Date/Time: Wed, 16 Sep 2026 22:10:06 +0000
New Spreadsheet Functions
View Count: 2980
| [2014-09-15 23:35:12] |
We have noticed some complicated techniques to truncate/round-down date-time values, such as to the second, or to the minute. Therefore, to solve this we have added three new formula functions. They are documented below. These will be out in the next release. TRUNCHOUR Truncate to the Hour {double} TRUNCHOUR(DateTime, [Hours = 1]) Number of arguments: 1-2 Argument-expansion: values Returns the given DateTime truncated down to the exact hour. If Hours is greater than 1, the given DateTime is truncated down to the interval of the given Hours (e.g. 2 hours, 3 hours, etc.). Returns #NUM! if the given Hours is less than 1. Returns #VALUE! if the given DateTime is not a number, or the given Hours is not an integer. TRUNCMIN Truncate to the Minute {double} TRUNCMIN(DateTime, [Minutes = 1]) Number of arguments: 1-2 Argument-expansion: values Returns the given DateTime truncated down to the exact minute. If Minutes is greater than 1, the given DateTime is truncated down to the interval of the given Minutes (e.g. 5 minutes, 10 minutes, etc.). Returns #NUM! if the given Minutes is less than 1. Returns #VALUE! if the given DateTime is not a number, or the given Minutes is not an integer. TRUNCSEC Truncate to the Second {double} TRUNCSEC(DateTime, [Seconds = 1]) Number of arguments: 1-2 Argument-expansion: values Returns the given DateTime truncated down to the exact second. If Seconds is greater than 1, the given DateTime is truncated down to the interval of the given Seconds (e.g. 5 seconds, 10 seconds, etc.). Returns #NUM! if the given Seconds is less than 1. Returns #VALUE! if the given DateTime is not a number, or the given Seconds is not an integer. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
