Date/Time: Wed, 19 Mar 2025 02:24:58 +0000
Allowed Systems - Using 3rd System
View Count: 160
[2025-01-01 22:51:21]
Oxcap - Posts: 73
Hi Support,
I am trying to understand better my allowed systems. I currently have a total of 3 systems using Package 12.
Allowed Systems: 2 out of a total of 3 system(s) are currently being used.
Can you advise on how I can utilize my 3rd system at the same time? Do I need to go register a separate SC account per link below? I would like to use all three systems simultaneously.
https://www.sierrachart.com/RegisterStep1.php
[2025-01-02 00:49:40]
Sierra_Chart Engineering - Posts: 18836
There is nothing special you need to do to use the third system. You just log in with your Sierra Chart Account Name and Password.
However, you cannot get any data from the Denali Exchange Data Feed on a third system. Refer to:
Denali Exchange Data Feed: Connections
You can only get delayed data.:
Delayed Exchange Data Feed
[2025-01-02 18:45:30]
Oxcap - Posts: 73
Ok - my understanding was that I would be able to receive real-time data on the 3rd system as well. Thanks for clarifying.
