Date/Time: Fri, 18 Apr 2025 06:35:25 +0000
NPL is calculating ghost positions
View Count: 115
[2025-01-02 17:58:12] |
K-1 - Posts: 15 |
Greetings, I trade with prop firms and have 2 accounts with takeprofittrader via Rithmic. After trading one account today with no issue, i went on to the other and once i entered a position, it exited a position(which i didn't take) from before the holiday and this is continuing with each subsequent trade. My NPL shows +33710 and while i wish this was true, unfotunately is not. It should be more like +$295. This has happened twice in the past. Is there a way for me to clear the data/positions or whatever of these ghost trades so that I can have the proper NPL? Thanks! K-1 |
[2025-01-02 18:38:33] |
Sierra_Chart Engineering - Posts: 19259 |
Refer to: Help With Daily Profit/Loss Value: Simplified Steps to Solve Incorrect Daily Profit/Loss Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2025-03-28 15:19:36] |
K-1 - Posts: 15 |
My PNL is off and showing ghost exits/positions that didn't exist. I tried doing the steps listed in "Help With Daily Profit/Loss Value: Simplified Steps to Solve Incorrect Daily Profit/Loss" but no dice. Any other ideas?
[2025-03-28 19:31:14] |
John - SC Support - Posts: 39353 |
If you set the "Order Fills Start Date-Time" correctly, then the fill that was from December should no longer be "in play" and the orders you took today should be aligning only with the orders from today. This is what the given link is all about. Please ensure that the information is set correctly as defined at this link: Help With Daily Profit/Loss Value: Simplified Steps to Solve Incorrect Daily Profit/Loss There is also additional information in the following section: Help With Daily Profit/Loss Value: Help With Daily Profit/Loss Value And keep in mind that if you are looking at your Trade Activity Log, you are most likely missing an order fill somewhere - the link given above gives more on that topic. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
