Date/Time: Tue, 22 Apr 2025 18:14:12 +0000
Add Instances to account
View Count: 161
[2025-01-03 15:48:27] |
User733502 - Posts: 46 |
Could you please advise how we can add 3 more instances to this account? Thank you |
[2025-01-03 15:50:28] |
John - SC Support - Posts: 39416 |
What exactly do you mean by "instances"? You can have any number of instances created through "File >> New Instance". Refer to the following: File Menu: New Instance (File) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2025-01-03 16:57:28] |
We want to setup more than 2 computers. Is it possible to purchase another 3 instances for this account? Thank you |
[2025-01-06 14:52:25] |
Since you are on the "Integrated Advanced" package, you are allowed to have Sierra Chart running on 3 different computers at the same time. This is the limit and there are no options for adding additional systems. If you want to run Sierra Chart on more than 3 systems at the same time, then you would have to have a second Sierra Chart account and that account could have its own 3 systems that it is using. Note that the exchanges only allow for a maximum of 2 different computers connected through a single account. And this requires that you pay the exchange fee a second time. Refer to the following: Denali Exchange Data Feed: Denali Exchange Data Feed on Two Computers Simultaneously For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
