Date/Time: Tue, 22 Apr 2025 18:06:04 +0000
Multiple Orders in same direction - Order association display
View Count: 131
[2025-01-03 21:58:08] |
User631345 - Posts: 36 |
Hi John, I often take multiple clips / trades in the same direction. When doing so, and when managing the Stops and Targets for each individual Clip it becomes a challenge to see which Order is associated to which Stop and Target (In spite of having the “Order Association Lines” option set to “Yes”). I work with the LIFO Execution method. I often end up taking 3 Clips in the same direction and it becomes a challenge to manage the Stops and Targets for each of those Clips Question / Need – 1) Is it possible to name each Clip and its associated Stop and target orders separately? E.g. somewhere in the Order Information line it needs to mention EntryClip1, StopClip1, Target1Clip1, Target2Clip1, Target3Clip 1, Target4Clip1. The same logic to apply for the Second Clip i.e. EntryClip2, StopClip2, Target1Clip2, Target2Clip2, Target3Clip2, Target4Clip 1 2) Is it possible to have separate colors for the Order association lines for the Stops and Targets associated with each Clip i.e. For Clip 1 color could be “Yellow” and for Clip 2 color could be “White”? Current Display of Orders Direction Entry Stop Target1 Target2 Target3 Clip1 Short 6063.5 (-12t)TQ:4,2 (+14t),2 (+30t),1 (+48t),1 Clip2 Short 6062.5 (-8t)TQ:4,2 (+17t),2 (+34t),1 (+52t),1 Expected Display of Orders Direction Entry Stop Target1 Target2 Target3 Clip1 Short Clip16063.5 Clip 1(-12t)TQ:4,2 Clip 1(+14t),2 Clip 1(+30t),1 Clip 1(+48t),1 Clip2 Short Clip26062.5 Clip2(-8t)TQ:4,2 Clip2(+17t),2 Clip2(+34t),1 Clip2(+52t),1 The screenshot has an example of 2 clips of 4 Lots each - Short Trades in the same direction (The screenshot is a plain vanilla Chart. During execution I have a lot more lines drawn on my execution Chart) Kind Regards |
[2025-01-06 15:01:11] |
John - SC Support - Posts: 39416 |
Both of these would be feature requests. There is nothing in the system that currently does these. We take all suggestions, but we can not say when we would get to any particular request. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2025-01-06 19:17:19] |
Thanks for clarifying John. Both those features would be helpful if and when ever they get done Kind Regards |
