Date/Time: Tue, 22 Apr 2025 18:06:02 +0000
Spreadsheet for Trading: Columns O to Z
View Count: 126
[2025-01-08 00:53:31] |
User374751 - Posts: 41 |
Good Day Sierra Chart support, and community. What is the proper way to use columns O to Z? I have two trade strategies. The strategies function properly in combined Entry statements, as well as combined Exit statements. I would like to separate them so that I can use a much different Exit strategy for one of the sets. How can I properly separate these trade sets so that I can reference one set? I have attempted to separate them, one in column K, and one in column O. However, the system doesn't perform order entry action for the trade strategy in column O. What is the concept that I do not comprehend? I have reviewed this info: Spreadsheet Systems, Alerts and Automated Trading: Order of Formula Column Processing and Internal Calculation Order |
[2025-01-08 15:03:02] |
Support, I think I have the proper comprehension: 1.input an entry formula into a selected cell, O, for example. 2.input an exit formula into a selected cell, P, for example. 3.input combination entry strategies into cells k and m, which can perform entries based on true/false values of formula in reference cell. 4.input combination exit strategies into cells l and n, which can perform exits based on true/false values of formula in refernce cell. Is this correct? |
[2025-01-08 16:07:30] |
John - SC Support - Posts: 39416 |
That is fine. We think what you were not understanding is that the Entry/Exit cells are only in the K, L, M, and N columns. The other columns are for formulas, but they will not generate any orders. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
