Date/Time: Wed, 16 Sep 2026 07:30:06 +0000
Why does chart suddenly look all squashed up?
View Count: 1863
[2014-09-16 03:50:10]
User59863 - Posts: 36
(Using InteractiveBrokers data, chartbook is 32 mg)
1/ Why does chart suddenly look all squashed up?
(see: squashed-chart.png)
Settings were not changed at all.
Seems to happen only on certain active windows - not all.
Has happened with daily as well as intraday timeframes.
Phenomenon only happened past few days after being stable for long while
2/ How to get it back to normal like: normal-chart.png ?
Date Time Of Last Edit: 2014-09-16 03:57:45
imagenormal-chart.png / V - Attached On 2014-09-16 03:43:36 UTC - Size: 51.12 KB - 480 views
imagesquashed-chart.png / V - Attached On 2014-09-16 03:47:16 UTC - Size: 54.61 KB - 492 views
[2014-09-16 04:00:26]
1, 2. There is a difference of bar spacing between these two charts by 12 pixels. You need to increase the bar spacing:
http://www.sierrachart.com/index.php?page=doc/doc_WorkingWithCharts.html#ChangingBarSpacing
