Date/Time: Tue, 22 Apr 2025 18:28:09 +0000
Something is off with my data
View Count: 110
[2025-01-02 17:11:52] |
User328099 - Posts: 23 |
Something is off with my data, Its not showing current data, it looks like its missing on my charts but the price is showing, not sure what is causing this. I tried to reconnect but it didnt work. I will be sending you over my logs for analysis
[2025-01-02 17:44:07] |
here is another picture
[2025-01-02 18:39:52] |
John - SC Support - Posts: 39418 |
You have symbols in your Chartbook that are not Rithmic symbols. This creates and issue for Rithmic. Refer to the following: Rithmic Trading Platform Service: Frequent Reconnections For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
