Date/Time: Tue, 04 Nov 2025 18:08:27 +0000
Auto-coloring of Subgraph based on +/- over another subgraph
View Count: 447
[2024-12-31 04:15:00]
User763335 - Posts: 119
Hello
I have two subgraphs in a study, call it X and MovingAvg(X). I'd like to auto-color X, based on if its above or below MovingAvg(X).
I couldnt find an option under Auto-coloring drop-down. Was looking at Study Subgraphs Subtract/Difference, but not sure how to color based on the difference of this study.
How can I do this?
thanks
[2024-12-31 13:34:41]
emmanuel - Posts: 63
There's a way you can cheat to create the appearance of auto-coloring the subgraph.
Let's say subgraph X is ID1.SG1 and MovingAvg(X) is ID1.SG2.
1. Add a Spreadsheet Formula study to the chart, and set the formula to: IF(ID1.SG1 > ID1.SG2, ID1.SG1, 0)
2. Copy the 1st Spreadsheet Formula study and change the formula to: IF(ID1.SG1 < ID1.SG2, ID1.SG1, 0)
3. Adjust the subgraph colors in both Spreadsheet Formula studies, as needed.
This will produce two new subgraphs rendered in the same chart region, but since they alternatively only produce values when X is above or below MovingAvg(X), and be default subgraphs don't render zero values, you should see what appears to be a single subgraph which changes color.
If you see weird connecting lines, you may need to use "Line skip zeros". See Chart Studies: Avoiding Vertical Joining Line for Study Subgraphs
[2024-12-31 18:11:24]
Sierra_Chart Engineering - Posts: 21306
Instead of doing the above, you also can create your own custom study to do what you need. You can control the color at each chart bar through the Subgraph Data Color array:
ACSIL Interface Members - sc.Subgraph Array: sc.Subgraph[].DataColor[]
[2024-12-31 20:11:03]
Will try, thank you both.
[2025-01-02 16:09:54]
John - SC Support - Posts: 42761
You can also use the "Color Bar Based on Alert Condition" to do what you want. Refer to the following, specifically the section for "Coloring Subgraphs of Other Studies":
