Date/Time: Tue, 22 Apr 2025 18:22:21 +0000
individual tab to switch between charts is missing after update
View Count: 100
[2025-01-06 16:51:54] |
Copernicus - Posts: 2 |
Hi, after updating and restarting sierra, i used to have all my charts in a single chartbook all in tabs bar that existed at the bottom of the screen near scroll bar that i could switch between, I unable to locate this now, Thanks, |
[2025-01-06 16:52:43] |
John - SC Support - Posts: 39418 |
Refer to the following setting that controls whether the Chart tabs bar is displayed: General Settings Window: Use Chartbook Tabs (Global Settings >> General Settings >> Windows >> Chartbook Tabs) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
