Date/Time: Tue, 22 Apr 2025 18:11:36 +0000
Reset Volume by price on DOM
View Count: 151
[2025-01-07 19:02:17]
Kilian Le Gall - Posts: 3
Hello, i want to reset VBP on my DOM every 30min, i tried to put on 'One period at end to fixed time lenght' and 'from session start time to end' but the profile don't reset every 30 min.
Thank you for help
[2025-01-07 19:08:46]
John - SC Support - Posts: 39416
The Trading DOM only allows for a couple of the options for the "Volume Graph Period Type". Refer to the following:
Volume By Price Study: Volume Graph Period Type
As such, there is not an option that would allow for a specific time period that resets at each interval. The best you could do would be to use the "Volume by Price Reset Button" study. Refer to the following:
Volume By Price Reset Button
Otherwise, you would need to use a regular chart for the Volume by Price as you want to see it.
[2025-01-07 19:38:25]
Sébastien - Posts: 58
I use One period from most recent period start to end for this purpose and it works with the Trading DOM.
Date Time Of Last Edit: 2025-01-07 19:39:16
