Date/Time: Tue, 22 Apr 2025 18:30:44 +0000
Download Historical data 2m, 3m and 5m
View Count: 191
[2025-01-02 15:13:50] |
User78439 - Posts: 22 |
I like to do some back test for large ETFs. I need 2M, 3M and 5M candle chart data(high, low, open, close and volume). 1) it is possible to get these data into excel file or CVS file ? 2) it is possible to get data back up to at least 2-3 years ? Thanks.
[2025-01-02 17:52:55] |
John - SC Support - Posts: 39418 |
1) Once you have the data in your system, then you can export the data that is displayed in the chart to a CVS file. So if you have the data displayed as 2 minute bars, then you will get the 2 minute bars output, if you have the bars set to 5 minutes, then you will get the 5 minute output. Refer to the following: Edit Menu: Edit >> Export Bar Data to Text File 2) In general, we have data going back at least 3 years, but it depends on what data you are wanting. Refer to the following: Sierra Chart Historical Data Service: What is Included For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
