Date/Time: Tue, 22 Apr 2025 18:16:45 +0000
Denali symbol format Q
View Count: 143
[2025-01-04 15:39:53] |
User244592 - Posts: 46 |
Is there a particular Denali symbol format for NYSE preferred stocks? The preferred symbol format of ABCDE or ABCD are fine but for a stock like ABR their preferred symbol is usually ABR PRD or ABR/PD , neither of these work. Also after I customize the top control bar( I only use one) is there a file I can use to transfer this to a new install without making a copy from scratch? Thank you. |
[2025-01-04 18:36:35] |
Sierra_Chart Engineering - Posts: 19305 |
Preferred stocks use the symbols specified by CTA and UTP. So they are just the standard non-translated symbols. Perform a search, using the primary stock symbol and you will see them: File Menu: Searching for Symbols For example, you could search for the symbol BAC and then see all of the additional variations on it including the preferreds. Here is one of the preferred stocks for Bank of America: BACpB Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2025-01-04 18:37:06
