Date/Time: Tue, 22 Apr 2025 10:17:28 +0000
Spreadsheet Data for Sessions Profile Chart
View Count: 228
[2025-01-04 07:49:51] |
User467141 - Posts: 3 |
Hiya! I would like to find a way to be able to split up my daily bars into multiple sessions. I know SC has the option of an evening and daytime session, but i'd like to be able to at least split it up into 3 sessions (Asian, EU and US). I know there is a possibility to split the TPO profile chart into sessions, but i need the data in excel and from what i've tested and seen, the spreadsheet from a TPO chart does not come out per session (has this wierd glitchy thing where it shows the data in seconds for the first couple of seconds and then nothing). I would need some kind of way of making a chart containing bars that are as long as each session (For example asian 00:00 - 09:00, EU 09:00 - 15:30, US 15:30 - 23:59) and be able to apply the Volume Value Area Lines Study to it to be able to have the OHLC, volume, Value area high and low and the VPOC per row (per session). Then i can copy and paste the data into excel and continue my work. Any idea's on how I could achieve this, or should i search for someone that can code it for me? Thanks! |
![]() ![]() Attachment Deleted. |
[2025-01-06 15:09:45] |
This would require a customs study with custom chart bars. There is no other support for having 3 sessions. Refer to the following: ACSIL Interface - Custom Chart Bars https://www.sierrachart.com/index.php?page=doc/SierraChartStudyAndSystemProgrammers.php For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2025-01-18 10:23:02] |
Hey John Ok Thanks. I appreciate the reply! |
