Date/Time: Tue, 22 Apr 2025 18:33:46 +0000
Tool settings not loading completely after SC update
View Count: 168
[2024-12-31 18:16:10]
User512353 - Posts: 65
I updated from SC2700 to SC2726.
Since the update, some pre-configured tool drawing properties do not load completely when selected.
Example:
For the 'Horizontal Ray' tool, in
Global Settings >> Tool Configs >> Horizontal Ray Config >> Settings
I have a configuration that has
Text Opaque = No
Show End Point Price = Yes
stored under TC3.
(The SC defaults, also stored under TC1, of these two properties are reverse.)
On a chart I create a new Horizontal Ray. This ray gets the SC defaults.
a) I right-click the new ray and select
Configuration >> Config 3
and the configuration loads OK.
b) I right-click the new ray and select
Chart Drawing Properties >> Settings >> Configurations >> TC3
or
Chart Drawing Properties >> Config >> TC3
then the settings only load partially, e.g. the 'Line Color' and 'Line Width' load correctly and are immediately displayed, but the settings for 'Text Opaque' and 'Show End Point Price' do NOT load from the TC3 configuration Global Settings.
[2024-12-31 20:11:14]
Sierra_Chart Engineering - Posts: 19305
We are checking on this. We apologize for this.
