Date/Time: Tue, 22 Apr 2025 18:11:37 +0000
Running SC on debian12 with wine
View Count: 147
[2025-01-07 17:40:58] |
User358514 - Posts: 11 |
Hey! I am using SC on linux and I just faced with the issue what you discussed in this thread before: Slow data with v2524 The interesting thing is, I noticed this issue only in a specific symbol(MNQ) which has quite high volatility. After SC restart usually the data is in sync, but after a couple of minutes the latest received data gets some delay(1-3 minutes). I was using wine 8.0 til now, but I just tried with 9.0 and the symptons are the same. Have you managed to find the root cause and any suggestion to resolve this issue? I have done that debug round what you suggested on the thread above and I attached the message log about it. I ran this test with single buffer configured in SC. BTW wine prints these lines when I open this symbol: 0188:err:sync:RtlLeaveCriticalSection section 000000000011EC98 "?" is not acquired
0188:err:sync:RtlLeaveCriticalSection section 000000000011EC98 "?" is not acquired 0188:err:sync:RtlLeaveCriticalSection section 000000000011EC58 "?" is not acquired 0188:err:sync:RtlLeaveCriticalSection section 000000000011EC98 "?" is not acquired 0188:err:sync:RtlLeaveCriticalSection section 000000000011EC98 "?" is not acquired Thank you for your help! |
Private File |
[2025-01-07 20:54:38] |
John - SC Support - Posts: 39416 |
Follow the instructions at the following link: Resolution of Poor Network IO Performance under Linux/Wine For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
