Date/Time: Tue, 22 Apr 2025 18:36:23 +0000
[Programming Help] - How to count the number of imbalance in a candle using Acsil
View Count: 265
[2025-01-01 02:48:09] |
User669552 - Posts: 26 |
Using Acsil i want to create a custom study that would require me to Count The number of selling imbalances. I can set them to 300% which is my optimise imbalance level but i do know how to access the numbers bar study and count them using acsil programming
[2025-01-01 03:40:21] |
cmet - Posts: 690 |
Here is a custom study that counts the number of imbalances in each bar and plots them in a subgraph. Threshold defaults to 2 (2x). Change to increase the imbalance you're looking for. Minimum Volume allows you to filter for size. Can choose Same Price or Diagonal comparison. #include "sierrachart.h"
SCDLLName("Numbers Bar Buy/Sell Imbalances Counter"); SCSFExport scsf_BuySellImbalanceCounter(SCStudyInterfaceRef sc) { SCSubgraphRef Subgraph_BuyImbalanceCount = sc.Subgraph[0]; // Subgraph for buy imbalances SCSubgraphRef Subgraph_SellImbalanceCount = sc.Subgraph[1]; // Subgraph for sell imbalances SCInputRef Input_ImbalanceThreshold = sc.Input[0]; // User input for imbalance threshold SCInputRef Input_MinimumVolume = sc.Input[1]; // User input for minimum bid/ask volume SCInputRef Input_ImbalanceBasedOn = sc.Input[2]; // Dropdown for "Same Price" or "Diagonal" if (sc.SetDefaults) { sc.GraphName = "Numbers Bar Buy/Sell Imbalances Counter"; sc.StudyDescription = "Counts buy and sell imbalances with options for same price or diagonal comparison."; // Subgraph configuration for buy imbalances Subgraph_BuyImbalanceCount.Name = "Buy Imbalance Count"; Subgraph_BuyImbalanceCount.PrimaryColor = RGB(0, 255, 0); // Green Subgraph_BuyImbalanceCount.DrawStyle = DRAWSTYLE_BAR; Subgraph_BuyImbalanceCount.DrawZeros = true; // Subgraph configuration for sell imbalances Subgraph_SellImbalanceCount.Name = "Sell Imbalance Count"; Subgraph_SellImbalanceCount.PrimaryColor = RGB(255, 0, 0); // Red Subgraph_SellImbalanceCount.DrawStyle = DRAWSTYLE_BAR; Subgraph_SellImbalanceCount.DrawZeros = true; // Input configuration Input_ImbalanceThreshold.Name = "Imbalance Threshold (Multiplier)"; Input_ImbalanceThreshold.SetFloat(2.0f); // Default 2.0 Input_MinimumVolume.Name = "Minimum Volume for Imbalance"; Input_MinimumVolume.SetFloat(10.0f); // Default minimum volume Input_ImbalanceBasedOn.Name = "Imbalance Based On"; Input_ImbalanceBasedOn.SetCustomInputStrings("Same Price;Diagonal"); Input_ImbalanceBasedOn.SetCustomInputIndex(1); // Default to Diagonal sc.AutoLoop = 1; // Enable AutoLoop sc.MaintainVolumeAtPriceData = 1; // Maintain Volume At Price data return; } if (sc.VolumeAtPriceForBars == nullptr) { Subgraph_BuyImbalanceCount[sc.Index] = 0; // No data Subgraph_SellImbalanceCount[sc.Index] = 0; return; } int VAPSizeAtBarIndex = sc.VolumeAtPriceForBars->GetSizeAtBarIndex(sc.Index); if (VAPSizeAtBarIndex == 0) { Subgraph_BuyImbalanceCount[sc.Index] = 0; // No data Subgraph_SellImbalanceCount[sc.Index] = 0; return; } int buyImbalanceCount = 0; int sellImbalanceCount = 0; float imbalanceThreshold = Input_ImbalanceThreshold.GetFloat(); // User-defined threshold float minimumVolume = Input_MinimumVolume.GetFloat(); // User-defined minimum volume int imbalanceBasedOn = Input_ImbalanceBasedOn.GetIndex(); // 0 = Same Price, 1 = Diagonal // Iterate through the VAP data for the current bar for (int VAPIndex = 0; VAPIndex < VAPSizeAtBarIndex; VAPIndex++) { const s_VolumeAtPriceV2* p_VolumeAtPrice = nullptr; if (!sc.VolumeAtPriceForBars->GetVAPElementAtIndex(sc.Index, VAPIndex, &p_VolumeAtPrice) || p_VolumeAtPrice == nullptr) { continue; } float bidVolume = static_cast<float>(p_VolumeAtPrice->BidVolume); float askVolume = static_cast<float>(p_VolumeAtPrice->AskVolume); if (bidVolume < minimumVolume || askVolume < minimumVolume) { continue; // Skip levels with low volume } if (imbalanceBasedOn == 0) // Same Price { if (askVolume >= imbalanceThreshold * bidVolume) { buyImbalanceCount++; } if (bidVolume >= imbalanceThreshold * askVolume) { sellImbalanceCount++; } } else if (imbalanceBasedOn == 1) // Diagonal { const s_VolumeAtPriceV2* p_DiagonalVAP = nullptr; // Diagonal Buy Imbalance (Ask vs Lower Bid) if (VAPIndex > 0) { sc.VolumeAtPriceForBars->GetVAPElementAtIndex(sc.Index, VAPIndex - 1, &p_DiagonalVAP); if (p_DiagonalVAP != nullptr) { float diagonalBidVolume = static_cast<float>(p_DiagonalVAP->BidVolume); if (askVolume >= imbalanceThreshold * diagonalBidVolume) { buyImbalanceCount++; } } } // Diagonal Sell Imbalance (Bid vs Higher Ask) if (VAPIndex + 1 < VAPSizeAtBarIndex) { sc.VolumeAtPriceForBars->GetVAPElementAtIndex(sc.Index, VAPIndex + 1, &p_DiagonalVAP); if (p_DiagonalVAP != nullptr) { float diagonalAskVolume = static_cast<float>(p_DiagonalVAP->AskVolume); if (bidVolume >= imbalanceThreshold * diagonalAskVolume) { sellImbalanceCount++; } } } } } // Update subgraphs with counts Subgraph_BuyImbalanceCount[sc.Index] = static_cast<float>(buyImbalanceCount); Subgraph_SellImbalanceCount[sc.Index] = static_cast<float>(sellImbalanceCount); } Date Time Of Last Edit: 2025-01-02 00:57:04
