Date/Time: Tue, 22 Apr 2025 18:06:05 +0000
Make RTH VWAP start on the first bar of next day while keeping the same draw style (line)
View Count: 177
[2025-01-04 18:32:17] |
User380359 - Posts: 8 |
I'd like to make the RTH VWAP start on the first bar of the next day's session without it "dragging through" the aftermarket session, I know it can be done by changing the draw style to something other than line or line - skip zeros but I like the way line looks. Same goes for full session chart where I overlayed the RTH VWAP study from a RTH only chart.
[2025-01-04 19:58:50] |
LudaTrades - Posts: 30 |
If you are using time based bars you can adjust the Volume by Price end time to be 1 bar shorter combined with drawstyle line skip zeros. Another option might be a spreadsheet formula to set the first trading day bar to 0 and the rest reference the vwap, using line skip zeros. The pattern being: drawstyle line skip zeros needs a break bar with a 0 value somewhere.
[2025-01-04 20:34:49] |
Thanks Luda you're a wizard, may your trading career prosper.
