Date/Time: Tue, 22 Apr 2025 18:08:46 +0000
I have a few questions
View Count: 128
[2025-01-07 10:32:18]
User437588 - Posts: 69
Hello
1. how do I additionally see the bid and ask traded pieces in numbers in the draw volume profile?
2 . Which setting is necessary so that the draw volume moves with the price movement. See screenshot.
3. is there a study for displaying an EMA 200 Daily on hourly and min basis?
Thanks for the support
image07-01-_2025_11-27-47.png / V - Attached On 2025-01-07 10:32:01 UTC - Size: 99.44 KB - 39 views
[2025-01-07 16:26:43]
John - SC Support - Posts: 39416
1. If you want to see the Bid and Ask volumes in the Volume Profile, then refer to the following setting:
Volume By Price Study: Display Volume in Bars
If you are looking for something else regarding prices, then we are not certain what you are looking for. Please give us more information.
Refer to the following for how to setup the configuration for a Drawn Volume Profile:
Volume By Price Study: Step by Step Instructions to Configure the Draw Volume Profile Tool
2. The Draw Volume Profile will not move with the price movement. The purpose of this tool is to select a region of the chart over which you want the profile. If you want a profile that covers a time in the future, then you would need to use the standard Volume by Price study. Refer to the following:
3. You would need to setup the EMA 200 Daily on a Daily chart and then use the "Study/Price Overlay" to overlay it to another chart. Refer to the following:
Study/Price Overlay Study
