Date/Time: Tue, 22 Apr 2025 18:14:13 +0000
Does 'Combined pulling and stacking' on the DOM put an extra increase on CPU?
View Count: 135
[2025-01-05 12:15:20] |
J DIDDY - Posts: 142 |
HI Support Does 'Combined pulling and stacking' on the DOM put an extra increase on CPU as opposed to separate pull/stack columns? Because I just changed this on my DOM and it slowed down replay to a standstill. Be good to know if there is an issue with resources with this option, and I can stick to separate columns! Thanks |
[2025-01-05 18:18:01] |
Sierra_Chart Engineering - Posts: 19305 |
No, there is no performance difference at all. There must be some other issue you are having. Refer to: High CPU Usage | Inactive User Interface | Poor Performance | Long Time to Load Chart Data | Charts Reloading Often Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
