Date/Time: Tue, 22 Apr 2025 18:14:11 +0000
Realtime Chartbook Sharing
View Count: 115
[2025-01-06 11:59:27]
cnev - Posts: 19
FYI: I trialed using the realtime chartbook sharing and found an issue. Everything worked with the sharing, but once you share the Disallow feature does not work. The chartbook goes to the recipient just the same as giving them the CHT file. There is no way to revoke access or remove sharing once the process starts.
[2025-01-06 12:46:38]
Sierra_Chart Engineering - Posts: 19305
The sharing should stop. We will check on that. The file is not going to be removed from the receiver when removing them from sharing.
Date Time Of Last Edit: 2025-01-06 12:48:04
