Date/Time: Tue, 22 Apr 2025 18:16:43 +0000
Highlighting 0 Values in NB Charts
View Count: 147
[2025-01-03 03:32:56] |
ssangha84 - Posts: 128 |
Is there a way to highlight 0 values in the bid or ask columns in number bars?
[2025-01-03 04:28:07] |
Sierra_Chart Engineering - Posts: 19305 |
No, but this is supported: Numbers Bars: Highlight Nonzero Bid&Ask Volume at High/Low Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2025-01-03 20:33:33] |
Hmm, yea I want to highlight zero's. Not non zero. So this would be the opposite.
