Date/Time: Tue, 22 Apr 2025 18:06:03 +0000
increments on DOM ladder
View Count: 105
[2025-01-02 09:19:07] |
User265150 - Posts: 12 |
my price ladders are showing gaps - eg in Crude oil i'm only seeing 2c gaps...for instance 72.01 and the next price is 72.03. how do i fix this...the price increment appears to be set for 1 tick
[2025-01-02 17:17:47] |
John - SC Support - Posts: 39416 |
What you see is going to be dependent on what can be drawn given the current space available. But, you can tell the system where you want to have the prices drawn by setting the "Scale Increment". Refer to the following: Chart Scale and Scale Adjusting: Scale Increment (Scale Settings) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
