Date/Time: Mon, 15 Dec 2025 09:28:33 +0000
Display horizontal scale
View Count: 266
| [2025-01-03 11:08:50] |
| cgavachart - Posts: 15 |
Hello I am searching for a way to display the difference in ticks between the horizontal grod lines (in the header would be great but somewhere else would be ok). The goal is to quickly estimate risk//stop size. Thank you |
| [2025-01-03 15:32:59] |
| John - SC Support - Posts: 43443 |
There is not a way to do this using the built-in tools, at least not in any automated way. You can always calculate the difference in ticks manually and display that as you want. But to automate this, you would need a custom study. Refer to the following: ACSIL Interface Members - Variables and Arrays: sc.BaseGraphHorizontalGridLineIncrement https://www.sierrachart.com/index.php?page=doc/SierraChartStudyAndSystemProgrammers.php For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
