Date/Time: Tue, 22 Apr 2025 18:06:02 +0000
need to consolidate tick for dom
View Count: 200
[2025-01-04 02:26:19] |
User711600 - Posts: 10 |
for nq i swithced my dom to 4 to 1 compression ratio for tick but someof the number and imposed on each other and hard to read, image attached below. how do i get hte columns in the domt o also consolidate
[2025-01-06 15:06:11] |
John - SC Support - Posts: 39416 |
The only other columns that allow for combining is the Recent Bid/Ask columns. To also have the combining apply to those columns, you need to set the following option to "Yes": Chart Settings: Apply Combine Increment in Ticks to Other Market Data Columns (Chart >> Chart Settings >> Market Depth menu) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
