Date/Time: Tue, 22 Apr 2025 18:11:39 +0000
Suggestion: Stack chart tabs when attached to window, instead of scrolling
View Count: 169
[2025-01-03 17:51:55] |
n8trading - Posts: 44 |
Could you please add an enhancement to stack chart tabs that you have attached to the main window, so that you can see all of them in multiple rows instead of having to scroll a single row through them?
[2025-01-03 18:18:05] |
User431178 - Posts: 654 |
Already possible. Chartbooks: General Settings Window: Support Multiple Rows (Global Settings >> General Settings >> Windows >> Chartbook Tabs) Chart Windows: General Settings Window: Support Multiple Rows for MDI Tabs (Global Settings >> General Settings >> Windows >> Window Tabs) |
[2025-01-03 18:24:26] |
Sierra_Chart Engineering - Posts: 19305 |
This is a good idea and we had forgotten about that functionality already being added and is very capable now that we are using our own internal Control Bar functionality. So yes this is already supported. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2025-01-03 18:24:48
