Date/Time: Tue, 22 Apr 2025 18:11:40 +0000
[User Discussion] - linked bar periods across different symbol charts and also individusal period possible?
View Count: 217
[2025-01-02 09:37:43] |
MMM1238 - Posts: 20 |
Hi, I have many charts with different symbols in my chartbook. I have linked the bar periods. So when I change the bar period on chart all charts are changing. But I need to check each chart in detail too. That means I would like to adjust the periods quickly for one chart if it looks interesting and then switch back to my main bar period. If I do it without linking I have a bar period mess across the charts after a while. If I link the bar periods it takes time to change all charts but I need the change only for one charts mostly. I could also illustrate the bar period on the charts to see it immediately, but my request would be more interesting: Is it possible to set the bar period linked (or firm globally) and also individually for each chart by two different functions? I would be impressed if I could adjust the bar period individually (quickly) for the open chart only by the shortcut e.g. "5 enter" and if I want to have all charts back to my main timeframe to press the 15 min control bar button to change to 15min for all charts. many thanks Date Time Of Last Edit: 2025-01-02 09:42:20
[2025-01-05 06:28:37] |
Sierra_Chart Engineering - Posts: 19305 |
We are thinking about this.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2025-01-05 06:28:42
