Date/Time: Tue, 22 Apr 2025 18:06:03 +0000
Trade Activity - Notes - Parent Order Tag
View Count: 118
[2025-01-02 21:47:54]
Oxcap - Posts: 73
Hi Support,
I am running an automated strategy and have enabled notes under the trade activity log.
How do I remove the 'Parent Order. Tag: part under notes? Is this a setting I simply need to disable?
I would like to have the activity log only show for example: LTS-L1-L-OCO-G1.
See attachment if needed
Thank you
imageTrade Activity Notes.png / V - Attached On 2025-01-02 21:46:42 UTC - Size: 59.17 KB - 43 views
[2025-01-03 02:47:52]
Sierra_Chart Engineering - Posts: 19305
It is not possible to remove that text. This text gets added, during the order submission process.
