Date/Time: Tue, 22 Apr 2025 18:06:04 +0000
Spreadsheet Study
View Count: 136
[2025-01-07 21:31:59] |
User841161 - Posts: 275 |
I am using the Current Price Line Study on my chart#1 and using Spreadsheet Study-6E(DailyFigures)SSheet. I have Current Price Line Subgraph1 unchecked to included in Spreadsheet. Why is CPL still showing up on spreadsheet(columnAA).
[2025-01-08 00:29:56] |
John - SC Support - Posts: 39416 |
We are not certain why this is the case. Our best guess is that it is leftover from when the spreadsheet was first saved and after you changed the setting for the Current Price Line, it has not updated to the Spreadsheet. Select the column that has the Current Price Line subgraph in it (Column AA from your image) and then select the "Delete" button on your keyboard. You will be prompted as to whether you really want to clear the data, answer "yes". Then go back to your chart and force a recalculation by selecting "Chart >> Recalculate". Then look at your Spreadsheet and see if the data has repopulated or not. It should not. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
