Date/Time: Wed, 27 Nov 2024 15:43:05 +0000
Back testing
View Count: 1049
[2014-09-15 19:30:18] |
User83963 - Posts: 18 |
Back testing/ market replay the candlestick on 1 min chart are not complete. Moving averages are missing on tick chart, and it dosent seem to be accurate with 1 min chart.
[2014-09-16 02:21:24] |
This is not clear for us. Maybe you are replaying a futures contract at a point in time where it is inactive.For the other issues we need to see images of the charts. Provide an image of the chart, by following these instructions: http://www.sierrachart.com/index.php?l=PostingInformation.php#Image Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-09-16 02:21:58
[2014-09-16 14:57:45] |
I rolled the date back to 8/19. http://www.sierrachart.com/image.php?l=1410879265586.png http://www.sierrachart.com/image.php?l=1410879305987.png |
[2014-09-16 19:51:41] |
1. For the first image, you are looking at an inactive point of time in that particular futures contract. Use the Continuous Futures Contract feature to solve this: https://www.sierrachart.com/index.php?page=doc/doc_ContinuousFuturesContractCharts.html 2. What moving average do you have on the chart and what is the Length set to? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-09-16 20:05:31] |
I have 5period 20 period and 100 period averages on that chart. Sorry, I am not sure what "length set to" means.
[2014-09-17 04:02:38] |
Does not make much sense that you would not see the Moving Average with a Length of 5 or 20 on that chart. Go to the chart the contains the Moving Average studies, and activate it and then select Edit >> Copy Chart Values and paste it here. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-09-17 19:19:33] |
Current Quote ESZ4-CME: 2014-08-21 12:39:06.0 Thu: LastPrice:1980.50 LastSize:1 Daily Price Chg:0.00 Ask:1981.00 Bid:1980.50 Bid Ask Avg:1980.75 Bid Ask Diff:2.0 Ticks Bid x Ask:1 x 1 Daily Open:0.00 Daily High:0.00 Daily Low:0.00 Prev Close:0.00 Daily Volume:0 Num Trades:0 ******************************************* Chart Values for Last Displayed Column: 2014-08-21 12:22:39.0 Bar Begin Time: Region 1: Paused 120.0X: ESZ4-CME 55 Trades #5 () : Price Chg:-0.50 Open:1980.75 High:1980.75 Low:1979.75 Last:1980.50 Volume:23 # of Trades:19 OHLC Avg:1980.44 HLC Avg:1980.33 HL Avg:1980.25 Bid Vol:11 Ask Vol:12 Moving Averages (Smp, Last, 5, Smp, Last, 20, Smp, Last, 100) : Avg1:1980.80 Avg2:1978.50 Avg3:1972.73 ******************************************* Chart Values for Tools: Y: 1987.56 : 2014-08-19 15:50:00.0 Bar Begin Time: Region 1: Paused 120.0X: $INX [M] 10 Min #7 () : Price Chg:0.07 Open:1981.48 High:1981.60 Low:1981.20 Last:1981.48 Volume:34524944 # of Trades:120 OHLC Avg:1981.44 HLC Avg:1981.43 HL Avg:1981.40 Bid Vol:14796021 Ask Vol:19728928 Moving Average-Simple (Last, 5) : Avg:1981.76 Moving Average-Simple (Last, 50) : Avg:1979.83 Moving Average-Simple (Last, 20) : Avg:1981.19 |
[2014-09-18 03:26:22] |
Are the moving averages at the end of the chart but not at an earlier date in the chart?
[2014-09-19 13:06:34] |
I went back 2 weeks then 3 weeks and have the averages. Around 3 1/2 weeks is when they aren’t visible. |
[2014-09-19 13:26:36] |
The question is at 3 1/2 weeks and earlier, what are the values of those Moving Averages? You can determine that with the Chart Values tool: http://www.sierrachart.com/index.php?page=doc/doc_Tools.html#ChartValues Are they within the visible price range of the chart bars that are visible at that point in time. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-09-19 13:51:05] |
I changed the Continuous Contract option on that chart and it seemed to correct it. Thank you.
[2014-09-19 13:55:26] |
OK this is good.
