Date/Time: Tue, 22 Apr 2025 18:08:45 +0000
Compiler Response is Empty
View Count: 209
[2025-01-06 17:49:19]
G369 - Posts: 23
I have compile a file successfully and it has created a dll. It is not showing in the list of Custom Studies? What am I doing wrong?
Please find attached screenshots(2).
regards
imagemessage log.png / V - Attached On 2025-01-06 17:48:58 UTC - Size: 73.49 KB - 30 views
imageKeltner.png / V - Attached On 2025-01-06 17:49:03 UTC - Size: 33.61 KB - 29 views
[2025-01-06 17:52:39]
John - SC Support - Posts: 39416
Please do the following:
- Select "Window >> Message Log"
- Select "Edit >> Clear Log". Select "Yes" to the query of whether you really want to clear or not.
- Select "Analysis >> Studies >> Add Custom Study"
-- If you have a group that should contain your custom study then open that.
-- If your study is listed in that group, then select it and select "Add".
- On your Message Log select "Edit >> Send for Analysis" (this looks like a menu, but is a button
- Post in this thread that you sent us your Message Log.
