06:02:24.108 | Mapping SIH5.COMEX to SIH25. Service code: comex
2025-01-08 06:02:24.108 | Denali Data Feed | Starting real-time market data updates for: SIH5.COMEX (SIH25). ID: 5 Service code: comex
2025-01-08 06:02:24.108 | Denali Data Feed | Requesting security definition data for: SIH5.COMEX (SIH25). ID: 5
2025-01-08 06:02:24.108 | Added historical Intraday data request for SIH5.COMEX to the queue.
2025-01-08 06:02:24.108 | Intraday data recording state for symbol SIH5.COMEX is set to download 'Pending'.
2025-01-08 06:02:24.108 | Triggering next historical data download in queue.
2025-01-08 06:02:24.131 | Mapping SILH5.COMEX to SILH25. Service code: comex
2025-01-08 06:02:24.131 | Denali Data Feed | Starting real-time market data updates for: SILH5.COMEX (SILH25). ID: 6 Service code: comex
2025-01-08 06:02:24.131 | Denali Data Feed | Requesting security definition data for: SILH5.COMEX (SILH25). ID: 6
2025-01-08 06:02:24.131 | Added historical Intraday data request for SILH5.COMEX to the queue.
2025-01-08 06:02:24.131 | Intraday data recording state for symbol SILH5.COMEX is set to download 'Pending'.
2025-01-08 06:02:24.131 | Triggering next historical data download in queue.
2025-01-08 06:02:24.131 | Mapping ESU4.CME to ESU24. Service code: cme
2025-01-08 06:02:24.132 | Denali Data Feed | Starting real-time market data updates for: ESU4.CME (ESU24). ID: 7 Service code: cme
2025-01-08 06:02:24.132 | Denali Data Feed | Requesting security definition data for: ESU4.CME (ESU24). ID: 7
2025-01-08 06:02:24.132 | Added historical Intraday data request for ESU4.CME to the queue.
2025-01-08 06:02:24.132 | Intraday data recording state for symbol ESU4.CME is set to download 'Pending'.
2025-01-08 06:02:24.132 | Triggering next historical data download in queue.
2025-01-08 06:02:24.132 | Mapping GCG5.COMEX to GCG25. Service code: comex
2025-01-08 06:02:24.132 | Denali Data Feed | Starting real-time market data updates for: GCG5.COMEX (GCG25). ID: 8 Service code: comex
2025-01-08 06:02:24.132 | Denali Data Feed | Requesting security definition data for: GCG5.COMEX (GCG25). ID: 8
2025-01-08 06:02:24.132 | Added historical Intraday data request for GCG5.COMEX to the queue.
2025-01-08 06:02:24.132 | Intraday data recording state for symbol GCG5.COMEX is set to download 'Pending'.
2025-01-08 06:02:24.135 | SC Data with Depth | Starting real-time market data updates for: USDX. ID: 9 Service code: fxstatscalc
2025-01-08 06:02:24.135 | SC Data with Depth | Connecting to the server ds12.sierracharts.com. Port 443
2025-01-08 06:02:24.135 | SC Data with Depth | Requesting security definition data for: USDX. ID: 9
2025-01-08 06:02:24.135 | Added historical Intraday data request for USDX to the queue.
2025-01-08 06:02:24.135 | Intraday data recording state for symbol USDX is set to download 'Pending'.
2025-01-08 06:02:24.135 | Triggering next historical data download in queue.
2025-01-08 06:02:24.135 | Mapping NQH5.CME to NQH25. Service code: cme
2025-01-08 06:02:24.135 | Denali Data Feed | Starting real-time market data updates for: NQH5.CME (NQH25). ID: 10 Service code: cme
2025-01-08 06:02:24.135 | Denali Data Feed | Requesting security definition data for: NQH5.CME (NQH25). ID: 10
2025-01-08 06:02:24.135 | Added historical Intraday data request for NQH5.CME to the queue.
2025-01-08 06:02:24.135 | Intraday data recording state for symbol NQH5.CME is set to download 'Pending'.
2025-01-08 06:02:24.164 | Mapping ESH5.CME to ESH25. Service code: cme
2025-01-08 06:02:24.164 | Denali Data Feed | Starting real-time market data updates for: ESH5.CME (ESH25). ID: 11 Service code: cme
2025-01-08 06:02:24.164 | Denali Data Feed | Requesting security definition data for: ESH5.CME (ESH25). ID: 11
2025-01-08 06:02:24.164 | Added historical Intraday data request for ESH5.CME to the queue.
2025-01-08 06:02:24.164 | Intraday data recording state for symbol ESH5.CME is set to download 'Pending'.
2025-01-08 06:02:24.164 | Triggering next historical data download in queue.
2025-01-08 06:02:24.248 | DTC Client socket (6) | Creating socket.
2025-01-08 06:02:24.248 | DTC Client socket (6) | New receive buffer size: 0
2025-01-08 06:02:24.248 | DTC Client socket (6) | Connecting to IP: 69.39.70.241.
2025-01-08 06:02:24.327 | Using Bid/Ask average for last trade price for SPX500
2025-01-08 06:02:24.327 | SC Data with Depth | Starting real-time market data updates for: SPX500. ID: 12 Service code: fxcm
2025-01-08 06:02:24.327 | SC Data with Depth | Requesting security definition data for: SPX500. ID: 12
2025-01-08 06:02:24.327 | Added historical Intraday data request for SPX500 to the queue.
2025-01-08 06:02:24.327 | Intraday data recording state for symbol SPX500 is set to download 'Pending'.
2025-01-08 06:02:24.327 | Triggering next historical data download in queue.
2025-01-08 06:02:24.377 | Mapping MNQH5.CME to MNQH25. Service code: cme
2025-01-08 06:02:24.377 | Denali Data Feed | Starting real-time market data updates for: MNQH5.CME (MNQH25). ID: 13 Service code: cme
2025-01-08 06:02:24.377 | Denali Data Feed | Requesting security definition data for: MNQH5.CME (MNQH25). ID: 13
2025-01-08 06:02:24.377 | Added historical Intraday data request for MNQH5.CME to the queue.
2025-01-08 06:02:24.377 | Intraday data recording state for symbol MNQH5.CME is set to download 'Pending'.
2025-01-08 06:02:24.377 | Triggering next historical data download in queue.
2025-01-08 06:02:24.378 | Mapping MGCG5.COMEX to MGCG25. Service code: comex
2025-01-08 06:02:24.378 | Denali Data Feed | Starting real-time market data updates for: MGCG5.COMEX (MGCG25). ID: 14 Service code: comex
2025-01-08 06:02:24.378 | Denali Data Feed | Requesting security definition data for: MGCG5.COMEX (MGCG25). ID: 14
2025-01-08 06:02:24.378 | Added historical Intraday data request for MGCG5.COMEX to the queue.
2025-01-08 06:02:24.378 | Intraday data recording state for symbol MGCG5.COMEX is set to download 'Pending'.
2025-01-08 06:02:24.378 | Triggering next historical data download in queue.
2025-01-08 06:02:24.389 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 06:02:24.389 | DTC Client socket (2) | Closed.
2025-01-08 06:02:24.530 | DTC Client socket (3) | Socket gracefully closed by remote side.
2025-01-08 06:02:24.530 | DTC Client socket (3) | Closed.
2025-01-08 06:02:24.600 | SC Data with Depth | Network connection to server complete.
2025-01-08 06:02:24.600 | SC Data with Depth | Starting socket receive thread.
2025-01-08 06:02:24.600 | SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: high
2025-01-08 06:02:24.887 | SC Data with Depth | Setting DTC encoding to Binary VLS
2025-01-08 06:02:24.887 | SC Data with Depth | Sending logon request message.
2025-01-08 06:02:25.137 | Mapping MESH5.CME to MESH25. Service code: cme
2025-01-08 06:02:25.137 | Denali Data Feed | Starting real-time market data updates for: MESH5.CME (MESH25). ID: 15 Service code: cme
2025-01-08 06:02:25.137 | Denali Data Feed | Requesting security definition data for: MESH5.CME (MESH25). ID: 15
2025-01-08 06:02:25.137 | Added historical Intraday data request for MESH5.CME to the queue.
2025-01-08 06:02:25.137 | Intraday data recording state for symbol MESH5.CME is set to download 'Pending'.
2025-01-08 06:02:25.137 | Triggering next historical data download in queue.
2025-01-08 06:02:25.172 | NQH5.CME[M] #17 | StartDateTimeForLoadingOrderFills: 2024-01-02 00:00:00
2025-01-08 06:02:25.175 | GCG5.COMEX[M] 5 Min #11 | StartDateTimeForLoadingOrderFills: 2024-01-02 00:00:00
2025-01-08 06:02:25.191 | MESH5.CME[M] 1 Min #1 | StartDateTimeForLoadingOrderFills: 2024-01-02 00:00:00
2025-01-08 06:02:25.341 | ESH5.CME[M] 5 Min #11 | StartDateTimeForLoadingOrderFills: 2024-01-02 00:00:00
2025-01-08 06:02:25.484 | ESH5.CME [CBV][M] 15 Min #10 | StartDateTimeForLoadingOrderFills: 2024-01-02 00:00:00
2025-01-08 06:02:25.628 | SC Data with Depth | Received logon response.
2025-01-08 06:02:25.628 | SC Data with Depth | Server Name: SC Realtime Server.
2025-01-08 06:02:25.628 | SC Data with Depth | Server protocol version: 8. Client protocol version: 8
2025-01-08 06:02:25.628 | SC Data with Depth | Successfully connected.
2025-01-08 06:02:25.628 | SC Data with Depth | Trading is not supported.
2025-01-08 06:02:25.628 | SC Data with Depth | MarketDepthIsSupported: 1
2025-01-08 06:02:25.628 | SC Data with Depth | Restarting real-time data updates for symbol: SPX500
2025-01-08 06:02:25.628 | SC Data with Depth | Restarting real-time data updates for symbol: USDX
2025-01-08 06:02:26.362 | SC Data with Depth | Setting external service identifier for symbol SPX500 to 55
2025-01-08 06:02:26.362 | SC Data with Depth | Received security definition for symbol SPX500
2025-01-08 06:02:26.362 | SC Data with Depth | Setting external service identifier for symbol USDX to 1
2025-01-08 06:02:26.362 | SC Data with Depth | Received security definition for symbol USDX
2025-01-08 06:02:27.484 | Denali Data Feed | Connecting to the server ds25.sierracharts.com. Port 443
2025-01-08 06:02:27.609 | DTC Client socket (2) | Creating socket.
2025-01-08 06:02:27.609 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 06:02:27.609 | DTC Client socket (2) | Connecting to IP: 64.152.155.20.
2025-01-08 06:02:27.855 | Denali Data Feed | Network connection to server complete.
2025-01-08 06:02:27.855 | Denali Data Feed | Starting socket receive thread.
2025-01-08 06:02:27.855 | Denali Data Feed | Sending encoding request to server: Binary VLS. Compression: high
2025-01-08 06:02:28.113 | Denali Data Feed | Setting DTC encoding to Binary VLS
2025-01-08 06:02:28.113 | Denali Data Feed | Sending logon request message.
2025-01-08 06:02:28.853 | Requesting market depth updates for: 6AH5.CME if supported. NumLevels=50
2025-01-08 06:02:28.853 | Requesting market depth updates for: ESH5.CME if supported. NumLevels=50
2025-01-08 06:02:28.853 | Requesting market depth updates for: ESU4.CME if supported. NumLevels=50
2025-01-08 06:02:28.853 | Requesting market depth updates for: GCG5.COMEX if supported. NumLevels=50
2025-01-08 06:02:28.853 | Requesting market depth updates for: MESH5.CME if supported. NumLevels=50
2025-01-08 06:02:28.853 | Requesting market depth updates for: MGCG5.COMEX if supported. NumLevels=50
2025-01-08 06:02:28.853 | Requesting market depth updates for: MNQH5.CME if supported. NumLevels=50
2025-01-08 06:02:28.853 | Requesting market depth updates for: NQH5.CME if supported. NumLevels=50
2025-01-08 06:02:28.853 | Requesting market depth updates for: SIH5.COMEX if supported. NumLevels=50
2025-01-08 06:02:28.860 | Denali Data Feed | Received logon response.
2025-01-08 06:02:28.860 | Denali Data Feed | Server Name: SC Realtime Server.
2025-01-08 06:02:28.860 | Denali Data Feed | Server protocol version: 8. Client protocol version: 8
2025-01-08 06:02:28.860 | Denali Data Feed | Successfully connected.
2025-01-08 06:02:28.860 | Denali Data Feed | Trading is not supported.
2025-01-08 06:02:28.860 | Denali Data Feed | MarketDepthIsSupported: 1
2025-01-08 06:02:28.860 | Denali Data Feed | Restarting real-time data updates for symbol: 6AH5.CME -> 6AH25. Market Depth data restarted.
2025-01-08 06:02:28.860 | Denali Data Feed | Restarting real-time data updates for symbol: ESH5.CME -> ESH25. Market Depth data restarted.
2025-01-08 06:02:28.860 | Denali Data Feed | Restarting real-time data updates for symbol: ESU4.CME -> ESU24. Market Depth data restarted.
2025-01-08 06:02:28.860 | Denali Data Feed | Restarting real-time data updates for symbol: GCG5.COMEX -> GCG25. Market Depth data restarted.
2025-01-08 06:02:28.860 | Denali Data Feed | Restarting real-time data updates for symbol: GCZ4.COMEX -> GCZ24
2025-01-08 06:02:28.860 | Denali Data Feed | Restarting real-time data updates for symbol: M6AH5.CME -> M6AH25
2025-01-08 06:02:28.860 | Denali Data Feed | Restarting real-time data updates for symbol: MESH5.CME -> MESH25. Market Depth data restarted.
2025-01-08 06:02:28.860 | Denali Data Feed | Restarting real-time data updates for symbol: MGCG5.COMEX -> MGCG25. Market Depth data restarted.
2025-01-08 06:02:28.860 | Denali Data Feed | Restarting real-time data updates for symbol: MNQH5.CME -> MNQH25. Market Depth data restarted.
2025-01-08 06:02:28.860 | Denali Data Feed | Restarting real-time data updates for symbol: NQH5.CME -> NQH25. Market Depth data restarted.
2025-01-08 06:02:28.860 | Denali Data Feed | Restarting real-time data updates for symbol: NQZ4.CME -> NQZ24
2025-01-08 06:02:28.860 | Denali Data Feed | Restarting real-time data updates for symbol: SIH5.COMEX -> SIH25. Market Depth data restarted.
2025-01-08 06:02:28.860 | Denali Data Feed | Restarting real-time data updates for symbol: SILH5.COMEX -> SILH25
2025-01-08 06:02:30.115 | Denali Data Feed | Clearing market depth for 6AH5.CME
2025-01-08 06:02:30.115 | Denali Data Feed | Clearing market depth for ESH5.CME
2025-01-08 06:02:30.115 | Denali Data Feed | Clearing market depth for ESU4.CME
2025-01-08 06:02:30.115 | Denali Data Feed | Clearing market depth for GCG5.COMEX
2025-01-08 06:02:30.115 | Denali Data Feed | Clearing market depth for MESH5.CME
2025-01-08 06:02:30.115 | Denali Data Feed | Clearing market depth for MGCG5.COMEX
2025-01-08 06:02:30.115 | Denali Data Feed | Clearing market depth for MNQH5.CME
2025-01-08 06:02:30.115 | Denali Data Feed | Clearing market depth for NQH5.CME
2025-01-08 06:02:30.115 | Denali Data Feed | Clearing market depth for SIH5.COMEX
2025-01-08 06:02:30.115 | Denali Data Feed | Setting external service identifier for symbol 6AH5.CME to 52126
2025-01-08 06:02:30.115 | Denali Data Feed | Received security definition for symbol 6AH5.CME
2025-01-08 06:02:30.115 | Denali Data Feed | Setting external service identifier for symbol ESH5.CME to 5002
2025-01-08 06:02:30.115 | Denali Data Feed | Received security definition for symbol ESH5.CME
2025-01-08 06:02:30.115 | Denali Data Feed | Real-time data for symbol ESU4.CME is currently unavailable.
2025-01-08 06:02:30.115 | Denali Data Feed | Received security definition for symbol ESU4.CME
2025-01-08 06:02:30.115 | Denali Data Feed | Setting external service identifier for symbol GCG5.COMEX to 1551
2025-01-08 06:02:30.115 | Denali Data Feed | Received security definition for symbol GCG5.COMEX
2025-01-08 06:02:30.115 | Denali Data Feed | Real-time data for symbol GCZ4.COMEX is currently unavailable.
2025-01-08 06:02:30.115 | Denali Data Feed | Received security definition for symbol GCZ4.COMEX
2025-01-08 06:02:30.115 | Denali Data Feed | Setting external service identifier for symbol M6AH5.CME to 42185124
2025-01-08 06:02:30.115 | Denali Data Feed | Received security definition for symbol M6AH5.CME
2025-01-08 06:02:30.115 | Denali Data Feed | Setting external service identifier for symbol MESH5.CME to 42005347
2025-01-08 06:02:30.115 | Denali Data Feed | Received security definition for symbol MESH5.CME
2025-01-08 06:02:30.115 | Denali Data Feed | Setting external service identifier for symbol MGCG5.COMEX to 69
2025-01-08 06:02:30.115 | Denali Data Feed | Received security definition for symbol MGCG5.COMEX
2025-01-08 06:02:30.115 | Denali Data Feed | Setting external service identifier for symbol MNQH5.CME to 42003617
2025-01-08 06:02:30.115 | Denali Data Feed | Received security definition for symbol MNQH5.CME
2025-01-08 06:02:30.115 | Denali Data Feed | Setting external service identifier for symbol NQH5.CME to 42288528
2025-01-08 06:02:30.115 | Denali Data Feed | Received security definition for symbol NQH5.CME
2025-01-08 06:02:30.115 | Denali Data Feed | Real-time data for symbol NQZ4.CME is currently unavailable.
2025-01-08 06:02:30.115 | Denali Data Feed | Received security definition for symbol NQZ4.CME
2025-01-08 06:02:30.115 | Denali Data Feed | Setting external service identifier for symbol SIH5.COMEX to 5556
2025-01-08 06:02:30.115 | Denali Data Feed | Received security definition for symbol SIH5.COMEX
2025-01-08 06:02:30.115 | Denali Data Feed | Setting external service identifier for symbol SILH5.COMEX to 42007667
2025-01-08 06:02:30.115 | Denali Data Feed | Received security definition for symbol SILH5.COMEX
2025-01-08 06:02:34.858 | DTC Client socket (1) | Socket gracefully closed by remote side.
2025-01-08 06:02:34.858 | DTC Client socket (1) | Closed.
2025-01-08 06:02:35.577 | HD Request # 127 | Downloading Intraday chart data for 6AH5.CME to the file 6AH5.CME.scid. Service: cme
2025-01-08 06:02:35.577 | HD Request # 127 | Download start date-time: 2025-01-08 06:02:06.000000. File last date-time: 2025-01-08 06:02:06.521001
2025-01-08 06:02:35.577 | HD Request # 127 | Using server: ds32.sierracharts.com port 10149
2025-01-08 06:02:35.698 | Socket (1) | Creating socket.
2025-01-08 06:02:35.698 | Socket (1) | New receive buffer size: 0
2025-01-08 06:02:35.698 | Socket (1) | Connecting to IP: 67.214.125.3.
2025-01-08 06:02:36.203 | HD Request # 127 | Setting DTC encoding to Binary VLS
2025-01-08 06:02:36.203 | HD Request # 127 | Sending historical data logon request message.
2025-01-08 06:02:36.498 | HD Request # 127 | Requesting Intraday data. Start date-time: 2025-01-08 06:02:06. Record interval: 0. Symbol: 6AH25
2025-01-08 06:02:36.746 | HD Request # 127 | Decompressing data.
2025-01-08 06:02:36.993 | HD Request # 127 | Receiving Intraday data for 6AH5.CME starting at 2025-01-08 06:02:06.521000
2025-01-08 06:02:36.993 | Socket (1) | CloseSocket call.
2025-01-08 06:02:36.993 | Socket (1) | Shutdown started. Waiting for graceful close.
2025-01-08 06:02:37.007 | Historical data download thread signaled to stop.
2025-01-08 06:02:37.007 | HD Request # 127 | Timestamp of first Intraday data file record written: 2025-01-08 06:02:16.484000.
2025-01-08 06:02:37.008 | HD Request # 127 | Received 8 Intraday data records from 2025-01-08 06:02:06.521000 to 2025-01-08 06:02:26.635001 (20.1 seconds. Delay: 10.4 seconds) and wrote 6 records for 6AH5.CME
2025-01-08 06:02:37.008 | HD Request # 127 | Add time&sales data | Remembered last file record date-time: 2025-01-08 11:02:26.635001
2025-01-08 06:02:37.008 | Added 4 Time and Sales records to Intraday data file for 6AH5.CME after download.
2025-01-08 06:02:37.008 | HD Request # 127 | Completion time: 2s.
2025-01-08 06:02:37.008 | HD Request # 127 | Intraday data download complete for 6AH5.CME. Unique request ID: 127
2025-01-08 06:02:37.008 | Removing historical data download ID 127.
2025-01-08 06:02:37.008 | Real-time Intraday chart data file updates started for 6AH5.CME
2025-01-08 06:02:37.008 | Intraday chart data file opened for 6AH5.CME
2025-01-08 06:02:37.008 | HD Request # 127 | Enabling Intraday chart updating for symbol.
2025-01-08 06:02:37.008 | Triggering next historical data download in queue.
2025-01-08 06:02:37.008 | HD Request # 128 | Downloading Intraday chart data for M6AH5.CME to the file M6AH5.CME.scid. Service: cme
2025-01-08 06:02:37.008 | HD Request # 128 | Download start date-time: 2025-01-08 06:01:02.000000. File last date-time: 2025-01-08 06:01:02.027001
2025-01-08 06:02:37.008 | HD Request # 128 | Using server: ds32.sierracharts.com port 10150
2025-01-08 06:02:37.009 | Socket (3) | Creating socket.
2025-01-08 06:02:37.009 | Socket (3) | New receive buffer size: 0
2025-01-08 06:02:37.009 | Socket (3) | Connecting to IP: 67.214.125.3.
2025-01-08 06:02:37.241 | Socket (1) | Socket gracefully closed by remote side.
2025-01-08 06:02:37.241 | Socket (1) | Closed.
2025-01-08 06:02:37.495 | HD Request # 128 | Setting DTC encoding to Binary VLS
2025-01-08 06:02:37.495 | HD Request # 128 | Sending historical data logon request message.
2025-01-08 06:02:37.782 | HD Request # 128 | Requesting Intraday data. Start date-time: 2025-01-08 06:01:02. Record interval: 0. Symbol: M6AH25
2025-01-08 06:02:38.022 | HD Request # 128 | Decompressing data.
2025-01-08 06:02:38.262 | HD Request # 128 | Receiving Intraday data for M6AH5.CME starting at 2025-01-08 06:01:02.027000
2025-01-08 06:02:38.262 | Socket (3) | CloseSocket call.
2025-01-08 06:02:38.262 | Socket (3) | Shutdown started. Waiting for graceful close.
2025-01-08 06:02:38.270 | Historical data download thread signaled to stop.
2025-01-08 06:02:38.270 | HD Request # 128 | Received 2 Intraday data records from 2025-01-08 06:01:02.027000 to 2025-01-08 06:01:02.027001 (0.0 seconds. Delay: 96.2 seconds) and wrote 0 records for M6AH5.CME
2025-01-08 06:02:38.270 | HD Request # 128 | Add time&sales data | Remembered last file record date-time: 2025-01-08 11:01:02.027001
2025-01-08 06:02:38.270 | HD Request # 128 | Completion time: 1s.
2025-01-08 06:02:38.270 | HD Request # 128 | Intraday data download complete for M6AH5.CME. Unique request ID: 128
2025-01-08 06:02:38.270 | Removing historical data download ID 128.
2025-01-08 06:02:38.270 | Real-time Intraday chart data file updates started for M6AH5.CME
2025-01-08 06:02:38.270 | Intraday chart data file opened for M6AH5.CME
2025-01-08 06:02:38.270 | HD Request # 128 | Enabling Intraday chart updating for symbol.
2025-01-08 06:02:38.270 | Triggering next historical data download in queue.
2025-01-08 06:02:38.270 | HD Request # 129 | Downloading Intraday chart data for SIH5.COMEX to the file SIH5.COMEX.scid. Service: comex
2025-01-08 06:02:38.270 | HD Request # 129 | Download start date-time: 2025-01-08 06:01:40.000000. File last date-time: 2025-01-08 06:01:40.390000
2025-01-08 06:02:38.270 | HD Request # 129 | Using server: ds32.sierracharts.com port 10149
2025-01-08 06:02:38.270 | Socket (1) | Creating socket.
2025-01-08 06:02:38.270 | Socket (1) | New receive buffer size: 0
2025-01-08 06:02:38.270 | Socket (1) | Connecting to IP: 67.214.125.3.
2025-01-08 06:02:38.502 | Socket (3) | Socket gracefully closed by remote side.
2025-01-08 06:02:38.502 | Socket (3) | Closed.
2025-01-08 06:02:38.739 | HD Request # 129 | Setting DTC encoding to Binary VLS
2025-01-08 06:02:38.739 | HD Request # 129 | Sending historical data logon request message.
2025-01-08 06:02:38.970 | HD Request # 129 | Requesting Intraday data. Start date-time: 2025-01-08 06:01:40. Record interval: 0. Symbol: SIH25
2025-01-08 06:02:39.201 | HD Request # 129 | Decompressing data.
2025-01-08 06:02:39.432 | HD Request # 129 | Receiving Intraday data for SIH5.COMEX starting at 2025-01-08 06:01:40.390000
2025-01-08 06:02:39.432 | Socket (1) | CloseSocket call.
2025-01-08 06:02:39.432 | Socket (1) | Shutdown started. Waiting for graceful close.
2025-01-08 06:02:39.454 | Historical data download thread signaled to stop.
2025-01-08 06:02:39.454 | HD Request # 129 | Timestamp of first Intraday data file record written: 2025-01-08 06:02:16.485000.
2025-01-08 06:02:39.454 | HD Request # 129 | Received 2 Intraday data records from 2025-01-08 06:01:40.390000 to 2025-01-08 06:02:16.485000 (36.1 seconds. Delay: 23.0 seconds) and wrote 1 record for SIH5.COMEX
2025-01-08 06:02:39.454 | HD Request # 129 | Add time&sales data | Remembered last file record date-time: 2025-01-08 11:02:16.485000
2025-01-08 06:02:39.455 | HD Request # 129 | Completion time: 1s.
2025-01-08 06:02:39.455 | HD Request # 129 | Intraday data download complete for SIH5.COMEX. Unique request ID: 129
2025-01-08 06:02:39.455 | Removing historical data download ID 129.
2025-01-08 06:02:39.455 | Real-time Intraday chart data file updates started for SIH5.COMEX
2025-01-08 06:02:39.455 | Intraday chart data file opened for SIH5.COMEX
2025-01-08 06:02:39.455 | HD Request # 129 | Enabling Intraday chart updating for symbol.
2025-01-08 06:02:39.455 | Triggering next historical data download in queue.
2025-01-08 06:02:39.455 | HD Request # 130 | Downloading Intraday chart data for SILH5.COMEX to the file SILH5.COMEX.scid. Service: comex
2025-01-08 06:02:39.455 | HD Request # 130 | Download start date-time: 2025-01-08 06:02:14.000000. File last date-time: 2025-01-08 06:02:14.062000
2025-01-08 06:02:39.455 | HD Request # 130 | Using server: ds32.sierracharts.com port 10150
2025-01-08 06:02:39.455 | Socket (3) | Creating socket.
2025-01-08 06:02:39.455 | Socket (3) | New receive buffer size: 0
2025-01-08 06:02:39.455 | Socket (3) | Connecting to IP: 67.214.125.3.
2025-01-08 06:02:39.663 | Socket (1) | Socket gracefully closed by remote side.
2025-01-08 06:02:39.663 | Socket (1) | Closed.
2025-01-08 06:02:39.921 | HD Request # 130 | Setting DTC encoding to Binary VLS
2025-01-08 06:02:39.921 | HD Request # 130 | Sending historical data logon request message.
2025-01-08 06:02:40.151 | HD Request # 130 | Requesting Intraday data. Start date-time: 2025-01-08 06:02:14. Record interval: 0. Symbol: SILH25
2025-01-08 06:02:40.381 | HD Request # 130 | Decompressing data.
2025-01-08 06:02:40.611 | HD Request # 130 | Receiving Intraday data for SILH5.COMEX starting at 2025-01-08 06:02:14.062000
2025-01-08 06:02:40.612 | Socket (3) | CloseSocket call.
2025-01-08 06:02:40.612 | Socket (3) | Shutdown started. Waiting for graceful close.
2025-01-08 06:02:40.629 | Historical data download thread signaled to stop.
2025-01-08 06:02:40.629 | HD Request # 130 | Timestamp of first Intraday data file record written: 2025-01-08 06:02:35.023000.
2025-01-08 06:02:40.629 | HD Request # 130 | Received 2 Intraday data records from 2025-01-08 06:02:14.062000 to 2025-01-08 06:02:35.023000 (21.0 seconds. Delay: 5.6 seconds) and wrote 1 record for SILH5.COMEX
2025-01-08 06:02:40.629 | HD Request # 130 | Add time&sales data | Remembered last file record date-time: 2025-01-08 11:02:35.023000
2025-01-08 06:02:40.629 | HD Request # 130 | Completion time: 1s.
2025-01-08 06:02:40.629 | HD Request # 130 | Intraday data download complete for SILH5.COMEX. Unique request ID: 130
2025-01-08 06:02:40.629 | Removing historical data download ID 130.
2025-01-08 06:02:40.629 | Real-time Intraday chart data file updates started for SILH5.COMEX
2025-01-08 06:02:40.629 | Intraday chart data file opened for SILH5.COMEX
2025-01-08 06:02:40.629 | HD Request # 130 | Enabling Intraday chart updating for symbol.
2025-01-08 06:02:40.629 | Triggering next historical data download in queue.
2025-01-08 06:02:40.629 | HD Request # 131 | Downloading Intraday chart data for ESU4.CME to the file ESU4.CME.scid. Service: cme
2025-01-08 06:02:40.630 | HD Request # 131 | Download start date-time: 2024-09-20 09:29:59.000000. File last date-time: 2024-09-20 09:29:59.856000
2025-01-08 06:02:40.630 | HD Request # 131 | Using server: ds32.sierracharts.com port 10149
2025-01-08 06:02:40.630 | Socket (7) | Creating socket.
2025-01-08 06:02:40.630 | Socket (7) | New receive buffer size: 0
2025-01-08 06:02:40.630 | Socket (7) | Connecting to IP: 67.214.125.3.
2025-01-08 06:02:40.739 | HTTPS connection ID:20 to downloads.rithmic.com:443 for request ID:20 (1) | Creating socket. Using TLS 1.2.
2025-01-08 06:02:40.739 | HTTPS connection ID:20 to downloads.rithmic.com:443 for request ID:20 (1) | New receive buffer size: 0
2025-01-08 06:02:40.739 | HTTPS connection ID:20 to downloads.rithmic.com:443 for request ID:20 (1) | Connecting to IP: 216.66.0.130.
2025-01-08 06:02:40.843 | Socket (3) | Socket gracefully closed by remote side.
2025-01-08 06:02:40.843 | Socket (3) | Closed.
2025-01-08 06:02:41.142 | HD Request # 131 | Setting DTC encoding to Binary VLS
2025-01-08 06:02:41.142 | HD Request # 131 | Sending historical data logon request message.
2025-01-08 06:02:41.395 | HD Request # 131 | Requesting Intraday data. Start date-time: 2024-09-20 09:29:59. Record interval: 0. Symbol: ESU24
2025-01-08 06:02:41.648 | HD Request # 131 | Decompressing data.
2025-01-08 06:02:41.900 | HD Request # 131 | Receiving Intraday data for ESU4.CME starting at 2024-09-20 09:29:59.011000
2025-01-08 06:02:41.900 | Socket (7) | CloseSocket call.
2025-01-08 06:02:41.900 | Socket (7) | Shutdown started. Waiting for graceful close.
2025-01-08 06:02:42.073 | Historical data download thread signaled to stop.
2025-01-08 06:02:42.073 | HD Request # 131 | Received 12 Intraday data records from 2024-09-20 09:29:59.011000 to 2024-09-20 09:29:59.856000 (0.8 seconds. Delay: 109.9 days) and wrote 0 records for ESU4.CME
2025-01-08 06:02:42.073 | HD Request # 131 | Add time&sales data | Remembered last file record date-time: 2024-09-20 13:29:59.856000
2025-01-08 06:02:42.073 | HD Request # 131 | Completion time: 2s.
2025-01-08 06:02:42.073 | HD Request # 131 | Intraday data download complete for ESU4.CME. Unique request ID: 131
2025-01-08 06:02:42.073 | Removing historical data download ID 131.
2025-01-08 06:02:42.073 | Real-time Intraday chart data file updates started for ESU4.CME
2025-01-08 06:02:42.073 | Intraday chart data file opened for ESU4.CME
2025-01-08 06:02:42.073 | HD Request # 131 | Enabling Intraday chart updating for symbol.
2025-01-08 06:02:42.073 | Triggering next historical data download in queue.
2025-01-08 06:02:42.074 | HD Request # 132 | Downloading Intraday chart data for GCG5.COMEX to the file GCG5.COMEX.scid. Service: comex
2025-01-08 06:02:42.074 | HD Request # 132 | Download start date-time: 2025-01-08 06:02:13.000000. File last date-time: 2025-01-08 06:02:13.820000
2025-01-08 06:02:42.074 | HD Request # 132 | Using server: ds32.sierracharts.com port 10150
2025-01-08 06:02:42.074 | Socket (3) | Creating socket.
2025-01-08 06:02:42.074 | Socket (3) | New receive buffer size: 0
2025-01-08 06:02:42.074 | Socket (3) | Connecting to IP: 67.214.125.3.
2025-01-08 06:02:42.153 | Socket (7) | Socket gracefully closed by remote side.
2025-01-08 06:02:42.153 | Socket (7) | Closed.
2025-01-08 06:02:42.553 | HD Request # 132 | Setting DTC encoding to Binary VLS
2025-01-08 06:02:42.553 | HD Request # 132 | Sending historical data logon request message.
2025-01-08 06:02:42.788 | HD Request # 132 | Requesting Intraday data. Start date-time: 2025-01-08 06:02:13. Record interval: 0. Symbol: GCG25
2025-01-08 06:02:43.024 | HD Request # 132 | Decompressing data.
2025-01-08 06:02:43.258 | HD Request # 132 | Receiving Intraday data for GCG5.COMEX starting at 2025-01-08 06:02:13.820000
2025-01-08 06:02:43.258 | Socket (3) | CloseSocket call.
2025-01-08 06:02:43.258 | Socket (3) | Shutdown started. Waiting for graceful close.
2025-01-08 06:02:43.265 | Historical data download thread signaled to stop.
2025-01-08 06:02:43.265 | HD Request # 132 | Timestamp of first Intraday data file record written: 2025-01-08 06:02:16.484000.
2025-01-08 06:02:43.265 | HD Request # 132 | Received 11 Intraday data records from 2025-01-08 06:02:13.820000 to 2025-01-08 06:02:41.380000 (27.6 seconds. Delay: 1.9 seconds) and wrote 10 records for GCG5.COMEX
2025-01-08 06:02:43.266 | HD Request # 132 | Add time&sales data | Remembered last file record date-time: 2025-01-08 11:02:41.380000
2025-01-08 06:02:43.266 | Added 4 Time and Sales records to Intraday data file for GCG5.COMEX after download.
2025-01-08 06:02:43.266 | HD Request # 132 | Completion time: 1s.
2025-01-08 06:02:43.266 | HD Request # 132 | Intraday data download complete for GCG5.COMEX. Unique request ID: 132
2025-01-08 06:02:43.266 | Removing historical data download ID 132.
2025-01-08 06:02:43.266 | Real-time Intraday chart data file updates started for GCG5.COMEX
2025-01-08 06:02:43.266 | Intraday chart data file opened for GCG5.COMEX
2025-01-08 06:02:43.266 | HD Request # 132 | Enabling Intraday chart updating for symbol.
2025-01-08 06:02:43.266 | Triggering next historical data download in queue.
2025-01-08 06:02:43.266 | HD Request # 133 | Downloading Intraday chart data for USDX to the file USDX.scid. Service: fxstatscalc
2025-01-08 06:02:43.266 | HD Request # 133 | Download start date-time: 2025-01-08 06:02:15.000000. File last date-time: 2025-01-08 06:02:15.000000
2025-01-08 06:02:43.266 | HD Request # 133 | Using server: ds12.sierracharts.com port 10149
2025-01-08 06:02:43.266 | Socket (7) | Creating socket.
2025-01-08 06:02:43.266 | Socket (7) | New receive buffer size: 0
2025-01-08 06:02:43.266 | Socket (7) | Connecting to IP: 69.39.70.241.
2025-01-08 06:02:43.494 | Socket (3) | Socket gracefully closed by remote side.
2025-01-08 06:02:43.494 | Socket (3) | Closed.
2025-01-08 06:02:43.556 | Rithmic Direct - DTC | Wrote file: C:\SierraChart - TopStep\RithmicConnections.json. Size: 81131
2025-01-08 06:02:43.557 | Rithmic Direct - DTC | Processed connection points. Count: 347
2025-01-08 06:02:43.762 | HD Request # 133 | Setting DTC encoding to Binary VLS
2025-01-08 06:02:43.762 | HD Request # 133 | Sending historical data logon request message.
2025-01-08 06:02:44.034 | HD Request # 133 | Requesting Intraday data. Start date-time: 2025-01-08 06:02:15. Record interval: 0. Symbol: USDX
2025-01-08 06:02:44.273 | HD Request # 133 | Decompressing data.
2025-01-08 06:02:44.324 | HTTPS connection ID:20 to downloads.rithmic.com:443 for request ID:20 (1) | CloseSocket call.
2025-01-08 06:02:44.324 | HTTPS connection ID:20 to downloads.rithmic.com:443 for request ID:20 (1) | Shutdown started. Waiting for graceful close.
2025-01-08 06:02:44.551 | HD Request # 133 | Receiving Intraday data for USDX starting at 2025-01-08 06:02:15.000000
2025-01-08 06:02:44.551 | Socket (7) | CloseSocket call.
2025-01-08 06:02:44.551 | Socket (7) | Shutdown started. Waiting for graceful close.
2025-01-08 06:02:44.562 | HTTPS connection ID:20 to downloads.rithmic.com:443 for request ID:20 (1) | Socket gracefully closed by remote side.
2025-01-08 06:02:44.562 | HTTPS connection ID:20 to downloads.rithmic.com:443 for request ID:20 (1) | Closed.
2025-01-08 06:02:44.585 | Historical data download thread signaled to stop.
2025-01-08 06:02:44.585 | HD Request # 133 | Timestamp of first Intraday data file record written: 2025-01-08 06:02:16.000000.
2025-01-08 06:02:44.585 | HD Request # 133 | Received 31 Intraday data records from 2025-01-08 06:02:15.000000 to 2025-01-08 06:02:45.000000 (30.0 seconds. Delay: -0.4 seconds) and wrote 30 records for USDX
2025-01-08 06:02:44.585 | HD Request # 133 | Add time&sales data | Remembered last file record date-time: 2025-01-08 11:02:45.000000
2025-01-08 06:02:44.585 | HD Request # 133 | Completion time: 1s.
2025-01-08 06:02:44.585 | HD Request # 133 | Intraday data download complete for USDX. Unique request ID: 133
2025-01-08 06:02:44.585 | Removing historical data download ID 133.
2025-01-08 06:02:44.585 | Real-time Intraday chart data file updates started for USDX
2025-01-08 06:02:44.585 | Intraday chart data file opened for USDX
2025-01-08 06:02:44.585 | HD Request # 133 | Enabling Intraday chart updating for symbol.
2025-01-08 06:02:44.585 | Triggering next historical data download in queue.
2025-01-08 06:02:44.585 | HD Request # 134 | Downloading Intraday chart data for NQH5.CME to the file NQH5.CME.scid. Service: cme
2025-01-08 06:02:44.585 | HD Request # 134 | Download start date-time: 2025-01-08 06:02:14.000000. File last date-time: 2025-01-08 06:02:14.289000
2025-01-08 06:02:44.586 | HD Request # 134 | Using server: ds32.sierracharts.com port 10150
2025-01-08 06:02:44.586 | Socket (1) | Creating socket.
2025-01-08 06:02:44.586 | Socket (1) | New receive buffer size: 0
2025-01-08 06:02:44.586 | Socket (1) | Connecting to IP: 67.214.125.3.
2025-01-08 06:02:44.788 | Socket (7) | Socket gracefully closed by remote side.
2025-01-08 06:02:44.788 | Socket (7) | Closed.
2025-01-08 06:02:45.101 | HD Request # 134 | Setting DTC encoding to Binary VLS
2025-01-08 06:02:45.101 | HD Request # 134 | Sending historical data logon request message.
2025-01-08 06:02:45.354 | HD Request # 134 | Requesting Intraday data. Start date-time: 2025-01-08 06:02:14. Record interval: 0. Symbol: NQH25
2025-01-08 06:02:45.608 | HD Request # 134 | Decompressing data.
2025-01-08 06:02:45.861 | HD Request # 134 | Receiving Intraday data for NQH5.CME starting at 2025-01-08 06:02:14.289000
2025-01-08 06:02:45.861 | Socket (1) | CloseSocket call.
2025-01-08 06:02:45.861 | Socket (1) | Shutdown started. Waiting for graceful close.
2025-01-08 06:02:45.951 | Historical data download thread signaled to stop.
2025-01-08 06:02:45.951 | HD Request # 134 | Timestamp of first Intraday data file record written: 2025-01-08 06:02:18.300000.
2025-01-08 06:02:45.951 | HD Request # 134 | Received 32 Intraday data records from 2025-01-08 06:02:14.289000 to 2025-01-08 06:02:42.684000 (28.4 seconds. Delay: 3.3 seconds) and wrote 31 records for NQH5.CME
2025-01-08 06:02:45.952 | HD Request # 134 | Add time&sales data | Remembered last file record date-time: 2025-01-08 11:02:42.684000
2025-01-08 06:02:45.952 | Added 1 Time and Sales records to Intraday data file for NQH5.CME after download.
2025-01-08 06:02:45.952 | HD Request # 134 | Completion time: 1s.
2025-01-08 06:02:45.952 | HD Request # 134 | Intraday data download complete for NQH5.CME. Unique request ID: 134
2025-01-08 06:02:45.952 | Removing historical data download ID 134.
2025-01-08 06:02:45.952 | Real-time Intraday chart data file updates started for NQH5.CME
2025-01-08 06:02:45.952 | Intraday chart data file opened for NQH5.CME
2025-01-08 06:02:45.952 | HD Request # 134 | Enabling Intraday chart updating for symbol.
2025-01-08 06:02:45.952 | Triggering next historical data download in queue.
2025-01-08 06:02:45.952 | HD Request # 135 | Downloading Intraday chart data for ESH5.CME to the file ESH5.CME.scid. Service: cme
2025-01-08 06:02:45.952 | HD Request # 135 | Download start date-time: 2025-01-08 06:02:07.000000. File last date-time: 2025-01-08 06:02:07.105000
2025-01-08 06:02:45.952 | HD Request # 135 | Using server: ds32.sierracharts.com port 10149
2025-01-08 06:02:45.952 | Socket (3) | Creating socket.
2025-01-08 06:02:45.952 | Socket (3) | New receive buffer size: 0
2025-01-08 06:02:45.952 | Socket (3) | Connecting to IP: 67.214.125.3.
2025-01-08 06:02:46.116 | Socket (1) | Socket gracefully closed by remote side.
2025-01-08 06:02:46.116 | Socket (1) | Closed.
2025-01-08 06:02:46.425 | HD Request # 135 | Setting DTC encoding to Binary VLS
2025-01-08 06:02:46.425 | HD Request # 135 | Sending historical data logon request message.
2025-01-08 06:02:46.658 | HD Request # 135 | Requesting Intraday data. Start date-time: 2025-01-08 06:02:07. Record interval: 0. Symbol: ESH25
2025-01-08 06:02:46.891 | HD Request # 135 | Decompressing data.
2025-01-08 06:02:47.124 | HD Request # 135 | Receiving Intraday data for ESH5.CME starting at 2025-01-08 06:02:07.105000
2025-01-08 06:02:47.124 | Socket (3) | CloseSocket call.
2025-01-08 06:02:47.124 | Socket (3) | Shutdown started. Waiting for graceful close.
2025-01-08 06:02:47.125 | Historical data download thread signaled to stop.
2025-01-08 06:02:47.125 | HD Request # 135 | Timestamp of first Intraday data file record written: 2025-01-08 06:02:16.599000.
2025-01-08 06:02:47.125 | HD Request # 135 | Received 64 Intraday data records from 2025-01-08 06:02:07.105000 to 2025-01-08 06:02:45.731000 (38.6 seconds. Delay: 1.4 seconds) and wrote 63 records for ESH5.CME
2025-01-08 06:02:47.126 | HD Request # 135 | Add time&sales data | Remembered last file record date-time: 2025-01-08 11:02:45.731000
2025-01-08 06:02:47.126 | Added 1 Time and Sales records to Intraday data file for ESH5.CME after download.
2025-01-08 06:02:47.126 | HD Request # 135 | Completion time: 2s.
2025-01-08 06:02:47.126 | HD Request # 135 | Intraday data download complete for ESH5.CME. Unique request ID: 135
2025-01-08 06:02:47.126 | Removing historical data download ID 135.
2025-01-08 06:02:47.126 | Real-time Intraday chart data file updates started for ESH5.CME
2025-01-08 06:02:47.126 | Intraday chart data file opened for ESH5.CME
2025-01-08 06:02:47.126 | HD Request # 135 | Enabling Intraday chart updating for symbol.
2025-01-08 06:02:47.126 | Triggering next historical data download in queue.
2025-01-08 06:02:47.126 | HD Request # 136 | Downloading Intraday chart data for SPX500 to the file SPX500.scid. Service: fxcm
2025-01-08 06:02:47.126 | HD Request # 136 | Download start date-time: 2025-01-08 06:02:00.000000. File last date-time: 2025-01-08 06:02:00.135000
2025-01-08 06:02:47.126 | HD Request # 136 | Using server: ds4.sierracharts.com port 10150
2025-01-08 06:02:47.206 | Socket (1) | Creating socket.
2025-01-08 06:02:47.206 | Socket (1) | New receive buffer size: 0
2025-01-08 06:02:47.206 | Socket (1) | Connecting to IP: 67.214.125.7.
2025-01-08 06:02:47.235 | Opened cached Intraday file: C:\SierraChart - TopStep\Data\6AH5.CME.scid. Thread ID: 16528
2025-01-08 06:02:47.235 | Opened cached Intraday file: C:\SierraChart - TopStep\Data\SIH5.COMEX.scid. Thread ID: 16528
2025-01-08 06:02:47.235 | Opened cached Intraday file: C:\SierraChart - TopStep\Data\SILH5.COMEX.scid. Thread ID: 16528
2025-01-08 06:02:47.235 | Opened cached Intraday file: C:\SierraChart - TopStep\Data\GCG5.COMEX.scid. Thread ID: 16528
2025-01-08 06:02:47.236 | Opened cached Intraday file: C:\SierraChart - TopStep\Data\USDX.scid. Thread ID: 16528
2025-01-08 06:02:47.358 | Socket (3) | Socket gracefully closed by remote side.
2025-01-08 06:02:47.358 | Socket (3) | Closed.
2025-01-08 06:02:47.699 | HD Request # 136 | Setting DTC encoding to Binary VLS
2025-01-08 06:02:47.699 | HD Request # 136 | Sending historical data logon request message.
2025-01-08 06:02:47.973 | HD Request # 136 | Requesting Intraday data. Start date-time: 2025-01-08 06:02:00. Record interval: 0. Symbol: SPX500
2025-01-08 06:02:48.217 | HD Request # 136 | Decompressing data.
2025-01-08 06:02:48.459 | HD Request # 136 | Receiving Intraday data for SPX500 starting at 2025-01-08 06:02:00.135000
2025-01-08 06:02:48.459 | Socket (1) | CloseSocket call.
2025-01-08 06:02:48.460 | Socket (1) | Shutdown started. Waiting for graceful close.
2025-01-08 06:02:48.485 | Historical data download thread signaled to stop.
2025-01-08 06:02:48.485 | HD Request # 136 | Timestamp of first Intraday data file record written: 2025-01-08 06:02:30.632000.
2025-01-08 06:02:48.485 | HD Request # 136 | Received 16 Intraday data records from 2025-01-08 06:02:00.135000 to 2025-01-08 06:02:47.736000 (47.6 seconds. Delay: 0.7 seconds) and wrote 15 records for SPX500
2025-01-08 06:02:48.486 | HD Request # 136 | Add time&sales data | Remembered last file record date-time: 2025-01-08 11:02:47.736000
2025-01-08 06:02:48.486 | HD Request # 136 | Completion time: 1s.
2025-01-08 06:02:48.486 | HD Request # 136 | Intraday data download complete for SPX500. Unique request ID: 136
2025-01-08 06:02:48.486 | Removing historical data download ID 136.
2025-01-08 06:02:48.486 | Real-time Intraday chart data file updates started for SPX500
2025-01-08 06:02:48.486 | Intraday chart data file opened for SPX500
2025-01-08 06:02:48.486 | HD Request # 136 | Enabling Intraday chart updating for symbol.
2025-01-08 06:02:48.486 | Triggering next historical data download in queue.
2025-01-08 06:02:48.486 | HD Request # 137 | Downloading Intraday chart data for MNQH5.CME to the file MNQH5.CME.scid. Service: cme
2025-01-08 06:02:48.486 | HD Request # 137 | Download start date-time: 2025-01-08 06:02:14.000000. File last date-time: 2025-01-08 06:02:14.289000
2025-01-08 06:02:48.486 | HD Request # 137 | Using server: ds32.sierracharts.com port 10149
2025-01-08 06:02:48.486 | Socket (3) | Creating socket.
2025-01-08 06:02:48.486 | Socket (3) | New receive buffer size: 0
2025-01-08 06:02:48.486 | Socket (3) | Connecting to IP: 67.214.125.3.
2025-01-08 06:02:48.703 | Socket (1) | Socket gracefully closed by remote side.
2025-01-08 06:02:48.703 | Socket (1) | Closed.
2025-01-08 06:02:48.991 | HD Request # 137 | Setting DTC encoding to Binary VLS
2025-01-08 06:02:48.991 | HD Request # 137 | Sending historical data logon request message.
2025-01-08 06:02:49.240 | HD Request # 137 | Requesting Intraday data. Start date-time: 2025-01-08 06:02:14. Record interval: 0. Symbol: MNQH25
2025-01-08 06:02:49.489 | HD Request # 137 | Decompressing data.
2025-01-08 06:02:49.738 | HD Request # 137 | Receiving Intraday data for MNQH5.CME starting at 2025-01-08 06:02:14.289000
2025-01-08 06:02:49.738 | Socket (3) | CloseSocket call.
2025-01-08 06:02:49.738 | Socket (3) | Shutdown started. Waiting for graceful close.
2025-01-08 06:02:49.747 | Historical data download thread signaled to stop.
2025-01-08 06:02:49.747 | HD Request # 137 | Timestamp of first Intraday data file record written: 2025-01-08 06:02:17.077000.
2025-01-08 06:02:49.748 | HD Request # 137 | Received 107 Intraday data records from 2025-01-08 06:02:14.289000 to 2025-01-08 06:02:50.328001 (36.0 seconds. Delay: -0.6 seconds) and wrote 106 records for MNQH5.CME
2025-01-08 06:02:49.748 | HD Request # 137 | Add time&sales data | Remembered last file record date-time: 2025-01-08 11:02:50.328001
2025-01-08 06:02:49.748 | Added 124 Time and Sales records to Intraday data file for MNQH5.CME after download.
2025-01-08 06:02:49.748 | HD Request # 137 | Completion time: 1s.
2025-01-08 06:02:49.748 | HD Request # 137 | Intraday data download complete for MNQH5.CME. Unique request ID: 137
2025-01-08 06:02:49.748 | Removing historical data download ID 137.
2025-01-08 06:02:49.748 | Real-time Intraday chart data file updates started for MNQH5.CME
2025-01-08 06:02:49.748 | Intraday chart data file opened for MNQH5.CME
2025-01-08 06:02:49.748 | HD Request # 137 | Enabling Intraday chart updating for symbol.
2025-01-08 06:02:49.748 | Triggering next historical data download in queue.
2025-01-08 06:02:49.748 | HD Request # 138 | Downloading Intraday chart data for MGCG5.COMEX to the file MGCG5.COMEX.scid. Service: comex
2025-01-08 06:02:49.748 | HD Request # 138 | Download start date-time: 2025-01-08 06:02:12.000000. File last date-time: 2025-01-08 06:02:12.810000
2025-01-08 06:02:49.748 | HD Request # 138 | Using server: ds32.sierracharts.com port 10150
2025-01-08 06:02:49.748 | Socket (1) | Creating socket.
2025-01-08 06:02:49.748 | Socket (1) | New receive buffer size: 0
2025-01-08 06:02:49.748 | Socket (1) | Connecting to IP: 67.214.125.3.
2025-01-08 06:02:49.987 | Socket (3) | Socket gracefully closed by remote side.
2025-01-08 06:02:49.987 | Socket (3) | Closed.
2025-01-08 06:02:50.243 | HD Request # 138 | Setting DTC encoding to Binary VLS
2025-01-08 06:02:50.243 | HD Request # 138 | Sending historical data logon request message.
2025-01-08 06:02:50.488 | HD Request # 138 | Requesting Intraday data. Start date-time: 2025-01-08 06:02:12. Record interval: 0. Symbol: MGCG25
2025-01-08 06:02:50.733 | HD Request # 138 | Decompressing data.
2025-01-08 06:02:50.978 | HD Request # 138 | Receiving Intraday data for MGCG5.COMEX starting at 2025-01-08 06:02:12.810000
2025-01-08 06:02:50.978 | Socket (1) | CloseSocket call.
2025-01-08 06:02:50.978 | Socket (1) | Shutdown started. Waiting for graceful close.
2025-01-08 06:02:51.049 | Historical data download thread signaled to stop.
2025-01-08 06:02:51.049 | HD Request # 138 | Timestamp of first Intraday data file record written: 2025-01-08 06:02:16.485000.
2025-01-08 06:02:51.049 | HD Request # 138 | Received 21 Intraday data records from 2025-01-08 06:02:12.810000 to 2025-01-08 06:02:47.806001 (35.0 seconds. Delay: 3.2 seconds) and wrote 20 records for MGCG5.COMEX
2025-01-08 06:02:51.050 | HD Request # 138 | Add time&sales data | Remembered last file record date-time: 2025-01-08 11:02:47.806001
2025-01-08 06:02:51.050 | Added 1 Time and Sales records to Intraday data file for MGCG5.COMEX after download.
2025-01-08 06:02:51.050 | HD Request # 138 | Completion time: 2s.
2025-01-08 06:02:51.050 | HD Request # 138 | Intraday data download complete for MGCG5.COMEX. Unique request ID: 138
2025-01-08 06:02:51.050 | Removing historical data download ID 138.
2025-01-08 06:02:51.050 | Real-time Intraday chart data file updates started for MGCG5.COMEX
2025-01-08 06:02:51.050 | Intraday chart data file opened for MGCG5.COMEX
2025-01-08 06:02:51.050 | HD Request # 138 | Enabling Intraday chart updating for symbol.
2025-01-08 06:02:51.050 | Triggering next historical data download in queue.
2025-01-08 06:02:51.050 | HD Request # 139 | Downloading Intraday chart data for MESH5.CME to the file MESH5.CME.scid. Service: cme
2025-01-08 06:02:51.050 | HD Request # 139 | Download start date-time: 2025-01-08 06:02:13.000000. File last date-time: 2025-01-08 06:02:13.600000
2025-01-08 06:02:51.050 | HD Request # 139 | Using server: ds32.sierracharts.com port 10149
2025-01-08 06:02:51.050 | Socket (3) | Creating socket.
2025-01-08 06:02:51.050 | Socket (3) | New receive buffer size: 0
2025-01-08 06:02:51.050 | Socket (3) | Connecting to IP: 67.214.125.3.
2025-01-08 06:02:51.223 | Socket (1) | Socket gracefully closed by remote side.
2025-01-08 06:02:51.223 | Socket (1) | Closed.
2025-01-08 06:02:51.526 | HD Request # 139 | Setting DTC encoding to Binary VLS
2025-01-08 06:02:51.526 | HD Request # 139 | Sending historical data logon request message.
2025-01-08 06:02:51.762 | HD Request # 139 | Requesting Intraday data. Start date-time: 2025-01-08 06:02:13. Record interval: 0. Symbol: MESH25
2025-01-08 06:02:51.997 | HD Request # 139 | Decompressing data.
2025-01-08 06:02:52.232 | HD Request # 139 | Receiving Intraday data for MESH5.CME starting at 2025-01-08 06:02:13.600000
2025-01-08 06:02:52.232 | Socket (3) | CloseSocket call.
2025-01-08 06:02:52.232 | Socket (3) | Shutdown started. Waiting for graceful close.
2025-01-08 06:02:52.271 | Opened cached Intraday file: C:\SierraChart - TopStep\Data\M6AH5.CME.scid. Thread ID: 16528
2025-01-08 06:02:52.271 | Opened cached Intraday file: C:\SierraChart - TopStep\Data\NQH5.CME.scid. Thread ID: 16528
2025-01-08 06:02:52.271 | Opened cached Intraday file: C:\SierraChart - TopStep\Data\ESH5.CME.scid. Thread ID: 16528
2025-01-08 06:02:52.271 | Opened cached Intraday file: C:\SierraChart - TopStep\Data\SPX500.scid. Thread ID: 16528
2025-01-08 06:02:52.272 | Opened cached Intraday file: C:\SierraChart - TopStep\Data\MNQH5.CME.scid. Thread ID: 16528
2025-01-08 06:02:52.272 | Opened cached Intraday file: C:\SierraChart - TopStep\Data\MGCG5.COMEX.scid. Thread ID: 16528
2025-01-08 06:02:52.375 | Historical data download thread signaled to stop.
2025-01-08 06:02:52.375 | HD Request # 139 | Timestamp of first Intraday data file record written: 2025-01-08 06:02:22.635000.
2025-01-08 06:02:52.375 | HD Request # 139 | Received 26 Intraday data records from 2025-01-08 06:02:13.600000 to 2025-01-08 06:02:50.331000 (36.7 seconds. Delay: 2.0 seconds) and wrote 25 records for MESH5.CME
2025-01-08 06:02:52.376 | HD Request # 139 | Add time&sales data | Remembered last file record date-time: 2025-01-08 11:02:50.331000
2025-01-08 06:02:52.376 | Added 116 Time and Sales records to Intraday data file for MESH5.CME after download.
2025-01-08 06:02:52.376 | HD Request # 139 | Completion time: 1s.
2025-01-08 06:02:52.376 | HD Request # 139 | Intraday data download complete for MESH5.CME. Unique request ID: 139
2025-01-08 06:02:52.376 | Removing historical data download ID 139.
2025-01-08 06:02:52.376 | Real-time Intraday chart data file updates started for MESH5.CME
2025-01-08 06:02:52.376 | Intraday chart data file opened for MESH5.CME
2025-01-08 06:02:52.376 | HD Request # 139 | Enabling Intraday chart updating for symbol.
2025-01-08 06:02:52.376 | No download requests in the queue to start downloads for.
2025-01-08 06:02:52.469 | Socket (3) | Socket gracefully closed by remote side.
2025-01-08 06:02:52.469 | Socket (3) | Closed.
2025-01-08 06:02:57.322 | Opened cached Intraday file: C:\SierraChart - TopStep\Data\MESH5.CME.scid. Thread ID: 16528
2025-01-08 06:06:08.549 | Chat | Message response. Chat ID: 429. Request ID: 1134629397
2025-01-08 06:26:38.178 | Chat | Message response. Chat ID: 429. Request ID: 1134629398
2025-01-08 06:36:48.890 | Chat | Message response. Chat ID: 429. Request ID: 1134629399
2025-01-08 06:39:54.451 | Chat | Message response. Chat ID: 429. Request ID: 1134629400
2025-01-08 06:42:10.898 | Chat | Message response. Chat ID: 429. Request ID: 1134629401
2025-01-08 07:24:38.378 | Chat | Message response. Chat ID: 429. Request ID: 1134629402
2025-01-08 08:38:04.731 | MESH5.CME[M] #18 | StartDateTimeForLoadingOrderFills: 2024-01-02 00:00:00
[2025-01-08 15:57:12]
John - SC Support - Posts: 39418
We do see the following in your logs:
2025-01-08 08:33:52.823 | DTC Client socket (1) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine.
2025-01-07 13:34:27.643 | DTC Client socket (4) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it.
But there is just the one of each, so it is not indicating a major issue, but it does point to a connectivity issue of some kind. Refer to the following:
Data/Trading Service Connection and Symbol Issues: 1.2. Network Communication or Server Problem
