Date/Time: Tue, 22 Apr 2025 18:22:22 +0000
Trade Activity Log will not open
View Count: 148
[2025-01-03 01:17:13] |
User265350 - Posts: 3 |
Have never had this problem over years on this software. Trade activity Log worked properly earlier today. Now when I attempt to open the Log, the pop up does not appear. Does not appear to be minimized. Is not hidden behind other windows. I activate the log via a button on the control bar. Button is active. When I click on it, the Sierra Chart header at the top of the window changes color from blue to white but no log appears. Have studied the documentaion and can't find a fix. Do not find any instance of Edit>>disable Trade Activity Log in the menue. Have restarted the program several times with no effect. Have also installed the latest version with no effect. Any thoughts or suggestions? |
[2025-01-03 02:45:21] |
Sierra_Chart Engineering - Posts: 19305 |
Use this command to reset it to the default position: Window, CB and CW Menus: Reset Windows (Window) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2025-01-03 04:31:25
[2025-01-03 06:29:49] |
That did it. Would never have known that. Thanks for your help.
