Date/Time: Tue, 22 Apr 2025 18:30:45 +0000
Open and Close for a bar using arrows
View Count: 140
[2025-01-07 23:38:29]
User226793 - Posts: 174
Is there an indicator that displays the Open and Close values for a specific bar, and can arrows be used to mark the Open and Close on bar charts?
[2025-01-08 00:36:53]
John - SC Support - Posts: 39418
There are any number of indicators you can use to display the Open and close for a specific bar. It just depends on what bar exactly you are trying to reference and how you want to see it. Please give us some specific information on what you want to accomplish and we will guide you to the answer.
With regards to the arrows for the Open and Close on a chart, you can do this. The general way to get an arrow at a particular level is to use the "Study Subgraph Reference" study. Add this to a chart and set the Study Subgraph to reference to be either the Open or the Close (you will need two copies of this study to do both). Then in the Subgraphs tab for that study set the "Draw Style" for the "Study Subgraph" to be either "Arrow Right" or "Arrow Left" depending on what you want. Be sure to set the "Width/Size" to a value that will work for you for that subgraph.
One last item - make sure the "Region" for the "Study Subgraph Reference" is set to "Region 1" or the arrows will be drawn in a different region.
You can use any of the draw styles that are available to mark these. We point this out as you may find the "Triangle Left" or "Triangle Right" to work better for what you are doing.
Refer to the following:
Chart Studies: Subgraphs Tab >> Draw Style
Chart Studies: Settings and Inputs Tab >> Chart Region
Date Time Of Last Edit: 2025-01-08 00:38:06
