Date/Time: Fri, 22 Nov 2024 07:59:19 +0000
Bug Chart SC
View Count: 1669
[2013-05-09 15:37:24] |
steph81 - Posts: 3 |
hi all, I want to know why the Sierra dom I have the movement of prices and volumes while on the candlestick chart I do not have anything to advance or price movement chart is freeze as if I use a historical chart. in the F5 menu I have the intraday chart goal chart is freeze for example on the chart i have THat 967.1 & on the DOM i have 968 thx Date Time Of Last Edit: 2013-05-09 15:39:23
[2013-05-09 15:43:31] |
You may have gone over the 5 symbol limit when using OEC. Please refer to all of the information in help topic 3 here: Http://www.sierrachart.com/index.php?l=doc/helpdetails3.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
