Date/Time: Mon, 15 Dec 2025 09:10:56 +0000
Message Log
View Count: 277
[2025-01-03 11:26:01]
User931541 - Posts: 19
I need the information from the message log over a longer period (x hours).
Is this possible, and if so, where can I adjust this?
Thank's
Date Time Of Last Edit: 2025-01-03 11:40:10
[2025-01-03 14:37:25]
Sierra_Chart Engineering - Posts: 21843
You can set the Message Log to be saved to a file and then you will have all of the data saved permanently. Refer to:
Message Log
[2025-01-03 19:05:35]
Great, that's exactly what I was looking for.
