Date/Time: Wed, 30 Sep 2026 02:12:08 +0000
Developing POC and VALs in Draw Volume Profile Tool
View Count: 2803
| [2014-09-15 21:22:25] |
| buylosellhi - Posts: 60 |
Hi, I really like the Volume Profile Tool where you can select the start and end of a swing and look at the volume profile. Is it possible to show developing Point of Control and Value area lines within this tool. So if the swing is 10 bars long, it'll show the developing PoC for the 1st day, then first 2 days, then first 3 and so on.... until it converges with the PoC of the swing as it currently shows. Its similar to developing value area lines, with the difference being the start and end dates are user defined (as a drawing tool). Hope I'm clear in what I'm asking for. Thanks in advance for your help... |
| [2014-09-16 02:24:21] |
The first step is for us to support a starting and ending Date-Time with the Volume Value Area Lines study. We will make a note of that but it will be sometime before we can get to it. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
