Date/Time: Tue, 22 Apr 2025 18:08:44 +0000
Exchange Codes Of Denali US Equities Consolidated Tape
View Count: 195
[2025-01-05 12:46:36] |
User337121 - Posts: 5 |
Hello, I'm coding a few things in Python and I have a Sip trades file, with a lot of exchanges, was trying to put the trades same as SC , for it filtering only the relevant exchanges, but the values are not corresponding or similar. Does someone know wich exchanges (or exchange codes, or mic and operating_mic codes) that Denali US Equities Consolidated Tape uses? this is really important
[2025-01-05 17:39:59] |
Sierra_Chart Engineering - Posts: 19305 |
Sierra Chart processes all of the market data on the CTA and UTP data feeds. So whatever exchanges are provided there are going to be what Sierra Chart uses.
[2025-01-05 17:49:22] |
Really, it has nothing to do with barchart feed?
[2025-01-05 17:49:53] |
for stocks only
[2025-01-05 18:18:40] |
Sierra Chart has not used the Barchart data feed for many years.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2025-01-05 18:18:52
[2025-01-05 18:28:26] |
SC uses the SIP feed?
[2025-01-05 18:57:57] |
Does SC uses some kind of volume denoise in Volume by Price study, the data from the SIP shows some levels more aggressed but in SC all seems more smooth
[2025-01-05 19:12:28] |
This is one of the data feeds that Sierra Chart uses: https://www.ctaplan.com/index No: Does SC uses some kind of volume denoise in Volume by Price study,
