Date/Time: Tue, 22 Apr 2025 18:33:48 +0000
Can't Delete VbP Drawing
View Count: 114
[2025-01-07 00:51:24]
connordw - Posts: 49
Hello, I have a delta by price drawing on the right side of my screen I can't delete. The rectangle that is normally there to click and drag or delete is not there. I also do not see the drawing listed in the Manage Chart Drawings Window. I have tried restarting my system and also updating to the current version. Any ideas on how to delete it? Thank you.
Date Time Of Last Edit: 2025-01-07 00:51:59
imagedelete.PNG / V - Attached On 2025-01-07 00:51:56 UTC - Size: 52.93 KB - 37 views
[2025-01-07 14:35:36]
I resolved this. For some reason it wasn't showing in the Chart Drawings Window but it was showing in the Studies window. So I deleted it there.
[2025-01-07 16:40:37]
John - SC Support - Posts: 39418
What you did is the appropriate resolution.
