Date/Time: Fri, 20 Sep 2024 06:42:55 +0000
ACSIL - Custom Study
View Count: 1113
[2014-09-15 21:54:00] |
NickH09 - Posts: 10 |
Hi there! I would like to know where can i find some reference in the ACSIL documentation to change the main price color from a custom study. Does anyone ever tried to? Thanks! Nick |
[2014-09-16 03:20:56] |
Have a look at /ACS_source/studies2.cpp >> scsf_ColorBarBasedOnSlope This file is located in the folder Sierra Chart is installed to on your system. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-09-16 16:29:07
[2014-09-16 22:59:33] |
User88907 - Posts: 1 |
Sorry, i mean that i need to change the color of the main price graph(intraday) based on conditions of my study.
[2014-09-16 23:28:36] |
Yes, that particular study we have referred you to, does provide an example of how to do this.
[2014-09-24 14:33:40] |
Ok thanks! Where can i find the source code of Color Bar Based On Above/Below Study?
[2014-09-25 05:17:57] |
You can find it in the /ACS_source/ folder in the Sierra Chart installation folder.
